PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 [126] 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. TAD, TAB and codes 41/91
  2. The best MAF Kit to buy?
  3. Wobbly Steering Wheel
  4. Valve covers
  5. Doing the fuel pump at home, any suggestions?
  6. 347 install
  7. 95 gt air bag
  8. Tachometer signal source
  9. Rockers
  10. A/C Not working!
  11. information panel under dash
  12. FUSE PANEL
  13. fuel gauge problem
  14. Belt Size
  15. Speedometer Calibration after changing rims/tires
  16. boggin at 5k plus rpms
  17. New throttle body!
  18. Fuel Pressure Regulator
  19. how do i get my stang to sound like this?
  20. t-5 rebuilt
  21. Just brought home my new toy
  22. Stock Springs?
  23. Heater core bypass quick Q
  24. H/C/I choices and brands
  25. what size
  26. Installed O/R H, but have problems...
  27. looking into a rare? 79 indy pace car.
  28. fuel line for carbs
  29. fuel pressure question
  30. Professional products intake
  31. what type of manifold gaskets?
  32. Help on an '84 gt350
  33. Performance companies in Texas?
  34. royal purple power steering fluid
  35. Help about RHS Heads
  36. engine removal
  37. Rules 4 Track - Battery Relocation
  38. lifters for e303 cam?
  39. manual rack and pinion
  40. switching sides
  41. Tranny Noise?
  42. 41/91 codes after o2 replacement
  43. TFS or Holley?
  44. what gauges do u all recommend
  45. Holy Crap !!!! SCARY Experience
  46. Relocating Batterie!
  47. Upgrading Altenator?
  48. About my Annoying starter (Need help guyz)
  49. any1 running BBK AFPR respond
  50. Aftermarket Steering Wheel ?
  51. stripped !$@#$ bolt
  52. Throttle Issues
  53. engine is always hot
  54. Systemax II
  55. EGR QUESTION
  56. Weighed in at 3150lbs!!
  57. 2.3L 5 speed
  58. who runs a 4.5-4.8" rear backspacing on your rims
  59. idler pulley. reverse thread?
  60. wheel question
  61. Delta fan control
  62. stock cam?
  63. How many volts should I see at idle
  64. No Compression
  65. throwout bearing
  66. seat and subframe connector?
  67. starting a sitting 5.0
  68. Will this breather fit?
  69. Chassis
  70. eibach drag spring
  71. Bkk eq shorties, bbk h pipe, and mac cat back
  72. timing question
  73. doesnt seem to get fuel
  74. TIMING AND FUEL PRESS. PROBLEM
  75. HELP...DIZZY PROBLEM
  76. 5.0 NEWB question
  77. rev limiter install
  78. Quad shock with air ride
  79. MOVED: convertible speakers
  80. big big big problem....
  81. MSD PLUG GAP AND WHAT KIND OF PLUGS TO USE
  82. fuel pressure question
  83. NAWZZ gauge
  84. headers question
  85. Plugs
  86. power question
  87. Clutch question
  88. 85 t-tops
  89. Megasquirt Base Tune **AdderMk2**
  90. Starter cranks really slow when car is hot
  91. Radiator Question
  92. BBK H/X pipe fit MAc Long tubes?
  93. Engine #'s
  94. older model twisted wedge heads
  95. WOT switch
  96. Radiator Question
  97. how to tell which line is return and the pressurized line
  98. PMAS 75mm MassAir??
  99. Cam and headers?
  100. o2 sensor question
  101. Tranny gone.....
  102. tire question
  103. Boost gauge and gauge pod
  104. A/C Removal
  105. are aluminum driveshafts really worth it???
  106. do i need caster/camber w/ 4cyl springs???
  107. MOVED: 86 gt trim
  108. It's finially ready
  109. Exhaust
  110. V6 springs?
  111. ? Header- Takeoff/Install question?
  112. axle
  113. thinking about cutting pipes for dumps
  114. hi
  115. Camshaft Selector?!
  116. *Pics Added* Help, Electrical problem in the fuse block!
  117. Power steering
  118. cold air intakes
  119. 88 5.0
  120. Doug tuning Fox bodies?
  121. new exhaust set up
  122. LX emlem on trunk lid. Location
  123. wont start..Fried ignition? Battery light ON
  124. water pump ?
  125. Running rich... after the normal things are checked
  126. what radiator to get
  127. 4.9 fuel system?
  128. bbk unequal shortys
  129. 3.73, 3.90, 4.10 which one?
  130. burn out with true-trac
  131. hp questions?
  132. stock question
  133. Roller rockers??
  134. Headers
  135. using some oil
  136. Sad Story....
  137. Alternator charging question
  138. valve stem seal replacement
  139. Converting to Power Windows
  140. supercharger
  141. saleen
  142. FRPP cams really that bad?!?!?!?!
  143. Just Ordered a MGW Shifter! Install Tips??
  144. Cam help!!!
  145. timing retarding
  146. time to start looking at suspension mods
  147. Aod drive gear removal?
  148. flywheel?
  149. iac or maf?
  150. Flashing Light
  151. I'm really close to that point...
  152. MAF
  153. need some advice!!!
  154. This cant be normal!!!!
  155. which radiator cap?
  156. what do i need for a h/c swap???
  157. What gears do i have?
  158. lug nut problem
  159. vogtland springs
  160. About to pull my dash, evap. core?????
  161. Timing
  162. Biggest bang for the buck
  163. Synthetic oil for a Crown Vic
  164. Radiator Support Help
  165. valve lifters
  166. Timing Question for H/C/I
  167. ahh! no forged pistons
  168. suspension help!
  169. cooling problem
  170. Tachometer stuck?
  171. Need help identifying sleeve thing that covers castle nut on wheel bearing
  172. stock F.P.R
  173. manual steering rack
  174. h pipe, and long tubes, best sounding setup?
  175. plug gaps
  176. Driveshaft?
  177. how to burp cooling system
  178. exhaust preferance cats or no?
  179. question about injectors
  180. I need help
  181. engine building?
  182. 225k on motor want to rebuild it myself, whats do i need to do?
  183. Whats a good brand for subframe connectors?
  184. BBK CAI
  185. heads clicking
  186. I have alot of questions? HELP
  187. CAI + Exhaust
  188. Car wont start.
  189. Need Trunk carpet for my 89 Hatchback
  190. bad vibrations and loss of power
  191. water pump.. new but smells
  192. question about TPS
  193. 4 cylinder to 5.0 swap question??
  194. stock suspension replacement
  195. Idle (again)
  196. Quick stroker question.
  197. automatic to manual swap..
  198. intake backfire
  199. throwout bearing or everything?
  200. any ideas??
  201. gt trim ?
  202. My ACT was through the roof today!
  203. IDLING ISSUE
  204. Stroker Windsors
  205. smog pump removal part 2
  206. Update on project and pics:)
  207. No parts from Ford???
  208. Which flowmasters are thesE?
  209. 416RWHP/ 392RWTQ-Back from Dyno
  210. tuning question
  211. New here
  212. will these work with my application?????
  213. throttle cable
  214. boss block
  215. stock air box and mass air conversion???
  216. Need some emergency clutch help!
  217. Lean codes 41/91 and longtubes
  218. Mass air question
  219. AFM powerpipe??
  220. wierd problem
  221. higher than 150 shot = race fuel?
  222. calibration
  223. running engine w/ belt off ok?
  224. Battery Cables
  225. starting problem
  226. fan belts
  227. checking and adjusting valves, how to???
  228. power window problems
  229. how much hp
  230. For whom uses a Trans Cooler
  231. Cowl bent??
  232. Pushrods
  233. squeeking noise
  234. vacuum harness picture help
  235. 3.8 Electric fan Conversion Wiring
  236. where is the fuel inertia switch
  237. Buying a paxton SN93 for my 95 GT?
  238. MSD digital window switch
  239. Summit aluminum radiator
  240. will these headers fit?
  241. micro switch help
  242. confused about exhaust....
  243. How do you change the fluid in the rear end??
  244. New Clutch
  245. mechanical roller
  246. I need a real Ford techs help
  247. Front suspension problem maybe
  248. falken tires
  249. 303 cams
  250. Back and Running!
