PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 [150] 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. upper arm axle bushings. mystery part
  2. gotta sell the 85
  3. Fuel????
  4. engine tune up
  5. Explorer Heads
  6. for you AODE guys
  7. Got a 70mm, need a 65mm...
  8. Skinnies on a 94 Cobra??
  9. 70mm t/b on stock intake?
  10. 94-95 gt ? about supercharging...
  11. Getting close to firing it up!
  12. What vehicles have T-5s
  13. Ebay headers...
  14. Idea...
  15. Shocks
  16. Car Covers?
  17. HELP! DID MY CLUTCH CABLE BREAK??!
  18. old 302 or 351?
  19. shop book i need one which is good
  20. 5.0 HO speed density cams
  21. Quick locker question
  22. cam question
  23. I need to find my paint code, but there are problems...
  24. is something missing? pic inside
  25. will these pistons work on twisyted wedge
  26. Just sharing with you guys
  27. new 1/2" fuel rails and CHP stainless fuel lines
  28. shortys or long tubes?
  29. 83 mustang gt
  30. Gear question
  31. This is how you mess up a rear end!!!
  32. thermactor problem.
  33. pics of the stang
  34. hey what up guy? need help with old filter.
  35. supercharger
  36. Custom Cam from Jay Allen
  37. Manifold Help Please
  38. 1/8 mile time slip
  39. another vert subframe thread
  40. lost keys
  41. MGW or tranny problem
  42. Glasspacks, no cats.
  43. NEED TO KNOW!
  44. whats easier
  45. so pissed!
  46. bad oil pan...
  47. Timing Chain
  48. transmission intallation...
  49. Contorl Arms
  50. Speedometer and Fule Guage Question
  51. question about fluid capacity
  52. PCV with Supercharger
  53. 95 mustang gt miss firing
  54. Paint ideas
  55. What to replace/rebuild on 87 302?
  56. has anyone ever shipped gt40 heads, intake
  57. ordering exhaust
  58. Mishimoto Radiators
  59. [Deleted]
  60. non HO exhaust manifolds
  61. Fan Diameter
  62. How Rare???
  63. Stock '03 GT vs. slightly modded '93 LX 5.0
  64. 289 - 302
  65. gm dude
  66. What heads to go with????
  67. good aftermarket block?
  68. check engine light
  69. Portland, Oregon swap meet
  70. All Done!!!!!
  71. afr 185 on a 393 stroker
  72. help
  73. door jam
  74. gains from electric fans
  75. Worst Spring Break Ever
  76. Collectible?
  77. A few steps closer to race season!!!
  78. IAC Doesn't match up to my throttle body
  79. camshaft
  80. JunkYard Aluminum raditors. Any good ones?
  81. Just put on my hood pins!
  82. help!!!
  83. Jeg's O/R H Pipe
  84. how do i know
  85. Does anyone have Bullitt springs on a fox?
  86. Fuel Pump Spliced Wires?
  87. Help Needed! Question About Exhaust Ports
  88. engine oil
  89. firing order
  90. catted or un.....?
  91. HI, NEW MEMBER, NEW 5.0, electrical issue
  92. Battery wont charge
  93. computer
  94. Any1 else here of this?
  95. iFYI
  96. Rust
  97. 4 cyl swap to 289 v8 mustang
  98. A9L computer ?
  99. need help asap
  100. Video of Kenne Bell 347 untuned
  101. 408 or 96 Cobra
  102. 99 Mountaineer injectors?
  103. Supercharged People Look!
  104. well I got some
  105. trick flow high ports anyone?
  106. Running on E85?
  107. I need help please
  108. Airbag Light On
  109. 18' saleens
  110. Gears 3.73 for 89 5.0
  111. went to junkyard
  112. having problems setting timing
  113. shifter knobs
  114. Anyone with a Blower..what up with PVC
  115. High oil consumption...
  116. VIN Code
  117. Dont Buy Proform! Picture inside....
  118. HP combo
  119. removing iac
  120. Steering Wheel Vibration
  121. hb installation
  122. deal on maf stuff ?
  123. YAY!
  124. Differential Question
  125. procomp electric water pump
  126. rear end question on 89 gt
  127. subframe install question.
  128. Gears?
  129. Shoud I BUY IT.. Spider Intake on ebay
  130. cylinders
  131. some pics of my junk
  132. backfiring
  133. MAP / Barometric Sensor Cofusion
  134. Twin Turbo!!!
  135. What HP should this combo produce?
  136. mass air not working
  137. differences in water pumps
  138. New addtion to the stable, sorry but its GM
  139. duh
  140. efi to a carb?
  141. 92 Mustang Fuel rail and line install
  142. Wheel ?
  143. my project
  144. DEEP Exhaust
  145. went to the track tonight
  146. Speaker question
  147. new rims on the way.
  148. Angel Eyes and pedal covers
  149. t-5 rebuild
  150. fuel pressure check
  151. Power Windows and Door Locks
  152. Antenna
  153. computer for mustang
  154. my car limit
  155. 4cyl springs and strange 10 ways installed!
  156. 2 sec question
  157. Anyone have a manual rack ?
  158. Zex window switch install
  159. quarter window moulding cover
  160. 86 gt paint
  161. Steering
  162. Hey got my notch all finished on the outside!!
  163. imput
  164. Looking for Stang shop in Chicago burbs
  165. ware pump
  166. DONT SHOOT
  167. I NEED HELP ASAP!!!
  168. AHH wiring help needed very badly
  169. chrome ponies
  170. smooth idle, no more searching
  171. AOD/AODE
  172. How long do you smoke your slicks?
  173. difference b/w these kits
  174. Timming and cooling questions
  175. Air silencer Removal
  176. Fuel smell
  177. MAC cai filter cleaning???
  178. Please help
  179. Lightning Maf
  180. 1989 convertable
  181. I Just blew my ****ing motor
  182. New Car to me Need Help 2 things
  183. 87 mustang ?
  184. Need help
  185. why wont it fit
  186. 85 GT Engine Wiring Harness
  187. Has anyone on here KENNE BELL'd their 347 not the 331s
  188. 3.73 rpm?
  189. fuel mileage of the 5.0
  190. edelbrock victor junior heads
  191. fox or sn95
  192. still cant get it to work
  193. OFF ROAD H-PIPE 50+HP?
  194. c-clip eliminators?
  195. clutch pedal
  196. 94 gt
  197. A 15426378 firing order on 93'HO WTF?!
  198. NEED HELP FAST
  199. my first run at the strip
  200. b303 in 94 gt
  201. what do you guys think?
  202. Backfire problem, before warmup
  203. 96 and under no emissions!
  204. UPR CLUTCH CABLE
  205. How to tell
  206. Race how close?
  207. Paint Job? clear coats
  208. Car needs paint and bondo in Norther Ca
  209. Best ways to reduce underhood noise
  210. widest tire on a 9inch rim?
  211. Wiring Issue.
  212. Mustang vs. 2.0L Jetta?
  213. Got my H pipe on and played with timing
  214. looking for hood abd bodykit.
  215. Non World Class T5
  216. Exhaust
  217. Finalizing setup...input appreciated...
  218. Mac pro dumps
  219. thunderbird
  220. Need Help on Choosing Intake Manifold!!!
  221. break-in time
  222. need some more electrical help guys
  223. V6 to V8 engine swap
  224. wires
  225. piston rings
  226. slp
  227. clutch alignment question
  228. My Electrical System is Disintegrating !
  229. guess the car
  230. runs like sh1t after cai install
  231. Stock Radiator...
  232. ford racing lowering springs
  233. DEFINITELY the nicest 4 eye Fox I have ever seen
  234. Serious power steering rack question.
  235. too rich...e303..too broke to guess
  236. too rich...e303..too broke to guess
  237. Clutch adjust
  238. tranny question
  239. Eww gross body kit
  240. cowl vent cover
  241. Car sounds diff after FPR install.
  242. Recent pics of the stang after wax!
  243. browsing ebay and found this
  244. Air plastic thing under the stang
  245. opinions please
  246. Hood Pins.
  247. What is my paint code?
  248. Tranny Fluid... Easier to shift?
  249. Full exhust on a Built Procharged motor.
  250. may my mustang rest in pieces
