PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 [289] 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. 5.0. rebuild
  2. New Autolite plugs
  3. 347 stroker kit
  4. Engine swapp pics before and after (if anyone cares to look)
  5. why would my engine knock from an intake gasket repair?
  6. hollow cats, how to?
  7. whats it cost to have the trans rebuilt?
  8. Best bolt ons with a SOTP difference?
  9. 1994 Cobra VS. GT performance differnces
  10. Common fuel/vaccum Problem .???
  11. oil pressure question
  12. Help! firing order
  13. Fuel sending unit swap
  14. GT 5.0 Convertible won't start.
  15. Well, I thought it would be faster
  16. Building Engine help
  17. Stock intake silencer??
  18. egr delete.
  19. Fuel Pump
  20. Guess what i just did
  21. 5.0L HO swap
  22. ignition sticking
  23. Seatbelt Chime
  24. BEST CLUTCHES?
  25. 1982 Mustang GT Bumper COVERS!!
  26. '93 COBRA INTAKE
  27. Problems after compression test
  28. Choosing Throttle Body
  29. Engine rolls over but will not fire, 306 new replacement engine.
  30. First time to the strip with the stang... *detailed*
  31. WENT TO THE TRACK!!!!!!
  32. Just got a 1990
  33. Wierd squeeking noise
  34. I need advice on what to do next...
  35. bouncy idle
  36. good combo? intake/cam
  37. Timing question on an 88 Gt?
  38. A/C clutch removal?
  39. Wat kinda intake?
  40. next up..which cam?
  41. Pictures of Progress...(If anyone cares)
  42. 408 stroker question
  43. Supercharger, Wise choice?
  44. Loudest exhaust?
  45. Some new parts for me...
  46. Wiring a Coil in a 83 5.0 carberated?
  47. aode swap and crank
  48. Kenne Bell for a 93.
  49. fox 5.0 h-pipe the same as 94-95 gt?
  50. How Fast is this Techies
  51. What comes with a pro5.0 shifter?
  52. Can someone please help!!!
  53. 3rd made me look like a fool tonight....
  54. hard time starting sometimes
  55. fuse help!
  56. bolts for shifter
  57. Breaking in Clutch
  58. WHICH SPARK PLUGS????????
  59. Idle Problem
  60. 1/4 mile E.Ts? on 88 GT
  61. 331 vs. 347
  62. transmission question
  63. Tune-up and drivability questions for 1995 Mustang GT 5.0
  64. might become part of the 50 family
  65. Quick question
  66. Rims and Tires for Drags
  67. 5.0 RPMS HANGING AT LIKE 3K
  68. Need some 5.0 Advice
  69. car runs Horrible!!`
  70. Hard to shift! Clutch adjustment?
  71. cam idleing problems....
  72. my 5.0
  73. Dash wiring harness replacement
  74. Mustang powered Volvo Wagon. 65mm Throttle body?
  75. AOD Gear?
  76. How much grease in universal joint?
  77. Clutch/Flywheel Advise
  78. throttle body?
  79. car shuts off?
  80. For a good time call
  81. Cold air intake vs short ram
  82. turbonator???????????????????????
  83. rear brake conversion
  84. 1993 5.0 Swap To 1989 4 cylinder body??? New here
  85. Exaust
  86. Brakes
  87. could I get a decent 5.O for under $3000?
  88. 8.8 rearend????????
  89. how hard is it to put in a new clutch??
  90. transmission
  91. 5.0 Overheating
  92. 5.0 rear
  93. New axles??
  94. Clutch Quadrant ?
  95. Cam HELP?
  96. Scanners can't read any signal O_o
  97. got a mass air meter.... need help...
  98. Best cat-back for a 94-95 5.0
  99. common causes for battery drainage?
  100. Which Tranny is stronger
  101. maf size?
  102. converting a v6 car to a v8
  103. Got the Car Fixed and Added New Parts
  104. 95 5.0 swap problems: Gauge cluster, Exhaust
  105. ProForm Shifter
  106. Carb/Intake
  107. does any other fox body style drive feel this way?
  108. Air silencer question...
  109. Factory Alarm 1995 GT
  110. thinking of going supercharged
  111. stock Automatic gears.
  112. intercooled supercharger
  113. distributor
  114. New engine problem!!!!
  115. need help on 1988 Mustang GT Just bought.
  116. cutting out
  117. What exhaust should i use
  118. waterpump bolts
  119. hot cooling!!
  120. finally broke into the 13's
  121. cold air?
  122. Fuel pressure on stock motor with 190 pump
  123. to rich
  124. Fuel pump... Holley or BBK (190lph)
  125. Explorer INTAKE help
  126. 3:73 gear questions
  127. Just saw 315s on the rear of a fox
  128. deep tranny pan?
  129. water pump hose problem!
  130. 5.0 Engine flooding?
  131. looking into a hydraulic clutch..
  132. High Idle Problem
  133. which gear w/supercharger
  134. over rev
  135. injector size????????????????
  136. throttle cable bracket problem!
  137. sound right ??
  138. Header Install Question
  139. 3.73s
  140. Head/Intake Poll
  141. Camshaft question
  142. bolting on 2.5" to 2.25"???
  143. problems with C4 trans
  144. need advice on a 5.0 witha carb
  145. Problems with maxing out the 85mph speedo on trip odom?
  146. 89' Mustang GT Problem
  147. rocker arm advice
  148. No fuel to motor?????
  149. your opinions
  150. need mustang door moldings
  151. need more power for my mustang
  152. need advice on how to put more power in my mustang
  153. PISTONS
  154. s/c port on vacuum tree
  155. suspension mods....
  156. power package?
  157. girdle what torque
  158. 97 NHRA mustang
  159. Black Saleen Wheels
  160. difference between a 87-93 GT and regular 5.0
  161. My first 1/4 mile run
  162. SN95 ele. fan on 87-93 5.0
  163. Horsepower
  164. What does bassani exhaust sound like on a 5.0?
  165. Buying GT
  166. v10 fox?!?!?!
  167. 160 Thermostat
  168. Rear louvers
  169. vacuum to MAP sensor
  170. 95 gear ratio??
  171. Clutch Noise
  172. manual to automatic ?
  173. 2:73 to 3:73..gear install overrated!
  174. starter
  175. Any HP gains if I have hollow out my converters?
  176. Is the Smog and AC delete worth the HP, if any?
  177. Question about Water under the hood
  178. TIRES?
  179. runs like crap
  180. need a trak lock, 3:73 gears, and a master rebuild kit for a 94 mustang 5.0 for cheap!!
  181. Turbo or Supercharger
  182. Predictions
  183. cant brake-stand!
  184. engine rattling
  185. HELP, b&m shifter
  186. where do I look for a shorter belt?
  187. valve covers...
  188. Do 94-95 mustangs have 28 spline rear axels or 31 spline?
  189. Part wanted
  190. Can I bypass some components?
  191. Im sooo P*ssed off!!
  192. 94 Mustang Misfire HELP
  193. rear end questions
  194. Auto Tranny
  195. cheap aluminum radiator
  196. Overheating, need help!
  197. mustang 5.0 in newer f150?
  198. Short Throw Shifter?
  199. need help asap
  200. truck efi lower
  201. Pick a number!!!
  202. big,big problem!!
  203. Big and Littles on a 5.0 Cobra
  204. need a good place for motor
  205. Torque Link
  206. What would you get X or H pipe???
  207. Sticky throttle...help
  208. Power loss when switching A/C Off
  209. Dang Beeping from dash area...
  210. '86-'93 interior question
  211. Fox Body?
  212. 302 5.0L gears?
  213. Car is better and a ? or 2
  214. newer updated cams...
  215. can't stay cool
  216. 87 5.0 Motor into an 82GT
  217. woohoo, i passed california emissions.
  218. What do you think my horsepower is
  219. lsc rear in a stang help..asap
  220. motor mod progress pics
  221. Thinking of getting a 94-95 GT
  222. 1986 and older 5.0s w/GT40 heads
  223. 94-95 5.0 rear end
  224. 95 cobra
  225. distributor
  226. couple of newbie ???'s
  227. Cleaning the TB
  228. 1/4 mile times
  229. Superchip
  230. can I run a 70mm tb?
  231. nova
  232. Best way to ship an engine?
  233. Air Sliencer
  234. 89, 5.0L Mustang LX, 23,000kms
  235. Rear End Rebuild Help
  236. 5.0 engine instalation?
  237. Need a non a/c power steering bracket
  238. Gasket Seal Help
  239. BIG suspension problem!
  240. Tires
  241. From Camaro to Mustang
  242. What does the tranny governer do?
  243. Its official-- just sealed the deal on the '89 GT 'vert! Pics!
  244. Engine Re-Build
  245. Is a 5.0 faster than a 4.6 Stock?
  246. no horn
  247. baking inside my car help with fans!
  248. Heart shaped combustion chamber?
  249. Ford racing cat backs?
  250. head swap
