- h or x pipe
- Will a 429 fit?
- MOVED: block question
- Why are my signal lights my reverse lights?
- x-pipe or h-pipe flow better?
- lifter removal
- Throttle problem
- 1.7 rocker arms on stock 302
- Quad shocks
- where does this vacuum go?
- air fuel ratio
- MOVED: 86 front end
- door adjustment
- no spark for 94 mustang. need help
- C&L 76mm MAF question
- 24 lb/hr fuel injectors
- which would u do... 2 intake/cam set ups
- removing smog pump
- Quick Help with Keyless entry
- making my car lighter
- Transmission
- posy ?
- Unexplained loss in fuel economy.
- Help Me Troubleshoot!
- During WOT, Stops at 4k!
- quick simple question about tie rods
- latch
- Issues..... need some input from you knowledgeable techs
- MOVED: Getting a 5.0
- 95 GT lifter tappinging
- Door Hinge Repair
- need help trouble shooting
- help!!! Huge loss of power!
- quick question
- transmission upgrade
- can lack of back pressure cause ticking
- rear window sealer?
- check out my website
- Sounds like it's getting close...
- Tires?
- Tranny swap
- 26 splines or 10 splines
- clicking when i push the clutch in??
- Paints
- 91 octane qustion
- Spark plug wires
- quick question about camshafts for 5.0s
- Fuel Injector Cleaner
- Transmission
- Turbo ideas please
- Your thoughts on motor
- off road h pipe?
- stock 90 heads should bolt onto my 85...
- subframes
- how light can a fox get
- throttle body-question
- Drag/street stang rear susp help for newbie here please!
- rear differential cover
- Quick throwout bearing installation question
- 347 in fox body?
- 5.0 L Oil Change
- Car wont start, smoke coming from passenger side inner fender
- pre-detonation/ping
- gauge install?'s
- lug nuts
- Possible?
- cobra irs in fox
- how do i re atched the window+motor
- steeda adjustable clutch cable
- The Time Has Come; GT40 heads/intake
- smoking
- Interior Help
- exahust silencer
- Camber plate question
- MOVED: Will an '82GT lower front airdam fit an '85??
- MOVED: Any MF oldtimers around? New build started!
- MOVED: Good Deal or Bad Deal???
- Fuel and Oil Pressure Gauge Not working
- MOVED: 351 vs 429BB
- cam/head ?
- MOVED: where to mount msd box?
- fuel injection question
- 351W Heads
- front strut broke while driving!!
- ticking noise
- Smog Removal??
- 5.0 won't start/run with spout installed
- Heads
- 347 Build...need advice
- 66 Mustang 289 to 5.0 Swap
- Quad Shocks
- T-5 De code
- Header flange stud.
- couple ?'s
- car wont start
- cylinder head for my mustang...
- Headlight Positioning
- Will not Rev
- 87 5.0 gt
- upgrade question?
- MOVED: BIG WHEELS!!
- t-56
- carb vs fuel injection
- STOCK COMPUTER SETTINGS FOR A 95 COBRA
- This is weird
- Finished fuel pump - New Problem..
- NEED HELP ADJUSTIN ROCKERS
- EGR tube from heads, what bolt fits hole?
- Cast iron heads #'s
- Flywheel de coding question
- Engine shuts off and then dosn't start up
- Please help
- are 1 3/4" LT's worth it?
- Coolant leak from firewall
- ignition problem?
- Passenger Window Problems
- transmission slippage ???
- Weight reduction
- question
- Eibach Pro Kit
- What rockers for my heads
- Rear suspension questions
- MOVED: hp question ???
- Idle problem after intalling MAF sensor
- Ford Torque Specs.
- Battery relocation ground help
- Question on check engine light???
- idle problem at startup
- clutch cable snapping
- clutch problem
- 89 w/diablo question
- saleen wing
- Displacement
- is this good or bad?
- 210cc heads with 205 valves, what motor to put on
- Stock 5.0 Intake Manifold
- will not idle!
- Finishing up the build...
- roller to flat tappet cam
- Question concerning my engine
- MOVED: Summit wheels vs Weld draglites???
- 5 in.-Hg vacuum at idle
- Cheap Manual crossmember
- Bleeding Air Out of Cooling System
- 93 COBRA COMPUTER CONVERSION KIT
- Want a Turbo....but on a budget
- stabbing the dizzy question
- What is this noise?
- Foxbody Fenders
- Cementing Block
- MOVED: Hello new guy with questions
- Jumping Tachometer in 95 GT
- EGR Valve
- sluggish starting
- clutch or cone diff
- MOVED: looking for 95 roush sideskirts
- My GTS ..still isn't starting right.
- MOVED: Has anybody ever changed the air filter here?
- Can't find Coolant leak
- Whats the difference on a v8 five speed and a 4 cylinder 5 speed???
- Fuel/Exhaust help
- tko in a 331 stroker
- newbe ??? 96 stang
- MOVED: Power steering pump replacement?
- MOVED: Hoods
- EGR valve....85 GT...?
- stroker kit?
- 93 gt heads on a 95 gt?
- smog pump
- Will i need camber plates??
- exhaust ?
- What involved in balancing
- BBK Fuel Pressure Regulator
- C/C Plates
- oil pump question
- spun lifter, and cam question
- Hurst 1/4 stick install in 91 Fox? Need help
- Hows This Sound???
- Wider tires!!!!
- buzzing noise exhaust ?
- which tranny?
- throttle body
- Rear brake hoses for disc brakes
- Driveshaft rub: problem caused by eibach sportline springs
- 3.90 or 4.10 gears?
- Gears
- Lost the Tranny
- MOVED: need more power
- factory tightening sequence for heads...
- MOVED: i know this shouldnt go here
- AOD Shifting
- HELP!!!!! smog delete belt size
- 89 LX 5.0; T-5 "whizzing/vibration" at rpm
- Heat only comes out of the defroster no matter where i turn the knob...
- REAR END..!!!
- AOD dead??
- 91 5.0 alternator upgrade question
- 91 5.0 engine code
- popping noise back fire? help
- Super Easy Dent Fix?
- How are is it really?
- 4 lug to 5 lug
- damn rust
- smoke under spark plug boot
- loose rocker arm
- Help me understand Alum Head CC's
- PCV location
- Something is not right
- fuel pump and regulator
- 5.0l truck engine parts??
- major ignition problems.... help
- Sensor ranges??
- Starter Troubles
- too much pressure radiator
- 8.8 Reaend Has Play..... Need Help
- help with some pulleys
- bad idle
- Strange Brake?
- Are my heat vents supposed to make a weird noise?
- MK vii interchange
- ARP studs... rod and main bores?
- About to replace Harmonic Balancer
- Spoiler brake light
- 8.8 rear end bearing caps
- quick answer needed about headgasket/cam
- Trick flow roller rockers
- Anyone have a pic of their coil cover?
- firing order for a 86 5.0
- need advice on 95 mustang
- another exhaust question...
- is this a 289 or 302 block???
- ah! help.
- T5 main shaft help
- Engine noise right after ignition
- Carb secondary adj.
- supercharging my 95 GTS
- where does the speedo cable go?
- How do you know if your heater core is gone?
- Manual brake conversion
- 5.0 HO question
- what is this?
- whats stronger
- MOVED: Skinnies
- Gap less ring vs Normal rings
- Back Pressure?
- Emmission Check Valve won't come off
- 8.8" or 7.5" rear
- Quarter panel repair/replacement on a hatchback
- MOVED: skinny tire size(yes another one)
- MOVED: Added a new 'stang to the family
