- ahhh ..... come on Pro5.0SC
- MOVED: Paint time
- MOVED: wanting to get a New convertible top
- 3.73's Installed!
- MOVED: Best engine stop leak??
- My Mysterious 331
- windsor sr cast heads
- next mods to my 91 gt 5sp?
- sn95 dash in a 89 LX ?????
- ATCO NMRA Pre-Cruise
- 1996 Explorer Intake Elbow
- O2 sensor
- Rebuild time
- I hate brakes! Any help very much appreciated!
- help finding parts???
- Cammed
- transmission pin needed for my 5.0 trans
- H-Pipe or X-pipe?
- trick flow kit
- Tranny question.
- Torque converter
- HELP!!! Anyone with a E303 & ped mount RR's
- Cheap Battery Mount for Trunk
- overheating
- tuning with a s/c. HELP
- 15x10 6.5" BS Weld Prostars MT Drags 26x10x15 need a lil info
- Explorer lower intake ?
- ecc IV codes - need help
- New exhaust not fitting properly!!!!
- Rear main seal/pan gasket
- SSBC
- Will 5 lug 15" new edge V6 wheels work on the back of a fox?
- Lifters
- gt front bumper for sale
- world heads?
- having trouble firing motor
- HCI done #'s are in!!!
- Pistons in an 85 5.0
- bad suspension setup
- Should I get my Cobra upper extrude honed?
- Stereo Static after installing Ford Racing Wires
- traction lock Q's
- rotors and brakes
- got some upper and lower control arms for free but i dont know who's they are
- Window question need help asap...
- Cobra MAF
- Wipers
- Power Steering
- Switching tranny from auto to manual
- Explorer Intake and Rods ( 98-2000 )
- Door ajar/Light's on Beep
- thunderbird tranny question!
- Short belt
- Gear problem?
- Heads and cam
- Stroker??
- speedometer help
- e7 heads on a 86 block??
- new fuel pump ?
- Anyone ever ran these heads? 32v for 5.0l
- ford 24# injectors
- valve adjusting
- no spark.... Help
- window motor
- hp and torq
- Torque Converter ?
- Headliner replacement
- about $4,000?
- A few questions from a beginner...
- different year t5
- Questions about upgrading brakes! HELP *PICS*
- judgement on engine kit
- running cold
- stock tach
- WHICH CAM??????
- Hushpower II Mufflers
- T5 install question
- spool or not?
- need some help with suspesion
- When do you need headers?
- Cam Question
- 306SB Procharger Build up PICS... Also question..
- hci swap
- Summit headers? Are they any good?
- Whats a good cam?
- Is this a good flywheel?
- best ecu/ecm for a 408w
- Struggling to solve problem, PLEASE read and give some input!!
- Coil over conversion pics?
- Combustion Chamber/Intake Cleaning via Water
- Melting #5 Plug with Nitrous????
- header question
- 347ci wanting to go turbo
- Clutch quadrant, firewall adjuster ?'s
- Long Tube VS Shorty
- 87 steering wheel on a 86?
- NeEd HeLp!!!!
- Lookin to turbo my 90 gt 302 any help?
- problem with front strut tower brace for 94-95 stang gt?
- 1262r's or 1265 intake gaskets?
- leaky macs
- Any idea?..
- What stall speed?
- need help with auto tranny!
- Big problem need help
- Back from the Dyno
- is this short shifter any good?
- a/c help
- driveshaft removal
- T-5
- GT-40 cast iron heads on 347 HELP!!
- hydraulic clutch
- roush side exaust skirts, and rear bumper
- need help with passenger door
- Leaking Tranny Cooler Line *help*
- shutting that tube going to the exhaust???
- wont start
- exhaust discharge
- I got this code from my computer DTC222
- Car overheating! Please help!!
- 351 heads
- ? for Carb Tuners
- need to know??clutch adjustment
- all sortsa questions..
- oil leak
- Hurst QuarterStick shifter?????????
- axle bushings..NAPA?POLY's?FORD?
- 7.5 to 8.8 rearend
- Whats this connector??
- update from last night code 33
- Difference b/t Mustang dyno and regular dyno?
- intake still making a noise
- Suspension Ideas?
- 91 5.0 stuff
- Installing poly mounts, Is grease needed?
- Trying to remove front & rear window molding
- Back firing problem
- Convertible Top Latch Question???
- timming and fuel preasure?
- Procomp Aluminum heads?
- couple ?'s
- Thermactor Plug's
- Header Torque Specifications??
- which wideband for tweecer RT
- Gauge cluster removal.
- chassis braces???
- SN 95 Cobra "Crabs"
- using a MM adjustable LCA to raise ride height???
- clutch cable problems..
- worn out timing chain?
- shes at the shop now what
- hey guys quick question before i go to junkyard
- 94-95 Fuel Lines
- Oil pump shaft Help?!?!?!
- suspension suspicion
- Who runs a 347?
- stock interanls?
- dyno tune vs. DIY tune
- tranny question
- Dash Removal
- Loose rod???
- Throw out bearing went up
- Just getting started...
- starving for fuel?
- Shifting Issue
- emissions?? pahhlease
- Relation between cam and air/fuel ratio and such...
- CAI Not Starting
- Oil pressure problem and gas consumption problem.
- 85/90 GT questions
- Mustang going downhill!
- MOROSO TRICK SPRINGS or 4cyl springs?
- 500hp rear end build q's?
- High Idle
- Hatch back quarter windows
- Just wondering about a few codes i got
- newbee performance questions
- SHIFT KIT STOCK TRANNY?
- Trick flow intake clearence
- Putting Timing chain on.. Need a little help
- how much vac?
- Air/smog pump
- idle prob... and yes, I did read the stickys
- has anyone else done this?
- Belt size?
- how does it work
- tech ADVICE please, vortec with my 5.0
- 1979 coupe exhaust
- Thoughts on Patriot Heads?
- Fuel Preasure
- radiator flush
- Shift light
- Write-ups on starting mods?
- Fuel pressure regulator?
- HELP
- transmission problem? Car shakes around 45mph
- Clutch Adjustment
- Underdrive Pulley Options
- Couple Questions
- New Balancer
- installing MAF and TB before h/c/i???
- Hard to start when cold
- Video of my engine... what is this noise? Valve tap?
- Have ZEX wet kit...
- Rack and Pinion Help
- Stock ride height.
- weird noise
- floor pan? question
- cam help
- need a little help plzz
- help with my 5.0!
- Auto tranny
- 98 Explorer 5.0 block
- is this a good tranny?
- Questions from a newbie...
- Trick flow valve covers
- power steering pump
- strut bushings/caster camber plates
- New Member- Anyone bought a 454 stroker?
- 500hp aod rebuild kit
- '89 Gt Rear Brake Question/Help
- New springs for my 1995 convertible 5.0
- water pump
- Best top end kit
- Will stock valve covers from a 91 stang work with e303 cam and 1.7rr?
- will this rear tire combo fit?
- question about CAI and the throttle body
- Harmonic balancer?
- C&L maf kit???
- upper torque box reinforcements, how necessary??
- quick question
- Clutch adjustment
- Aurora Wire sets, Blue streak cap
- cam install
- still need help! wont start...
- sensor and bracket for MAF
- where can i just buy slp mufflers?
- Broke a damn rolloer rocker pedestal
- Passenger side sits lower than driver. Help!
- clunking noise
- do i need new axles??
- throttle body, and heads?
- SLP loudmouth 1 or 2 with catted X
- remote key fob
- New question
- Brakes
- Header Questions
- Proper tv cable adjustment?
- clutch, flywheel, and yoke
