PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 [224] 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Old Pic of the Stang
  2. any free/cheap hp mods out there?
  3. Houston Stang Meet #2
  4. Idle prob...
  5. HELP ME!!...IDLE TO HIGH!!!...HAVE TO GO TO WORK SOON!!!!
  6. GOT IT STARTED.....IDLE WAY TO HIGH....HELP!!!!
  7. would you buy it? advice!
  8. won't restart when hot, Vol. 2
  9. Explorer intake?
  10. Duraspark ballast resistor.
  11. Idle problem after repair
  12. CAI Question
  13. Alignment
  14. need my exhaust louder
  15. does it sound like a ripp off?
  16. Trick flow package?
  17. Car won't start - Help!!
  18. Question
  19. fuse
  20. 351 Swap Questions/Expectations!!!!!!!!!!
  21. headers
  22. ARP Head bolts.
  23. Should I even bother? opinions needed ASAP
  24. voltage regulator
  25. MOVED: Turbo charging
  26. Cool Trick
  27. Pushrod length?????
  28. FRPP Sportsman Block?
  29. Here is a question for you guys
  30. probably a stupid question
  31. belt squeak!
  32. MAF Kit
  33. Heads Heads Heads...
  34. 50 Shot too much?
  35. 1st time ever losing a race...to another mustang though
  36. Drag radials , control arms, and headers done.
  37. 4 cyl to 5.0 tech question
  38. LIVE IN BAY AREA CALI? WANT TO MAKE SOME MONEY??
  39. 8.8 question
  40. engine question
  41. New seats?
  42. I dumped my Underdrive Pulleys today.
  43. 8.8 rear end new or rebuild?
  44. Adjustable Fuel Regulator
  45. aluminum radiator question
  46. pics of my mustang
  47. horsepower estimate
  48. Correct Pushrod Length
  49. Stroked Motor
  50. Has anyone installed a GT 40 Intake?
  51. New Shifter...
  52. Bumping Timing?
  53. Timing chain question...HELP
  54. Anyone from the Memphis TN area
  55. Pics of my 5.0 FINALLY
  56. Need Help Quick!!!!!
  57. Wheel and tire size for an 86 GT
  58. 91 LX Fuse diagram please
  59. Feedback welcome on this 351w shortie
  60. STILL NO START.....WHY!!!!!!!!!!?????????
  61. Installing FPR and GuageQuick ?
  62. STALL HELP
  63. Dropped her off at tuners today
  64. HCI +400$
  65. ordered and on the way BUT
  66. Any Know Track Times?
  67. H/C/I - Intake opinion poll
  68. Fox lake GT40P's
  69. S/C pics or turbo pics also
  70. HELP PLEASE!!
  71. Which Fuel Pump ???
  72. Clutch fittting?
  73. looking for OEM crankshaft pulley
  74. new to dayton
  75. Fuses..Fuses..Fuses..
  76. 275+ Hp for cheap???
  77. New mods
  78. steering wheel change
  79. Can I use these stangs for project cars?
  80. Timing Please help
  81. Made a decision... buying a S/C this week, but I need your help!
  82. pulley alignment for 95 GT. ASAP
  83. Upholstery
  84. atco ford nationals
  85. Replacing fender apron and radiator core support?
  86. heli coil
  87. High temp reading
  88. before and after...finaly!
  89. NEED HELP
  90. anyone in the central FL area? lookin for a good shop.
  91. 91 5.0 with Mustang II performance???
  92. Why do i keep having to replace my terminals??
  93. WTF is this?
  94. Best Header for stock 5.0
  95. Please HELP right now- I need to get to work in the morning!
  96. ground question
  97. wont turn off!!
  98. new block , need some ides
  99. need a stang?
  100. dont understand....
  101. 86 mustang
  102. Before and after videos
  103. 95 Stock Cobra Rims?
  104. Casino Pay.. little closer to buying mustang!
  105. WONT START!!!! HELP ME!!!
  106. Serpentine Belt Problems
  107. Gears at dealership?
  108. 1984 parts
  109. Popping noise when pressing the clutch.
  110. Door Switch
  111. gt40 heads or tf intake?
  112. REPLACED IAC...WONT START!!!!!?????
  113. @sshole
  114. Question...Please help
  115. Shifter??
  116. Need help With New ECU
  117. best mods for $3000
  118. 94-95 5.0
  119. new pix of my 5.0
  120. Help me blow some $$$!
  121. Power lock switch ques...
  122. clutch self adjuster
  123. trickflow rearend cover
  124. Eibach Suspension Kit
  125. The new torque converter is IN!!!
  126. question on cylinder heads
  127. 5.0 400 HP - How to build
  128. Freakin' skip under load!
  129. radiator ques..
  130. Camming with stock heads...is there a point?
  131. 347 block question
  132. got the new mac exh on. - PICS!
  133. exhaust question
  134. what engine to install
  135. 5.0 swap
  136. Compressor Swaps?
  137. What's this vacuum line do?
  138. bucking and power loss
  139. Does anyone in the Houston TX area have a 94-rolling chassis?
  140. Manifold Question
  141. REROUTING BELT AFTER AC AND PS REMOVAL
  142. rack limiter ?
  143. need help No spark!
  144. whats better gt40 or gt40p heads
  145. To those who have put a Clutch Quadrant in...
  146. anyone have a link for a cr
  147. what the f*ck is knocking
  148. timing question..
  149. Duraspark ignition
  150. speed density and mass air
  151. Thoughts on QA1 10 way adjustable shocks?
  152. pro 5.0 shifter install
  153. price
  154. Anyone have a alt bracket 4 sale?
  155. 373s
  156. !!!HELP!!! MUSTANG PRICING
  157. bad vibration, help fast
  158. S/C pics
  159. What Size Sway Bar Bushing Do I have ?
  160. OVERHEATING, tried Shop(s), done everything!!!!11
  161. Buying a used engine
  162. MY 5.0 DIES AT STOP LIGHTS!!! WHY????
  163. weld racing pro stars
  164. Aftermarket cam guys...
  165. Anyone had trouble with idle hunting?
  166. Nitrous works egr plate
  167. differential cover
  168. Smog Pump Delete????'s
  169. Temp sending unit
  170. dyno and tune?
  171. Kickdown cable not attached at TB
  172. 95 GT Needs Help!!!
  173. engaging 1st
  174. New Guy Needs Help!
  175. New clutch cable stiff as hell. What the deal?
  176. Door handle question
  177. What about belts?
  178. rear end
  179. ive got to share
  180. Bangin noise...
  181. Destroyed Motor, looking at new setup
  182. selling my red 90 gt only 66k on it!!!
  183. Seat Belt help
  184. New Hood Pics
  185. MAF Conversion
  186. 87-90 AND 90-93 FENDERS
  187. Motor install, headers on or off??
  188. 1st gear and clutch
  189. A/C delete question
  190. anyone got a 4cyl exhaust manifold left over from a 5.0 conversion
  191. Stock heads?
  192. throttle plate
  193. SLP exhaust system
  194. clutch pedal
  195. Bog down.
  196. What to do with a stock 5.0?
  197. engine won't restart when hot
  198. IM SURE YOU WILL LAUGH ABOUT THIS
  199. Tried to install c-4 last night...Help
  200. Check engine light! HELP PLEASE ASAP!
  201. which to do??
  202. fram boost?
  203. Once I get the money....
  204. weird noise?
  205. aluminum driveshaft/ driveshaft problems
  206. gt-40 question
  207. this makes me worried
  208. Power Window Motor rebuild?
  209. Oh dear God, someone help me!
  210. pics of my stock five-HOOOO!!!
  211. upper axle bushings
  212. Night At The Track :(
  213. Help with door handles
  214. Bad Father....I Admit!!!
  215. Adjustable clutch cables?
  216. Auto X tomorrow
  217. mustang vs supra?
  218. Head question
  219. 17inch cobra rims.. WHAT size tire do i need?
  220. CHANGE STANGS? YOU BE THE JUDGE
  221. tranny swap?
  222. Manualy shifting with an AOD
  223. removed carb spacer, now runs like crap. why?
  224. tranny swap?
  225. FEL PRO oil pan gasket
  226. Will I feel a power increase???
  227. ECC-IV swap question
  228. best stroker for n2o??
  229. Compression?
  230. Maryland, Lower PA, Eastern WV ANYONE??
  231. What Next Guys??
  232. Hello
  233. Instructions on changing clutch cable?
  234. broken head gasket?
  235. Timing*
  236. Stock balanced Weight??
  237. Need help with t5 borg warner!!!!
  238. distributor disassembly...
  239. WHAT TO GET NEXT ON MY 5.0
  240. Just finished balancer. Some thoughts.
  241. my new rims!!
  242. Slick question.
  243. Hydraulic Clutch Question HELP!!!
  244. Where can I find...
  245. GOT MY NEW TORQUE CONVERTER!!!!
  246. what spark plugs with boost?
  247. tfs h/c/i help
  248. AFR or Twisted Wedge for a Turbo?
  249. wher can i get a 331 shortblock? will it pass smog ?
  250. super dumb QQQ??????
