PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 [251] 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Adjusting Rear Brakes
  2. Give me your opinion on Altiza Tail Lights
  3. rear disc brakes
  4. Cold Air
  5. fuel presure?????
  6. Anderson??
  7. Upgrading my driveline
  8. Building bulletproof 302
  9. 4 - 5 bolt conversion
  10. Starting problems...
  11. idle issues
  12. combo confusion?!?
  13. clutch pedal squeek
  14. Need some "will it fit" help
  15. MAF/Computer
  16. Purchasing Help
  17. MOVED: 5.0 to 5.8 swap
  18. What Kind of Gas are you putting for your Stang?
  19. gonna set my dyno appontment tomorrow...
  20. RollerRocker question
  21. The bolt-ons gave AWESOME results!!! Very pleased!!!
  22. UPR control arm bearings........
  23. intake swap help!!!!
  24. i did it!
  25. Im Looking for a armrest..
  26. tensioner question
  27. UNREAL
  28. Clutch issues
  29. Carb to efi
  30. Replacing 302
  31. compression ratio
  32. 93 5.0 with issues
  33. Camber Plates
  34. bellhousing
  35. Brake ques...
  36. 77 cobra exhaust
  37. What is this Shifter Cable? Now with Pictures!
  38. Adjusting Base Idle
  39. Do any of the '93 and older...
  40. 255/50 on a pony rim
  41. edelbrock mufflers?
  42. 95 mustang cobra SVT
  43. which MAF for a fairly stock setup?
  44. I NEED WIRING DIAGRAMS!!!!
  45. OMG UNBELIEVABLE
  46. Springs done!!!
  47. Good cats?
  48. stalling
  49. ValveCovers
  50. car runs better in cold temp.
  51. Torque link
  52. E cam ques....
  53. Timing question
  54. What size intake runner it to big for 302
  55. Tach needle stuck
  56. koeo codes....
  57. How many gallons does my tank hold
  58. power windows ~ help
  59. Exhaust!?!?
  60. cats on 95 quick ?
  61. who's got the lowest original miles on a fox 5.0?
  62. I Finally Got Some New Pics!!!
  63. bleeding brakes
  64. EEC
  65. pretty dumb questions, but I dont' know...
  66. WATER TEMP TOO LOW
  67. Drilling Fiberglass Hood?
  68. Power Window Motor Removal
  69. FUEL PROBLEMS!!!
  70. Rear Disc brake - how do I get a flexible line on?
  71. LX..GT.. Oil filter?
  72. What are these hoses called...
  73. Last Cable Clutch
  74. performance chip question
  75. Convertible top frame
  76. Just installed some mods - Something not right.
  77. maf / 84 carb / speed density
  78. Subframe connectors
  79. Broke-off Water pump bolt
  80. quick question
  81. Factory Starter/Long Tube Headers
  82. Who has tinted windows
  83. Manual Steering System
  84. Do I Need To Advance Timing Cause of Smog Pump
  85. mass air flow
  86. top speed?
  87. specs
  88. Haus, please say something...
  89. Instrument panel
  90. help
  91. auto trans problems
  92. Black smoke and gas smell?
  93. Very slow acceleration in 94 GT 5 speed
  94. Timing and Octane
  95. To replace my motor mount...
  96. where to put gauges?? need a some opions
  97. Changed spark plugs - Idle has gone to crap! help!
  98. SVO heads?
  99. Headlight and sidemarker removal
  100. Headlight and sidemarker removal
  101. To sell or not to sell?
  102. Clutch pedal 'popped'?
  103. stock spark plug gap?
  104. ac condenser
  105. EFI??
  106. door panel removal
  107. Compatible gears for 89 5.0 convertible?
  108. coils
  109. under-hood tornado finally gone :)
  110. Gears?
  111. Battery Relocation
  112. RUNNING REALLY RICH..
  113. rear gear question
  114. Went to the track today
  115. OH NOES!! CLUTCH IS GOING OUT!
  116. 5.0 differences
  117. finally a pic of my car...
  118. thinking about seafoam
  119. new I should have took that piss
  120. dash
  121. Automatic Shifter Question
  122. Italian tune-up
  123. charging problem..
  124. first time at track
  125. TB?
  126. 93 Bullitt Rim?
  127. lowering springs.
  128. Quick question
  129. Cervini hood
  130. convertible seats --> hatchback
  131. 347-e
  132. Door locks?
  133. 74 intake manifold on a 95?
  134. CONVERTING TO FUEL INJECTION
  135. Swirl Marks....Best Wax???
  136. Transmission pan with temp sensor in it?
  137. T-5 Problem
  138. trickflow
  139. DOES ANYONE KNOW WHERE I CAN FILL MY NITROUS BOTTLE IN MARYLAND OR DELAWARE?
  140. powerpipe for 95 GT with powerdyne
  141. 5.0 Member pics!
  142. Rear end : Widest tires possible on pony's?
  143. first time sig maker!!! grade me.
  144. hey you
  145. Lieing member!!!!!!!!!!!!!!!!!!!!!
  146. t5 question
  147. missing PCV
  148. EGR CEL FIX
  149. gears!
  150. Caster Camber Plates being a huge pain. please???
  151. Disappointing results...
  152. Whats the name of the piece that holds door rod to lock
  153. carfax vin?
  154. NO key?
  155. Should I...
  156. What octane to us with 13 Degrees of time advancment?
  157. Starter Noise
  158. 5.0 302=DOHC?
  159. Whats the trick on spring swaps....PITA
  160. Door wont open from inside
  161. radiator fluid ques....
  162. Suspension
  163. window stuck down
  164. 0 Oil Pressure :-(
  165. STUPID STARTER QUESTION
  166. Picked up some new goodies today!!! :)
  167. smog pump delete install
  168. 2.3L to 5.0L conversion...
  169. Please help with a fuel problem
  170. watched some racing last night..
  171. oil psi sender
  172. Hatch Recall
  173. whing noise
  174. 130amp alt.
  175. tuning
  176. fan clutch
  177. Some electrical problems?
  178. SMOG PROBLEMS
  179. springs?
  180. SUPERCHARGER... BYPASS VALVE???
  181. fuel question
  182. Quick question
  183. this pissed me off
  184. Fuel injectors ques...
  185. GT40Ps
  186. MOVED: Getting a S/C. but which one?
  187. NO Radiator fan!
  188. Phenolic Intake Spacer?
  189. Newb modding question....
  190. EGR Valve complications .. DIY cleaning??
  191. New Parts... Finally suspension..
  192. whats better a 331 (stroker) or stock 351w?
  193. starting problems
  194. WILL THIS WORK?
  195. No air out of vents
  196. gas is getting into my oil on 5.0
  197. ERRRR!!!! WTF???
  198. SELL ME WHEELS!!!
  199. Alternator Issue
  200. Need AFR 165 HELP Please!
  201. summit battery relocation kit questions
  202. brakes
  203. notch w/ a 5.0L cammer
  204. Injectors failing
  205. 2 quick questions
  206. carbon fiber
  207. stock hatch weight?
  208. Foglight/Headlamp Fix- HELP PLEASE!
  209. crane?
  210. foxbody sidepipes Yeh or Neh?
  211. does your car get more power w/o an a/c system
  212. Hows this cam kit sound?
  213. Aluminum cylinder head price is this good
  214. Strange exhaust leak
  215. Looking For A Cylinder Head Kit
  216. Let the vids begin...
  217. MUSTANG???
  218. PLEASE HELP! Tuning problem
  219. 351 lower intake?
  220. whats ur ride weigh?
  221. Recommendations
  222. Stock Starter VS Mini Starter
  223. splash shield?
  224. injectors
  225. pulley question
  226. engines and stuff
  227. rearend help!!!
  228. new axles
  229. Running Rough
  230. Getting ready to do my pullies and tb, got some questions!!!
  231. Tuning Software
  232. 5.0 swap
  233. seat bolt pulled out of my floor
  234. Notchback GT...
  235. injectors
  236. whats the difference?
  237. thinking speed
  238. whats the first thing?
  239. EBrake light
  240. trick flow intake on a 95 5.0??? spacer or what?
  241. timing advance question.
  242. check engine light
  243. EBAY CAI's
  244. what size belt
  245. Rear seat delete
  246. MSD Coil Makes Noise?
  247. relocated battery now problems
  248. Chroming my Pony Rims?
  249. New wheels & tires on (with pics)
  250. anyone bought from merzainc???
