PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 [305] 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. mustang8719
  2. EGR
  3. Full Throttle
  4. nitrous intall pics???
  5. a 3700lbs. car with 300 horses to the ground...
  6. bigdaddy408
  7. Trans 6spd
  8. Engine swap.
  9. wait a minute
  10. 300 HP
  11. rattle
  12. any diff between 88 merc 302 and mustang
  13. 1985 gt
  14. Cam info needed
  15. Widest Tire on a stock rim
  16. Race seats - Harness
  17. Look at this car
  18. Kenne Bell Installed Pic
  19. Looking to Buy a 1990 through 1993 Mustang GT HELP??
  20. "tornado"
  21. HP estimate
  22. cold air intake
  23. Real Seal Question
  24. pushrods
  25. need some help
  26. Dyno Tuning
  27. What pushrods do I use with Edelbrock Performer Heads?
  28. mcd blaster coil
  29. mounting shut off relay questions anybody mounted one???
  30. Needing some suggestions on parts....
  31. heater core, etc...
  32. Caster Camber plates???
  33. Speedometer issues... need help...
  34. Exhaust Dumps
  35. AMS N-41
  36. AFPR
  37. wut kinda cam
  38. DYNO Prices
  39. DYNO Prices
  40. new bottom end how long for break in
  41. 28" tall tires...
  42. Look at this setup
  43. shorties wont fit?
  44. Got gaskets for the manifold today.
  45. metal block under pinion.
  46. Will SN95 shorties fit a fox?
  47. Valve Cover Problem
  48. ECU question
  49. Anybdy familar with chips for 5.0 stangs?
  50. Head Gasket
  51. Heads
  52. AOD to manual
  53. Call me stupid
  54. Installing cd player
  55. trickflow cam...
  56. Underdrive Pullies
  57. MOVED: black cobra R's
  58. Rearend Leaking
  59. Computer Info Needed ASAP.... Need car running
  60. C&L MAF
  61. got a new stang
  62. What size MAF
  63. suspension upgrade
  64. buying 93 GT
  65. F cam W/ 1.7RR
  66. HP estimate
  67. is this a good tire...
  68. passing emissions
  69. New engine
  70. All The Basic Needs
  71. New Mods
  72. questions bout camming
  73. Build Number
  74. turbo 5.0l exhaust manifold
  75. Turbo or Super?
  76. 90mm maf or similar for 5.0l?
  77. speedo cable
  78. upper and lower intake maniflod
  79. plugs
  80. factory tach
  81. tach
  82. 347 or 393. PLEASE HELP!
  83. Dip stick w/ long tube headers
  84. tranny problem
  85. Trick Flow intake question
  86. 347 or 396
  87. C&L MM Idel problems??
  88. 84 or 85 5speed ????
  89. long tube header install
  90. cooling system diagrams
  91. Thermostat problem
  92. my heads are these
  93. Fuel
  94. Spout Connector
  95. Installed new TB...revving higher now and check engine
  96. New Comer
  97. rear end
  98. Cam Questions....
  99. how much
  100. how much
  101. AFR's vs VJ
  102. Gt40 Ported and Polished
  103. parts
  104. for obsol3te
  105. my flowmasters dont sound loud anymore
  106. shes comin home!
  107. BBK SSI vs RPM II intake?
  108. compression
  109. aluminum head installation ?'s
  110. overdrive bul**i*
  111. Bad Oil Pan Gasket?
  112. CRUISE CONTROL
  113. phelonic spacer?
  114. which t5's fit??
  115. 5.0 and 4.6 intake
  116. What do you think?
  117. spring spacers?
  118. 17's anybody?
  119. e 303 cam
  120. IDLE
  121. New lines for air condition, how much $$$$ ?
  122. Hopefully Getting this 1990 GT
  123. Relocating battery right now.
  124. AFR's vs GT40's
  125. Taking the stang out tommorow!!!
  126. head bolt broke off in block
  127. Coolant leaking?
  128. complete tranny flush
  129. Horse Power Estimate
  130. 1985 mustang question...
  131. I have no idea????
  132. Engine Bucking..now wont start
  133. 95 cobra surging
  134. 5.0 torque specs heads intake upper lower
  135. what color is my car?
  136. wet kit or dry kit
  137. Looking for HP
  138. 302 Turbo?
  139. K member
  140. i got my 347
  141. Ran Car (time slip)
  142. AFR question
  143. I GOT ONE!!
  144. Need a new cooling fan
  145. Nitrous Question
  146. exhaust installed
  147. TPS?
  148. 14*timing vs. 16*-or more...
  149. removel of fuel pressure regulator
  150. speedo
  151. t-5 NEED
  152. 5.0 Block ??
  153. Holley Heads
  154. Installed my alternator!!!
  155. fuel pressure regulator
  156. Installing Prothane engine mounts.
  157. Intake question
  158. Gt-40's
  159. Are Computers Worth It?
  160. hopefully buying this
  161. How hard would it be to put a 351 in a 5.0 wiring wise....
  162. ANOTHER VALVE COVER QUESTION
  163. valve covers
  164. my first mustang!!!!!!!!
  165. Rear disc brake conversion
  166. 2G Powermaster alternator installation
  167. Very strange fuel problem with 95 5.0
  168. New fuel tech ?
  169. 93 computer in a 95
  170. 88 5.0 idles up and down when warm
  171. white smoke
  172. Gears?
  173. h-pipes?
  174. New toys to play with...
  175. bbk intake
  176. Just wondering
  177. computer
  178. Wont start...Brand new battery!
  179. 83gtho front drop springs
  180. 83gtho front drop springs
  181. Not sure on the cars statistics :/
  182. If you had $1500 to spend
  183. MAC SUCKS!!
  184. Exhaust wrap
  185. Valve Clearance?
  186. MSD coil?
  187. fuel upgrades?
  188. Got my driveshaft loop today...question
  189. COMPUTER ??????????????????????????
  190. 1995 GT
  191. when did ford fuel inject?
  192. Roundman - UPDATES WANTED!
  193. Cheap Mods
  194. 347 build
  195. Underdrive Pulley question...crank pulley bigger?
  196. Best cam to use with Performer heads
  197. How well do These engines hold up with alot of miles on them.??
  198. speed density issues
  199. Maximum Motorsports Suspension Question.
  200. speedometer?
  201. TrickFlow Kit
  202. Hi, Questions on auto to 5spd swap on 85 5.0.
  203. bumpsteer kit
  204. me vs. buddies T/A
  205. Venom 400 module
  206. rear gear installation
  207. can 302 heads be drilled
  208. Is this a good buy??
  209. Head Installation Advice Needed Please !
  210. Power Steering noise?
  211. A good 306 package
  212. A good 306 combo?
  213. Please answer
  214. Shocks/Struts
  215. shocks
  216. Typhoon vs. Trickflow
  217. idle
  218. hmm new ebay part
  219. 302 to 351 heads
  220. dammit got a check engine light.
  221. FREE rotors and FREE alternator
  222. Ice Drags
  223. Eagle 347?? ( or eagle 331 kit )
  224. Please Help MAF ?????????? Roundman, Anybody
  225. Passengerside front wheel rubbing
  226. Best fuel pump and nitrous setup?
  227. Little Mustang problem
  228. Gears ....!
  229. MANUAL RACK STEERING
  230. Computer chip?
  231. AOD QUESTION-WEIRD PROBLEMS
  232. Different 5.0s
  233. will this fit
  234. distributor
  235. cats back
  236. What do u thin about a 400M?
  237. weird question/problem
  238. MAF?
  239. cam without mass air
  240. 95 ECU
  241. MAF !!! Check this out
  242. hood insulation
  243. noise in rearend
  244. 88 or 95???
  245. Tire Size
  246. Instrument panel voltage regulator
  247. New Exhaust...Kinda
  248. Junkyard/DIY Performance
  249. mustang starter?
  250. shift kit install
