PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 [140] 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. tuner for 95 gt
  2. GT40 Head question?
  3. which bondo is the best
  4. O-ring Bushings between head and block
  5. Is my tach crap or the car.
  6. swirling coolant
  7. fuel system
  8. Need Help!
  9. noise concern
  10. 1988 Mustang GT Pricing Info
  11. stock sway bar diameter?
  12. Need anyone who uses Astro Performance to look here>>>>>
  13. big block swap
  14. need input
  15. Horizontal shock; scientific name?
  16. Pics of your 1.5" cowl hood
  17. Coupe and hatch rear seats interchangeable?
  18. Definately the fuel pump?
  19. flowmaster 44s
  20. 94 GT
  21. Removing grille and ground effects
  22. 4valve 302?
  23. h/c/i question
  24. ENGINE OIL
  25. 7up mustang
  26. New too Mustangs
  27. 50resto?
  28. Fuel pump size
  29. i wanna see proof
  30. POST WHORE PICS...PROGRESS ON THE BANGED UP 86GT
  31. So check this out... AC
  32. shifting peak?
  33. Special Edition?
  34. Money to spend
  35. front sway bar bracket broke! (now with pictures)
  36. Carb Question
  37. headlights and fog lights
  38. Biggest Cam?????
  39. Question.
  40. Stock Mufflers
  41. fender braces?
  42. cam question
  43. UGM 1994-2004 Saleen Stainless Scuff Door Plates
  44. gear drive timing set
  45. Engine Build Plans
  46. Low engine coolant light?
  47. Need help
  48. if i didn't have bad luck i wouldn't have any at all
  49. Selling my 89 notch back
  50. overheating problems
  51. stock heads with cam
  52. Build a good 5.0l
  53. EGR question
  54. Exhaust clip
  55. engine bay cleaning
  56. 86 GT Heads???
  57. flowmaster question...
  58. more bodywork on 86gt
  59. Is this to much
  60. pushing the limit of stock 5.0 H.O. block
  61. 95 gt computer questions
  62. 351w for $200 is it worth it??
  63. Pedastal mounst 1.7s
  64. used sc value?
  65. Coilover spring rate????
  66. breaking tires loose at high speeds
  67. Price Check
  68. cam for 1972 351W engine
  69. Wiper Troubles!
  70. Gauges and cd player installed.
  71. I bought a used 3.73 off' evilBay...
  72. let me know what u think of my car !!!!!
  73. cobra intake fast?
  74. HELP!! Lost 5th gear!! What's up!?
  75. ram clutches??
  76. Electric fan conversion causing car to stall
  77. Injector 5.0 vs. 4.6l
  78. New autometer gauges!
  79. 429 in a swap
  80. trick flow roller rocker help please
  81. Injector
  82. Help with 5.0 Ident
  83. timing questions
  84. 5.0 VALVE ADJUSTMENT
  85. volkswagen gti vs stock 5.0
  86. GT ground effect painting
  87. afr
  88. 5.0's in your area
  89. can you put 5 lug rotors on 87-93 spindles
  90. How much abuse does your car take lol.
  91. Adjustable Clutch Cable (Help!)
  92. Is this wrong?
  93. mustang 2-step?
  94. takin care of it once and for all
  95. I need help with my ecu ???
  96. what fuel pump to get?
  97. Exhaust
  98. cost for 5 lug conversion
  99. What kind of sand for my Sand blaster?
  100. Oil pressure problems!1st mustang and need help!
  101. Why isn't reverse sync'd????
  102. Water pump
  103. Started on interior resto
  104. Which sandpaper grit should I use
  105. check out this 89
  106. 88 GT How do i change the Mounts.
  107. Starting Problem
  108. Mac Performance Spring Blow Out Sale!!!!
  109. tach position
  110. manual
  111. tps problem!
  112. Running 'em hard.
  113. some hesitation
  114. Got mah dumps on
  115. 1988 mustang lx hatch 5.0L question
  116. CantStopTheFox.....?
  117. HOOD CABLES
  118. mass aif flow calibration?
  119. how much oil does YOUR 5.0 burn between 3k
  120. Convertible pump, fill fluid?
  121. Sweeeeet
  122. loud knock
  123. what is the problem with my car guys?
  124. which will be better?
  125. keyless entry
  126. where to start my road to a supercharger?
  127. I need some help finding some wires.
  128. New dash opinions?
  129. engine question
  130. yellow injectors
  131. interior dash lights
  132. starter problem
  133. 86 gt question
  134. rom test failure
  135. Any Mechanics In Virginia?
  136. i think my car is running rich...
  137. Throttle body
  138. suggestions?
  139. Computer Chip Question
  140. my car's is paint
  141. green wire tach???
  142. Tach issue, need some advise
  143. cervinis stalker
  144. does this really work?
  145. gauge cluster
  146. Kinda Funny Steering Wheel Question
  147. Is $250 worth if for a later roller 5.0L Exploder? What do the casting lines mean???
  148. Stupid blinkers
  149. SSDD Oil Pump
  150. Nitrous...for show?
  151. I SWEAR SYNTHETIC OIL CAUSE PROBLEMS
  152. 95' Stang front clip images??
  153. First question is.....
  154. afrs wih a flat tappet???
  155. clutch install problem
  156. stupid maf question
  157. HELP
  158. long sleeved or short sleeved
  159. SVO brakes?
  160. 86 lx rear
  161. where can i find these!
  162. t-stat Issue?
  163. alternator
  164. found out my speedo is off 10mph
  165. belts
  166. MAF cleaning?
  167. KB VS Procharger
  168. what website..??
  169. Do all 5.0s blow headgaskets eventually?
  170. Holley SystaMax Intake & TFS Trackheat heads
  171. Headgasket?
  172. Intake
  173. Explorer heads and headers
  174. Dyno #'s.
  175. twisted wedge
  176. Catch Can/Expansion Tank
  177. terrable idle (video)
  178. 351 from truck?
  179. Big Day...
  180. OMG, FINISHED my cam swap!!!
  181. Saleen Graphics
  182. Headlights ( sorry)
  183. PLEASE post pics of coolant catch cans
  184. What have I forgotten??
  185. Should he buy it????
  186. 4 cyl springs?
  187. Upgrading help.......
  188. Cruise control
  189. Cars A Dog
  190. '85 Boss?
  191. Vacuum Gauge
  192. waxed and ready to go (pics)
  193. How does this combo sound???
  194. new clutch
  195. ACCEL ignition control modules
  196. Finally got in
  197. SCT MAF or a standard MAF for tune?
  198. Can't get car to rev!!!
  199. Looking to buy a 1995ish GT
  200. what up? engine problem
  201. how much lift can
  202. *Engine won't run right after head install....PLEASE HELP!!!*
  203. 5.0 Power????
  204. Headlights restored, washed and waxed PICS
  205. will kirban fpr clear the egr on a fox
  206. 88 GT Rear end. Decode Please.L73A887K08
  207. UPR rear control arms. Any good?
  208. MSD 6AL??
  209. fuel pressure?
  210. SUB FRAME & TACH COMING TOMORROW!
  211. 1/4 times with horsepower #'s
  212. my Speedo cluster?
  213. Need Some Help & Opinion!!!!!!!! 85 lx 5.0
  214. Which carburetor is best?
  215. Turbocharger vs Supercharger
  216. BIG OPINION???????
  217. Clear coat and/or Repolishing
  218. just raced 2 sport bikes with my new motor!!
  219. taking the tranny apart
  220. GT 40 P Heads?
  221. engine rebuild ?
  222. Switched hatches last nite
  223. NEW 5.0 OWNER
  224. crash damage fixed........
  225. Aluminum flywheel
  226. kb or suspension
  227. 351 heads onto my 91 5.0
  228. pistonto valve clearance??
  229. No more emissions testing for under 1995 in Illinois!
  230. fmu
  231. explorer motor
  232. i took a dump
  233. what EXACTLY causes these trannys to grenade?
  234. alternator question
  235. front 5 lug conversion
  236. MSD Starter Saver
  237. What should i do with this car, for a cheap temporary fix? (paint)
  238. 1988 swap possibilities
  239. What's Next?
  240. help
  241. air con field coil
  242. if was to sell my car
  243. new hood
  244. My new ride PICS
  245. my project car(progress pics)
  246. Alternators at Advanced?
  247. clutch
  248. o2 sensors
  249. throttle sticking
  250. bbk cai cleaning
