PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 [321] 322 323 324 325 326 327 328 329 330 331
  1. timing gears
  2. Spacers
  3. headers on a stock 5.0
  4. OIL PRESSURE SWITCH
  5. AUBURN GEAR ECTED
  6. battery strap?
  7. Tread Life
  8. Water pump rotation question
  9. Check Engine codes?
  10. 88 automatic to standard conversion
  11. how hard is it to put a T56 in. .
  12. What Runs Fuel Pump?
  13. if anyone know how to save wieght or anything to take out
  14. Need Exhaust Hangers!!!!!!!
  15. short? need help
  16. help i run too slow
  17. 88 Capri engine
  18. Best way to grenade a stock GT rearend?
  19. what struts to get
  20. 1995 5.0 Auto Tranny Shift Issue
  21. are lx's HO??
  22. Damm. Deal on a mustang :)
  23. A/C delete kit
  24. car won't stay running getting pissed
  25. injector question
  26. Car not running up to par
  27. 190 Liter/Hour Fuel Pump
  28. what is the max hp for?
  29. Fuel Gauge Help!!
  30. Tension pulley loosening
  31. How to get deep throaty exhaust sound?
  32. HELP with speed density mods
  33. Foglights
  34. Stock measurements???
  35. HEY! I have a t-5 question help plz
  36. Help picking a mustang
  37. 1000 bucks towards motor
  38. Fuel Filter or Pump
  39. Air filters
  40. How much of a pounding can a stang take?
  41. holley mechanical fuel pump in the way???
  42. Fuel pump? worried for my 5.0s life
  43. Idle problem...
  44. Bigger MAF makes car run badly
  45. Best MSD Coil?
  46. Alternator...
  47. Thinking about crossing to the darkside...
  48. Pipe Plugs??
  49. Fusible link guage to AMP conversion?
  50. What flywheel do I have?
  51. MAP SENSOR
  52. Aftermarket Keyless Entry
  53. Clearance Issues
  54. noise form upper intake?
  55. modified mclaren?
  56. 5.0 tops
  57. Misfiring at certain RPM
  58. Stock Style bar plz help???
  59. anyone know?
  60. 87 mass air conversion. 89ecm vs. 90-93
  61. would a 6 speed be worth it?
  62. how hard can this be??
  63. 4.6 19lb injectors in a 88 5.0 HO will it work?
  64. K&N cone on mass air
  65. low oil sensor
  66. best exhaust setup
  67. 4 banger/gt to 4 banger LX
  68. How much HP can a 302 handle?
  69. 1990 GT stock. What clutch? HELP!?
  70. 94 mustang gt convertable for sale
  71. best way to drain the gas tank??
  72. 351w question!!!!
  73. backspacing
  74. Injector Size Issue
  75. TPS tesing, WOT
  76. axle data decoding
  77. Need some help on A/C delete kit.
  78. Smog pump removal on 86 GT
  79. Acceleration and RPM woes
  80. Best Performance Chip Out there...
  81. Clutch Cable feels like it is rusted in place.
  82. Outer Door Weather Strip
  83. major hail damage
  84. No go 5.0...please help!
  85. moderate build up
  86. which is best for oil
  87. n/a dyno numbers requested
  88. wrong computer?
  89. shift fork bent hard to fix?
  90. throttle body spacer
  91. Grinding in reverse....clutch?
  92. Stock cam? help
  93. '95 V8 stock check engine light popping noise
  94. Rebuilding engine..
  95. will i need new cylinder rings
  96. Mass air conversion
  97. t5 trans. Install troubles....new bearing retainer
  98. Free power
  99. how much NOS should i use?
  100. Is my distributor in right?
  101. Converting Coupe to Convert.?
  102. Need new Shocks
  103. Stroker motor
  104. Tires
  105. SPYDER INTAKE
  106. Trick Flow intake
  107. TIMING ISSUE IN MY 93'
  108. GT-40 Intake
  109. Shocks and Struts
  110. aftermarket crossmember
  111. cruise
  112. Timing a 93' 5.0
  113. 302 and n.o.s.???
  114. Best shocks?
  115. Exterior Door handle trauma..
  116. 95 GT computers
  117. ? from a new stang owner
  118. Head Light covers
  119. Four Tires Mounted on Car=$1,055.78
  120. best performance mod
  121. cruise control
  122. Rev limiter stock?
  123. Best Cam setup on a 331? Injectors? Main Girdle?
  124. Small Fenderwell vs. Big engine sitting
  125. Now the cranck pulley?????
  126. Last bolt on water pump pulley????
  127. MAF Effect?
  128. Anyone using VALVOLINE FULL SYNTHETIC?
  129. What's your preference? Fuel Injected or Carbed?
  130. how far to advance
  131. Exhaust makes my E-Brake Rattle
  132. Leaky Diff
  133. Roller rocker installation
  134. Question, I don't know where to post.
  135. Cold start and idle problems
  136. Project Car Input
  137. Tubular k member
  138. Header Leak
  139. DO I NEED TO....
  140. 87 gt horsepower rating
  141. 5.0 ENGINE
  142. Will the 5.0 oil pan come stait down to replace the gasket?
  143. Carburetor
  144. oil consumption
  145. 87 gt 85 mph to 200 mph gauge calibration
  146. valve noise?
  147. Fuel Pump Relay - 1990 Conv
  148. valve clearance
  149. GT40P heads
  150. how do you guys feel about the mallory hyfire VI a
  151. Which speedometer gauge cluster?
  152. How to clean headlights??
  153. h pipe
  154. Wax tips
  155. Aftermarket speedometer calibration
  156. Compcams Powerbox intake
  157. Saleen/Vortech Intake Manifold
  158. Need Help with 5.0 automatic transmission
  159. Header Gasket??? BEST?
  160. headers?
  161. AIR PUMP ELIMNINATOR KIT???
  162. low coolant reservoir
  163. Need Suspension Help
  164. Avoiding 'Open Loop' Mode
  165. KNOCKING above 2300rpm
  166. t-5 swap
  167. Heeelp
  168. equal length headers melting wires
  169. Little problems with $300 find...
  170. 3.55 gear in a automatic
  171. rough running fora few
  172. roller lifter installation
  173. t5 noise
  174. i gotta 88 convert
  175. 373 gears
  176. Cylinder out?
  177. 351W Crankshaft in a 302?
  178. More injector sizing questions... opinions please...
  179. t5???
  180. hp estimate
  181. what Lbs of injectors should i get
  182. Should I?
  183. TURBO ?
  184. Electircal Problem
  185. through the hood blower?
  186. looking for some answers
  187. Clutch problems
  188. installed tach, which one is closer to being correct rpm?
  189. new member and new stang
  190. Built engines
  191. Kumho Ecsta 712s
  192. E-303 Cam Timing???
  193. Rack break light on my 91 GT Convertible
  194. WHY DOES EVERYBODY ?
  195. f-303 cam
  196. bent car-help?
  197. my car?
  198. Leaky Injectors! HELP!
  199. for all you nitrous junkies; teach me!!!!!
  200. Engine plans???? is it any good.
  201. having computer problems
  202. What engine combo should be used?
  203. pulleys?
  204. Question
  205. Alternative Tranny.
  206. TIMING HELP NEEDED!!!!!
  207. Can Everyone Read This One Please!
  208. Witch Motor???
  209. Ignition Module Installation
  210. best oil
  211. does anyone have any twisted wedge heads for sale for a 347?
  212. screen names PLEASE!
  213. Injector size change?
  214. Black Smoke HELP!!!!!!!
  215. Timing Help!!
  216. 89 5.0-swaped "74" into 89 kept EFI
  217. MOVED: average age
  218. main (engine) harness pin-outs
  219. x pipe or h pipe
  220. Keyless entry??????
  221. more legroom?
  222. Body Shop
  223. spark question...
  224. Suggestions...?
  225. STAINLESS STEEL EXHAUST QUESTION
  226. THE BIGGEST SIZE TIRE ALLOWED
  227. spool?
  228. 351 heads on 302 block
  229. GT vs. Cobra
  230. Can I take the spoiler off a 94-95 GT?
  231. best 347 setup!
  232. 351W with 375-425 HP....??
  233. Spark Knock
  234. 3.73's vs. 4.10's
  235. hp?
  236. how do i fix this?
  237. 94 cobra computer in a 94 GT?
  238. speedometer w/gear change
  239. 351w stroked to 427
  240. Convert limited slip to posi??
  241. Starting..
  242. Who Produces an AOD that...
  243. Starter problem
  244. Over Priced mustang's?
  245. Anyone from Rochester, NY?
  246. Better brakes & rotors??
  247. will the cobra computer from a 95 work in my 94 GT
  248. What gears are the best?
  249. EFI-CARB conversion using stock electric pump
  250. swap question
