PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 [159] 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. new heads on old motor
  2. Tuning???
  3. PLEASE HELP!! START AND IDLE PROBLEM!
  4. high rpm idle after punching it abit
  5. Help with car
  6. Going to check out 5.0 :)
  7. stock 5.0 dyno pull?
  8. what does a 327 need?
  9. Head & Intake Recommendations for 500-550hp 408w
  10. Sticking Speedo
  11. Cheap Driveshaft???
  12. High 13s a possibility?
  13. lift ongt40p heads?
  14. electrical problems
  15. tapping
  16. I just ordered my...
  17. 1984 GT350 with 98 original miles???!!!
  18. 3:73 Gears
  19. ford racing cam
  20. Shocks and Struts for street use?
  21. how to install Lightning MAF ?
  22. the right pistons
  23. Wow they fit
  24. 2 ?s about my 87 5.0 please give me input
  25. hard starting
  26. Went for a ride today (Help)!
  27. timing causing vibration
  28. Dyno tune gains
  29. C4 spitting fluid
  30. Timing question.
  31. e.ts in a quarter
  32. what to do next?
  33. intake porting
  34. cant find timing marks on balancer
  35. Torque & Horsepower Gains
  36. Traction issues
  37. Head Install Tips??
  38. Motor Mount Install.........DONE
  39. what sensor is in the block? *now with a pic*
  40. Speedo Cluster
  41. Motor suggestions
  42. 1993 5.0 rwhp
  43. took the fifty out of the garage for som PICS!
  44. estimate horsepower
  45. f*cking tranny wont go back in
  46. what is this part?
  47. starting ?'s
  48. fog light wiring diagram
  49. weird squeaking in leftfront of stang? ideas?
  50. superchargers!!!
  51. can someone help find me
  52. distributor question
  53. oil pan question
  54. are these shocks any good?
  55. F-CAM
  56. camshaft thrust plate
  57. how to identify a holley carb
  58. wiring dagrams?
  59. sway bar with 90/10s and trick springs
  60. Anyone know if a 1994 cobra requires premium fuel?
  61. oil level sensor problem
  62. ebay MAF conversion kit?
  63. I need a price check on these items..
  64. dipstick broke.
  65. Need help. Cometic Head gasket leak
  66. turn signals
  67. benefits of a cam?
  68. couple more
  69. finally got to wash her (pics)
  70. fuel pump problems
  71. do i need a tune ?
  72. Two part question??
  73. Air intake restricter
  74. T5 Tranny fluid
  75. Stang out from winter and won't start
  76. Anderson-Vortech Mondo intake?
  77. typhoon intake??
  78. pressure plate torque? HELP ASAP!
  79. z303 cam HAS ANYONE EVER HEARD ONE?
  80. Cobra r rims
  81. case of the slips
  82. Proform electric fan..who has one?
  83. Need Help...
  84. L@@king to get another 25 more h/p
  85. Plug gap?
  86. starter or solenoid in fender???
  87. 88 5.0 HO
  88. in-tank holley fuel pump install
  89. Changed coil now car runs like $hit.. Why?
  90. car show or big forum car club?
  91. Tune-up
  92. what is it with pics
  93. What kind of power am i putting down?
  94. WHat exhaust is this?!
  95. what is it for
  96. aNOTHER f*cking POST.. YOUVE GOT TO BE KIDDING
  97. saftey and roll cage....?
  98. GOT IT BACK
  99. what should my tax return get spent on?
  100. cam or not
  101. Cam question
  102. ecu
  103. laptop messed up my PMS
  104. Egr plate help
  105. Keep FMU?
  106. compression test results.
  107. Anyone have pics of their wiring harness?
  108. Spark Plugs Wires
  109. Started motor mount install....
  110. fuel pump
  111. Finally got my tranny and clutch all done
  112. Cometic head gasket water leak
  113. rebuilding my motor
  114. roller 351?
  115. Timeing gears?
  116. here's my car
  117. SO im going to
  118. mustang website
  119. Door belt molding replacement
  120. just wanted everyone to see
  121. Car won't turn over when engine is hot
  122. ? about dumps
  123. Am I gonna need Heads?
  124. PMS
  125. GT40P vs. Twisted Wedge
  126. I need help
  127. need original front bumper anyone ??
  128. Question
  129. G-Force T-5 vs. Astro Performance "A-Five" Speed T-5 Gearset
  130. anyone ever have to shim a starter?
  131. 5 lug swap
  132. Domestic newbie, 5.0 questions...
  133. violent virbration
  134. 94' speakers
  135. Heads switch question
  136. Egr? vacuum leak? I have pics, please help!
  137. 408w... where to buy?
  138. EEC relay wire
  139. AWESOME info in 2007 Ford Racing Catalog: TIP
  140. 302=5.0 351=5.8 so what is a 347
  141. electric fan, pusher or puller
  142. My 89 LX
  143. HELP!
  144. Long or Short
  145. intercooler
  146. cats
  147. Is this worth getting
  148. will this work?
  149. code 87 &95
  150. exhaust question
  151. Confused about Smog pump and cats
  152. UnderDrive Pulleys vs. Alternator
  153. found this in middle of the road!
  154. How much power?
  155. Why wont it go.
  156. Rear gears and Torque Coverter
  157. motor knocks so hard but doesn't use any oil *now with Video*
  158. Hooker super comp headers
  159. What brand tires???
  160. Why does my car back fire
  161. Filled up with 93 octane
  162. BBk Fuel Pressure Regulator
  163. best header
  164. question bout buying something from ebay
  165. List of tools needed for a rebuild
  166. alittle progress made
  167. 5.0's That have raced New GT's COME IN!!!!!!!
  168. what is all this stuff?
  169. 28 spline VS 31 spline
  170. new suspension
  171. What rear control arms do you recommend?
  172. Valve question..........help
  173. Clutch Question
  174. Adjustable rear CA's or non adjustable?
  175. Is this SC kit good??
  176. 86 5.0 with E7's???
  177. Clutch cable or?
  178. Sunroof hardware
  179. Differential
  180. SUSPENSION HELP
  181. Another clutch adjustment question
  182. HELP!!! Will an SN95 5.0L O/R H pipe fit a fox???
  183. my new stang (with pics)
  184. Finally got it done
  185. power steering pump pulley removal
  186. how to id a cobra
  187. Diff between Street and track heat
  188. stock midpipe removal
  189. Fuel Pump, in tank?
  190. got my new project
  191. Aligning pulleys up.
  192. what thermostat for aluminum heads
  193. STILL HAVING STARTER GRINDING?
  194. Anyone know about this???
  195. toploader in fox
  196. my 94 gt runs like crap...
  197. smog pump hose leaking air?
  198. E-Brake
  199. just a guess
  200. FUEL PUMP ?
  201. got my car back from shop need help
  202. OT: but not too OT (search feature)
  203. first time firing new motor (pics and vid)
  204. No start now a start
  205. ranger ?
  206. Looking For A BOTTLE HEATER ! ! ! !
  207. GT40 heads
  208. pulleys and belts
  209. Intake Options
  210. cheapest non ported aluminum heads
  211. Oil Pressure??
  212. Intake swap and got problems
  213. ATTENTION MARYLAND, AWESOME CRUISE
  214. Pics of Blow off valve install
  215. I need a new tranny!!
  216. Am I cursed???
  217. Should I yank out the front sway bar before I go to work???
  218. 1.1g's..what do i need
  219. Crank pulley bolt?
  220. need a good shortblock for 5.0
  221. Oil Pan Replacement
  222. Clutch Gone? (Help!)
  223. 2 step
  224. over heating help
  225. How Long and where from? <----- Everybody answer
  226. Help!!, nothing can be done to fix need opions
  227. EGR on 94
  228. need help!!!!!! rockers adjustments
  229. Fox or SN95 for 10sec street car?
  230. bronco chip question
  231. What makes a good nitrous cam?
  232. a good lesson for current/future nitrous users
  233. Ugly Fox's
  234. cam help
  235. video of the stang let me know what u think..
  236. 2 more
  237. more new parts just came
  238. anyone run any thumper ported heads?
  239. stCam Question
  240. Driving A 5.0
  241. What do Foxs weigh?
  242. Phenolic spacer
  243. 2.02 valve on a stock block
  244. Ball Socket Flanges
  245. Battery light on after 2000 rpm
  246. windshield washer pump?
  247. X-pipe vs. H-pipe
  248. Need a good off the shelf cam
  249. went to set tps
  250. transmission question
