PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 [234] 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Random pics of my fox..
  2. question that is dumb
  3. Most power from exhuast
  4. what hp numbers will this make
  5. on cams
  6. PLEASE help I have speed density problems
  7. anyone running an F cam?
  8. H or X pipe?
  9. Big TaTa's in here guys, come take a look!
  10. I fianally got one!
  11. throttle body
  12. Anyone Using Hooker?
  13. Equal Length vs non equal length shorty's
  14. What tranny
  15. what kind of 1/4 times can i expect...?
  16. h/c/i, turbo, or s/c?
  17. Hi flow cats....
  18. gears
  19. Messed Up Idle!
  20. 95 gt vs 96 gt
  21. braided line
  22. copper rod/nail?
  23. just installed tfs top half lots of problems
  24. HELP HORRiABLE NOISE
  25. A Little Help
  26. a/c clutch problem?
  27. Shifter
  28. Looking at a 88 GT, 50k original but Q's...
  29. First time H/C/I, head ?s
  30. CAT POWER...
  31. emissions failed help!!!!!
  32. pics of the turbostang....
  33. are you good behind the wheel?
  34. Brakes
  35. 94-95 Intake Elbow
  36. fox vs.. 94-95?
  37. cooling situation
  38. weight difference between notch and hatch?
  39. How Much HP????
  40. dumb question o' the day
  41. Rocker lash
  42. Rebuilding
  43. will these babies fit
  44. Blue book value of 89 LX hatch 5.0?
  45. where can i buy this?
  46. My 225/60/15 tire's rub when turn full left?
  47. power steering
  48. distributor wires
  49. 5 lug conversion? why?
  50. Changing H PIPE
  51. Fuel Pres. Reg.
  52. Installing 1970 351w heads onto a '91 302 HO
  53. Which Would You Worry About First? Looks or Power?
  54. Intake Swap
  55. springs installed!!!!!
  56. Ballpark costs
  57. How fast can you do a 90% cornor
  58. DOT lable on door question?
  59. where to buy
  60. Where is a good place to buy...
  61. going to the dyno friday!!!!!!
  62. 5.0 problem...help
  63. 86 AC/Heater Panel Guage Pods
  64. WHEELS
  65. any idea what this would run 1/4?
  66. MUSTANG WEEK!!!!
  67. TFS Heads on a Stock Block
  68. GT40 Vs. Trickflow Track-Heat
  69. 91 rim width
  70. finally got my car back
  71. ROTM
  72. GOT the stang in the garage, now the fun begins, any suggestions??
  73. Quad Shocks?
  74. Coolant leak after rebuild
  75. gage cluster
  76. Shift kit?????
  77. Well, I f**ked up!!!!!!!
  78. 95 Cobra
  79. Bay Area California Stang Owner's Read!!
  80. All my mods have become useless
  81. wiring harness
  82. Sound Clip of X/Z Cam?
  83. anyone know were?
  84. 88 LX 5.0
  85. Problem
  86. Which engine gasket set?
  87. Drag Radial owners, HEEELLPP!!!
  88. Smog pump eliminator question
  89. deleting the egr.
  90. idle speed question
  91. for pro50sc typhoon gasket question
  92. Street Legal? why?
  93. fuel line question
  94. My stang pic.
  95. Best aftermarket shop?
  96. SLIPS !! CAMARO GOT OWNED!!!
  97. Pic of my car
  98. horrible "mustang" on the highway last night
  99. Radiators....
  100. cams
  101. Engine shaking and running ROUGH
  102. Engine Swap 89 GT
  103. Cam ID
  104. 27.5x12 inch slicks Too Big? Need Help Quick!
  105. idle problem with a twist
  106. My door sensor seems broke
  107. Need some help with my suspension..
  108. race
  109. best custom cam grinder??
  110. C&L MAF question
  111. Just got an 88 hatchback lx 5.0 efi
  112. plug wires too close to headers. help!!!
  113. CARFAX Help
  114. HAS ANYONE?
  115. Oil pressure
  116. what tires to buy....
  117. power programmer?
  118. exhaust
  119. IAC
  120. IM stuck
  121. thermostat question
  122. Aluminum or brass?
  123. MOVED: 5.8l swap questions
  124. 5.0 intake question
  125. WANTED PARTS
  126. World heads
  127. (HELP) 86 5.0 QUESTION
  128. Changed plugs wires and put an msd cap and rotor
  129. Good Price? Michigan Area.
  130. HP Gains
  131. plugs...denso?
  132. flywheel
  133. "AOD Shuffle"on art carr aod
  134. changed plugs last night
  135. Vacuum/fuel pressure
  136. clutch cable help please?
  137. changing thermostat to 160
  138. What's this and why is it loose?
  139. Stupid Chevy people
  140. Pro's and Cons of dry gas?
  141. Header and wheels help please
  142. Aluminum Radiator / Electric Fan
  143. AOD WHINE/grind AND RPM GOES UP
  144. Performance parts for the 3.9L LS?
  145. BALANCE FACTOR
  146. SPARK PLUG?
  147. Driveshaft Question
  148. insurance
  149. Slicks/Tires
  150. Never knew
  151. How to set idle?
  152. I want some catbacks
  153. help on choosing exhaust
  154. electric fan help!
  155. cam choices
  156. Eaton and 3.73's going in tomorrow!
  157. wierd question
  158. overhaul.. what to mod??
  159. what else should i buy?
  160. rear end gears
  161. LEARN FROM OUR MISTAKES
  162. What injectors should I get?
  163. bbk tb high idle fixed
  164. Water temp probs...any suggestions?
  165. Idol & hesitation problem
  166. airbag in an 88'
  167. HELP!!!!
  168. can will not run
  169. Cleaning an engine
  170. Well well well, Found the Problem...
  171. Sell the 5.0???
  172. Convert a auto to a 5spd
  173. Clutch smell?
  174. Throttle body water lines?
  175. Stock 87 LX 5.0 Auto shutdown on the way home from work
  176. its running again YAY
  177. flexplate/starter gear hitting?
  178. Surge in RPM between shifts
  179. what kinda clutch?
  180. Smoke Screen
  181. Chip buring question.
  182. trade my 24's???
  183. to all you pussies whining about your t-5s
  184. Body Shops - Are They Nuts?!?
  185. Installing headers
  186. Removing BS from Engine bay
  187. electrical problem
  188. what will generally cause this
  189. ac removal kit for my notch
  190. Starting Issue
  191. Where are you from
  192. My Ride
  193. transmission swap help needed
  194. guage problem
  195. Speedo removal need help!
  196. New to the stang world and need help.
  197. silenoid wiring prob
  198. tansmission question
  199. Anyone with a 94/95 GT
  200. I need a Tune/Chip Question
  201. Need Help Guys...
  202. updated oil pumps for fox bodies
  203. engine decision...
  204. Rack and Pinion
  205. Idle Problems
  206. Quick weight question
  207. front fascia support
  208. Decent vacuum distribution diagrams?
  209. Lowering
  210. Distributor Bolt
  211. 91 LX 5.0 Problems starting
  212. Rear 5-Bolt conversion
  213. Nitrous, tune up?
  214. Clutch clacks when pushed sometimes?
  215. New power window motor help plz
  216. perhaps i bought the wrong car?
  217. 351 mpg
  218. Engine Shaking!!
  219. ARG!!! Now WHAT???? (streering wheel)
  220. I've narrowed it down to...
  221. 351
  222. sticky for admin
  223. Deal or No Deal??
  224. New engine
  225. SHOCKS&STRUTS HELP
  226. 91 GT with freezing oil pumps
  227. Suggest a Clutch
  228. Acceleration
  229. Transmissions
  230. New color??
  231. Header question
  232. friends buyin a stang
  233. Good news
  234. What you guys think?
  235. what do you think of this car?
  236. HP numbers
  237. Noob Question........
  238. What Do I Need To Launch?
  239. can i get a link to...
  240. 1990 mustang bra
  241. whats my ets..
  242. What are the biggest Wheels/Tires I can put on my 95 GT
  243. Will I crack 13s with this set-up???
  244. Getting code for MAF
  245. finally got my typhoon lower intake fixed today
  246. Dyno
  247. Torque Specs
  248. 4 lug FR500's
  249. Tranny cooler for AOD from Summit???
  250. 5 Lug Conversion?
