PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 [317] 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. tps
  2. headers
  3. 28X12.5 WILL FIT LX WITHOUT MINI-TUBS
  4. Re-locating battery to the back?
  5. head upgrade
  6. power door locks not working
  7. something sounds like its grinding or rattling
  8. rear end vibration
  9. just put a cobra intake on, engine wont turn over...
  10. 5.0 block/lifter compatibility question
  11. UPR shifter installation
  12. Can I take him? Me Vs Eclipse GSX
  13. 94-95 GT
  14. I want heads
  15. hp q?
  16. HOW MUCH HP CAN A STOCK BLOCK HANDLE??
  17. launch times, shift points
  18. trick flow intake
  19. Auto---------->manual?
  20. Goal of 450 RWHP
  21. Does SLP make nice exhaust systems?
  22. i need input...my 95' 5.0 or '03 cobra?
  23. 28X12.5 ET STREETS UNDER 89 COUPE???
  24. 93 Cobra Owners - MAF Question
  25. buying LX over GT...
  26. fixed fuel pressure problems..MUST READ!
  27. can u help me out ??
  28. ranger transmission in mustang
  29. going on my 3rd set of valve cover gaskets??
  30. GT-40 heads
  31. Silenoid?
  32. Y-303, E-303, Performer RPM?
  33. Speedo Cali. w/ new gears?
  34. Stock airbox mounts...are you kidding me?
  35. Nitrous?
  36. 1990 Ford Mustang LX Sport *Need CarFax Report*
  37. what will be the cost to swap a 5.0 into a 2.3l?
  38. 351 swap idea
  39. destroke my 5.0
  40. Anyone use the Diablo Sport Delta Chip?
  41. 1993 Cobra woth 15,500?
  42. 347 Stroker on Daily Driver
  43. what MAF and TB should i get?
  44. new headers wont sea!
  45. installing a cam
  46. Tranny/Motor spacer plate
  47. What's more benificial?
  48. Voltage Problem
  49. 331 Stroker
  50. Will cam know Mass Air from Carb on 5.0
  51. NO FUEL PRESSURE!
  52. Dyno Pulls
  53. HP question on a 87' GT
  54. 1990 GT STOCK
  55. maf installed, bad idle problem
  56. mods
  57. 306 Stroker
  58. intake manifold
  59. Just got my AFR 165's.. now what?
  60. head porting!!no buddy now how to port heads?
  61. High Oil Pressure
  62. bigger gain?
  63. HELP WITH POWER LOSS
  64. Camshaft Dilemma
  65. Heads and Wanting more horse
  66. How wide can i go on tires88LX?
  67. Simple PCV Q on 86 GT
  68. Thermactor plug
  69. I can save any one you a lot of money
  70. 65 or 94
  71. heavy or lite
  72. Auto 87' GT mod questions?
  73. What chip for 95GT?
  74. I just cant decide...No one side stories
  75. engine options....
  76. horsepower ideas
  77. Idle Bypass Valve??
  78. problem...please read.
  79. Starter Emergency
  80. "free rev situation"
  81. a pillir gauges
  82. Project car!
  83. PCV valve
  84. exhaust leak
  85. C.F.I. to Carb. ???
  86. Steering colum
  87. chrome
  88. ponies
  89. cooling
  90. 88 mustang with 175k
  91. lost and ford can't get it
  92. sealed chassis?
  93. harmonic balancer question
  94. what next mods
  95. computer chip?
  96. the o2 sensor unplugged q
  97. ignition question
  98. msd question
  99. blaster 3 ignition coil
  100. question
  101. wheres the flasher for the turn signal
  102. 3:73 Gear Speedometer Change Instructions
  103. shifting problems please help???
  104. pcv valve
  105. msd 6 a l
  106. 88gt beginner mods
  107. Ratchet Shifter for a 95GT
  108. 5.0 electrical/heater/AC issue *FIXED*
  109. 85 GT Exhaust Upgrade?
  110. fuel system and injector cleaner
  111. taylor 10.4mm race wires
  112. What do you think of these Headers?
  113. I need more horsepower
  114. power shifting
  115. 94-95 PVC Valve Help
  116. Small backfire
  117. loud noise
  118. IAC Sensor?
  119. summit rebuild?
  120. problem with cold start up
  121. Stalling troubles
  122. quick question
  123. AOD Help
  124. couple of simple questions.....
  125. All the tuning problems solved!
  126. air/fuel ratio gauge
  127. Rear End Noise
  128. long tube headers
  129. fuel pump size
  130. Rebuild or Crate Engine?
  131. what headers should i get?
  132. Help, 88 5.0 Stalling!!!
  133. 245/50/16 and 225/50/16..................
  134. gauge install question!!!
  135. 1984 "mustang GT" 302 CFI
  136. injector size
  137. heddman headers
  138. Dumps worth it??
  139. WANTED 'Stangbabes' :0)
  140. couple of questions??
  141. 3.8 - 5.0 swap
  142. Should I work on suspension or performance?
  143. Paint job cost?
  144. MOVED: 92 for sale
  145. Might be getting a free dyno tune
  146. Whats up with this?
  147. mystery solved on stalling(i hope)
  148. NEW ,,CAR AND MOTOR PICS
  149. GT 40
  150. dilemma
  151. Strange vibration......what's wrong? :-/
  152. COMBO QUESTION!? SHOULD I CHANGE!!
  153. idle control sylinoid?
  154. MOVED: sc and turbo y not
  155. fuel pressure regulators
  156. sparkplug wires?
  157. Aluminum Driveshaft
  158. fuel pressure regulators
  159. Throttle Body
  160. Equal Length Headers
  161. K-member
  162. Battery shut off doesn't shut motor off...
  163. Oil Filter
  164. 8.8 Swap from Cougar
  165. Best Trany?
  166. 94-98 v6 mustang to 5.0 swap???????
  167. HOW did i ever keep up?
  168. what the f***
  169. intake hose
  170. check engine
  171. 1983 5.0 heads
  172. Squeaking in Left Front
  173. Gt40p heads
  174. If...
  175. Help Me With Re-Build
  176. Ongoing Project
  177. LX HB VS. GT HB?
  178. serious problem!
  179. engine light
  180. gear grinding...
  181. Manual steering shaft.
  182. Newbie to 5.0 Ltr's and have questions
  183. Error Code 172
  184. stock gears
  185. liquid in upeper intake
  186. High-Low fan relay.
  187. How far can you go?
  188. clutch
  189. MAC PROCHAMBER what is it?
  190. Intake manifold?
  191. Speedo calibration question
  192. help!!!
  193. bbk o/r h pipe question!
  194. HELP!! Problem wit my engine Ideal !!!???
  195. Race
  196. who knows were to get test pipes
  197. deep emerald green
  198. flowmaster question
  199. clutch cable feels like its binding
  200. Up n coming Project
  201. bassani cat less xpipe
  202. spark plug clearance?
  203. pro 5.0 shifter
  204. Stroker Kit HP?
  205. 1/4 mile times...
  206. AutoGage Tach
  207. Oil Light
  208. PLEASE HELP!!!
  209. Quickest/Cheapest way to run 13s?
  210. tail shaft seal
  211. intake manifold install
  212. all around best...
  213. Rebuild kits and a new block
  214. raced new Maxima SE...
  215. dumps???
  216. red hot cats!
  217. wire looms for 9mm plug wires
  218. How much should it cost to get some gears installed?
  219. x pipe install help
  220. valves
  221. Ordered my gears!
  222. Rear view Mirror
  223. convert rear window
  224. misfireing HELP!!!!
  225. Best Camshaft for stock 87 5.0LX
  226. Wow, check this out!!!?!? Vampire storyteller?
  227. 4 lugs to 5
  228. headers?
  229. Bad vibration at 1000 and high RPM
  230. Does this sound like heat soak?
  231. Throttle body spacer
  232. when a engine needs to be rebuilt?
  233. 120k-130k miles too old?
  234. Starter issuse!
  235. millage
  236. go tthe crap scared out of me today!!!!!!!
  237. A Simple Timing Question
  238. wheel hop
  239. Gear question
  240. timing Question
  241. Out Door Weatherstripping Cont...
  242. Cam in a '94-95 5.0- problems with idle?
  243. MAJOR gas probloem
  244. first thing first...
  245. x pipe x pipe x pipe
  246. 2 cylinders not working
  247. cracked head
  248. Rough Idle Issue
  249. Bumper for 1993 mustang gt
  250. Headers?
