- 30 39 42lb injectors??
- wat size piping
- dashboard swap
- cobra intake a direct bolt on?
- Thrust Bearing Cap question.
- rear axle seal??leaking
- How Much Horsepower - Just got a COBRA INTAKE MANIFOLD
- 351 in my hatch (yes ive searched)
- clutch pedal makes racheting noise
- Tranny Cooler
- coil
- Car seats
- car slugish
- axle tag
- Rough Idle after Smog
- Extremely Weird Problem
- Anybody using the Paxton SL (self Lubricating) superchargers?
- 83 mustang question
- vacume line question
- Transmissions
- fog light switch....
- Rear suspension question
- HELP: thermostat
- Clutch time
- rear again?
- carpet...
- Supercharger Options
- choked engine & back fires from the engine
- .550 lift is tough on retainer/guide relations
- Electric Fan Setup....
- Battery Relocation Please!
- 4cyl to 5.0 transmission question:
- AODE problems
- rear end
- anyone have a stock fuel pump?
- Turn the key and does not start???
- Transmission fluid??
- Oil leak??
- IS IT TRUE
- got a 83 stang have question
- Window Fails to Go Up all The way - How to fix
- Holly Systemmax II
- how expensive is it to do a 5lug conversion?
- megasquirt II tunes
- Neutral Safety Switch Please Help!
- Intake manifold???
- FR Steering Shaft Help
- very dissapointed.. need advice
- nitrous, methonal injection, boost cooler
- what 3rd member has 3.73's
- supercharger pulley????
- fogs light illegal!
- Draglite
- 95 Front crash sensors
- rev limiter?
- msd cap and rotor
- alternator bracket
- that little red wire
- no cruise control
- Tensioner bracket
- Pics and a question:
- water pump
- turn signal frustration
- Power steer pump bad?
- small 3G alternator?
- another tire question
- firewall adj. help
- Almost Positive its a miss now
- MOVED: 1989 5.0 LX
- 94 performance help!?
- New Problem
- turn signals not working
- gangsta lean?
- Flowmaster catback- hits everything
- power loss after warmup
- best cold air intake?
- heads question
- balancing rotating assembly?
- Squeeking noise...
- Explorer intake
- 5l swap wiring help
- 8.8 parking brake
- torque specs on intake
- bumping up the timing
- torque box reinforcment
- cracked block? warped head? what?
- bad vibration
- How can I get 400 HP out of my mustang?
- MOVED: FINALLY GOT MY 5.0
- headers
- EGR eliminator plate? How does that fit?
- X or H Pipe IMPORTANT!!
- Compression stock 302
- running no 02's question
- recent idle problem
- Oh Crap! Intake help!
- Throttle body setup
- turning radius
- Motor Mounts!!!!!!!!!
- 5 lug conversion
- B+M shft improv.kit??
- cam specs
- 6al question
- comp polymers?
- idle problem??
- Harmonic Balancer
- 2.5 2.25 3.0 what is stock on a 91 mustang gt rack and pinion?
- front end
- '90 mustang LX 5.0 OBD1 Connecter?
- injector size
- Cams, cams, and more cams.
- MOVED: What t5 shifter are you using?
- Mass air flow meter question!!!!
- Shocks, struts, and springs . . . oh my!
- FK-35 Install help
- tranny
- MOVED: anyone know what would be the best lubricant on wheld wheel lugs??
- bigest stroker w/o boring
- Motor mounts...
- Steeda #19 Questions
- MAF questions
- BBK Throttle Body Gasket Set
- Another electric fan question
- Bad Alternator?????
- Best Size throttle body and mass air meter
- bbk intake question
- 1976 Mach 1
- Need a special tool to take of Fuel Filter?
- 5 lug conversion
- Need help pulling gauge cluster out
- ALUMINUM RADIATOR AND PRESTONE RAD FLUSH
- Liberty tranmission parts
- SUPERCHARGED MUSTANG
- 93 Cobra Help
- vacuum tree
- Dash upgrade?
- shift light help
- Need Timing Help
- WTF is wrong???
- What Carb
- cam? not about which profile
- Rear brake conversion?
- how big of a shot
- Steering Wheel Help?
- 93 cobra air intake
- Eibach drag springs
- fuel guage problem
- high rpm backfire
- Anybody exceptionally good with engines?
- 2 questions
- EGR removal
- Fuel Pump (?) Question--And a Wierd Coincidence? Diagnostic Challenge?
- E-303 in a 95 GT
- 87 Mustang GT won't start
- Possible Misfire?
- 24lb injectors maf for 30's
- CLUTCH HELP
- tfs efi hci kit
- Anyone Not Running Smog & PS ???
- MOVED: 11 Second Street Car with Stock Black and Cam?
- how long will this last trying to go 10's in my 2800lb sn95
- suspen?
- Help with wheels for 93 Notchback
- carb conversion almost complete
- MOVED: This is my dream mustang... Check this out
- wont idle after tb install
- patriot heads.
- Mufflers and H-pipe vs X-pipe
- Short Block
- MOVED: Looking for a 91LX 5.0
- valve spring help
- buying 3.73s this friday need advice
- MAF Advantages?
- The best HCI combo for under $1800 ?
- need help question about belt size?
- MOVED: Looking for another mustang
- 7.5 Rear end
- Hooking up an engine?
- MAF Conversion
- Fuel Line **PICS INCLUDED** help!!
- smoke on startup
- what would you do?
- shock question
- 93 COBROA INTAKE GASKET SAME AS 94 FIT??
- Problem - Setting Timing with a "Timing Light"
- Power Window Switch Oddity
- anit-lock light??? 94 gt 5.0
- window wiper help????
- STEERING WHEEL ADAPTER
- patriot heads
- MOVED: Whats a fair price??
- maybe im just dumb but need your help 3g upgrade
- gonna stay with the fi
- is this worth it?
- DOG BONE? for 351w?
- MOVED: 351w Guru's Help!!
- starting problems
- MOVED: 351 (427) gud idea??
- Smog delete .. what size belt would i need.
- Question about slicks
- Can a speed density computer have a check engine light/
- wheel hop
- under-carb'd
- afr heads
- puttin the motor together...im guessing pump gas is a no-no
- Swapping in motor, unsure of cam
- PICS! choosing to repair my vert or get another
- Harmonic balancer.... and rear end
- MOVED: used parts?
- Nitto Drag Radial Help
- Have MPH gauge problem 10 to 15 off and bounces
- Motorcraft spark plug wires?
- motor mounts
- engine codes?
- Oil pan gasket???
- help me
- Cylinder Heads comparison
- Couple issues
- K-Member help with steering install
- 85 or 92 stang?
- 93 cobra intake for 94 5.0 direct fit?
- 160* thermostat
- My new Fox Overheating...
- replacing valve guides in heads?
- Headers and exhaust
- help with building a motor
- fuel pressure release
- quick question
- balancer
- 92 bronco 351 heads
- trickflow or edelbrock??
- surface rust and ? about bearings
- Base idle Question?
- front suspension kit>?
- How easy is this to fix?
- Vibration question's--
- aod guys with 4.10s
- cat back suggestions
- tires
- Quick Underdrive Pulley Question
- HELP
- texas smog laws blah!
- Differences in 1986 wiring harness? Check engine light wiring help needed.
- has anyone installed those window retainers from 50 resto
- T-5 Inputshaft
- first time at track, how well will i do with my mods.
- New clutch
- stalling
- Steering Problem
- cooling concern .. 95 cobra
