PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 [129] 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. ac lines
  2. running rich something seems to overheat
  3. WHITTY TUNERS NEEDED!!!!!!
  4. Need some drag racing advice (shocks & springs)
  5. Carburated or fuel injected
  6. crash sensor cover??
  7. yukon or ford racing gears?
  8. Dyno Numbers
  9. intake question
  10. is there a diffrence between these?
  11. best carb around?
  12. quick question?
  13. please make me a list for 306 build
  14. 5.0 motor issues...motor shake...ruff idle?
  15. change window motors and door lock actuators?
  16. Weekend project complete w/ pics (56k beware)
  17. What are some good headers
  18. 351 HELP!!!!
  19. Straight pipes or off road x-pipes
  20. CAI
  21. Ground Problem
  22. Buying a m5 car with C4 conversion. Questsions.
  23. Motive gears?
  24. Strange vibration and noise
  25. Question about fuel pump install...pictures
  26. firing order question. help please!!!!
  27. Cobra Clone
  28. 140mph guages.I we
  29. C&Ls are Junk??
  30. Convertible top problem - Picture included
  31. Wow, been running with no secondaries... Pics included
  32. Crossmember bushing?
  33. Got another stang its my DD need advice on something
  34. Parts
  35. RHS or Holley heads
  36. 174 weiand blowewr for 302, will it fit on a 351?
  37. opinions on this turbo
  38. Which Clutch?
  39. Looks like I've got some work ahead of me! Pics inside!
  40. Suspension Help Please
  41. need some advise
  42. tv cable
  43. Battle Boxes
  44. 5.0 + cam =overheating?
  45. what kind of spray paint for interior trim?
  46. speedo ?
  47. maf with cold air tune vs maf regular tune
  48. Need advice on '82 Capri
  49. heres a question
  50. jacking car from rear dif
  51. 331 stroker?
  52. went to track times
  53. Does this sound right?
  54. O2 sensor location
  55. p/s pump
  56. 88 turbo coupe rear swap HELP!!!
  57. good or bad deal
  58. 87-93 Mustang Interior work in 1986 Mustang?
  59. swaybar question
  60. overdrive not working
  61. why would they do this lol
  62. has anybody had experience with this website???
  63. header opinions?
  64. 95 GT running bad
  65. new motor timing n fuel pressure questions
  66. 86 into a 87
  67. WHEEL SPACERS!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  68. need help identifying a wire!
  69. PMS or have it Tuned?
  70. SD to Mass conversion
  71. Overheating woes - Need Assistance - This is weird
  72. SD to Mass conversion
  73. Aftermarket ECU's
  74. MOVED: 87' GT
  75. Went to the track friday nite.
  76. belt question
  77. this sucks bad it happend yesterday im memphis
  78. dynomax mufflers
  79. '84 gt350
  80. Brackets!!!
  81. FULL-REBUILD Parts getting ordered this week
  82. Damn Filters!!
  83. Help
  84. Vortech installed need help trouble shooting 2 things
  85. Supercharger question
  86. any1 using pypes exhaust?
  87. please help!
  88. help with 85gt
  89. 345 hp 5.0 motor or 347 stroker???
  90. Clutch/Shifter options
  91. Ford Racing headers for cheap.
  92. Good, cheap brake upgrade?
  93. For those interested in oil consumption issues
  94. fuel problem. help please!!!
  95. Transmission
  96. TFI Module
  97. 95GT Flasher Relay Help!!
  98. 87 5.8 h.o engine any good
  99. oil pump problems
  100. what happened
  101. this a good h/c/i combo?
  102. 80mm Lmaf w/ obd-1
  103. aod problems
  104. Bump Steer??
  105. Ford Racing Clutch
  106. freshening up a 91
  107. 95 mustang gt chrome or aluminum valve covers?
  108. Not your average Cam Question
  109. CAN TRICKFLOW CAM CAUSE A ROUGH IDEL?
  110. 393 C.I. LONG ROD HELP PLEASE
  111. ****ing schweet
  112. Stock TB on SN95
  113. F4TE heads...any good?
  114. lowering springs
  115. intake prep question...
  116. New Project
  117. 92 GT Cooling problem
  118. MOVED: "Universal" Black paint
  119. MOVED: 351W out of early 90's pickup
  120. MOVED: what are the odds a 91 351w
  121. SN 95 brakes on fox
  122. heater core bypass
  123. anyone running a c-4 trans
  124. firing order
  125. O2 Sensors and Check Engine Light
  126. anyone with a cobra spoiler i need help!
  127. X or H pipe?
  128. T-5 Tranny Question
  129. this a good ignition set-up
  130. inital work on the 5.0 swap
  131. Starter, 02, help plz!
  132. I need some crafty idea to solve this one
  133. Question regarding the speedometer gear
  134. need some advice
  135. Fuel pump not working(what next)
  136. gas sticking
  137. windsor jr heads
  138. 306, gt40 iron and supercharger
  139. MOVED: ashtray cover snapped out
  140. MOVED: Anyone have junk 302 parts?
  141. boss 5.0 block
  142. Anyone has pics of racing seats?
  143. need help... replacing fuel pump... and other stuff
  144. Low oil sensor.
  145. need clutch help!
  146. Just found out my rear sping is broke.... how the hell?
  147. FRPP 351w sportsman block
  148. 92 Saleen running hot
  149. 1984 Mustang Gt...
  150. some advice for me????
  151. ALternator question?
  152. nervous about going aftermarket bumper any advice?
  153. LCAs ...going out of my freakin' mind!!!!
  154. Engine Swap Help!
  155. axle dampner
  156. Throttle Body & Mass Air Question
  157. cobra grill insert.
  158. rpm at wot problem!
  159. Ebay Vac hose Kit?
  160. Supercharger????
  161. Enginge build problem! Timing cover help!?
  162. egr plate,where does the coolant hose go?
  163. 95 shorty header install
  164. Retarding the cam question.
  165. MGW-HELP!
  166. anyone heard of or running these
  167. low coolant sensor??
  168. retrofit interior
  169. Do I need a short driveshaft lowered
  170. Air Conditioner Electrical Issues
  171. Lets Play Name That Sensor
  172. few questions...kinda imp
  173. Alarm System
  174. NEW ENGINE BUILD!!!!!!!!
  175. over heating issues
  176. car running like crap
  177. retrofit interiors
  178. wheel spin around a corner and from.....
  179. lowering coil springs
  180. header to plug clearence
  181. instument cluster
  182. WTF? Where is my lope?!
  183. 87-93 Radio relocation kit
  184. HEATER CORE BYPASS
  185. Thermactor Air System, Code 94 Help
  186. x-pipe
  187. clutch quadrant help
  188. cleaning
  189. would this change value?
  190. MAF question
  191. which MAF?
  192. new intake
  193. Tire Experts
  194. What is the average cost for interior for a 5.0
  195. P and J Speed Shop
  196. explorer heads/intake
  197. bbk shorties
  198. not a mustang but tech related
  199. F150 heads
  200. injectors
  201. c+l airmeters
  202. fog light fix
  203. which battery relocation kit?
  204. fuel pump?
  205. rpm needle climing rough?
  206. Im making NO boost... HELP!!
  207. 331 and P's
  208. adjusting throttle cable?
  209. RE: Pintle vs disc injectors
  210. how hard to change pvc on 94 mustang
  211. ID Auto Trans'
  212. 5.0 swap into a S197
  213. HCI - Teardown 95% Complete [PICS]
  214. championship fiberglass products
  215. engine knocks when hot under acceleration
  216. blowin high compression ratio?
  217. best way to install new springs?
  218. why would a 86gt be faster than a 03 gt?
  219. quick question
  220. Gas everywhere!!!
  221. idle problem, low power, and running hot
  222. mustang question
  223. Emblem Help
  224. Swapped transmission and driveshaft, bad vibrations...
  225. forged internals
  226. got my lower arms on..
  227. 5.0 specs
  228. Help on fluids after HCI
  229. sway bar mounts
  230. swap part $$
  231. remanufacture ecm?
  232. CEL
  233. Changing T5 fluid
  234. TrickFlow combo/BBK strut tower brace
  235. Want to Buy a fuel kit
  236. injectors
  237. 5 lug question
  238. What more for suspension?
  239. Cats?
  240. simple mods for 1990
  241. Which ratio is better for T5 tranny?
  242. Which Shifter??
  243. five lug conversion
  244. Camshaft
  245. installing AFPR
  246. What cubic inch motor should I build?
  247. mexican block ? good or bad
  248. This or That?
  249. Best place to get replacement bushing?
  250. weird idle?
