PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 [93] 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Need some input!!!!!!
  2. which injectors?
  3. GT-40Ps with BBK Shortys
  4. 91 mustang fuel pump
  5. MOVED: Carfax??
  6. MOVED: funnt ricer pics
  7. MOVED: Custom paint
  8. please i need input.
  9. Explorer intake question
  10. 1994 5.0 cast or forged pistons.
  11. saleen wing on a hatch
  12. what bore?
  13. heads and cam
  14. 347 stroker question
  15. Strut Tower Braces
  16. Oily Plug Threads
  17. 1993 Cobra intake gasket set
  18. Change original transmission fluid at 200k?
  19. I need your expertise
  20. relieve fuel pressure
  21. Factory Tach
  22. chips or tuners????
  23. brake ?
  24. HELP with radiator problem
  25. Stock Tach broken...
  26. C4 Swap
  27. UPR Triple Hook Problem
  28. 96 explorer heads,intake,and tb??
  29. Gears question???
  30. Tutorial: How to port and polish GT-40 heads (pics)
  31. clutch selection
  32. COMP Polymers upper intake. any1 use one?
  33. need help with 93 lx
  34. What is the difference?
  35. compression test results
  36. MOVED: Drag Lites help??
  37. 73 mm MAF
  38. Yukon Axles? Who here has used them and opinions
  39. Push rods?
  40. Driveshaft removal
  41. exhaust re-vamp, which X-pipe?
  42. NEed help on adjusting stock Valves
  43. pinion angle 1" drop
  44. head gasket question
  45. weird clicking soundthe
  46. Stock 5.0 want to modify
  47. what size are stock throttle bodies?
  48. floteck headers
  49. MOVED: ground effects
  50. kennebell superchargerrr
  51. How do i get a snapped roller rocker bolt?
  52. Pulling starter from 351w
  53. MOVED: Can I join you guys??
  54. 2 qustions ?
  55. Exhaust Leak
  56. backfire in 95gt
  57. oil separator needed?
  58. 94-95 gt alt
  59. Did I screw up MAF?
  60. Alternator Question??
  61. exhaust question
  62. gahhhh flow tech and prochamber
  63. 1.6 & 1.7 rockers for homeade dual pattern cam
  64. SN-95 spindle/hub question...
  65. MOVED: New ClutcH?
  66. ????answer me this????
  67. MOVED: beat this....
  68. how wide, and what size rim/tire can i run now after mods?
  69. IS THIS MASS AIR???
  70. what kind of head gaskets
  71. x cam on 347 please HELP!!!
  72. 24lb injectors-what else do I need
  73. hooking up daytime running lights
  74. how to make a reliable 350hp?
  75. 94 GT 5spd - What would you do tranny?
  76. T-5 Tranny HORROR part 2!!!!!!!!!!
  77. wheel bearings
  78. Fog Lights wiring
  79. 1994 gt trans. upgrade
  80. 94 wiring problems
  81. Need technical help!!!!
  82. mustang Gt troubles....help me
  83. TW "R" Heads Questions?
  84. 351 swap
  85. Idle questions
  86. TFS streetburner intake clearance?
  87. crankin up fuel psi..
  88. Can't figure it out...
  89. 90 Notch AOD
  90. trying to find a leak
  91. My 5.0 accelerates it self when i turn it on. What is wrong??
  92. Ideas on tucking and hiding wiring
  93. Tranny grinds into reverse. Help?
  94. notched ideas
  95. since there's alot of tranny swap questions...
  96. New carpet ?
  97. Decisions HELP Windsor or Boss 302
  98. MOVED: Parting out 1994 Cobra. Good, new engine!
  99. Building a stronger Borg Warner?
  100. emissions
  101. notching the pistons?
  102. rebuilding the heads?
  103. NO SPARK?!?!
  104. Wiring Harnesses Interchange??
  105. Charcoal cannister purge solenoid and idle
  106. MOVED: good deal on gt40's
  107. GT40 Charcoal Cannister Line Input / Idle Issue
  108. smog delete
  109. MOVED: 10 Second Mustang For $1000
  110. What year is my engine?
  111. Brakes
  112. F/S 79-93 Mustang Saleen Wing Hatch! CHEAP!!!
  113. Trick FLow or Cobra Intake
  114. 5 Speed Identification? With Pics!
  115. Junkyard Hunting for Gt-40's
  116. Are BBK lowering springs staggered?
  117. Ram Air Vs Cold air
  118. How do I tell if I have the H.O or not?
  119. ULTIMATE EEC AND TROUBLE SHOOTING SITES.
  120. MOVED: What is the weight of a 1987 Mustang GT Vert???
  121. Need some opinions on a Tranny swap on a '90 Fox
  122. engine knock
  123. 4 lug rear disc
  124. headlight
  125. Seat Belts
  126. Tranny noise
  127. Another tranny problem.
  128. eibach springs question
  129. MOVED: stupid Question
  130. 89 5.0 motor build ??s
  131. bolt stuck
  132. Oil pump question
  133. control arms
  134. 94 Valve covers
  135. MOVED: Does anyone have....
  136. plugging air injection holes
  137. O2 Sensors on 1990 5.0
  138. MSD Problems Still
  139. INJECTORS NOT WORKING HELP!!!!!
  140. got a lean miss-fire
  141. Eibach Drag launch springs....
  142. 70'S 306 SHORTBLOCK
  143. Car runs bad
  144. Ford Crate Engine
  145. Need some suspension Help
  146. Looking to do a full service
  147. timing for dummies
  148. need help choosing lca
  149. '88 GT stock block capability
  150. intake
  151. how long do you have to wait
  152. c-4 swap need help fast !!!!
  153. cam
  154. 03 GT Axles in a 94 GT?
  155. Tailpipes, I need some help
  156. performance ? just for laughs
  157. Are Brodix ST 5.0 Cylinder Heads any good?
  158. Proper Clutch Adjustment?
  159. dont understand this....
  160. 94 GT Fuel system
  161. MOVED: HOLY SH*T 21LBS OF BOOST
  162. STEERING SUPER TIGHT,WHAT HAVE I DONE WRONG?!
  163. MOVED: All original 94 GT Convertible - Thoughts
  164. What are gt-40 power bands like?
  165. 351 with stock hood
  166. mega squirt?
  167. injector ?s
  168. Baer Brakes do you have them?
  169. FlowTech Headers 12104FLT
  170. MSD Box Question..
  171. MOVED: Zero to 60 & 1/4 Miles Times
  172. Idle issue help
  173. starter wiring
  174. Windshield trim and leak?
  175. gas smell from intake
  176. 351w heads question
  177. GT 500 Steering Wheel
  178. Installing a Steeda #19 cam?
  179. Project ready to start, gimme your thoughts
  180. SN-95 rear end
  181. Scat Rods???
  182. breather system or pcv with oil seperator
  183. Battle Boxes
  184. Breathers continued
  185. ingnition coil problem
  186. Halp with distributor install!!!!
  187. Will I get more lope from a steeda #19 cam or an ABC cam?
  188. installation of shorty headers on 94 GT
  189. couple questons about roller lifters
  190. C4 Swap
  191. New here, got some questions bout auto transmissions in a '90 Fox
  192. T5 Tranny
  193. 95 Mustang Cobra Brakes
  194. Need help to figure out vibration!!
  195. Lost on my next step
  196. Just bought a 302
  197. Valley Girdle?
  198. fouled plugs
  199. MOVED: my new project
  200. Connectors: HELP!!!
  201. T-5 Trans HORROR!!!!!!!!!
  202. 24 lbs injectors
  203. gt40 intake
  204. looking at buying a cold air intake....
  205. Question about t-top doors. Again.........
  206. coolant leak help
  207. MAF Sensor Question
  208. Taking the T handle shifter off?
  209. Intake manifold installation
  210. flaming river manual rack
  211. axle help
  212. throttle body
  213. New fuel level guage
  214. installing headers... help!
  215. help.....suspension knock
  216. 1995 GT Transmisson T-5
  217. MOVED: Looking for a Good Dyno shop PA
  218. 1994 GT brake calipers
  219. H/C/I for speed density 5.0
  220. 347 crank with stock heads
  221. How mush power will a 75mm MAF handel?
  222. Fuel pump for fuel cell
  223. too much injector
  224. do i need guide plates?
  225. Best Suspension for Money
  226. optimal S/C for mild build
  227. Trick Flow underdrive pullies
  228. Porting on GT-40
  229. Air/fuel question
  230. QUick head identification
  231. MOVED: BBK Intake
  232. Computer question
  233. Oil Pan Gasket??
  234. accel dfi thruster?
  235. tranny help
  236. Timing belt or chain
  237. need your help screwed um my tires bad tonight!!!!
  238. help plz... electric fan questions
  239. OBD
  240. PUSHRODS
  241. Can I just yank my A/C?
  242. evaporator removal???
  243. MOVED: Camaro Owner tryna to convert to 5.0
  244. fuel pump help (dont want to explode)
  245. Heater Core?
  246. MOVED: Whats your engine bay look like?
  247. E-303 w/ 1.7 rockers or F-303 w/ 1.6's?
  248. MOVED: how much money do u think i could get out of this hood?
  249. Hatch Striker Bolt
  250. Changing the Transmission mount
