PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 [98] 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Need more help!!!
  2. What compression will a stock 89 shortblock be with 56.5cc heads.
  3. Igniton Box location
  4. Need Someone with some knowledge
  5. MOVED: 1988 - 1993 mustang convertible
  6. wiring guages in a fox
  7. Bolt size
  8. trans>bell bolts
  9. english guy needs help please
  10. Chipped Gear In T-5
  11. anyone ever heard or DRP heads??
  12. HEADS HEADS & more HEADS!
  13. sn95 Five lug
  14. Long or Short Headers
  15. trans problems
  16. Rear Seat Delete
  17. bogging problem... OMG!!!
  18. Changing exaust
  19. MAF Voltage Low
  20. Help me with mods plz!! :)
  21. egr block off
  22. Another Smog Pump Delete?....
  23. manual tranny
  24. TREADSTONE FOX TURBO KIT
  25. MOVED: short shifter
  26. H/C/I plus nitrous?
  27. ported intake
  28. Higher revs & top speed
  29. Looking for suggestion: PS Delete Options
  30. BEST SHOCKS TO USE FOR STREET/TRACK?
  31. Hard to get into gears
  32. Another 5 lug conversion
  33. mass air q's
  34. oddball t-top
  35. car dings when lights are on and doors closed
  36. Fixing a rear bumper Updated w/ Pics
  37. 88 gt is dying every time i put gas in
  38. hot starting problim
  39. not firing up fast enough!!
  40. intake??
  41. COLOR???
  42. cam and intake question
  43. roller rockers..cleareance ?
  44. speedo cable problem.
  45. Summit Racing 70mm TB
  46. Throttle Cable Removal
  47. Need help with codes.
  48. bent pushrod
  49. shift kit install help?
  50. Rear coils.
  51. MOVED: 255/45/17 up front??
  52. What is the towing capacity of a 95 GT?
  53. EGR question for a 95 GT
  54. MOVED: ALARM????
  55. trans problem.
  56. Manual Valvebody Qs
  57. just wondering
  58. power steering pump
  59. Main Cap torques
  60. Paxton Fuel Control Unit
  61. Crower springs - help
  62. Powermaster 140Amp Alternator
  63. Fuse box bracket
  64. pretty sure I blew a head gasket
  65. MOVED: New Mustang
  66. Typhoon time?
  67. whats narrower a nitto or a bf goodwrich??
  68. Check Engine Light
  69. GT-40 Intake Manifold
  70. heater core is out
  71. kenne bell
  72. Advancing timing? & fox body computer upgrade?
  73. help me!
  74. Question
  75. MOVED: Need opinions on what to do any help appreciated
  76. help
  77. MOVED: Changing Upholstery!
  78. MOVED: Wheel ?
  79. Cam??? for Carb 5.0
  80. still heating issues
  81. Intake Manifold??? And Throttle Body????
  82. quick tire size help about to order?
  83. Camshaft ???
  84. found a new motor. get it?
  85. Taurus Fan
  86. short throw install question
  87. Brake adjusting knob???
  88. Possible starter problems?
  89. Need help
  90. rear end
  91. mixed combo works!!! 1.6 intake/ 1.7 exhaust
  92. whats the best disturbor to use?
  93. help with trans
  94. MOVED: 1/4 mile times70
  95. MOVED: about to buy these wheels what ya think?
  96. Removing charcoal canister, will it throw a code?
  97. High Idle
  98. BUMPER HELP
  99. how can you have to big of an injector?
  100. calibrator for new gears?
  101. MOVED: help me rosolve this please
  102. Brake upgrade ?
  103. oil pan removal
  104. Power steering pump ?
  105. Wideband O2 Debate
  106. 87 to 93 timing pointer
  107. 2000 T-5 into 89lx
  108. battery wont keep charge?
  109. MOVED: Where to buy wheels for Fox
  110. MOVED: need a good tire size for a 17x10 rim?!!
  111. Help
  112. RPM'S try to drop then car dies
  113. ATTN: rbarn and other boosted fellas...
  114. How long do rebuilt engines last?
  115. need help changing speedo gear in tranny
  116. MOVED: zoom multifriction clutch
  117. MOVED: NMRA Pure Street buildup
  118. using a explorer short block
  119. upper and lower controls arm
  120. SD to MAF
  121. Plugs/Gap 93 (306)
  122. conversion from V6 to v8 GT
  123. Need a good Cold Air Intake for my 95 GT
  124. Help identifying this tranny???
  125. MOVED: anyone add a cobra grill insert?
  126. fuel pump relay
  127. is this a good transmission?
  128. MOVED: wat do you guys think of this setup
  129. CAI on an SN95
  130. Random Switch Under dash to the left? I KNOW WHAT IT IS!
  131. car dies when **updates**
  132. gears for my stang
  133. What size k&n?
  134. Stroker Combo opinions.....
  135. Bumpsteer kit? Can it be done?
  136. revving between shifts
  137. Engine Rebuild Kits?
  138. F303 + Vortec + roller rockers
  139. how do you know what codes your car is giving?
  140. Oil in Intake
  141. Easy question about car sitting up for a long period of time
  142. Turbo question
  143. Oil Choices in High Mileage Motor
  144. cracked timing chain cover?
  145. Starter Problem
  146. How do I wake up my AOD?
  147. smog pump hose removal
  148. 95 gt rear calipers
  149. MOVED: 5.0 or 2.3T?
  150. MOVED: has anyone heard of vrs mid pipes?
  151. Synthetic or Regular Oil?
  152. wiring diagrams
  153. MOVED: combo performance
  154. MOVED: title question
  155. About to buy stuff for 3G alt swap, few questions
  156. Jacobs MM carbureted, which distributor?
  157. MOVED: 2.5k to spend, what would you buy?
  158. MOVED: Whats The Best Intake Manifold??
  159. what kind of turbos????
  160. new motor
  161. c4 question
  162. where do i start?
  163. Intake Problem, PLEASE HELP!!!
  164. MOVED: What Is The Best IntaKe Manifold to Buy?
  165. Probably a dumb question...
  166. found good body
  167. rear compatability, NOT fox...
  168. Oil around head bolts
  169. Motor year problems
  170. mac equal length hitting motor mount
  171. MOVED: state inspections!!
  172. MOVED: Looking at 94' GT
  173. question about my EGR vacum line ?
  174. the oil in my 87 5.0 smells burnt
  175. is this cam with 1.7rr ok?
  176. Lug replacement for dr's
  177. Blowing flames between gears
  178. high idle, running rich, and codes galore!
  179. cutting off at 5 grand
  180. 1991 gt rear end question
  181. Where to bolt up to on motor w/ hoist.
  182. cheap engine
  183. Line loc anti lock brakes....
  184. backfire through carb new heads
  185. :-)Does anyone know this "fake" Saleen
  186. adjustable alternator bracket
  187. cluster gauges
  188. Tremec's
  189. MOVED: wheels & tires
  190. smog tube... gt40 heads... uh wtf to do???
  191. Heater Core Tubing
  192. Crate engine 'kits'?
  193. Power Steering Pump Replacement
  194. MOVED: Gt tail lights question
  195. anyone who has done an aod to t5 swap got a quick question?
  196. 5-lug conversion for 91gt
  197. MOVED: Shaker hood on a 5.0?
  198. radio wire harness
  199. aod 5.0 lx notch
  200. MOVED: Anyone ever had to ship a rear-end!!??
  201. MOVED: Car Craft Article about AFR's
  202. Saleen parts on a 5.0 GT
  203. Fmu = Temporary Solution?
  204. Dying at start up!
  205. MOVED: Any one here ever have body work done?
  206. MOVED: cleaning the top?
  207. rear-end question!
  208. To those with stuck PCV Valve Screens
  209. Drive belt
  210. 5.0L thunderbird engine rebuild ?'s
  211. u joint problem i think????
  212. coolant overflow bottle.
  213. MOVED: modified exhaust violation
  214. Problem after SN95 MC install.
  215. how to test the ECT sensor?
  216. Installing new plugs in my 95 gt?
  217. TAKING OUT VENTS AND OTHER DASH ITEMS
  218. Having trouble starting new rebuild
  219. what backspace fro 15x10's?
  220. any way to make intake pass ?
  221. What suspension mods are best?
  222. Longer Than Stock Torque Box / LCA Bolts
  223. where is 91 5.0 fuel regulator?
  224. very fast idle
  225. Chrome valve covers, will they fit?
  226. HELP!!OIL ON TOP OF TIMING COVER
  227. melted solenoid
  228. Fuel & Oil Pressure on a 5.0
  229. Edelbrock Intake Q?
  230. shift problems
  231. weight
  232. Next Mod
  233. PCV mesh screen + gas + match = new PCV mesh screen?
  234. Installing the Explorer upper and lower onto GT
  235. electrical probleM?
  236. Where is my PCV, I've looked at the articles and still now clue
  237. Want start, timing???
  238. s/c pinging question
  239. top end need help
  240. how many vacuum lines are there and where are they?
  241. heat/ac question and pics...
  242. GT-40 head ?
  243. running warm at an idle!
  244. steering shaft help please
  245. Performer RPM intake
  246. Need a bolt...
  247. '05 Mustang rims on my Fox?
  248. tv cable
  249. need wiring harness diagram for radio
  250. Which rockers do i need???
