PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 [161] 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Cleaning Out Garage!!!
  2. clutch safety switch
  3. quick tire question...
  4. magnafluxing?
  5. Problem
  6. GOT MY UPR's!
  7. Got My D-1 Procharger:)
  8. fenders for an 86
  9. the battle never ends
  10. Selecting the right exhaust
  11. Ride Quality
  12. WTF is this?
  13. Trunk Release question
  14. MAF PROBLEM
  15. Problem removing lower control arm
  16. SN-95 GT40P Question
  17. exhuast
  18. Dyno sheet thread
  19. pics
  20. h.o. vs normal 5.0
  21. 94 gt smog lines?
  22. Spindles....Struts
  23. these fuel pumps any good?
  24. 347 stroker
  25. got a question
  26. egr spacer
  27. Wheels For Sale!!!
  28. anyone need ac compressor with pully?
  29. window problems
  30. what springs?
  31. turn signals not working
  32. front struts
  33. motor mounts? which ones?
  34. mods???
  35. convertable car
  36. Clutch cable problems
  37. ????
  38. Oil change
  39. O2 Sensor connector
  40. cold air intake
  41. Recharging ac question
  42. E7's?
  43. Found Proof!...OMGod!
  44. Update....
  45. does anybody have this???
  46. Shorty, Equal Length Or Long?
  47. 95 mustang has power but wont start
  48. How do you polish stuff?
  49. to much wheelspin?
  50. 190 to 302 engine swap
  51. my car's running hot..
  52. Mustang weight?
  53. Couple of 5.0 Questions
  54. Blow-through carb
  55. 3.55 or 3.73??
  56. stock 91 5.0 h.o. rocker arm ratio
  57. do i need screw in studs? for the rocker arm
  58. Need Help with Supercharger
  59. sorry for alot of post
  60. heads for boost
  61. where can i get the
  62. cams
  63. THIS CAR IS FAST!
  64. what size tb?
  65. 3.90 or 4.10
  66. clutch question
  67. Leaking Oil
  68. gears
  69. 93 cobra
  70. 93 cobra
  71. ZF 6 Speed in a 95 GT?
  72. stock clutch..would it last?
  73. T-5 Problem
  74. Need Some Advice Quick!
  75. Seafoam, Where?
  76. Oil Pressure Sensor...
  77. Hanging Idle...
  78. Need HELP with NOS
  79. 4 to 8 ?
  80. Weather Striping
  81. SSBC vacuum pump kit
  82. PCM Help
  83. got a ??
  84. Question for you high HP/TQ T-5 5spd guys
  85. What hp?
  86. 500 hp
  87. Anyone know what this is?
  88. for you guys!!!!!!!!
  89. Best numbers running GT40 heads?
  90. will 350 HP b possible?
  91. Best Top End Build
  92. bent pushrod?
  93. AC elimantor pulley
  94. What heads & Intake to buy?
  95. 5.0 rebuild cost
  96. Just bought a fox body.
  97. why can't i beat an ls1????
  98. need help with procharger brackets..
  99. i have a 94 5.0 and was wondering what all i can do to it?
  100. Transmission Oil
  101. headers and flows?
  102. MY WORLD CLASS BROKE, IMAGINE THAT
  103. power loss
  104. ok i gotta ask...
  105. Dont be stupid like me!!
  106. Motor Mount Install.........DONE
  107. ebay cold air intakes
  108. 1985 gt or a 1993 gt????
  109. Need a stock MAF before friday night!
  110. 95 gt stock mech. or auto meter elec. speedometer
  111. 90 GT Vert - BBK shifter Problems
  112. Wiring Harness
  113. New Car
  114. Smog "stuff" needed if running w/o cats?
  115. I Need a Rubber
  116. F to X, any good gains??
  117. New Parts!
  118. next upgrade
  119. piston markings ?????????????????
  120. My new engine!
  121. engine build
  122. 5.0 owners, UNITE!!!
  123. update couple new pics
  124. LA CRUISE DETAILS: Saturday May 12th Galpin Auto Sports
  125. do i need new axles??
  126. how do i
  127. need some wiring diagram help please...
  128. New stuff causes backfire
  129. Throttle Response
  130. best option for me???
  131. This forum is the Sh*t
  132. '93 lx coupe suspension
  133. murphys law
  134. twin 67MM turbos even possible
  135. CA, smog legal 500rwhp turbo 351w...
  136. Body Work Question
  137. Just got back from the track.
  138. Heat Delete
  139. Uneven Header Temperatures
  140. just a quick subframe connector question
  141. My timeslips from today
  142. End of March/Middle April. Mods!
  143. Procharger ?? for 2Grand P1
  144. different brands of H pipe
  145. Stage 2 clutch
  146. Fan conversion
  147. Taloon VS 5.0
  148. Larger sunroof
  149. Upgrading to a 5 lug
  150. pro 5.0 or B&M
  151. Oil Change?
  152. 347 install update
  153. c clip eliminators???
  154. motor mounts
  155. Clip of my car @ idle, weird noise under the hood
  156. oe wheels rims
  157. What should I do next?
  158. Could a 5.0 Beat A Mark VIII
  159. Rattle Noise when put in Reverse
  160. 5 lug swap helpppp pleasee
  161. found this behind interior plastics what is it?
  162. New gears, need to put in speedo gear.
  163. Busted Door
  164. Exhaust ?
  165. I´m PISSED
  166. SCORED BIG AT THE YARD !! !!!
  167. hey carfax report
  168. 5.0 flywheel and pressure plate
  169. Just swooped up a free shortblock
  170. how do i get the timing chain cover off??
  171. rim size
  172. aod shift kit 25$
  173. Rear Control Arms
  174. site any good?
  175. Is it time for a new speedo cable
  176. belt tensioner bolt size
  177. 85 gt wiring
  178. 95 5.0 question
  179. 5 lug stangs?
  180. those of you who removed the smog stuff...
  181. My 89 LX
  182. need help quick
  183. 1983 mustang body kit?
  184. need new pistons....
  185. Any takers pt.2
  186. found another NOTCH!!
  187. Flywheel question!
  188. What's the best way to fix this? PICS
  189. i need helpppp fast please
  190. 1,6rr vs 1,7rr question (birthday present)
  191. pic of the stang for yah guys
  192. quick question
  193. Lower rectangle of LX tail lights? And pics.
  194. Bassani
  195. Need help, 89 stang running rich?
  196. Anybody care to guess? (PICS)
  197. fox body movie
  198. Going to go to 3.73
  199. those of you with superchargers
  200. ps pump moving question
  201. 460c.i.d
  202. Alternator questions on a 351 conversion
  203. HOW DO U
  204. KB pistons
  205. Doors stick reallly bad.
  206. air fuel ratio gauge
  207. Where to get an LX spoiler
  208. 12's
  209. for my 5.0 hommies...saving some $$ on parts
  210. EGR Delete? consists of what?
  211. paint scheme?
  212. will some type of air induction show me a lot?
  213. Florida Radar Detection Ban!
  214. timing cover & water pump torque specs.
  215. black rims
  216. wont start. fuel/no spark
  217. Surging idle
  218. trick flow spacer?
  219. Locking header bolts?
  220. Torque box reinforcements in today!
  221. is there a track near me
  222. Torque box reinforcements
  223. My car
  224. 140 speedo in 87 notch hard?
  225. question
  226. lug nut problem
  227. heads up?
  228. Want to Buy
  229. Which ARP bolts do i need
  230. Pics of your 5.0
  231. Rebuilding power window motors
  232. can a battery be charged?
  233. rotors help
  234. condenser
  235. window trim
  236. Upgraded the stang, lmk what you think
  237. TB spacer...worth it?
  238. comp. engineering...
  239. New Pony in the stable, what's 1st?
  240. 60 ft times...
  241. tach output on 6al msd ignition
  242. electric throttle linkage
  243. wierd doughnut question
  244. parts and such!!
  245. big block swap in a fox
  246. please help
  247. Removing Quad Shocks
  248. Parts on a 5.0 in a Mark VII
  249. Shot Engine Mounts
  250. GT kit on da LX or not?
