PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 [106] 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. AOD Help
  2. cai and maf question
  3. Projector Headlights
  4. Serpentine belt
  5. please help!!
  6. new combo change. advice help
  7. torqueing down valve covers
  8. Moving driverseat back?
  9. Anyone using an AOD in their SN95??
  10. how to get the top bolt off front strut
  11. TPS voltage question again!
  12. No Power ... Help!
  13. Racing suspention...most cost effective
  14. 89 5.0 idle problems, battery guage drops any advice?
  15. 347 Stroker
  16. Torque Specs
  17. Stock Block
  18. Ford Mustang Cobra with Hellion 88mm turbo
  19. What's the Oil Capacity???
  20. headers
  21. people with 4.30 gears?
  22. Clicking noise from right rear...
  23. hesitation
  24. Billet grill help and hood latch
  25. battery relocation question
  26. what year's will fit ????
  27. clutch
  28. MSD 6al
  29. MAC Prochamber question
  30. Fuel System - 89 Mustang
  31. neutral switch
  32. distributor problem
  33. look what i broke!
  34. wiring harness questions
  35. 5.0 i want to beat a 4.6
  36. wiring problems
  37. Clicking drives me CRAZY!!!
  38. electrical problem...
  39. cant get the spring in
  40. rough idle/jerking foward
  41. zex nitrous?
  42. AFPR question
  43. Perfomance Chip for 94 AODE??
  44. AOD to T-5
  45. horn location ?
  46. Throttle Body Cleaner
  47. Good Turbo?
  48. Tires
  49. 95 GT ?s
  50. Tire size/disc brake for 89 mustang gt
  51. what would win!
  52. Adjusting fuel pressure
  53. trunk pins??
  54. Another Fuel Question
  55. which tranny?
  56. egr question???????
  57. adjusting pedistal rockers
  58. MOVED: value of 351 Cleveland
  59. Smog Pump Removal?????
  60. Need a pic please
  61. 8LG PCM
  62. pinging, sea foam, and dieseling
  63. qustion
  64. intake manifold worth it?
  65. MOVED: Multi-Port Fuel Injected Distributorless Carb - Check it Out !!!
  66. check engine light
  67. MOVED: Synthetic or non?
  68. quick question, see who can fill in the blank
  69. drag spring install
  70. iat sensor
  71. smog pump
  72. AOD to C4
  73. tweecer opinions
  74. MOVED: Buddy just built a 92 sluggo
  75. c-clip elims and disk brakes question
  76. MOVED: What rims should I get?
  77. 90/10 or 70/30's
  78. MOVED: Ooops....
  79. new pistons
  80. Cap and rotor...
  81. Clarify...99+ calipers on 88
  82. stock valve covers
  83. Megasquirt
  84. MOVED: Lots of new mods, when to upgrade fuel? (i searched)
  85. MOVED: Can anyone show me?
  86. chirping
  87. MOVED: New goal
  88. I read the codes on my 5.0 and got these...
  89. MOVED: TORN BETWEEN TWO PONIES
  90. would you trust this part
  91. Vacuum leak, got me stumped
  92. Need everyone's help on this one....
  93. harmonic balancer question
  94. 86 bronco part?
  95. Explorer Heads
  96. ?? for people with 5 speed swaps
  97. Purchasing a 5.0 fox.
  98. 225/50/16 ok?
  99. Deep Dish 17x10.5 bullitts
  100. cam ?
  101. MOVED: Can this run a 10.99
  102. programer for 90 fox
  103. what is so good about using 4cyl front springs?
  104. Battery relocatin help
  105. anyone running this fan controller?
  106. what cam
  107. MOVED: Rims, Dubs, D's
  108. MOVED: stangs in northern virginia
  109. T5 QUESTION?
  110. A/C & Heater delete question.
  111. Do I need a new fuel level sending unit?
  112. 92 mustang interior help?!?!
  113. are hoods interchangeable?
  114. what size tires can i fit on the rear of a 91 lx?
  115. Replacing valve in head
  116. Two questions prostar / smoke
  117. car wont hold a charge....
  118. Astro Performance T-5 opinions, 408 with 11:1 comp making power to 7200 rpm
  119. PMAS GOOD BAD UGLY?
  120. Need help w/ 94 Mustang 5.0 conversion
  121. Speedo cable woes...need help asap
  122. MOVED: Just bought a 94GT
  123. 88 LX mods
  124. map light woes...
  125. Driveshaft length question/help!
  126. supercharger intake hose
  127. Cam comparison - e303 vs cs1085r
  128. im stoked! got my setup now......
  129. Flywheel part numbers
  130. Do hedman headers always fit like crap?
  131. electric fan
  132. rear end
  133. Upgrade fuel pump? Simple yes or no.
  134. MOVED: n-21 cam sound clips?
  135. Pony Dash Emblem Help
  136. what kinda gears do i have?
  137. need help
  138. engine hoist help
  139. distributor help please
  140. 3.8 to 5.0 Engine Mount
  141. Urgent water pump problem
  142. GT-40P headers question
  143. anyone know if 99-04 seat covers will fit my 95?
  144. new mustang owner question
  145. Dipstick!!!!!
  146. header bolts ?
  147. upper intake connections
  148. QA1 Coil-over vs. Other
  149. H-Pipe Question
  150. what the hell?
  151. Trickflow H/C/I with Speed Density
  152. Help with vacuum reading
  153. exhuast advice
  154. starting from the rear
  155. which subframe connectors
  156. anyone know where i can get a bolt that fits the cam shaft thrust plate?
  157. injector/fuel pump upgrade?
  158. Starter engagement problems
  159. Intake Parts
  160. 5.0 engine build
  161. patriot of procomp heads
  162. low voltage
  163. MOVED: gt5.0 vs. rsx type S 05
  164. squar fuel tank/ with sump
  165. well today was hell
  166. Just bought my 2nd 5-0, help me get back in the game
  167. Er... power steering fluid?
  168. what should i do
  169. best intake mani
  170. power gains-cobra top end???
  171. Cali Smog Sucks!
  172. Input needed
  173. slugish of the line... help please...
  174. vacuum line? (pic inside please help)
  175. What would you do
  176. Air pump problems
  177. 13 INCH COBRA BRAKE CONVERSION HELP
  178. B&M hammer shifter/shafty mechanic
  179. how will it run?
  180. suspension chime in
  181. 5 speed swap ?
  182. 40 Series Delta Force Race Mufflers
  183. Fuel Pump Install Problem
  184. alignment specs
  185. 5.0 non HO VS. 5.0 HO
  186. rocker arms
  187. speedo question please help
  188. gauge cluster speedo funny
  189. oil pan
  190. 1988 Guage Problems?
  191. Will these fit?
  192. pedestal rockers???Please help
  193. whining
  194. Need some advice with headers
  195. Installing 4 barrel TB
  196. A/C only blows
  197. how do remove the motor mount on the driver side?
  198. mustang question
  199. Fuel Pressure.?
  200. 351W intake and T5 boltup?
  201. Tech Article on fooling your incoming air temp, can't find it
  202. help with window motor install
  203. electric fan push or pull
  204. gasoline question
  205. AOD??
  206. Tuner Chips for 95 Mustang GTS
  207. head flow
  208. driveshaft
  209. is anyone running a paxton novi 1000?
  210. MOVED: Good deal?
  211. Well i'm back with something new to build.
  212. Computer (SD) controlling electric fan?
  213. does ford rebuild a9l?
  214. replacing heads difficult?
  215. 1993 GT Overheating
  216. new radiator before heads?
  217. wat do u guys think gasket or tube? coolant leak
  218. a few questions...
  219. new clutch
  220. quiet electric fuel pump?
  221. bbk exhaust
  222. need a quick fix
  223. oil pressure guage
  224. heater/ac vent question...
  225. FMU question
  226. Switch Panel
  227. BAD IDLE FIXED PART 2 General Info
  228. 10* Timing and it still pings with 93 octane- Help
  229. MOVED: carpet color help
  230. T-5 is quitting me? Any Suggestions?
  231. Oxygen sensors
  232. Shocks/springs
  233. Emissions Help!!!!!!
  234. 94 stang 5.0 new oil pan
  235. MOVED: any idea what color this is?
  236. idle problem
  237. MOVED: how much should i ask for it?
  238. engine code
  239. n/a hp and torque on sn95
  240. little prob
  241. 1994 mustang GT 5.0 auto>5 speed swap
  242. Trying to retard timing in a 94
  243. help pulling motor
  244. What to do if engine is ticking
  245. What size MAF is best for my application
  246. 86 top end rebuild problem
  247. Battery Issues
  248. Weld 15x8 backspacing & Bolt pattern
  249. Vibration--HELP!!!!
  250. MOVED: is this a good deal
