- will it lift
- Dexcool okay coolant to use?
- 5.0L engine numbers
- spin ou
- anyone want to sell speedo cluster w/or without gauges 4 a 89
- Idle with Cam????
- LOOK!!!MUSTANG PICS FROM CAR SHOW- GT500 , CALIF SPECIAL OTHERS
- any idea??
- fuel sender
- normal?? idle was high today and seemed to rev as clutch pushed in
- Take Off's Fly By's and Doughnuts!
- Can I replace my 94 GT 5.0 with a 97 Mountaineer?
- What headers to use?
- strange cooling pattern
- What size tire will be equal height to my old set up?
- two issues related to supercharger (I think)
- Vacuum/main seal problem
- Tall valve covers. Do i need spacer ?
- No spark geting to coil wat could it be????
- problems possible with converting 93 ho to carb
- 1986 gt sugested mods
- removing rear bumper
- how does the MAF sensor work???
- Need Help ASAP on timing
- Texas Registration
- Electric fans...
- slp1??
- Sportsman Block
- edelbrock rpm 210cc ??????????
- pics of fox gt's w/ cobra rear?
- speedometer gear???
- rear arm bushings
- Is my oil pump dieng????
- aod people to the table
- H or X Pipe
- emblem still made? where?
- exhuast question
- black/chrome cobra wheels
- Is this the right part i need
- glasspacks vs> flowmaster
- intake parts
- 5.0 carbed
- Fox Spindles
- Finally got the new wheels! Pics
- Gas tank filler neck removal
- Looses power/stutters under load
- GT-40 heads
- Interior/Fabric Dye? Anyone ever used it?
- Light Issues
- How bad would it be...
- Info Websites
- Got a new set of heads, so in the market for a new cam
- Next Mod, help plz
- 95 Computer
- Almost finished my suspension last night!
- '95 GT Decisions
- Finally fixed automatic window
- irs is it worth it
- PMS system
- 95 GT
- anyone remember a "how to" post on running 12's?
- going to look at an 84 5.0 tommorow
- egr
- track
- 95 Mustang Alternator in Fox...
- what size injectors& MAS
- 94-98 SN95 with Saleen rims?!
- k memeber help
- I need to mod up my car...suggestions?
- TRI-STATE cylinder heads, For real?
- Interceptor Engine vs Regular 5.0
- Any one from miami?
- pissed
- Radiator
- WTF!!!
- Clutch Pedal
- Mach 1 hood
- exahst clips???
- Wat Da Hell Could Dis Be??????
- front bumper cover
- Coolant temp sensor location?
- flat tire today :(
- What piston rings for a 1988?
- Stanton Michigan...who wants to race
- Good price for a 93LX?
- 1989 manual seat tracks.
- FORD vs CHEVY
- 94 and newer rear
- Water Pump Help!
- Who's car is running just fine?
- rockers and cam?
- 9 sec. 5.0 w/o any TC or NOS
- what oil do you use?
- 331 NEED HELP
- Next mod
- Steering Noise
- tire size ?
- exhaust louder?
- SN95 Owners
- How do u tell if car is lowered?
- 89 gt convertible worth??? with mods
- Auto Meter Gauges....
- 347 Stroker Build
- heads for my 86 5.0
- outside door trim??????
- What do you think?
- what converter ?
- o-ringed heads
- 3.90s
- Questions about heater bypass...
- Rims 17' for a fox 88 (need some help)
- Getting my 4.10's installed today...
- interior ideas
- Made some car-mod plans for next weekend. - Daddys new shoes!
- 5.0 temps
- Fox 3-Link
- AOD-E Into 93 GT
- Blew up my 94' 5.0
- bogs
- new emblem
- Yet another idle problem
- Put my car on EBAY check it out
- Idle question
- Automatic headlights??
- breather
- cooling
- Still haveing headlightt issues.
- Door lock modulator
- Locks
- Window Guide Bushings
- pulley question
- Tail lights
- injectors
- 11.50s for $1500 or less... including the car.
- Visor lights and trunk release dont work
- Broken Crankshaft
- Mufflers
- 3.8 and 5.0 parts interchangeable?
- Panhard Bar Installation ...
- Afr and 1.7rr question
- Tarus fans? SHO?
- 89 mustang gt not holding a charge
- Here is a REALLY stupid question....
- would this be a good head
- wiring a a/f ratio gauge
- 3 inch catback
- wtb stock fan blade
- entering 1st car show-- what to expect??
- 26 degrees Before TDC????? dude
- Timing
- fuddle torque converters?
- 5.0 pullies, where???
- is this bad
- Gas leaking from my 86!!!
- Broken Crankshaft
- Finally got some pics of my 95 stang...
- Got the right rockers....I HOPE
- Shocks..
- interior question 86 GT
- Weird timing issue
- Why wont she start?????
- Transmission help
- rolling fenders
- pistons w/ twisted wedges?
- Exhaust question
- turbine wheels
- 300+hp
- Help guys!!!! With monster Tach
- 85 LX 5.0
- chevy jokes???
- Has anyone's T5 held up?
- Automatic trans options????? 500+RWHP
- Put my Mustang on EBAY check it out..
- ohio/michigan guys
- Gas Tank: cleaning way to clean it out?
- Stalling Engine
- Full set of MINT black tweed seats!!!
- MAF computer
- Gotta love JEGS
- Look what i pulled out of my motor!!
- 302-stroker?
- 5.0
- throttle body
- What's the Diff... 95 GT vs. 95 Cobra?
- Car really hard to shift.
- belt with no smog
- tranny problems...needs fixin
- FAST ENGINE EMERGENCY ADVICE NEEDED
- How much these worth...
- Do 15x3.5 or 15x4 welds hit SN95 calipers?
- can't get my cuise control to work after t-5 swap, help!
- Need input on paint job!
- EVO's AND STI's
- 357W ready for blast off!!!!!
- !HELP! OIL PRESSURE
- Injector size on my new engine
- What is needed to run 12's on my 94 gt?
- Converter
- which midpipe should i go with?
- Best way to go on a DD Stang
- rear end gears
- cars goin in for paint
- true cold air
- new cam suggestion
- i f*ckin hate the t-5
- Should I buy this 91 5.0/
- Ignition module
- 302-stroker????
- Carbin Fiber cal hood?
- stall converter
- 130 amp alternator
- Quick Question
- Anderson Motorsports PMS
- I need HELP
- need your help for my photoshop project!!
- New Car
- front strut bar.
- valve covers
- another question about heads?
- I broke my car tonight...
- Switching to carb
- speakers
- alternator whine
- 3.55
- found more rust :(
- CHANGING MY MIND ????
- computer module
- Video of my car finally!
- 351c heads on a 302
- What Cam?
- cartech turbo kit
- SN95 body, foglights on only
- Brake Problems.. HELP
- Starter Problems
- CARB/ DIZZY VACUUM QUESTION
- Car Battling??
- Aluminum heads
- Need help big time with the starting/charging system
- Brake Booster
- Maryland Stangers
- Same oh Fan Question
- NEED HELP ON DASH/GAUGES...PLEASE
- mass air flow
- kids in my school!
- what makes it a fox??
- needing help(info) on my 91
- Need some help (info)on a 91 5.0
- 79-93 Mustang 8.8 31 spline axles w/eliminators Strange
- solid motor mounts??
- Body parts..............
