PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 [179] 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Should I replace my weatherstriping (convertible)?
  2. rear end
  3. Anyone installed SN95 brakes onto a fox 8.8 before?
  4. Door locks....
  5. Odd overheating
  6. is a 5.0 interference engine?
  7. Priming though distributor
  8. help
  9. Color option on moulding
  10. fuel injectors
  11. rear seat delete??
  12. KVR CD or Slotted Rotor Super Sale!
  13. changed motor in my 87 and now it wont start.
  14. No start
  15. need help from the 5.0 boys
  16. one hell of a burnout
  17. 2.73 or 3.08?
  18. woooo my trans came today so excited
  19. *Update* Re-torque lower intake bolts? *Update*
  20. Subframe Connectors
  21. Whats the best motor swap?
  22. What do i have?
  23. Won't turn over...
  24. Cleaning TB ?
  25. Weird Loud Sound
  26. 347 ?
  27. what to look for without touching?
  28. Heater and a sweet smell
  29. OD band screwed up?
  30. need opinions please
  31. 429Cobra Jet swap
  32. heater core
  33. SS454 vs 5L with bolt ons
  34. Are In-Line Pumps Noisy?
  35. How much weight does an aluminum block save? and more cubes?
  36. Speed Density Driveability problem
  37. Which gauge series do you run?
  38. 5.0 engine swap
  39. funny clutch
  40. Well Im moving..
  41. tps voltage screwy
  42. Explorer swap
  43. Suspension/Wheels
  44. mass air question. junkyard
  45. I NEED HELP I AM STUMPED??????
  46. Q 4 All Those Who Have Done Wire Hidding.....
  47. 93 MUSTANG PROBLEMS
  48. 1200 watt Subs
  49. Used T-5
  50. Seat Belt Fitment Question 93 in an 88
  51. What do the pro's here think this equals?
  52. looking for a block to build a motor with
  53. North Carolina area!
  54. This Is Why I Drive A Ford!!!
  55. chicago area shops
  56. 5.0 Cardomains!
  57. right bank running rich
  58. headlight question
  59. 10.2 second cobra video
  60. rice burn video
  61. Oil Pan Gasket
  62. gears
  63. Crashed today...
  64. 4.10 Question
  65. almost hit a telephone pole
  66. what do you guys think
  67. what cat-back?
  68. DMV $hi* help
  69. need some advice for a neb for this stang
  70. Negatives of running w/o a thermostat?
  71. anybody know an authorized 5.0 slp dealer?
  72. So our page is up!!!
  73. harmonic balancer
  74. Why do my 1/4 times suck so badly?
  75. price on h-pipe install?
  76. what ya think about this 93 cobra ??
  77. where is neutral safety switch??
  78. Junkyard
  79. stock exhaust
  80. what to do with the stock parts
  81. CHP problems
  82. Seat Covers.....
  83. converting to mass air
  84. Weld BackSpacing
  85. What size throttle body will work better with an Edelbrock Performer RPM 2 upper and lower intake?
  86. paint for the fox
  87. how about remote start check this out
  88. 1995'S(COBRA'S?) WHEEL FITMENT
  89. CHEAP TOPS
  90. Is it worth waiting for a 92 and down with forged pistons?
  91. 2 front clip holders on sunroof
  92. Proform roller rockers
  93. Smog pump replacement?
  94. healp!! tire size ????
  95. no more gay maplight
  96. so GD frustrated with myself!!!!
  97. is there an import out there that can touch a stock 5.0 ?
  98. why do imports get 15 mpg and run 16's ??
  99. 351W EFI
  100. current picture
  101. Why do mustangs only race in straight lines!?!??!???
  102. Why do domestic cars always kick my ass
  103. simple balancer question
  104. I DISLIKE PRO50SC
  105. Taillights on a GT, LX or GT
  106. tach mounted.
  107. Performance Automatic V/B
  108. Hood ?
  109. $350 for a 351, good price?
  110. need help fast about nitrous
  111. Need some opinions
  112. info
  113. which weighs more??
  114. threw a connecting rod today
  115. engine light/code problems
  116. exhaust pipe broke off!
  117. Got rid of the 98 GT. Now it's back to the 5.0
  118. Explore stuff
  119. Cam Suggestion
  120. driveshaft help
  121. gear oil
  122. I've been doing a little thinking
  123. PLEASE HELP..KEY STUCK IN IGNITION!!
  124. Viper Alarm
  125. clutch pedal assembly?
  126. trickflow upper and lower intake
  127. Slower than ever?
  128. need some help
  129. SPEC stage 2...
  130. sweet!!! no emissions!!!
  131. torque question
  132. stuck!! my car needs your help
  133. quick cat question
  134. got off my butt and cleaned up my ole fox...
  135. 85 GT Single To Dual Exhaust ??
  136. 4AN Fuel Line?
  137. paint
  138. Machining...
  139. help me identify this noise..with video
  140. Upholstery Q....
  141. Converting my 5.0(dunno if this belongs here)
  142. loudest catback?
  143. MUSCLEHEADS....spend my money!!
  144. 89 block vs 88 block
  145. 94 stock fuel rails tfs manifold
  146. Is this right???
  147. Rear End Girdle
  148. 88 gt wont go in time
  149. Finally got my clutch in!!!
  150. performance estimate?
  151. 5 lug guys...
  152. 94 GT question..
  153. 1966 FORD MUSTANG RESTORED 5.0 COBRA MOTOR
  154. Another Head thread
  155. Mass Air Conversion???
  156. Is there different styles in stock interior for the foxbodies?
  157. How to identify Heads/Motor?
  158. Stock Height
  159. 93 mustang problems
  160. sent her to the shop
  161. 306 idle and missing issues
  162. power setup
  163. Please Help!!!!!
  164. subframe connectors
  165. is this a good deal?
  166. Cant Pass 3k Rpm
  167. Good Deal?
  168. I raced a Ford GT
  169. What should i do next?
  170. water leak
  171. about to blow my head off...
  172. painting interior
  173. suspension
  174. lightning heads
  175. gt40 head price?
  176. would i be stupid to start modding a vert
  177. GT-40 Intake
  178. egr removal...
  179. Crazy Fan Noise
  180. Drag Tires
  181. Accelerator Pump
  182. which trans to get?
  183. 2 front suspension questions/
  184. stroker
  185. cervinis
  186. the stang likes to buck
  187. stang box installed pics
  188. emissions in texas
  189. nitrous and supercharger
  190. subframe install
  191. intake manifold question
  192. UPR products
  193. headlight spray
  194. Vinyl/carpet DYE
  195. i need some advice asap
  196. Ford Short Block
  197. sn95 vs fox
  198. omg.
  199. Vacuum leak??
  200. hey all!!.....got pics of my stang finally
  201. new track runs after suspension upgrades
  202. bought me a virgin 95 Gt Conv, want more power
  203. Best cleaning method???
  204. found some pictures of my junk.
  205. 95 stang opinion
  206. WFC10 in Indianapolis
  207. X pipe
  208. 84 fog light bar
  209. steering wheel adapter for 87
  210. world class t5 ?
  211. Quad Shocks ???
  212. AODE to C4
  213. Fuel injected to carb swap
  214. help me and my 88 5.0, please
  215. TRANNY HELP!!!!!!!
  216. Need some help guys.
  217. Who will have a superchager?
  218. Mustangs holding value
  219. Is my transmission goin bad?
  220. head gasket leaking only under pressure?
  221. G-Force T-5
  222. Any LEAK experts ?
  223. ENGINE PROBLEMS PLEASE HELP!!
  224. install issue w/rebuilt AOD need help
  225. help A.S.A.P ?
  226. What us this suspension part?
  227. i know why the PS pump is so loud
  228. Ram Air / Cowl Hoods
  229. ARGGG! Balancer/ Cam Degreeing Question
  230. anyone in ohio with a 5.0 engine for sale thats cheap
  231. Car Stalls when putting it in gear? please help
  232. I got 5K to spend over the next 6 months (PICS)...
  233. 28 spline spider gears
  234. FRPP 351W or dart???
  235. throttle body and EGR swap
  236. new differential
  237. Which intake manifold?
  238. Does Anybody Know???
  239. Cowl Hoods
  240. Tranny swap?
  241. what cam to run
  242. windshield wipers not variable...
  243. t-5 trouble
  244. prochamber?
  245. What's the deal with cork?
  246. aluminum head advice
  247. quick thermostat ?
  248. rear end
  249. RPM's ques??
  250. cutting floor
