PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 [175] 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Any advise (trany)
  2. Apparently some of you are having trouble.....
  3. code checking question
  4. stupid suspension question?
  5. problems
  6. Tuner in Milwaukee Area
  7. realistically what should i do?
  8. Stock or Drag Strip Ready?
  9. fiproblems with 94 mustang gt
  10. Dizzy gear
  11. intake manifold
  12. fuel injection to carb?
  13. car wont stay running
  14. Any one ever used these?
  15. What is this 86 LX 5.0 Convertible Worth
  16. Body and Paint
  17. engine chattering
  18. What a Waste
  19. TRW Pistons?
  20. widebody mustang info
  21. How Much Is It Worth
  22. help! coolant problem...
  23. Any of you have experience with replacing inner fender aprons?
  24. estimate today
  25. Mufflers or not
  26. Engine Quote
  27. got my headers on
  28. detonation
  29. Blow by?? need opinions
  30. TF stage 1 cam
  31. Decisions????
  32. gear install
  33. cobra inyake
  34. B or C springs?
  35. engine questions ? which heads etc..
  36. Backfire?
  37. Hello Everyone
  38. Cleaning o2s
  39. What is a PCV BYPASS KIT
  40. would this screw up my computer?
  41. Springs
  42. In-line vs. In-tank Fuel Pumps
  43. knock sensor
  44. timing
  45. Fuel system
  46. Kenny Brown Double Cross subframe connectors
  47. Need Help
  48. Whats the differnce in Long tube and short?
  49. Tire Rotation Question
  50. forged alum and steel
  51. sn95 c&l CAI onto 87
  52. piston to valve clearance
  53. what size tire can i fit?
  54. bbk long tubes?
  55. EGR removal, howd you do it ?
  56. just wonderin how
  57. 94-95 headers vs. 87-93
  58. Suspension??
  59. Finally got my motor out..
  60. What should my timing be at?
  61. Engine shops in Maryland??
  62. i have questions about superchargers...
  63. 91 lx?
  64. For Sale
  65. Bad Idle & rich exhaust, Painful!!
  66. which cam ?
  67. SOLD
  68. 84 5.0 + gt40's = valve clearance?
  69. Newb With questions
  70. WOO.. Painted hood... I bet you never saw THIS happening!
  71. Stock gauge cluster question
  72. airbag light code 72
  73. Block casting numbers
  74. are the 7.5 an 8.8 axel shafts the same?
  75. Best site
  76. think im going trick flow?
  77. V6-V8 swap
  78. K-MEMBER ?
  79. nitrous
  80. World Windsor SR Head
  81. HEEEEEELLLLLP.. My AOD wont shift!!!!!
  82. tire size question
  83. just got quoted
  84. Rebuild engine or new one?
  85. thermostat install?
  86. are these engines the same?
  87. Hey Guys - New / few questions
  88. wet sump dry sump?
  89. 306 numbers
  90. need new battery how much are red tops?
  91. tko problems... or clutch problems...
  92. going to the dark side(no not chevy)
  93. stock rods
  94. Stock alternator, and alternator fitment questions.
  95. feul pump problems ??
  96. 5 liter fuel injection on a 71 challenger...
  97. got new engine pictures
  98. Keep or sell??
  99. 3g alternator install problem?!?!
  100. temp is sky high after thermostat gasket install?!?
  101. I have no MAF, its 87 but can i use this CAI?
  102. serious problem
  103. Floor panel repair
  104. wierd clicking
  105. What's my factory weight
  106. Selling my engine what can i get for it?
  107. Idling high issue
  108. ignition coil help
  109. MM suspension questions
  110. antifreeze in oil pan!!!!
  111. need some help
  112. 5.0 help, need as much info as possible
  113. Hurst Shifters
  114. a v6 guy needs your help
  115. Performance Upgrades
  116. mustang vs VR6
  117. since everyone else has problems today
  118. Speedo Gear Help?
  119. MM Road and Track kit...???
  120. Kinda Off Topic..
  121. combustion chambers??
  122. Whats it worth?? input needed
  123. New Battery?
  124. what kind of plugs
  125. White Gauges Messup
  126. WTF happen to my clutch cable???
  127. cam option
  128. ideas, carb or fi?
  129. Finally switch over to 3G
  130. Combo question...injector selection?
  131. Suggestions
  132. hood clearance problem
  133. Car sputters above 3500
  134. turbo
  135. lowering my car
  136. question on rear bumper cover
  137. Did he spray?
  138. Great article on HP vs TQ.
  139. What do you guys think???
  140. starting problem
  141. k member ?
  142. mac shorty's and prochamber from 95 onto 87
  143. wat is this
  144. Want Run Black Smoke
  145. Mustang vs Corvette
  146. STALL CONVERTER
  147. EFI to carb
  148. Deciding On Build... Starting to build...
  149. HoleShot!
  150. advice on gear whine
  151. The carb on the 88 GT...
  152. what about the 95 gt? hp? response to mods? and 1/4 mile time?
  153. question about starter
  154. rough ride
  155. How to make Oil Separator??
  156. 302 or 306 ET Times with AFR's
  157. Help me, fellas! Electrical issue.
  158. Fuel Injected to carb
  159. Speedo gear....stupid question
  160. Zex kit 82023
  161. clutch rubbing on bell housing
  162. 91 seat delete and engine
  163. CAI vs. K&N filter
  164. Mustang upper and lower intake
  165. 351w
  166. aftermarket head questions
  167. 3 angle valve job????
  168. socket to fit oil sending unit
  169. need help NOW...alternator pulley
  170. CLUTCH CABLE QUESTION PLEASE HELP
  171. b-303
  172. Vibration in my a$$
  173. Doing a 5 Lug fox swap and need HELP!!
  174. rear window motor
  175. 88 5.0 electrical gremlin
  176. 331 QUESTION
  177. whats the best setup
  178. **** IM GONNA KILL THIS GUY!!!!!
  179. Mallory coils
  180. Newbie, has a few questions
  181. why all the clatter ?
  182. DD rims
  183. limited edition flowmasters?
  184. 18x10 on a fox?
  185. dynamat hoodliner
  186. Video request
  187. Cant Pick A Front Bumper
  188. cold natured as hell
  189. 5.0 explorer
  190. AFR 185's
  191. OMG!!!11!!!
  192. where to buy
  193. Help with mustang forums
  194. 95 5.0 having trouble staying ON
  195. H2O Temp Gauges ???
  196. MISS WHEN FIRST STARTED
  197. today should be a good day
  198. IS IT MY FLYWHEEL?
  199. bassani shorty to bbk h
  200. Injection is nice, but i'd rather be blown
  201. wet and dry sump pump?
  202. Dying seatbelts?
  203. not getting an ignition signal....?
  204. rx-7 motor swap with 5.0
  205. Fan question
  206. signature...
  207. Think you can drive a stick well?
  208. R.I.P. ????
  209. Computer problem
  210. for those with the 3g alt upgrade
  211. car value
  212. need to fix speedo cable
  213. what do you guys think about this
  214. Drove it for the first time, few problems.
  215. future 5.0
  216. whats a good price?
  217. Low Coolant Sensor Removal - 88 GT
  218. Does this cam good or bad??
  219. cobra intake
  220. Car won't run KOER codes!! Help.
  221. need help with 347
  222. spark plug help
  223. LT's on my fox???
  224. who on here is an admin?
  225. GT body kit
  226. exhaust
  227. thick wire on the 3g alt
  228. I want a pony again..........Help!!!
  229. help. its almost done
  230. LX Cobra..haha
  231. need to remove header bolts
  232. Air management 2 circuit failure (AM2/TAD)????
  233. Heater core instalation?
  234. Do worn shocks hurt traction?
  235. Tire Pressure
  236. feed back what do you think?
  237. Pypes exhaust??
  238. swapping 351c into 65 stang
  239. Engine Components???
  240. Another ? on the gas gauge
  241. bbk header finish bad
  242. MPG
  243. Noisy T-5 W/C
  244. 5.0 @ Barrett Jackson!!
  245. head recommendation
  246. need help with headers
  247. driveline ?
  248. Boring out EGR spacer?
  249. NEED to buy foxbody GT springs
  250. Where can i get a c4 and what are they in
