PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 [230] 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. overheating issues
  2. Suspension Kit...which one to get!?
  3. I'm about to order a set of deep dish Bullitts & tires for my '94 GT. Few Q's???
  4. tips on getting collectors to seal
  5. Welding Torque Boxes??
  6. header fitment 85 LX
  7. Hatch or Trunk?
  8. New 302 Block
  9. 3.73 gear install kit
  10. Convertible Luggage Rack
  11. platinum vs regular plugs
  12. Running with no mass air or density...
  13. What air cleaner will fit a stock 85 carb?
  14. window problem
  15. header gasket
  16. Forged 347 Stroker Kit?
  17. how much tranny and rear end fluid?
  18. quad shocks n upers/lowers
  19. Quick question
  20. a lil info on vacum gauge reading
  21. hey there, quick question! new here
  22. Header installation- making me crazy
  23. High speed sound
  24. throwout bearing??
  25. Someone has got 2 know!!
  26. would this fix it
  27. How much for a paint job?
  28. Cold Air Intake!
  29. would this be a good motor to buy?
  30. Best stroker 331 vs. 347
  31. EFI 5.0 In a Classic
  32. 4cyl to v8 swap
  33. Grind/Rattle in the Engine
  34. 03 cobra calipers in fox?
  35. Hood struts ?? who's got em
  36. MOVED: Kenne Bell supercharger question
  37. is this a good setup
  38. anyone have pics of installed sub frame connectors?
  39. How do you get the F*****G lock actuator out???
  40. painted car. ( updated pics as promised!)
  41. t-5 trans id
  42. Pinks Weds. night
  43. rebuilding heads?
  44. ? about 302 block
  45. Going to need a tach and shiftlight soon!
  46. Need help for 95 gt
  47. A/C Help Quick!
  48. heads and cam?
  49. Roller Rockers?
  50. Fuel sending unit
  51. $1000 Bonus
  52. quick block question.
  53. Need some help. Top end issues.
  54. ADVICE
  55. Smell from exhaust
  56. Max Horsepower
  57. Max Horsepower
  58. ok im going to put a bulletin it.
  59. cog pulleys on a vortech
  60. Edelbrock upper ?
  61. Fianlly...pics of my new '92
  62. Best heads for S/C 14psi????
  63. pro mustang efi manifold
  64. Shift Kit install
  65. strange ignition problem
  66. need help buying an exhaust
  67. advice on a 1986 mustang gt
  68. How Old Is My Engine?
  69. cam
  70. Granatelli MAF
  71. 3g altanator clearence for my Fox 5.0
  72. 92 idle issue
  73. Does wax protect from the sun?
  74. rebuild
  75. Bad Vibration
  76. hatch cover wont friggin fit
  77. Afr 165's or 6psi s/c?
  78. Rear disc brake swap from Cobra
  79. Can someone help me?
  80. ok, I'm honestly stuck
  81. Roller rockers
  82. Why do I like this car so much?
  83. aod rebuild kit
  84. Noob question
  85. Anybody have a Performance Automatic Super Streeter AOD?
  86. OFF ROAD BASSANI X PIPE FOR SALE!!
  87. In Cabin Fuel Pressure Gauge
  88. hp guessing game
  89. stock hp/tq
  90. To buy or not to buy...
  91. I NEED parts. Window motor, Tranny speedometer gear, quad shocks
  92. 5-lug Conversion???
  93. shocks..springs
  94. fuel sender
  95. Delete me!
  96. stuck tv valve?
  97. Hesitating
  98. tunning tips please.
  99. quarter windows
  100. GF loves me... lol
  101. Send me your stang pics
  102. victors jrs
  103. fuel tank fuel line question
  104. Electrical help needed ASAP
  105. Rear Seat Belt routing?
  106. Spring Rate
  107. MOVED: Blower question ?
  108. Idle air control question
  109. Rear stands
  110. water pump
  111. off topic: best mustang/5.0 tattoo
  112. good deal? should i buy?
  113. eratic tach
  114. ha got permission
  115. Dyno on Tuesday, Any Guesses?????
  116. 89 GT VS 87 LX
  117. how much $$$ to get heads tested for cracks?
  118. Anybody have this kit on their car?
  119. how to tell leaning?
  120. carfax....
  121. VIBRATION!!!
  122. heads/cam/intake question
  123. Shakey clutch
  124. How the **** do you pull off the crankshaft pulley!?!?
  125. Looking to buy some new springs for my car
  126. Question about summit
  127. heads question
  128. Car Noises!!!!!!!!
  129. MOVED: N2O Line routing...
  130. sh*t i hate cars
  131. electric fan HELP!!! PLEAZE
  132. Smog Pump
  133. Lentech VB???
  134. stock or not
  135. fuel pressure regulator
  136. 1.6 or 1.7 rockers
  137. INSTALLING NOW! NEED HELP!!
  138. Do my rims look better?
  139. 92 idle problems
  140. 10.5 inch rear wheels
  141. Thinking about buying an 06GT YEA or NAY?
  142. Rockers?
  143. ?'s on Alternators
  144. Car won't crank please help
  145. 8.8 rear end gears
  146. white face gauges
  147. best short throw shifter
  148. wierd noise
  149. Location of BYPASS VALVE?
  150. flywheel?
  151. WOHOO THE SHAKE IS GONE
  152. Overheating problem
  153. Control arms
  154. 93 coupe for sale
  155. Afr ques..
  156. How the f@#* Do I get the belt Off
  157. 289 parts?
  158. Will '96 up style tail lights fit on '94/'95's directly?
  159. New guy..with a few questions...:)
  160. **Drag radials**
  161. will this cam and head combo work
  162. Tough to get out of 2nd
  163. need some price opinions
  164. 5 Lug rear disk brakes
  165. EFI to CARB on an AUTO 5.0
  166. 5 Lug rear disk brakes
  167. got 6500 for motor, 408 or 347
  168. Will rear cobra bumper fit on GT??
  169. HEELLLPP PLEASE!!!!!
  170. Valve question
  171. 93 GT Vert
  172. fuel pump?
  173. The day the engine died...
  174. oil pan + gasket
  175. Vortech Supercharger? Good deal for a 302?
  176. Tranny Advice!
  177. REALLY GOOD DEAL
  178. Typhoon intake
  179. Destroyed bushing
  180. '87 LX Notch $400
  181. Leaking injectors!
  182. lx taillights
  183. Header gasket question- install in the morning!
  184. need help fast
  185. transmission...?
  186. TEMP
  187. 5 grand buget build Pics!!!!!!!!
  188. Quetion on '84 'Stang
  189. To those whom remember
  190. What should I do next?
  191. convertible interior
  192. MOVED: 88 GT convertible
  193. meed help on a good electric fangood flow#s
  194. fueltank?
  195. Recommended Mods to a stock 95 GT Convertible?
  196. exhaust
  197. Traction locks ????
  198. Procedure for A/C Recharge
  199. cowl hood
  200. How do I find out information on my 5.0 engine?
  201. REAREND NOISE...NEED HELP
  202. need help on brakes
  203. 5.0/AOD Questions ( My First 5.0 )
  204. Lets play pick a cam shaft...
  205. 4 cyl springs on a v8
  206. Speedo gear
  207. FINALLY GOT MY STARTER IN!!
  208. what price should I ask for exhaust sys.?
  209. car wouldnt start today.....ignition??
  210. eBay Seats? Anyone have these?
  211. ..the much anticipated pictures
  212. Powerdyne s/c...
  213. Ooooo.. new paint!
  214. Exhaust
  215. Car wont start
  216. What's the width of 94+ GT rearend?
  217. What's the best AODE?
  218. IDELS GREAT BUT DRIVE LIKE CRAP!!
  219. fuel filter
  220. Ebay aluminum heads
  221. cold air intake kit
  222. Biaaaach Azz POS!!!! Get in Here!!!
  223. Not so smooth ride
  224. Transmission
  225. what size tires do i need?
  226. what could be causing this....
  227. Help!!!! I'm Having clutch problems
  228. How do I keep the oil out of my throttle body
  229. AOD Help Needed
  230. Roller Rockers
  231. 95 CAM?
  232. Sig
  233. HELP!!!
  234. compression test
  235. A PIC OF MY CAR...
  236. Will a stock '94 GT's driveshaft fit on a '93?
  237. went 8-0 racing latenite
  238. Another Clutch Question
  239. Funny Fix: valves/engine chattering
  240. Mystery cam
  241. tranny
  242. HELP!!!!! went to the dyno!!!
  243. engine oil dipstick
  244. Water Leak - Driver side - Near the firewall
  245. spark plugs
  246. Aluminum Radiator!!!
  247. 302 Heads
  248. Newbie here w/ A/C question
  249. gt 40 ?
  250. My Spec Clutch
