PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 [182] 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Damn.... got more rust than I expected...
  2. Pics of my Ride!
  3. Another In-Line Fuel Pump Question
  4. what do i need to know
  5. Any Moment now...
  6. What do you think?
  7. help regarding kill switch
  8. luminics pure blue headlights
  9. Rate my 1989 GT Please
  10. '94 MAF Question
  11. Stock 5.0 Long Block
  12. Yea
  13. Question about damaged floor in fox
  14. please help me... very much appreciated
  15. gauge
  16. spare tire and jack
  17. 245/45/17 with c springs?
  18. Tokico Shocks
  19. 255/70/15s On My Wheels....
  20. 4th gear gets stuck HELP!
  21. Holy crap thats bad
  22. Speedometer Cable
  23. stereo kits?
  24. I don't feel the power
  25. Black!
  26. Gone and searching...
  27. Can Someone Help me...
  28. Anyone here running either one of these combos?
  29. 4 Banger!
  30. Shock question
  31. headlights stopped working
  32. Happy New Year
  33. roll cage question
  34. Fender/front clip alignment....
  35. Cheap decent shortblock or crate motors
  36. help please
  37. 50resto
  38. fuel sending unit wiring
  39. roller rockers?
  40. Interia switch?
  41. Vacuum leak running lean??
  42. What you think of this Notch
  43. to build or not
  44. What do you all think of these?
  45. SN-95 alt bracket???
  46. how??
  47. power steering?
  48. need a rebuild kit for a t5 tranny.
  49. What is a "core" and "core charge"?
  50. stang box
  51. Intakes
  52. Aftermarket steering wheel
  53. 94 Cobra-125k miles, stock
  54. looming smoke from exhaust?
  55. anyone here have to repair torque boxes yet
  56. Just a question
  57. 1/8 mile track races
  58. just installed my tri ax
  59. starting issues
  60. dyna matt? i can't remember the name...
  61. 1968 289 Engine Question
  62. supercharger boost for stock motor
  63. how do you bypass ac 92 vert!! help
  64. another stang to see
  65. Near stock combo
  66. good combination of heads and manifold?
  67. What do I need to reach 12's on my 94 gt conv.
  68. Glass Pack Bottles
  69. a/c compressor troubles
  70. Wiper cowl question?
  71. does this H/C/I set up sound okay?
  72. Trying to get started. Need some suggestions.....
  73. 351 drivetain and handling questions
  74. Roush 427
  75. does anybody know how many...
  76. My tires
  77. Steel Hood
  78. Loud Squeling after new clutch install
  79. Suspension
  80. 1984 mustang
  81. Pulling Rear
  82. Dead Speedo, where to start?
  83. SN95 1piece headlights
  84. lengthening the engine bay wires
  85. Hell Ya!
  86. Smoke Rear Lights?
  87. Help with pulley noise
  88. what kind of valve springs to get?
  89. my rear seat delete *pics*
  90. New Guy Needs Help With Carfax
  91. More Top ????
  92. converting to black interior
  93. My car was in Hong Kong!
  94. help me spend my $$$
  95. 5.0 5sp question?
  96. 76mm mass air meter, what size throttle body?
  97. Possible rear end problems
  98. Don't think this is a repost
  99. fuel pump question, please help the dumb newbie
  100. No mufflers
  101. need help with 88 gt mass air swap
  102. Hangers
  103. Waterneck
  104. Post pictures here of torn up torque boxes...
  105. help
  106. Actron compression tester
  107. scary happenings...
  108. quick question about cobra bumpers!!!
  109. deleting a/c and smog safe???
  110. a/c delete help
  111. gauge cluster voltage regulator
  112. coilovers squeal
  113. radio install
  114. HELP!!!! HELP!!!!
  115. turbo coupe rear installed
  116. ring and pinion ?
  117. Mac Prochamber
  118. The diff in a MAS and a MAF?
  119. transmission
  120. Problem with the heater...please help
  121. Vert Top Question
  122. What mass air meter do you order for 5L GT40 motor?
  123. What are your thoughts on these rims on a Black 95SN
  124. does running rich always give black smoke?
  125. another oil leak question
  126. My hatch doesnt latch - Is this a normal problem???
  127. My heater Core/Speedo mech or Electric/top/and many other questions thread
  128. 83 and 93 fender question
  129. 331 build in planning...
  130. Idle Issue
  131. Weiand Superchargers?
  132. any one has some cobra R's and want to get rid of e'm
  133. what are the odd's
  134. 1993 Mustang GT Tire Questions
  135. coil spring rate
  136. First Fox
  137. gas mileage and other specs for the GT..
  138. which plugs for supercharged car?
  139. how much would u pay ona 90 model with 14k miles
  140. 250amp alternator?
  141. rear diff ring and pinion
  142. Story On Weld Racing?
  143. d THE CAMZILLA
  144. crate motors
  145. should i get a 87 or 90 modle?
  146. New Stang...
  147. BAD FEEL AND SOUND(updated)
  148. Just got it running....again (pics)
  149. side exhaust
  150. Trans Brake.
  151. codes for turbo coupe rearend
  152. need advise
  153. What to do next???
  154. Hooker headers
  155. 95 gt supercharger
  156. Quick question about 95 3000GT SL vs 89 GT
  157. Just curious
  158. head question?!
  159. More goodies for Project 1992 Coupe
  160. bassani for 5.0s?
  161. Stang now in my drive! Got Carfax???? W/pics
  162. cobra intake
  163. should i get rid of
  164. pcv valve
  165. Manual rack install
  166. off topic
  167. my 86 notch
  168. low volts
  169. 88 lx hatchback help needed!
  170. My friend just bought a new car.. check this out
  171. Long Block
  172. SHOCKS ANYONE
  173. Trickflow elbow for sn95 ????
  174. free sluts
  175. torque converter
  176. Ohh yeah!
  177. steering shaft hitting headers
  178. Air Intake Question
  179. worth $5000?? 92 LX
  180. big block?
  181. DAMMNIT!
  182. exhaust
  183. Someone please explain the brake proportioning valve
  184. weird fuel pressure
  185. converting to mass air?
  186. Bad Jerkin' Question
  187. Seat Belts Don't Seem to Retract - Questions
  188. 302 or HO?
  189. 90 GT Front Bumper Rivets..Help
  190. Help needed, '95 5.0 A/C repair
  191. crazy question
  192. 18 x 10
  193. LOL @ ebay , cheap cobra intake
  194. Need help finding a new part.
  195. porting upper intake?
  196. If your fox is lowered and rubbing read this....
  197. check this stang out!!!!
  198. anyone have problems with torque boxes cracking yet?
  199. Do you prefer an Auto or a Manual Transmission?
  200. videos of my stang
  201. !!I Need How To For Valve Rocker/Valve Adjustment!!
  202. not cranking??
  203. Here's how you cool rice
  204. What suspension is everyone running
  205. what do you guys think of these headers ?
  206. No More Mods For The 5.0!
  207. dream handeling
  208. Play in the Tilt steering
  209. Would this work ?
  210. New 351W Motor has antifreeze in oil
  211. spacers ?
  212. auto to t-5 with engine swap
  213. Got some questions about some wheels
  214. new seats install
  215. 351 BLOCK...WHICH ONE???
  216. if you could change 1 thing?
  217. Body Rivets
  218. Installing Gauges
  219. 5.4L question
  220. Newb. steering problem
  221. Sell this 84 5.0 GLX convertible or not? Help!
  222. 60mm 70mm ???
  223. 5.0 explorer motor
  224. king cobra clutch or not..help
  225. Next step in Project 1992 coupe
  226. Hello all. Got a question.
  227. which is better Mac or BBK ?
  228. fuse box layout
  229. Rear upper/lower Control Arms ?'s
  230. Mac Exhaust
  231. dss
  232. '07 wheels
  233. Better brakes
  234. how to delete smog pump ?
  235. 351w first run (video)
  236. How many HP ?
  237. another new setup
  238. rear shock question?
  239. best way for 350whp
  240. Guys, thinking of buying this 1994 Cobra, Yes or No?
  241. Just lowered the stang.
  242. result of my stolen car
  243. Degreeing cam help
  244. bogart wheels??
  245. Fuel Filter Location?
  246. Engine questions.
  247. electrical??
  248. New Explorer GT-40 intake question
  249. interior resto
  250. Powerdyne Question
