PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 [296] 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. line lock before proportioning valve??
  2. NEED HELP FAST!!!!
  3. Are Underdrive Pullies Really Worth It?
  4. Smog Pump Removal ? (All Precautions)
  5. how wide of a tire?
  6. got my regulator today but have a question
  7. MSD
  8. TPS Voltage
  9. could someone with a convertible do me a favor?
  10. Polished Parts
  11. Gears help!
  12. Some Pinging at High RPM
  13. i give up
  14. turn signals took a dump
  15. Forged bottom end
  16. Help Diagnose SPEC Stage 2 Clutch Problem LOTS OF PICS(NO 56k)
  17. SUSPENSION POLYURETHANE BUSHINGS
  18. OMG I have a BIG PROBLEM- please help
  19. I'm Confused
  20. gas in oil?
  21. Want to delete A/C, PS and smog...
  22. suspension help
  23. want shift light do I need an msd
  24. control arm recomendations needed please
  25. Removing body panels
  26. Buying manifold need help
  27. a/c eliminator, this one ok??
  28. Dashboard help!?!?
  29. Please Help, Problem with Spec Stage 2(Pics NO 56K)
  30. Gear oil
  31. MSD or FORD wires?
  32. Electric Fan Prob! Help
  33. Someone school me...
  34. how to hookup aftermarket tach?
  35. AIR Bag Troubles
  36. Door Lock Actuators
  37. Valve Covers...
  38. exhaust
  39. ignition control
  40. just ordered nitto drag radials
  41. oil preasure gauge & gas gauge.. NOT WORKING!
  42. signal lights
  43. How Hard???
  44. what do you guys think
  45. help alll was fine then it died
  46. K Member Torque Spec
  47. NEED HELP WHAT TO BUY??
  48. 351w into 94 v6
  49. rim width
  50. was this a mistake buying this?
  51. SHIFTER QUESTION????
  52. IDLE PROBLEM
  53. flushing the cooling system
  54. 5.0 Fox Body Drag (Please Help Me)
  55. Clutch Cable Route?
  56. Will these axles work?
  57. please help rim rubbing!!
  58. control arms
  59. CLUTCH
  60. Pics of my friends new 88 GT 5.0(NO 56K)
  61. pre 91 mustangs tire size
  62. msd? for an 83?
  63. engine bore question
  64. need advise for my 5.0
  65. BBK SSI INTAKE
  66. MUSCLE MUSTANGS STANG STORE
  67. Cutting out....PLEASE HELP
  68. ELECTRIC FAN
  69. Hood Pins
  70. Differences bet 87-93 5.0
  71. what do you think?
  72. Quick Question Plz Help
  73. which intake manifold will show more gains then the cobra
  74. 2 q's runing rich and rack
  75. I caught her smoking today...
  76. 1985 Mustang GT Top Speed?
  77. Are these heads worth the price?
  78. WHAT'S THE MOST LIFT A PEDESTAL MOUNT HEAD CAN TAKE?
  79. Fixed Tranny
  80. How do these mods sound? Opinions needed...
  81. H pipe
  82. need help asap
  83. tire size question
  84. 3.90 Gears
  85. smoking from rear tire
  86. new here, my baby and some mods done.
  87. I'm going to an automatic guys.
  88. Cam selection
  89. cruise control
  90. Injectors big enough??
  91. cam
  92. ignition swich
  93. looks good...Notches with GT ground effects?
  94. got new advatar
  95. 4 Cyl to 8 Cyl Conversion
  96. 5.0 wont run/start
  97. pics
  98. I GOT BEAT BUY AN SRT-4
  99. 24 lb injectors
  100. air filter
  101. WHO HAS AFR 185's PEDESTAL MOUNT? LOOK INSIDE.
  102. how to make two 2.5l
  103. Car Has no power under load
  104. Mods???
  105. 2002 GT potential
  106. Distributor Gear??? Bronze or Cast Iron???
  107. $6000 invested, Few ?? need some Answers
  108. roller rocker conversion
  109. Which caster camber plates do you recommend?
  110. grille insert molded
  111. Problem with Spec Stage 2 Clutch
  112. Tune up.
  113. Intake manifold shootout...
  114. Pistons and connecting rods
  115. pro 5.0 vs Steeda
  116. porting stock heads
  117. Complete Wiring harnesses
  118. thank god!
  119. tore into my motor today
  120. whats this 5.0L worth?
  121. how can you get rid of the EGR system?
  122. AOD-T5 swap
  123. Automatic transmission problem
  124. Gas gauge problem please help
  125. NEED MAF HELP
  126. went to track, dissapointed.
  127. fuel tank installation problem
  128. Fuel pump question
  129. 87 5.0 Dies out
  130. clutch install
  131. wideband o2 sensor
  132. MSD ignition worth it??
  133. This any good....
  134. Venom 400
  135. NEED HELP WITH HEADS
  136. twested wedge vs edelbrock rpm heads
  137. what cam should i use
  138. still overheating
  139. TPS question
  140. 95 gt vert engine build
  141. TUBULAR FRONT END-COMMENTS PLEASE
  142. how...timing???
  143. Dome light question
  144. Stock 302 to 347 Stroker...
  145. Need T5 info ASAP!
  146. Need T5 info ASAP!
  147. clutch alignment tool
  148. What goes here?
  149. $500 problem???
  150. RPM drop after clutch pressed...??
  151. lost 4 miles an hour on 1/4 over winter
  152. MY OVERFLOW DON'T WORK NEED HELP!
  153. Chance to win free MF decal!
  154. 16 inch rims
  155. Anyone have the PA Mini-Starter?
  156. what cam for my heads?
  157. Best chip
  158. Diablo Sport Chip
  159. straight up....
  160. oil pressure
  161. Main bearing trouble
  162. underdrive pulley
  163. burnout
  164. Rich after mass air conversion
  165. $2000 spent and still not fixed!
  166. time for fuel pressure reg? what psi
  167. 5.0 cammer
  168. 460 info
  169. opinions.
  170. debating/welding
  171. How do i change the ebrake
  172. THE BEST HEADS....
  173. quick answer for fuse location on 91
  174. how much???
  175. COMING UP!
  176. how fare timeing
  177. white pony's
  178. Suspension and Brakes
  179. Question About Gears
  180. H/C/I
  181. NEED YOUR FEED BACK ON TUBULAR FRONT END
  182. Advise on 460 swap in a 91'
  183. The worst luck!!
  184. Fuel Pressure Gauge Install Questions
  185. Scat Vs. Eagle
  186. Help with a code pulled this afternoon
  187. Advanced my timing...holy cow
  188. 94-95 5.0 same as 87-93?
  189. instructions to convert to a 5.0L
  190. COLD AIR KIT
  191. vacuum readings
  192. Fuel Injected 351 Cleveland
  193. how hot is too hot?
  194. car's loos felling
  195. FI vs Carb?
  196. idle jumpy
  197. headers
  198. Gear install $$$
  199. Tranny Bolts
  200. HELP! 93 longtubes
  201. 351W in a 95GT?
  202. EEC IV code help
  203. 88 mustang
  204. push rod length
  205. egr spacer
  206. clutch question
  207. Got some birthday presents today!
  208. Online Manual & AC Compressor NEEDED
  209. 93 cobra's
  210. HELP needed with 95 gt online manual
  211. rims
  212. anyone have an idea what this fox is worth?
  213. Suspension
  214. Exhaust Resonating
  215. Freeze Plug :(
  216. need ac help
  217. help with idle
  218. tranny??
  219. AOD to C-4 Swap HELP!!!!
  220. what kind of gas millage does a 331 get...
  221. Floor Jack Question
  222. Antifreeze Leak
  223. 302 vs 306 vs 331 vs 347
  224. 5 lug conversion w/ 4w disc brake!
  225. Stock heads E5TE E7TE both on my motor
  226. Will I Pass Emissions?
  227. Questions
  228. Help me with this pinging problem
  229. 94 Factory h pipe on a 92 lx
  230. Red Top Optima?
  231. Driveshaft
  232. 302 to 331 Stroker - What is involved
  233. AOD Transmission crappy
  234. starting problem
  235. My battery wont charge
  236. 5.0 Mustang Drawing !
  237. Wheel Spacing...
  238. spark plug cables
  239. 2 chamber flows
  240. Car Stalling at a stop sign
  241. Problem Is Getting Worse
  242. Why does my car die?
  243. idle problem in gear
  244. Need some selling advice please
  245. what to do next to my 5.0
  246. cam recommendation
  247. stang making funny noise and vibration.
  248. Header suggestion's
  249. exhaust hp ?
  250. altenator question
