PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 [128] 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. question about a car at the track
  2. Fuel Filter
  3. Hey tire/wheel guys...
  4. Changing Heads
  5. need help on this one guys
  6. Where the pcv on an 87 5.0?
  7. 1980 manual rack and pinion
  8. transmission popping out of gear
  9. PCV Screen?
  10. What the Best shifter for my 92 5.0
  11. Rotors
  12. alignment quesion
  13. Dipstick pops out ?
  14. got some wot pulls
  15. OMG! Cant find Vacuum leak!
  16. 351 heads on a 302
  17. Carb. Questions
  18. 24 lb injectors?
  19. Fuel guage/sending unit question
  20. Electronics question
  21. gear differential
  22. radiator question
  23. quick question about headers
  24. CODE 96
  25. Rear window louvers
  26. starter question
  27. 01-04 gt calipers
  28. Trac-Lok
  29. GT40 OWNERS NEED YOUR INPUT
  30. dies on start up
  31. bbk cai question
  32. Ran a lot better but there's still improvement.
  33. Help with tire selection
  34. brake booster and master cylinder off a 95 gt to my 84
  35. running problems!!
  36. have codes can't read them
  37. Horsepower on a 1993 Mustang 5.0?
  38. check engine codes
  39. motor build prices
  40. Master Cylinder
  41. Shift Kits
  42. another timing question
  43. HOW MUCH CAN I GET!! ! ! ! ! !
  44. rearend re build help?
  45. Window issue
  46. Removing rear shocks help
  47. 84 Performance exhaust
  48. Looking for some cheap HP Gain
  49. Stock MAF & 24lb injectors
  50. ok, I cant get into reverse with engine on!
  51. Quick engine build question...
  52. power steering
  53. Car Acting Wierd
  54. Converting AC to R134A ?
  55. mass air and TB
  56. Supercharger with stock internals
  57. 94 gt valvecover ?
  58. Body question
  59. LOVE MY UPGRADE.
  60. just my luck
  61. gears
  62. Need Help. Intake question
  63. need help
  64. titanium ud
  65. Fuel Pump ????
  66. strange smell??
  67. supercharger ?
  68. 2 ?'s 1 post
  69. Whats to many miles on a 5.0 motor
  70. 50 resto 351 long block
  71. Put aluminum UD's Today
  72. nitrous
  73. transmission
  74. The Grind...// h/c/i and charger?
  75. mustang 1/4 windows
  76. tko 500 with stock driveshaft.
  77. going to carb?
  78. vaccum line ???
  79. need a good T-5 articles..plz
  80. Changing front end of an 86 to an 87-93 front end?
  81. quick stupid question..
  82. radiator needed asap!!
  83. where/what balancer and flywheel?
  84. how much on a block
  85. need to find out what size bolt i need
  86. WHICH HEADS???
  87. 1996 Ford Explorer 5.0 Motor
  88. NHRA tech questions....
  89. Power loss after engine rebuild
  90. Just bought an 84, need help
  91. 302, 400hp???
  92. new motor mounts
  93. gunmetal cobra r wheels
  94. timing question
  95. stroker motor
  96. gear quetsion
  97. gt-40 intake question
  98. What size bolt is this?
  99. simple purge question, and switched 12v. source
  100. Supercharger or Heads?
  101. balance of 89 5.0 28 or 50 oz????
  102. corba wheels ??
  103. Best place to buy remanufactured 302??
  104. Suspension
  105. timing help
  106. AC problems
  107. Starting problem
  108. Exhaust Help: 2.5" or 3"
  109. 88 notch 4 cyl is it worth the money?
  110. 86 GT's
  111. E G R plate
  112. hating my electric fan!
  113. steering problem
  114. if everything sounds good ill order now
  115. finalizing SD cam choice???
  116. 1988 Grand Marquis donor
  117. mac
  118. SN95 LT on a FOX
  119. drag car/gear Q's
  120. Water temp gauge install help!
  121. Weight, HP, and 1/4 times
  122. Mid 12's Possible?
  123. fog lamps
  124. Just got my seat delete kit
  125. gears question
  126. Idle problem
  127. new wheels
  128. fuel pressure???
  129. tach ???/
  130. mystery engine miss!!
  131. my 5.0 gave up on me
  132. Equus 3145 code scanner
  133. 3g Alternator wiring question
  134. 5.0 H.O in Cougar?
  135. Car back firing thru intake
  136. Steering Wheel
  137. opinions please, simple motor build
  138. lost time
  139. Plugs pulled and look chauky white Fuel/air issues?
  140. maiden voyage+ oil leak
  141. Rear end friction modifier?
  142. Reverse then nothing....Help
  143. New Update To the blue pony
  144. Tail Pipes
  145. Help With Decision
  146. 4.10's or 3.90's????
  147. bumping your timing
  148. Cobra bumper insert
  149. can a fuel pump get a dead short
  150. overheating
  151. Quick hyd. roller lifter questions
  152. What clutch to run with my set up?
  153. MOVED: whats a good price to sell alum. gt-40s
  154. fuel pressure ?
  155. Did you drill your aftermarket TB??
  156. rim fitment
  157. Any difference in a 93 cobra flywheel and
  158. MOVED: saleen wheel pics!
  159. Free code check
  160. Question about transmission / shifting
  161. Play in steering
  162. heads cam intake combo?
  163. bent push rod
  164. Shock help!
  165. will a bronco II rear end fit a fox?
  166. wheel wells
  167. Overheats under load, NOT at idle????
  168. Trick flow combo
  169. Mac Underdrive pulleys...help!
  170. for those with Tokico Illuminas...
  171. sparks?
  172. installing mac headers
  173. Fuel injected or carburetor?
  174. Downside: Solid Motor Mounts?
  175. t-5 help
  176. t-5 syncros
  177. is manually shifting an automatic good?
  178. can a 302 be fitted to a 2.9l bronco II tranny
  179. summit headers on gt-40p heads???
  180. new motor
  181. should I get spacers ?
  182. put together my oil feed fittings
  183. cam question
  184. GOOD MACHINE SHOPS??????
  185. Electronic fan conversion
  186. High Pressure Power Steering Hose
  187. TFS v.s. edelbrock
  188. still overheating
  189. sct x calibrator 2
  190. stator plug
  191. steering wheel
  192. 95 gt 5.0 NO power
  193. car problems during hot weather
  194. 351 vs 331/347
  195. What lenght push rods?
  196. Fuel Pump Question
  197. Leaking Oil?
  198. Cleaner for automatic tranny
  199. new arp head bolts leaking
  200. just did a compression check!
  201. When to change my tranny fluid?
  202. How much should i sell my 5.0 engine?
  203. idle problem
  204. Intake and kenne bell question...
  205. 89 LX; A/C good when above 2000rpm
  206. 1986 gt t-top for sale, whats it worth?
  207. FIDANZA FLYWHEEL balences
  208. 160* t-stat
  209. Just found cut wires! idk where they came from
  210. MOVED: sigh i got a ticket
  211. help suspension car hops when I take off
  212. car bogs then backfires then takes off
  213. voltage reading sporadic
  214. a/c delete
  215. 1994 Mustang Trans Question
  216. Finally Dyno Next Thursday Night 6/28
  217. What is the Rpm rev limit on 94 auto gt?
  218. how much antifreeze
  219. buddy wrecked his gt got some questions on parts
  220. injectors?
  221. Why do I have to pump my e-brake?
  222. Reallllyy weird problem possibly tranny?
  223. Power window relay....need help
  224. T-5 Whine
  225. still SD, what heads and cam???
  226. TPS Voltage
  227. Starter help *UPDATED*
  228. Budget 331 stroker.
  229. LOOKING FOR WC T-5 PARTS HELP PLZ
  230. motor shake?
  231. Help me decide
  232. what and where? programmer chip for 89 lx
  233. NO start........dead
  234. Mac shorty headers and flowmaster 40 series exhaust
  235. Do I use stock length pushrods for 351 heads with roller rockers and x cam?
  236. My hood folded back onto my windshield ;(
  237. Been awhile
  238. Anderson high rev cam
  239. MAF ?'s
  240. Supercharging Experts!!
  241. alternator pulley
  242. Need a new clutch
  243. a/c help
  244. anyone ever relocate the battery? and intake question too
  245. Trunk idea's
  246. Air filters
  247. S/D timing
  248. so many engine choices
  249. Got my car dyno'd the other day
  250. exhaust rattle
