PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 [118] 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. 86 4 banger to V-8 Power Steering Question
  2. Strut Tower Brace...worth it?
  3. Rear wheel and tires
  4. 302 front brackets
  5. 1995 Mustang issues
  6. MOVED: what does it take....
  7. Help ASAP "quick Pulley question"
  8. Replacing Harmonic Balancer
  9. Temp Sensor/Sending Unit
  10. Overheating question.
  11. Body Repair
  12. radio wiring diagram?
  13. Wires
  14. MOVED: Pics of my stang
  15. Rectangle exhaust ports???
  16. Dash lights wiring diagram
  17. fuel pump?
  18. Can't keep my car charged
  19. MOVED: supra for 5.0
  20. shorter belt No air pump
  21. anyway?
  22. SHOULD I NOTICE A DIFFERANCE?
  23. TRANNY EXPERTS
  24. Seat belt removal
  25. 5.0 coversion
  26. turbo manifolds
  27. Oil Pan question ?
  28. leaking oil
  29. Starter question
  30. Timing
  31. Installing TPS
  32. airbag question
  33. MOVED: my ex just took my car
  34. a/c eliminator install
  35. shift kit?
  36. clutch specs for a tremec
  37. Drag slick size Question
  38. Were to put nitrous arming switch?
  39. how in the hell do you remove the body moldings?
  40. Beeping sensor help plz!!
  41. Leakin Antifreez Question.
  42. LT Headers Install
  43. clutch adjustment
  44. Backfire problem
  45. Track time EST.????
  46. timing confermation
  47. Installing a torque converter?
  48. MOVED: What Color?
  49. MOVED: Paint job cost
  50. listen to this $hit
  51. typhoon intake question
  52. Best way to align mufflers and tailpipes?
  53. should i go with a nos system?
  54. Intake V K&N V Factory.. Need a filter what to do??
  55. is it bad
  56. 347 stroker kit?
  57. rear end lockers. opinions please
  58. Lifter Tick
  59. A/C question.
  60. Edelbrock Performer intake question
  61. Some questions/suggestions bout buildn her up :)
  62. 4.6 and 3650 in my 89 notch
  63. losing power at a constant speed
  64. headers.....
  65. Need instructions
  66. Suspension questions
  67. would this harness work?
  68. 2k explorer motor swap
  69. nawwwwwwwzzzzzzzzzzz
  70. Studs and gaskets
  71. question..?
  72. March Engine brackets?
  73. its almost ready to go back together (updated 8/10)
  74. Decision
  75. Summit high capacity water pump
  76. wtf will be next
  77. 90-93 gauge cluster? asap please
  78. Fuel pump size?
  79. No voltage at TPS
  80. ignition problem
  81. MOVED: My project progress - Almost!
  82. torque box repair
  83. What color is the Volt lead ?
  84. Maybe valve float? Need help!!!!
  85. Rear Control Arm Bushing
  86. Wire harness
  87. Installing a 460 in a Fox Coupe?
  88. transmission install question
  89. tranny problems
  90. Nex wet nitrous install help pics
  91. Car Dies While Driving (Help!) TFI?
  92. brakestand rpm level
  93. Newbie here, need some advice
  94. need pics of non a/c car
  95. Electric Fan Install Help
  96. 302 w 11.1 Compression Ration In Florida
  97. 351 Heads on a 302
  98. SN95 timing cover
  99. Darn Freeze plugs!!!!!!!
  100. which key do i need
  101. bigger cam in a 86lx?
  102. '91 stock 5.0 won't start!
  103. Is there a relay associated with the A/C ?
  104. Pistons Comp ratio and pins
  105. c-4 or stick to stock aod???
  106. stuck idle
  107. modified 5.0 lacks power
  108. MOVED: Audio Wiring
  109. Ignition Options...
  110. MOVED: 1993 COBRA DRIVER SIDE SKIRT NEEDED
  111. push rod and rr combo
  112. intake backfire STILL
  113. D&D c/c plates
  114. hypereutetic or forged?????
  115. 92 lx aftermarket tach. where to get signal??
  116. few questions please help. thanks
  117. VIN # LOCATIONS
  118. Vaccum lines?
  119. MOVED: ? for those who live where it snows
  120. NEED PROS AND CONS ON SOLID TRANS MOUNT.
  121. 94 GT running rich on startup...
  122. i know this question is retarded
  123. should i make this transmission swap...
  124. Boost????
  125. Casting mark question...
  126. Electric Speedometer?
  127. carfax history report?
  128. Motor mount install, how to?
  129. Fox upper intake on SN95
  130. A/C Smog delete P/S bracket question
  131. oxygen sensor
  132. after manifold now smokes
  133. front end fiberglass clip
  134. MOVED: Looked at a notch today
  135. flush power steering?
  136. Alternator upgrade?
  137. What makes more power, S/C or H/C/I
  138. Flange Issues
  139. oil pressure
  140. smog control for 5.0
  141. Fuel return line?
  142. 95 Mustang GT- Help With Edelbrock performer heads
  143. flywheel dowel pin
  144. non ford auto problem help me if you can
  145. Injectors
  146. Throttle body question
  147. Trick flow upr and lowr
  148. 4cyl K members same as 5.0?
  149. Equals or Longtubes
  150. Cobra intake
  151. pcv and egr elimination
  152. egr removal bet
  153. This is a longshot, but any guys here familiar with CBAZA?
  154. Clutch install questions
  155. BIG Mustang problems
  156. Running Hot
  157. MOVED: Notch Vs Hatch. Not typical thread.
  158. stroker q's
  159. idle low and kills
  160. stock aode
  161. trannys
  162. How can I increase low end torque?
  163. found 8 autolite 65 plugs, what do they fit??
  164. for 79-86 if u want a bigger speedo, anyone do this??
  165. learning to rebuild motor
  166. wont start
  167. aod to t-5/t-56 conversion
  168. Idle question
  169. 5.0 in a 2.3 Hole
  170. 460 rear
  171. keeps catching fire
  172. which clutch
  173. 332 stroker
  174. whiper motor?/blinkers
  175. MOVED: motor pull pics
  176. I checked tps voltage and its 1.37?
  177. AOD shift points
  178. what to build c4 with??? (internals)
  179. Wiring stuff..
  180. Anybody install a ZEX Wet system lately?
  181. this may be a stupid question~
  182. sqeaker
  183. trailing arm bracket broke!!!!!!!
  184. rear end
  185. bellhousing removal
  186. Best type Of oil for 5.0'z
  187. proper tv adj
  188. bumping timing
  189. rusted doors!
  190. Anyone using this Hurst Shifter?
  191. not keeping fuel pressure
  192. WEIRD NOISES
  193. Starting front suspension 2morrow. have some ???
  194. checks these out
  195. a quick question
  196. Fuel regulator vacuum
  197. ticking in head
  198. injectors and check engine light
  199. Aluminum radiator
  200. '86 Mustang questions
  201. t5 issues
  202. what fuel pump???
  203. RED ALTO RACE CLUTCHES
  204. 302 blowthrough carb help
  205. how much hp can a 351 handle?
  206. ebay twin turbo kits
  207. what cam with explorer motor
  208. wireing harness help
  209. Tire size
  210. nitrous q's
  211. I think I found my problem. SPARKPLUGS
  212. 89 t5 - 95 t5?
  213. match for 19# injectors
  214. help! my batteries keep dieing!!!!!!
  215. bigger alt?
  216. What does a mass air kit include? (Computer pins wise)
  217. TUNING QUESTIONS
  218. neutral safety switch
  219. KB Supercharger?
  220. Timing
  221. Running lean on both banks
  222. What size gear tooth for 4.10's
  223. cLUtCh..?
  224. 5.0 Bolt-On Question
  225. Errr.. Joel.. Or other electrical geniuses
  226. T5 problems fixed
  227. Cooling system upgrades.
  228. 5.0 Spark Plugs
  229. MSD 6 Digital Ignition problem
  230. t5 tare down/rebuild
  231. Which Heads
  232. Power Windows
  233. Plumbing ???
  234. Air only blows out the defrost?
  235. MOVED: tailpipe fell off
  236. professional products??
  237. first mods?
  238. twin turbo 5.0
  239. Electrical help needed
  240. Oil leak
  241. diy alignment ?'s
  242. C clip removal HELP!
  243. MOVED: First time 5.0 mustang
  244. Downshifting
  245. New problem! NEED HELP ASAP
  246. better for boost?
  247. MOVED: Gold Wheels...
  248. need your advice!!!!!!!!!!!!!!
  249. is it possible to weld oil pan?
  250. motor mounts
