PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 [95] 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Mac Longtubes
  2. 87 5.0. Trying to figure out what these lose wires go to..
  3. Help me find a 12v Key on source.
  4. MOVED: 306 to 331 347???
  5. Will a Cougar fan shroud work?? 5.0
  6. Clutch question
  7. Restoring Compression for a 94 gt 5.0 h.o.
  8. MOVED: My 14000 mile no option notch
  9. MOVED: Anyone running the Crane HI-6s???
  10. MOVED: HOW TO BEAT AN LS1
  11. torque specs
  12. MOVED: mickey thompson street radial
  13. problem with clutch cable after aod to t5 conversion help!!
  14. rolling fenders
  15. Head Specs?
  16. finding a short
  17. Advice for tuning my stock 5.0
  18. Transmission upgrade
  19. gt40 rr machining.
  20. Dipstick
  21. do sealants really work??
  22. BOV for my powerdyne supercharger
  23. 351 vrs ls1
  24. tranny Q
  25. ENGINE SWAP
  26. Floor Pan and Torque box reinforcement or battle boxes?
  27. 90 Rear Hatch on a 87
  28. anyone heard of d&d motors?
  29. 94 gt 5.0 Brake Proportion Valve
  30. low profle intake question?
  31. oil pump problem
  32. god i hate to ask here.... but no other choice.
  33. H-H-H-Holla
  34. Shorty headers
  35. 2.3 to 306 Project... I need your help!!
  36. fuel gauge in fox mustang
  37. explorer motor rebuild kit
  38. gt-40 head ?
  39. which coilovers for the rear?
  40. BOSS Wing install
  41. 95 gt backfire???
  42. Please educate me on cams...
  43. Thermostat Replacement
  44. Push Rod measurement
  45. Panel Dimmer Switch
  46. 2.3 to 5.0l help?
  47. MOVED: how much does she weigh
  48. JUST INSTALL MY MM STRUT TOWER BRACE.
  49. MOVED: lx vs gt..
  50. problem
  51. Coolant Leak Guidance
  52. kenne bell supercharger on a 5.0 fox
  53. PATRIOT HEADS
  54. What do you think about these heads?
  55. Can you identify this part ?
  56. how does this work?
  57. What fuel pump to purchase?
  58. Cam in a 94 GT
  59. COBRA INTAKE,EDELBROCK OR TRICK FLOW,OPINIONS NEEDED,TIA
  60. what gears are in the car?
  61. Fuel Pressure
  62. Rocker Clearance
  63. alternator question
  64. crappy cold idle
  65. ignition coil upgrade question???
  66. stock port size on heads
  67. any good tuning devices for my 89 stang
  68. ignition coil
  69. gt wont start
  70. have my heads been worked?
  71. Serpentine belt trying to slide off of water pump?
  72. Coolant drain plugs on block - location?
  73. 5.0 out of a thunderbird
  74. Guage cluster question....
  75. Trans F@cked... How severe is it?
  76. hmm wats next
  77. why does my car stay running
  78. faint smell of antifreeze
  79. OEM AT shifters?
  80. Polished Pullies/Rad Hoses
  81. Torquey Cam
  82. Upgrading stock pullies
  83. 5.4' H-beam rods
  84. TPS
  85. 92 5.0 EFI buildup
  86. New carpet question
  87. Tuning???
  88. AHHH!! clutch cables problem
  89. Electrical question
  90. Damn, I feel stupid
  91. has anybody used these before?
  92. Typhoon Intake/Strut Tower Brace
  93. MOVED: Should I buy this 93 notch $400(read post before voting)
  94. MOVED: 86 Mustang 5.0.. Looking Into Change
  95. ECU Removal
  96. 350 in 92 fastbak
  97. Blower Install
  98. flowmaster 40
  99. What Gears should i get
  100. adjsting rockers need help???
  101. AC Delete / Smog Delete Q's
  102. MOVED: H/C/I combo ?
  103. 5.0l volvo bbk headers?
  104. 331 stroker
  105. need to get tranny in tonight need help please!!!!asap
  106. fuel float help
  107. underdrive pulleys and AC
  108. power steering bracket
  109. interior question
  110. MOVED: Should I buy it?
  111. long tube header question
  112. Help with a new stang
  113. HELP NO START !!!!
  114. Pulled 3 codes...
  115. MOVED: Whats your thoughts on this 92 LX?
  116. Best stall speed with F-Cam
  117. a newbie question
  118. problem with my header bolt
  119. engine decoding help
  120. just a quick question
  121. Fuel Tank Insert ?
  122. 42lb injectors or 19s?
  123. turbocharger
  124. Just a question
  125. Vacuum Line Diagrams
  126. Clutch Pedal
  127. s transmision
  128. Main/Rod bearing questions
  129. '91 302 timing chain, nylon sprockets
  130. UPR K MEMBER KIT
  131. quick questions
  132. need some help
  133. stuck driveshaft?
  134. MOVED: What should i go with?
  135. Engine whine
  136. A/C and PS removal
  137. 10 Hole Wheels
  138. Another overheater...lol
  139. MOVED: bullitt wheels on foxbody??
  140. Belt removal - tensioner?
  141. seems to good, anyone have it?
  142. how to tell apart? 302/351
  143. MOVED: anybody have these headlights?
  144. having pressure plate problems?? NEED HELP ASAP!!
  145. Really BAD news!
  146. crank bolt size
  147. What is needed for a 94-95 to make 350-400 rwhp? Budget?
  148. UPDATE running ritch
  149. Brakes
  150. MOVED: Pro 5.0 shifter for sale
  151. question
  152. need help with flywheel dowel pins real quick!
  153. need to redo my timing
  154. cant get rear main seal out help please!!!!!!
  155. springs
  156. Engine Troubles.. What to do? please help
  157. stall or gears?
  158. broken bolt for valve cover
  159. Pin hole leak in head gasket
  160. replacing header gasket....
  161. qustion about rear end
  162. oxyogen o2 sensor
  163. tubular front control arms
  164. Possible car/engine problem!!!!! Help!!!
  165. do i need full length subframe connectors?
  166. Nitrous Guys Look Here
  167. one chamber mufflers?
  168. What size Torque Conveter for 3300-3500 Stall
  169. need help pls
  170. how hard is it too.....
  171. speedo gears
  172. upr k member help?
  173. Nitrous Question
  174. Speedo cable off cluster?
  175. IVR and Gauge Questions
  176. Pressurized Gastank???
  177. annoying exhaust leak????
  178. Are all T-5 trannys the same?
  179. lookin for part
  180. T56 questions
  181. Where can I purchase seat support braces?
  182. HELP!
  183. Non-power brake kits for Fox mustangs
  184. rattling / clicking sound from my rearend
  185. EFI to CARB
  186. MOVED: where to get installed?
  187. Rear end on 5.0
  188. What H Pipe to go w/ Magnaflow
  189. 03 suspension on a 94
  190. Battery relocation to trunk question
  191. JUNKYARD PART QUESTIONS
  192. Gears: Speed vs. RPM
  193. MOVED: Finally back
  194. Exhaust Smoke Question
  195. MOVED: D&H auto parts
  196. MOVED: LX tails
  197. Lower shift boot- 50 resto
  198. MOVED: 94 cobra first mods
  199. Help Please! Car won't start.
  200. Can a sn95 5.0 engine go into a 76 mach 1 fastback?
  201. MOVED: 351w Engine Combo ?
  202. 4.6 heads on 5.0
  203. valvetrain / cam help
  204. Review: Unisteer Manual Fox Body Steering Rack
  205. EEC Code: 89 – AXOD lockup solenoid ??
  206. 94 mustang brakes
  207. tremec t56
  208. adjustable FPR install
  209. v6 to 5.0
  210. bullet wheels 315 tire!!!!!
  211. rod bolts
  212. Tach wire location
  213. electric fan controler
  214. power lock actuator removal?
  215. gt40p valve springs ok?
  216. Fox SC on an SN95?
  217. couple of questions regarding clutch install?
  218. hose on top of radiator cover?
  219. Headlight Switch
  220. High idle?
  221. Swaping Ingition Switch
  222. harmonic balancer
  223. cold air intake
  224. MOVED: 1967 v8 vs 1989 v8
  225. need help !!
  226. MOVED: 93 saleen?
  227. MOVED: 1989-92 Mustang Plans (look good?)
  228. belt setup
  229. Where is the door trigger wire????
  230. water leak
  231. roller rockers
  232. Stock Brake Upgrades
  233. AT problems
  234. What is this?
  235. MOVED: Where to find 83 convert seatbelt bezel
  236. MOVED: what cam?
  237. Car dies after driving
  238. MOVED: what to buy ?
  239. MOVED: NT1320's
  240. Are GT-40P's smog legal
  241. What MANUAL 5 speed tranny can I use?
  242. MSD???
  243. just bought this not sure where it goes??
  244. MOVED: motor suggestions
  245. 331
  246. do I need a harmonic balancer spacer?
  247. MOVED: h/c/i
  248. Performance Automatic Racing Transmissions
  249. F'n idle!!!
  250. how much would this help?
