PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 [313] 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. part check
  2. WHAT IS THE BEST INTAKEMAIFOLD?
  3. 88 chip
  4. yay for me.
  5. AOD to T-5 in my 95 gt
  6. HIGHWAY RPM'S WITH 4.10 GEARS???
  7. Purchasing a 5.0....
  8. Lookie here
  9. [Deleted]
  10. how much!! evey one
  11. mass air flow kit
  12. T-BIRD SC MAF
  13. is it a gain in HP
  14. TF or GT40
  15. What is a "fox body"?
  16. trac loc rebuild...worth it?
  17. HOW TO RUN 13's WITH STOCK HEADS?
  18. valve covers???
  19. NMRA World Finals
  20. experimental design
  21. Port the MAF?
  22. smog pump removal
  23. Gts help
  24. Itam Check Plz
  25. 347 Stroker Kit, yes or no?
  26. Fuse Map!
  27. Gear install in Chicagoland??
  28. check my future set-up
  29. Cold air
  30. TB Cooling
  31. Best place to buy parts *BUDGET*
  32. Spark Plug BS
  33. little silly problem
  34. Trick Flow Top End Kit
  35. Svo Bi-wing on a 5.0
  36. old bowtie whoopin
  37. TB and Head question
  38. Stang HEAD HELP
  39. Auburn Gear ECTED Differential
  40. mustang vs. older lightning
  41. EGR simulator/eliminator
  42. 88 intake
  43. do i need to break in gears
  44. Carbon fiber rear hatch?
  45. Help with bolt size
  46. Need help Quick...
  47. NEED HELP PLEASE!!!
  48. ROLLER ROCKERS INSTALL????
  49. 94 GT 5.0 - What to do to it???
  50. new member, first 5.0
  51. Billet A/C Eliminator on Ebay
  52. 1986 Mustang Gauges
  53. 04 cobra motor in Fox body?
  54. Automatic to Manual Tranny conversion, all help appreciated
  55. 94 gt trans, in an 86 gt?
  56. 93 center console
  57. Common problems`
  58. Oil change
  59. Bumper covers?
  60. How do you set your TPS voltage?
  61. Is There A Way To Find Out If You Have 3:73's?
  62. How Much Of a Bitch Is It To Pull The Tranny?
  63. ****otorsport....
  64. question about H-pipe fitment
  65. engine too cold
  66. Mercury Cougar 3.8 SC in 98 stang GT
  67. Engine swap compatible?
  68. Welding
  69. Help!!
  70. Header spark plug modification
  71. where can i find the article, 331 WAYS TO SMOKE AN LS1
  72. Gas and Cam Question
  73. Back to The beggining
  74. Ticking noise
  75. Oil pressure gauge!
  76. 83 mustang gt 5.0 ho
  77. LIL help
  78. 331 or 347
  79. Wish I could afford this car!
  80. afr heads and new rockers
  81. 88GT vs 2kGT
  82. Header bolts... torque or tighten?
  83. there is a miss in the engine in the morning when....
  84. intake manifold
  85. Plug wires, recomendations
  86. Quick Question.....real quick
  87. what's the difference between a 302 and 302ho
  88. Help! Broken Seat Belt Retractor on '91
  89. Ever heard of.....
  90. Is There Any Hidden Smog Stuff On My Stang?
  91. I Run 93 Octane Is It Just As Good To Use 87?
  92. Is this possible.
  93. 331 Question
  94. what's a good site to buy kits, heads, intakes
  95. Sh!t Happens.
  96. Need help intake to big for distributor cap
  97. Rear End Gears or U-Joints?
  98. Short Throw Shifter?
  99. Missouri Emissions Flunkee
  100. Drilling for nitrous in a 95...please help!
  101. holley 350ci stroker assemb
  102. Flowtech shortie headers
  103. 2nd Gear and Reverse Giving Problems
  104. Needs Some trouble shooting advice
  105. turbo chargeing
  106. stronger 5.0
  107. whats HTS coated mean?
  108. Mechanical water temp gauge?
  109. tensioner problem
  110. Still Failing Emisions!!!
  111. help my car is barely running
  112. clutch problems: please help: clutch expert needed!
  113. PLEASE HELP: CLUTCH PROBLEMS : Clutch Expert needed!
  114. new mustang goal
  115. MY TRANNY@!!!@!@!@!
  116. different guages and dash???
  117. New Pics
  118. Anybody here from South Florida ???
  119. equal and unequal headers???
  120. where are the block #'s at?
  121. 1st time to drag strip.. help?
  122. 91 GT 5.0 fuse description list?
  123. supercharger
  124. broke harmonic balancer
  125. Cylinder Head ?
  126. Clearing airbag light.
  127. Engine Rebuild
  128. oil coming out of the gaskets on the 302
  129. new exhaust
  130. Interior question
  131. CHP mustang...
  132. Tires and Wheels Rubbing
  133. *needle still bounces...*
  134. Power steering -
  135. changing cams!!
  136. gauges
  137. Which Crate Engine is the best bang for buck?
  138. portland area residents help???
  139. OBOSOLETE WHAT SIZE HOOD DO YOU HAVE
  140. wrong forum.
  141. Pingin' like a bitch
  142. 245/50/16 tires......anybody??
  143. stupid tach
  144. Installed Cam and Lifters..Now to much gap at the rocker??? Help!!
  145. [Deleted]
  146. Cobra R Rims Centerpieces
  147. Rocker Question
  148. Header ?
  149. f*cking exhaust
  150. 331-347---->351w
  151. '91 LX 5.0 tire size ??
  152. Pics of my car
  153. is this cam any good?????
  154. speedometer calibration gear
  155. engine swap
  156. What belt size to delete smog on '94-'95?
  157. where's the fuel pressure regulator?
  158. Voltage regulator
  159. Where is GM killer 331?
  160. Tires
  161. Dash Lights
  162. best shifter
  163. Mustang body styles
  164. speed density
  165. performance upgrades?
  166. Smog Pump Removal?
  167. Install help
  168. Big electrical problems need help bad!
  169. Help finding power source. When ignition is turned on
  170. suspension question
  171. Help! Fuel Pump Problem??
  172. best year for fox?
  173. cold air intakes
  174. RPM mods
  175. adj. fuel pressure
  176. used gears?
  177. virtual dyno specifically for 5.0
  178. New motor!!When to use synthetic??
  179. 1987 5.0 *24,000 original miles* Whats it worth?
  180. Intake Help!
  181. Computer Tunning
  182. What do you guys think of this part?
  183. Question for late model 5.0!!!!!
  184. Cam install
  185. MY PICS ARE UP!
  186. Having problems with my new engine, help!
  187. wiring harness v6 to v8
  188. Best Clutch for the money
  189. Parts interchangeability w/ other ford 5.0's?
  190. built 302 runs like crap
  191. whats the advantage???
  192. PCV valve
  193. HELP!!! Failed Emissions Twice...
  194. HEY MD i have ? for u!
  195. auto specialties underdrive
  196. Opinions sought on 5.0, 5spd, LX for daily driving
  197. new and looking for advice
  198. 351W Roller cams. Hydraulic or flat-tappet?
  199. Mustang purchase
  200. Check Oil light, and very clean oil 2600 miles after last oil change
  201. good launch?
  202. Starters
  203. This is a car with high expenses
  204. Strange Problem
  205. Christmas List
  206. winter plans please help
  207. Explorers
  208. NMRA FINALS!!
  209. Air/fuel ratio guage - how to?
  210. low oil pressure leaking valve cover.
  211. Does this "Module" work? or is it bogus
  212. what years do the E7 heads work on?
  213. gears again...sorry
  214. A Few ?'s
  215. ONE car length!
  216. Belt Size?????
  217. Electric Waterpump
  218. what kind of clutch?
  219. How to post pics of my car??
  220. front brakes
  221. egr valvle and polution polution control removal
  222. 351w oil pump
  223. Sell or Trade my 93" "FEATURE" 3xWhite LX 5.0
  224. spark plug question
  225. Tranny??
  226. head (engine) question
  227. Fuel Pumps
  228. Question about turbos, please help
  229. Export model '84 GT
  230. turbo mustang
  231. super chargers!
  232. Stock Header Studs
  233. Fuel pump/regulator questions
  234. Clutch Slipping?
  235. BBK Intake?
  236. 2 1/2 in vs 3 in exhaust?
  237. fixed a lot of problems with my exhaust today
  238. Fuel Pump Question
  239. gears AGAIN
  240. stangs
  241. sqeaky rear end
  242. exhausting questions
  243. best heads for 347
  244. t5 rebuild kits
  245. gotter done-gotta clue?
  246. need SERIOUS help
  247. People make me laugh!
  248. 2 bolts away
  249. 302 Rebuild question?
  250. Turbo question...
