PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 [261] 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Does any one know?
  2. car keeps dying....
  3. adjusting rockers
  4. Broke the rear sway bar (1995 GT Coupe)
  5. valve covers
  6. Rear window louvers on an 87-93 hatch
  7. air ride?
  8. tv cable bushing aka kickdown cable
  9. COBRA BRAKES ON MY 95GT
  10. Just thought i would post some pics
  11. T5 W/C VIBRATION AT HIGH SPEED IN5TH GEAR
  12. my 2nd gear problem
  13. Weird feel on taking off while turning in 1st and REV.
  14. can only chirp 2nd
  15. Some 10-hole rims need a spacer?
  16. car will die at a light sometimes....
  17. Found some pony rims for $160
  18. T5 Transmission
  19. Solid Motor Mounts
  20. Wiper help
  21. battle box question
  22. street slicks
  23. Found my trans problem....40 dollar fix
  24. Engine building question.
  25. Headlight/Alternator wiring?
  26. HELP!! need 1 24lbs injector fast!!
  27. Headlight problem PLEASE HELP!
  28. drag radials
  29. Gear install question
  30. Guage wiring question
  31. MOVED: 351ci of power in a 5.0
  32. Ignition
  33. What looks better?
  34. Idle Control adjustment with bigger Throttle Body?
  35. 5 lug conversion with 2001 parts
  36. prices on notchbacks
  37. 2 questions...for now anyway
  38. y303 heads?
  39. TPS issue
  40. mpg
  41. tires
  42. cam and heads
  43. Will these springs work for my GT40P heads?
  44. MAF Question
  45. throttle response
  46. loved my 5.0
  47. friend sold his car
  48. Quick Question
  49. Heater Core
  50. HI IM New to the forum
  51. 331 fuel tuning questions.
  52. MOVED: ProCharger on a 5.0 Cobra
  53. what are light blue injectors?
  54. Who wants to help?
  55. Video clip of my Vortech First Startup...
  56. Installing New Mods...Can I On My Own?
  57. cars running hot lately..
  58. My box is broken
  59. how much hp??
  60. what makes a 347...unreliable?
  61. Idle Fixed?
  62. Trick flow kit
  63. 4th Gear 4000 RPMs
  64. B&M shift kit VS. Transgo
  65. New "gear question"
  66. smog pump tube plugs
  67. High Idle question
  68. exhaust
  69. Hartman Polymere intake
  70. street heat or track heat with my combo?
  71. What kind of rpms with gear change?
  72. dizzy timing question
  73. MOVED: for those of you having a bad day..
  74. Hi guys
  75. 10-holes on a GT?
  76. 91 5.0 o2 sensor harness
  77. Lifters Not Pumping Up
  78. Make up my mind for me
  79. UPR Tripple Hook Quadrant
  80. 4.10's, 31spline 5lug conversion
  81. I NEED CONV. DOORS?
  82. Inspection Stickers
  83. Starter index plate
  84. Dont do this!
  85. Speaker Sizes STOCK
  86. installing rear control arms
  87. cam and lifters
  88. finally got pics of the stang
  89. Ring and pinion help, please!
  90. Head gasket differences....?
  91. how do i adjust timing?
  92. gas leak
  93. 87-93 Foglight bar Q
  94. what a delimma!
  95. An eleven second question
  96. air silencer removal q?
  97. Help
  98. dyno tune
  99. gt40 kit
  100. 3.55/3.73s and traction
  101. 302 or 347
  102. finished swap...now problems
  103. need help quick
  104. New pics
  105. look what i did
  106. need a cable bushing
  107. EGR Question
  108. Oil pressure sending unit
  109. picture?
  110. wheel spacers
  111. MOVED: Is this one fast 5.0 or what???
  112. vibration
  113. This has to be the most hideous mustang tail light ever
  114. The Best Clutch
  115. Is this car worth getting?
  116. Fenders...
  117. is this normal...
  118. 347 problems
  119. Stock bottom end oil Clearances
  120. Some kinda noise
  121. Holes In Motor Bay...
  122. synthetic lubricants
  123. 1986 to 1987 headlight conversion
  124. fastest stock time???
  125. TUNE question Help!!!!!!
  126. Intake Manifold off 92 Ford....?
  127. MOVED: wuts ur racing song?
  128. MOVED: radar detctors
  129. MOVED: question about camaro.
  130. front wheel play...?
  131. Trans ???
  132. question about launching.
  133. Broke down and Baught a Electric fan...
  134. fuel pump and CAI?
  135. Rear Seat Removal
  136. Cost?
  137. 89' notch what are the widest rims and Tires that will fit?
  138. ratech ring gear install kit, think twice!
  139. Steeda short throw in 2day, also have an unknown whistle
  140. carb and intake manifold?
  141. engine idle
  142. Any Notches out there
  143. Widest wheels and tires for a 89 5.0 notchback?
  144. finished FOG LIGHT Rewire!
  145. best engine combo?
  146. True or no?
  147. Coming Soon..3.73
  148. racing kills
  149. 93 Ford Mustang LX 5.0L 30k original miles *value?
  150. One hot LX
  151. Engine year
  152. Bumper Strips
  153. 88mm MAF w/ 75mm TB with 29lb injectors?
  154. why is my car so slow?
  155. Longtubes for gt40P
  156. 5lugs
  157. MOVED: few questions on 351
  158. will a stock block hold up??
  159. MOVED: boosting with a stock block?
  160. hard to get in gear
  161. my latest install
  162. Updates of my stang...
  163. just need 2 get around mid-low 11's
  164. first car?
  165. front caliper removal - help
  166. NEW MOTOR QUESTION???
  167. exhausts
  168. cruise
  169. beater stang contest
  170. carb to fuel injection
  171. stock mass air meter size
  172. belt tensioner
  173. got a nasty oil leak....
  174. 92' LX Gears?
  175. Got a Question
  176. off topic somewhat... engine build
  177. Question
  178. speed density guys what kind of mods do you
  179. 30 lbs?...more...less???
  180. SPITTING AND SPUTTERING AT HIGHER RPMS
  181. Tick Tick Tick
  182. MOVED: 5.0 turbo for sale
  183. 5.0 needs to beat 4.6
  184. Heads and Intake set up for boost?
  185. probe pistons?
  186. Replacing Doors
  187. 4.10vs2.73
  188. Painting 1991 LX Hatch
  189. 94 5.0 driveshaft in a 93 fox???
  190. 4cyl to 5.0
  191. Stupid spindle question
  192. Lower Control Arm Question
  193. Gears
  194. OMFG!!! This CANT be Normal???
  195. coolant leak
  196. wh
  197. F cam or Stage 2
  198. NOS
  199. 86 T-Bird question.
  200. What would ya call this piece?
  201. 91 gt vert rear suspension help
  202. launching at what?
  203. better tranny??
  204. Steel or aluminum?
  205. rear spoiler for conv?
  206. Granatelli 75 MAF
  207. back brakes
  208. auto/ 5 spds conversion
  209. CONverting the vert...
  210. Spring question
  211. TrickFlow Stage 2 cam
  212. Exhaust opinion
  213. Installed the new exhaust.....
  214. track or street Trick Flow intake?
  215. best heads?
  216. BAAH! IDLE WENT APE SHIAT AGAIN..FIXED IT..FOR NOW HAH
  217. 87 gt air conditioning
  218. 94GT almost alive......
  219. price on gear installation
  220. OBD1 vs OBD2
  221. stock 91gt 4lug or 5?
  222. Pics of goodies in my room
  223. When engine gets warm, check engine light appears
  224. Quick Q???
  225. Anyone in SoCal have wheels for sale?
  226. great first mods info link for newbies!
  227. noob ?..can u explain the tire size #'s
  228. 3 inch exhaust tips?
  229. Which block?
  230. 68 mexican block.
  231. need some help
  232. Any gains in MSD ign?
  233. clocking a MAF
  234. is my car 12 capable yet?
  235. Hi all, newbie
  236. Best Mod...
  237. size of belt?
  238. MAF
  239. Just Spent $380...Hope it was worth it!!!
  240. wtf????
  241. what kind of fox you drive?
  242. thumper heads
  243. interior
  244. got her done last night heres what i got!
  245. "Ford" hood emblem
  246. fuel system questions
  247. overhauling newbie
  248. MAF and Crap
  249. shifting @ what RPM...
  250. oil pan
