View Full Version : Classic Mustangs
  1. speaker holes
  2. Heater box (core)
  3. Window (rear) leak
  4. Still cleaning out the basement..
  5. grammar
  6. torque
  7. 427 thread pinned to the top
  8. MOVED: Car alarm with remote entry!!!
  9. Mounting carb to intake
  10. wheels for a 70 fastback
  11. how long until i need to change headers
  12. help idler arm and headers
  13. Capacitor conected to voltage regulator? 68"
  14. Running Horse Valve Covers
  15. SplitFire plugs...any opinions or comments?
  16. 05 Engine and Tranny in 67 coupe
  17. Ron Morris Front Suspension
  18. Pertronix Swap
  19. New Guy - Advise/Opinions
  20. '69 coupe window
  21. Fuel Injection
  22. 65/66 Seats in a 67?
  23. You think your mustang is worth $$$$$
  24. classic mustang?
  25. I think i need a new fender
  26. Brake lights don't work
  27. How to fix an unstable antenna?
  28. Exhaust on a 68 coupe?
  29. Mustang Show In Mustang OK
  30. dumping exhaust
  31. aGas
  32. Mustangs Plus *update*
  33. horsepowder
  34. 65 mustang fuse panel
  35. Cleaning out the basement.
  36. 68 Torino
  37. 67 C4 auto
  38. Quiet Thunder - Muffler Question
  39. Carlisle getting closer! Are you going?
  40. How do you decode 1960's Engine Tags ?
  41. pictures of fuel line
  42. Idle Issue-Please Help
  43. spacers or adapters?
  44. Fuel sending unit with low warning
  45. CAI for Carb?
  46. HP?
  47. linkage?
  48. fuel line replacement???
  49. Front End Alignment - Jacksonville, Fl
  50. Intake manifold choice
  51. Door replacement
  52. Shift kit
  53. I Have Made A Decision
  54. need answers
  55. I want a fastback!
  56. Carroll by day, Frank by night
  57. what production number is my mustang
  58. glass packs
  59. center console for a 68
  60. Now running on *8*....one question
  61. steering problems
  62. RPM's drop
  63. high rpm 289
  64. LA CRUISE DETAILS: Saturday May 12th Galpin Auto Sports
  65. Mario's 1969 Mustang Convertible
  66. Battery Replacement
  67. Kick down cable...
  68. Heads for 68 302???
  69. valve covers
  70. Hydraulic clutch VS Cable clutch
  71. Something funny
  72. Who has posi?
  73. Seats for your stang
  74. 66 coupe, $350
  75. Engine Mounts
  76. is a 1st gen stang a good DD?
  77. need your input on some 67 stang parts!
  78. transmissions
  79. Interior help on the classic?
  80. Stainless VS. OEM steel
  81. Shroud Gap Question
  82. Belt popped off...
  83. This is taking a lot longer than expected
  84. Turn Signal Question
  85. Pulleys
  86. Where's the fill plug on a t-5?
  87. i6 boyd rims in so. cal
  88. happy birthday
  89. engine swap anyone?
  90. How wide??
  91. Media Blasting
  92. Release of the NEW Aluminum 6 cyl Heads
  93. Best Mustang Shows
  94. 2 tubes
  95. Coolant Mixture debate/question
  96. Coolant/Overheating Question
  97. 1970 Mach 1 convert?
  98. Does this rearend seem legitimate/compatible?
  99. replica mustangs
  100. Options for a 289 C-Code air cleaner
  101. whats a power valve do in a carb
  102. gProComp cylinder heads
  103. restored my 2$ plate today
  104. C4 tranmission over flow valve
  105. Replacing vent window weatherstrip
  106. carburetor help 2 barrel holley
  107. Dyno please?
  108. 69 Grande Door Panels
  109. Reverse (tremec 5 spd) please help!
  110. Took her home today
  111. Insurance theft recovery deals.
  112. 1964 FOUR SPEED TRI POWER?
  113. Rear End Gear Oil
  114. Tranny lines....
  115. Transmission Output Seal
  116. 65 Rearend for a 289
  117. Fender flares? Are they needed for bigger tires?
  118. Stalling in driven gears
  119. bunch of little stuff need help finding
  120. How Safe
  121. Royal Purple in Ol' Yeller
  122. pics of my interior
  123. Clutch Cable Help
  124. Safe rotor size
  125. Shelby GT500 Eleanor Convertible
  126. Kicking myself in the butt
  127. C4 transmssion leak.
  128. came across this tonight
  129. Aluminum Vs. Copper
  130. starter prob after oil pan change
  131. Bellhousing
  132. Can you...
  133. Why satin black is recommended for the engine compartment?
  134. Emperor....you selling your car?
  135. My Daddy's new toy!!
  136. 6cyl, are they popular?
  137. drag stuff
  138. Casting numbers
  139. Radiator for my 67
  140. brake trouble
  141. i need some pics please!
  142. Gas cap for 67-68
  143. Looky here what I found!!!
  144. more exhaust issues
  145. anybody need a 289?
  146. yehaaa...MP disc brakes done!
  147. Got them! 40 series Flow / FAQ clip ???
  148. Need roof for 71 mach 1
  149. Fresh nose !
  150. A lot O/T but i can't find the info anywhere else!!
  151. i hear you knocking....
  152. Choke Help...
  153. Need Opinions, Searching for Mustang
  154. Need help getting trunk open on my '65 Mustang
  155. S-10 caliper question
  156. spring compressor
  157. Want a good laugh?
  158. Classic Mustangs in movies
  159. What do you guys think of this Master & Slave Cylinder?
  160. Removing pulleys, cam bolt, timing chain cover
  161. Speedometer Help.....
  162. Turn Signal & Brake Light Issues
  163. FYI Replacing fender aprons
  164. bucking bronco car at low speed
  165. 68 Rear Seat HELP!
  166. Working On Engine Compartment
  167. Fuel Sending Unit
  168. anyone else have problems loggin on?
  169. clutch master cylinders.
  170. Oil Pressure
  171. Flat spot from idle
  172. Restoration
  173. Pinion Seal Removal help.
  174. tire speed rating
  175. HELP 67 289 engine issue
  176. 1966 Mustang gages dont work??help
  177. 66 Coupe Rear Tire Size!!
  178. Which of these two tires would you recommend?
  179. I got another leak...
  180. OK, it's my (other) ride
  181. instead of lead??
  182. Work day with questions
  183. Welding help
  184. manual to power brakes with a 3 speed
  185. Last offer on parts!
  186. efi setup
  187. Few Pics of my car
  188. Oil Synthetic or Conventional
  189. Horn Test 1966
  190. New tranny
  191. Soda Blasting
  192. Removing drip rail moulding W/O special tool
  193. 1965 V8 C4 to 4 Speed Help...So. Cal
  194. New to this
  195. NEED HELP FAST I200
  196. Lower control arm
  197. Stay stock or hot rod? Chime in!
  198. 79 Fuel tank
  199. 69 Fastback question
  200. what size battery do i need ??
  201. Does anyone know what this opening is for?
  202. New to the forum
  203. WHOO HOO I found a 289 crank.... now i need rods LOL
  204. paint stripping
  205. cost of valve job?
  206. new to the forum
  207. Few brake assembly Q's?
  208. quarter windows
  209. seat belts in a 73
  210. '66 Ranchero 9"?-post 12
  211. pics of my baby
  212. Friend in need
  213. 1965, Headers??
  214. Nightmare
  215. really pissed also
  216. Pictures of 1969/1970 Cowl Removed?
  217. VIN history report
  218. craiglist ....great deal for md/va/dc
  219. Breather Cap Q?
  220. Pheonix Muscle Car 302 Crate engine
  221. took her for a spin this evening
  222. Hood Latch
  223. Tech in O/T??
  224. Explorer engine
  225. An offer i can refuse?
  226. where's Thumpin455?
  227. really pissed
  228. wheel tubs
  229. 1973 351C mach1 will not run right after a winter sit...
  230. My speedometer doesn't work after converting from a C4 to a toploader
  231. Another Title question. VIN # on title missing last digit?
  232. junkyard 302 block
  233. 64 1/2 d code ?
  234. Brake Hoses
  235. cheap exhaust
  236. Disk or Drums
  237. So Long !!!
  238. 1970 mach 1 steering
  239. Distribution Block...do i really need it?
  240. O2 Sensor, Good Idea?
  241. Certificate of title
  242. Custom Autosound....Need opinoins..Thanks
  243. Radiator and hYdRaUlIc-assisted clutch *recycled topic, post 10*
  244. Relocation
  245. 9" Rear
  246. engine painting
  247. oil for 3 speed trans
  248. Electric Fan Q?
  249. 1964 1/2 Fender bolt coating or finish.
  250. Interior colors
