PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 [117] 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. is this worth it
  2. Fuel Problem, Fuel Pump Maybe?
  3. ROCKER ARMS?
  4. Door Panel Swap
  5. 351W Overheating
  6. Bauman kit install tips?
  7. rattling noise?? Ughh...
  8. 5.0 info
  9. timing chain cover and nitrous
  10. 351c heads
  11. Timing retard MSD Question
  12. Sudden Power Loss ?
  13. Will a mid-90's t-bird rear work for a 5-lug convert?
  14. Codes
  15. popping in exhaust????? ADDER PLEASE HELP!!!
  16. Under Drive Pullies?
  17. quaderant pictures
  18. Quick question, Orifice Tube location
  19. Help me with some wiring...
  20. Bumpstop Help
  21. K-Member install............ Little help!!
  22. 87 GT handbrake adjustment
  23. Difference in gsakets?
  24. Need help with vacuum tree/pics included
  25. T5
  26. She's Fixed!!!....Pics Inside....
  27. belt size w/ under drive pulleys
  28. Floorpan replacing.
  29. air silencer
  30. Head Gasket?
  31. 1993 airbag
  32. transmission speedo question
  33. Whats first sub-connectors or driveshaft loop
  34. problems!
  35. Bad sputtering. 88 Mustang.
  36. help!! knocking engine
  37. parts from a '88 grand marquis swap
  38. poping back through intake and losing power!
  39. 89 lincoln mark interchangable parts?
  40. MOVED: Asking to much for this 1994 GT?
  41. T-Top Question.
  42. how to advance timing *?
  43. Stock CC size?
  44. decisions decisions
  45. starting 5.0 truck project
  46. Broken rocker nut
  47. MOVED: This is driving me nuts!!!!!!!
  48. MOVED: 93 Cobra Intake plaque
  49. B-303
  50. NEED HELP ABOUT FUEL!!!
  51. Quarter Window Rubber Seal TRICKS!!!
  52. MOVED: cracked windshield
  53. MOVED: cobra r wheels??
  54. h/c/i vs. supercharger; other noob mod questions
  55. Need help identifiying C4
  56. Engine Overheating
  57. valve clearances
  58. Hard starting when WARM
  59. engine won't start after warm
  60. swapping aode for c4!
  61. ****ty headers and i need help
  62. Odometer not working?!?
  63. new audio system
  64. Taking out the axles, please help!
  65. brake light issues
  66. HELP!!
  67. TORQUE BOX
  68. Mass air computer question. Price and different options
  69. roller rocker question
  70. Gas gauge not right
  71. Pressure of auto tranny cooler lines?
  72. Gearbox is grinding in every gear
  73. What RPM do you shift at on Average? Curious
  74. this is gonna sound dumb(clutch cable)
  75. pick which mod??
  76. Aerospace Components Disk Brakes
  77. summit draglites
  78. exhaust
  79. phenolic spacer
  80. sagging door
  81. want to build and engine that can handle alot of power need help please
  82. question regarding a swap...
  83. Summit Question
  84. engine sputtering
  85. straight pipes?
  86. Got The New Car....but...(Possible Clutch problem :()....
  87. Questons about a 5.0
  88. Who can help me with timing?
  89. still overheating
  90. MOVED: Im new. Here's a lil about my car.
  91. help need about fuel
  92. 1991 fenders
  93. wiring help needed
  94. f303 vs e303???
  95. how to fix my door?
  96. How many amps?
  97. How do I tighten the rear shocks?
  98. tire gear combo
  99. New motor mounts
  100. Quite Possibly the Strangest Thing...HELP!
  101. charging problem, any ideas??
  102. MOVED: holy crap thats expensive
  103. 347 prices
  104. Ground wire gauge question????
  105. Best setup for drag
  106. temp question?
  107. Window motor removal, please help
  108. engine codes
  109. Help!!! Weird thing on my stang
  110. belt to bypass ps, smog, and ac
  111. do i need to get upgraded axles
  112. Strange threaded 'sensor'(?) with a ball in it. Attaches to NSS on T5 maybe?
  113. aod shift improver
  114. F***IN Header Bolt!
  115. subframe connectors
  116. Quick fitment question
  117. bad luck
  118. Transmission question
  119. Smog Pump problems
  120. left tail light out?
  121. nitrous question
  122. Need Transmission help !!!
  123. Side exit exhaust on a fox
  124. the shakes UPDATED
  125. Front Struts ?
  126. steering shaft u joint specs; what r they?
  127. Possitive battery cable
  128. In the middle of a build plz help!
  129. AODE acting up...
  130. Smoke coming from vent - Help!
  131. Intake Gasket Differences?
  132. Oil Return Grommet For SC??
  133. AOD SHIFT PORBLEM
  134. what do you think about this?
  135. ADJUSTABLE VALVETRAIN
  136. What Brand lifters
  137. amazing power gains from a diff tuner
  138. Lots of questions regarding upgrades...
  139. which is better/what else needed?
  140. Car Idles at 3k!!! Help
  141. 86 fuse digram
  142. Fubar'd steering.
  143. Where does the starter get its power from?
  144. What are the best plugs to run with wet nitrous?
  145. another gauge question
  146. Best way to make clearance for the h-pipe to transmission crossmember.
  147. FINALLY fixed the Mustang!!
  148. 88 mustang starter not engaging?
  149. I can't find my oil leak!!
  150. y lifters calapsed
  151. Does this bump steer look right? UPDATED W/ PICS
  152. paint wheels?
  153. vacuum leak
  154. tire size?
  155. engine rebuild question...
  156. What I found when I took apart my engine - Suggestions wanted
  157. Replacement console for a '94 Convertible?
  158. manifold gaskets
  159. 140 speedo install wtf
  160. MSD Dizzy Gear
  161. replacing ignition coil
  162. AC harness
  163. GETTING READY TO SPRAY
  164. 50resto headlight kits
  165. something on my exhaust broke and i dont know what it is help please
  166. gt40p headers
  167. Reverse lights not working
  168. just bought my 5.0..few issues
  169. IAC with B303 Cam
  170. oops
  171. Need suspension help!
  172. wireing question
  173. A/C not working
  174. 93 pollution pump
  175. need pics of your fox body 5.0 engine
  176. Dash install now AC control issue
  177. Smog elimination
  178. 5.0 and a auto trans
  179. EEC
  180. new rebuild wont start
  181. fpr guage
  182. Will it pass smog?
  183. F P R help
  184. How to comp test?
  185. The perfect engine t-stat?
  186. AOD TV Cable Adjustment & rpm
  187. Help with my fuel pressure regulator!
  188. 347 in a street strip car
  189. so i finished
  190. some new info on her:)
  191. Shaking Mustang?
  192. two problems / questions or w\e
  193. front brake calipers
  194. heater core bypass
  195. squeeking sound...HELP!! please =)
  196. anyway .....?
  197. inline fuel pump issues
  198. I need pics from you procharger ppl!!
  199. Installing gear and lowering springs
  200. One leak stops and another starts.
  201. block prep, water pits/ water in the cylinder help!
  202. Fuel Pump died
  203. MOVED: 1/8th mile EST.??????
  204. 93 airbag to tilt???
  205. k-member
  206. Gear ?'s
  207. Is no sway bars okay?
  208. STALL?
  209. clutch issues
  210. i have a leaning condition on my 88 lx
  211. cobra grill insert??
  212. fuel rails
  213. Stiff Clutch
  214. intake/headers , ca smog legal?
  215. t5 tranny: rebuild or aftermarket
  216. BELT SIZE
  217. fuel filter? ringing noise in my speakers
  218. seafoam
  219. FOrd Falcon parts car?
  220. Quick question
  221. fresh rebuild..wont run....
  222. fuel pressure?!
  223. How to remove window trim
  224. Starting Issues Still
  225. Starter and fuel line routing suggestions please
  226. new engine
  227. suspension question??
  228. somebody please tell me what is wrong!!
  229. Exterior Rear View Mirror Paint ?
  230. Car dies when I come to a stop or idle it for a minute
  231. cai
  232. suggestions on my build idea :)
  233. how much would my ET drop...
  234. Leaking tranny fluid
  235. overheating problem
  236. Soft pedal with brakes
  237. 85 roller cam block Q
  238. TKO600 crossmember question
  239. coolant in my oil :( :(
  240. truck head to gt-40p
  241. strut dust boot?????
  242. few quick questions
  243. 94 gt and 94 cobra
  244. tranny fluid
  245. Everyone's Got One
  246. CHANGING YOUR CAM MADE EASY.
  247. What cam to get?
  248. Might Install Header Gasket myself....
  249. jegs max box intake?
  250. Car stops running when hot
