View Full Version : Classic Mustangs
  1. HEY!
  2. Glass Setting Tape
  3. Mechanic trying to screw me?
  4. rolling chassis?
  5. '65 Convertible for $45k
  6. Master cyl help, what a f-ing joke
  7. Grundy: Classic insurance for daily driver?
  8. Stock Suspension Hadling Question
  9. mach one gauges in a non mach. doable?
  10. Speedo Cable Question!!
  11. Safe To Rinse Off Engine With Water Hose?
  12. Suspension
  13. Article on Wheel Fitment 15,16,17" MODS: PLEASE ADD TO FAQ!
  14. cam swap gasket set
  15. 68 Distribution block
  16. What size bolt and thread for bolts connecting engine to bellhousing in 302?
  17. Pertronix coil thrower2
  18. opinions please.. cherrybombs vs. flowmasters
  19. Floor pan installation
  20. Looking at a '67
  21. Sad 68
  22. Car keeps stalling
  23. I need some help with buying some parts
  24. 4.7 V8 289 Start problem
  25. putting the car on jackstands
  26. 3 point seatbelts
  27. 68 center console
  28. Compression test without intake manifold?
  29. Hi from New Zealand
  30. Shelby Taillamp box-How does this attach???
  31. HPDE and Time Trials at Summit Point, April 19
  32. awesome dyno #'s
  33. Please help
  34. clean up and reinstall or replace
  35. Value of 67 Coupe?
  36. j-code motors
  37. First time down the track
  38. IDLE
  39. holes in firewall for after market guages
  40. How interchangable are exhaust parts with the classics?
  41. Hopefully going to the track soon!...Hopefully.
  42. 67 Deluxe dash - what do I need?
  43. efi swap / wiring
  44. CJ Pony 70 cowl pros/cons?
  45. Radio questions
  46. 1969 Mustang Upgrades
  47. got a good autolite!
  48. speedometer gears
  49. Help restoring 69
  50. FUEL ISSUE
  51. cost estimate
  52. Tuning kit for Holley
  53. 65 over hearting...urrgh!!
  54. Roll-cage
  55. Brake line questin, loop?
  56. Trunk lid hinges?? Same or not??
  57. my new stang
  58. Estimated E/T
  59. 66 coupe rear valance and battery location
  60. Dynomat and carpet
  61. Intake Question
  62. bad battery
  63. question
  64. seriously overheating ignition switch wire
  65. Will this 4 speed fit my car?
  66. export bar shag, almost done
  67. electical bug
  68. Help ID cobra air cleaner
  69. Looking to Fix 65 Horn -- The Three Spokes Don't Work, but the Center Does
  70. Quarterpanel Ornament Installation
  71. found a K code
  72. Fmx transmision
  73. Flames out the carb on throttle
  74. Do-it-your-self priming
  75. Locked Rear?
  76. proper head torque pattern for 302
  77. Z-Max additive?
  78. Car Domain
  79. Disc Brake Swap Problems, HALP
  80. Help installing KYB Gas-A-Just
  81. Tuning off-spec
  82. 69/70 Correct Grille Ornament Placement
  83. Drill a hole in the floor pan?
  84. Engine Oil Priming Question
  85. disapointed
  86. Does anybody know how to build a jig??
  87. 67 Fastback Shell Restoration Follow Along
  88. Vacuum leak HELP!!!
  89. Cleveland missfire
  90. Progress at last on the 70 coupe front end
  91. more flexplate questions
  92. 66 ignition switch issue,, overheating?
  93. another toploader question
  94. best aftermarket seats?
  95. Will this shifter fit?
  96. HAHAH, Get this guys
  97. What do you think
  98. are 65ish convertible seats different then standard coupe buckets??
  99. Replacing Gas Tank in 67
  100. What's in a VIN?
  101. Offset Shackles
  102. What a mess....
  103. DARN milky oil!
  104. keep the performer or get the stealth
  105. Checking oil...
  106. Custom Rotisserie question ...
  107. Questions about 65-67 Mustang as daily driver
  108. CARFAX Report and Wiring Diagram
  109. looking for gauge location pics
  110. Break in... all just opinions.
  111. how do i replace the fuel filter on my 1965
  112. ordered the XE256H com cam today. Next step is pick a carb. opinions please.
  113. Engine Bay Refresh - Pertronix, Wires, Air Cleaner....
  114. Installing old radio into my 65'
  115. heads are 64 casting without guide plates are my rocker selfcentering or not?
  116. Alternator wiring harness fire!!!
  117. 67 Fastback front fender question....
  118. Trany rebuild suggestions
  119. 72 convertible rear filler panel
  120. question about the 570 street avenger
  121. 1969 mach or gt?
  122. Dallas area Frame & Body recommendation
  123. Scary problem 3 days after getting the car back... (pictures)
  124. How much car do you need for a VIN
  125. 67 Shelby RearEnd Question. PLEASE HELP!
  126. Any ideas?
  127. Mustang Stuff...
  128. S L O W
  129. Wow, i guess i did get a good deal
  130. center counsil
  131. T-5 Fluid Capacity
  132. Looking for Classic mustang commercials
  133. one more try
  134. Canadian Parts Vendors?
  135. What color carpet?
  136. 1965 Door Panel removal
  137. Water pump gaskets
  138. Taillamp panel replacement-step by step instructions??
  139. Need big rims on small budget
  140. Detailing Chin Spoiler, Rear Spoiler, Louvers
  141. Stainless Export Bar?
  142. My dyno day with CPR
  143. disk brake question
  144. Mechanical vs. Electric Gauges
  145. Tig welder for panels??
  146. 8" and 9" rear end questions
  147. Metal installation order??
  148. posi rear end for 83 gt
  149. Got 347 together! Got Pics!!!
  150. Need a good mechanic in Utah
  151. You've seen the top...here's the bottom
  152. 66 Electronis Voltage Regulator
  153. FINALLY HAVE PICS OF THE STANG!!!!!!!!!!
  154. Power brakes with 5.0 EFI
  155. need opinion on cam. anyone used the Crane Z series
  156. Door Lock Issue
  157. Better Pic of my 66 Fastback!!!
  158. Question about my T-5 Tranny!!
  159. good find or pass?
  160. Engine code
  161. the Cleveland lives!
  162. just bought 289 heads with larger valves
  163. 1970 rusty cowl
  164. 67 frame rails
  165. Front and rear swaybars on the old girl?
  166. here it i, link to my car in PHR mag!
  167. Battery issue/advice
  168. 1968 interior quarter panles
  169. even more questions. should I automatically replace
  170. any one know stock C-code cam specs? I am considering
  171. when to shift
  172. T-5 / Clutch Question
  173. doors keep flying open
  174. Hood & Front Quarters
  175. Power Brake Conversion Question
  176. '66 coupe bolt pattern?
  177. Added crappy pics.. 69 Wheels and tires for the rear..
  178. dash speaker replacement
  179. Wheels deviation
  180. build date on a 65?
  181. any one running a 221 v8 ?
  182. AC evaporator replacement
  183. Quarter Window Question
  184. clutch pedal??
  185. 8.8 IN A 66
  186. chips
  187. 351 w piston
  188. Looking for correct accelerator return spring setup.
  189. Independent Rear Suspension
  190. Auto Meter Gauges - Who's cheapest?
  191. Rear end ?
  192. flex plate trouble???
  193. What is the best A/C unit?
  194. Pictures of my shell(home safe and sound) :)
  195. Mustang Plus SUCKS!!
  196. TCP/heidts Subframe connector question
  197. Rusty Cowl Panel-What would you do??
  198. Shelby Roll bar-How to install??
  199. Just out of curiosity
  200. Today is the day! - First drive with T5 :) :)
  201. Where to find custom size Torq Thrust 2's
  202. does my 289 sound healthy?
  203. Suspension project 1970 stang help
  204. how much should i sell it for
  205. running nitrous
  206. I need...
  207. Oil light / pressure activated light help
  208. AOD Cooling lines
  209. Chicago pony cruise
  210. cd - rom
  211. SUCCESS
  212. advice for buying '67
  213. Question on replacing heater hose on a '65 with A/C...
  214. OMG!!
  215. Question about door handle release on 66 Fastback
  216. t5?
  217. no fun on a hot day
  218. ron francis ignition switch/electrical problems
  219. light Problems
  220. 302 oil pump question??
  221. Going on a month now
  222. Is this the axel I need?
  223. V8 oil pan in 67
  224. Where to find Eleanor parts
  225. About to order Ron Francis kit, any pointers?
  226. Alignment shim - Rule of thumb?
  227. How much abuse can a 65 rear take
  228. Old Mustang sales books
  229. Cam Choices
  230. Timing pointer in the way of radiator hose - see pics
  231. I can't find heater box seals
  232. Firewall insulation sadness
  233. manual or power front disk brakes
  234. need a good door diagram
  235. B-Quiet® Extreme
  236. 2 stroke or not 2
  237. Just bought a shell, what year is it?
  238. another "what is this wire for" ?
  239. About to buy a 1968 mustang... but need some advice!
  240. Sparks are never good
  241. i need more torque
  242. 351c engine sleeves?
  243. fuel pump pressure
  244. bolt torque settings
  245. Rack & Pinion with Longtube and Clutch???
  246. gt40 buildup
  247. Mustang Electrical Troubleshooting
  248. Which is better 65 or 67 mustang
  249. Getting ready for paint
  250. No Brake Lights?
