View Full Version : 4.6 (Modular) Mustang
  1. Spydershaft Installed
  2. dyno dynamics?
  3. get rid of the predator for a dyno tune?
  4. OBD II?
  5. Is this a good deal?
  6. Best Price on SLP LMII's?
  7. anyone own Pypes exhaust?
  8. Procharger bov...
  9. somehting hitting on startup and bumps
  10. New to forum, Cheap beginner mods?
  11. bleeding
  12. Backpressure stock restrictions....
  13. Nittos
  14. Dashes in odometer, car freaks out
  15. PI Heads off of what car???
  16. racing in an automatic
  17. where can i get new springs for a pro 5.0 short throw(stiffer shifts)
  18. Problems w/ Mileage....
  19. Helicoil?
  20. paint job
  21. 4.6l engine swap.. Any suggestions?
  22. spring insulation
  23. 96 gt with mach wheels
  24. Which Sound system..?
  25. Transmission rebuild cost?
  26. spark plugs, white, 1 with oil???
  27. Seats out of a 99-04 into a 1996
  28. maybe someone could help with suspension
  29. Cyclinder Head Question
  30. ProCharger 42lb Injectors
  31. clutch slipping?
  32. Problem with the fuel delivery.
  33. Clutch Problem?!
  34. T45 rebuild and clutch change questions
  35. h/c/i opinions
  36. Big spark plug problem
  37. Weird Problem...Please some help here!
  38. 90MM MAF question
  39. MISFIRING ISSUE..... NEED HELP ASAP
  40. 4.10's girlfriend
  41. how much can i expect
  42. New 4.6 owner need help
  43. Think I Blew A Head Gasket!!
  44. TR3650 Info (problems; fixes)
  45. What wire is what for each coil?
  46. can somone explain the settings on the KYB shocks....
  47. Finally got some pics up!
  48. brake problem..
  49. Which Cams /w Pi Swap
  50. Anyone use these?
  51. 700+ rwhp supercharged car... 03 cobra or 4v 5.4L swap
  52. Cam 2
  53. question regarding shock/spring combo
  54. Another S/C Thread...
  55. Rear Axles and ABS sensors/wheel....... WTF?
  56. 01 GT Vert - Break 300HP?
  57. sc or pi swap?
  58. Tires
  59. STB needed?
  60. Good upgrades to do?
  61. MOVED: Where can i find this grille!
  62. Aftermarket tranny?
  63. stock t-45 input shaft, 2000 gt
  64. Header Selection Help
  65. Hi-Flow Cats?
  66. King cobra clutch problem
  67. Decking it out this summer
  68. Muffler question
  69. traction bars
  70. Best CAI and y
  71. GIVING UP!!! NEED HELP
  72. SLP Race pipes
  73. How much hp?
  74. Powerdyne Supercharger
  75. Misfire under boost???
  76. head gasket vs PI heads
  77. discount code for american muscle
  78. Hanging Idle.... out of ideas.
  79. i have no idea how to do this 'tho i've seen it done...
  80. brakes on a 96 gt
  81. theft light
  82. Will my new shoes fit 20x10
  83. 97 gt engine swap. information apprectiated
  84. passed smog in CA????
  85. Changing out the fuel filter
  86. Keyless Intry.
  87. ? about Royal Purple motor oil
  88. '02 billet dipstick tube?
  89. SCT vs Diablo
  90. Suspension Questions
  91. how much horsepower...
  92. or 4v how do i find out?
  93. Best looking aftermarket front fascia?
  94. AC blowing out hot air
  95. Setting Cam Timing on a Windsor Block
  96. MOVED: I can't decide!!!!
  97. MOVED: Just got her dyno tuned...
  98. pi intake
  99. Stumbling/non existent idle
  100. Bad MPG's With X-pipe????
  101. '01 Cobra Engine
  102. Bent Wheel
  103. HELP!! HELP!!
  104. Crackalin noise
  105. sqeek and knock sound
  106. ET question
  107. Possible to reset ABS light?
  108. MOVED: Just got 02 Vert, noob exhaust question
  109. MOVED: track times?
  110. MOVED: Want lots of input. Thanks!
  111. PI SWAP AND FACTORY COMPUTER
  112. MOVED: Buying a convertible
  113. MOVED: best price??
  114. my h-pipe has no cats
  115. help me out
  116. Need Some Help With Cam Selection
  117. PI INTAKE $130 W/GASKETS
  118. Stock plenum
  119. Question about my mods and running lean
  120. autometer whistle??
  121. new speakers
  122. explorer heads
  123. need help
  124. Screw size for Grille Delete?
  125. first oil change as owner of cobra
  126. fixing header leak
  127. PI Swap question!?!
  128. i need help wat should i do
  129. Just did cobra brake swap...soft pedal.
  130. MOVED: Louvers
  131. HELP White Face Gauge Install
  132. 03 cobra front bumper - chin spoiler question
  133. Kenne Bell 1.7 6 psi.......get more psi??
  134. Stock fuel pump
  135. Good price for Cobra SC?
  136. Will this Short throw work?
  137. Some Verification
  138. Will my diablo work with a mach1?
  139. Nitrous and Injector ?
  140. cracked intake? blown head gasket?
  141. how far can you go before you get a CEL
  142. Hard Start in '04 GT
  143. question about SLP and resonators
  144. coil pack?
  145. Procharger questions
  146. 2v coolant mod
  147. best manual for longblock assembly?
  148. idling problems....
  149. Exhaust Fitment Question
  150. any good revies sniper tuning
  151. DIABLO SPORT TUNE
  152. werd squeek and humm
  153. suspension mod
  154. tires??
  155. Question on 4 valve heads Aviator
  156. wiil a c4 bolt up to
  157. 4.6 block how much Hp will it handle?
  158. Brand New King Cobra clutch kit, New Tranny, New flywheel. T/O bearing rattling like an SOB
  159. What about Whipple?
  160. Break cleaner ok to clean IAC?
  161. Electrical Issue(ALT/BATT)
  162. Anyone got pics of their rear seat delete?
  163. CHEAP CONNECTING RODS ON EBAY
  164. Curb weight
  165. coil over kit? vs eibach pro kit
  166. MIL Elimantors...
  167. exhaust help slp
  168. Cylinder misfire question
  169. dohc or not ???????
  170. tko 600???
  171. Which is better??
  172. Installing power door locks
  173. new shocks
  174. wtf:real bad knock
  175. Power curve question
  176. Throw out bearing
  177. odd back of tires....
  178. 4v heads and kenne bell
  179. How Much?
  180. new suspension
  181. buying a stall tonight few questions
  182. Slanted rear end - ideas?
  183. Weird squeak noise after shifting..
  184. Coolant level warning light
  185. need advice!!!!!!
  186. Installing Cobra Bumper on '99 GT
  187. Engine shaking and Maintenance light came on
  188. i need help
  189. Blown Head Gasket!? Leaking oil.
  190. need help with idle???
  191. Replacing Shocks/Struts
  192. Coilover problem..... Help!
  193. Chatter shifting into 2nd gear, throw out bearing?
  194. 2001 Leather Question
  195. Building the rear end
  196. ADVICE FOR 4.6
  197. Floor Mats
  198. Oil change question...
  199. Welded Subframe Connector
  200. Replacing Fuel Pump and Filter
  201. 351 build or 5.4 swap???????
  202. plugs
  203. WTB - 03 Front Bumper
  204. kenne bell vs the rest
  205. Do UDPs cause charing issues?
  206. tire size help please???????
  207. What do ya'll think?
  208. BBK Performance
  209. Is this noise from my Flywheel??
  210. 28 or 31 spline
  211. 3.73 vs 4.10
  212. MAC h-pipe modular?
  213. would 24lb injectors fit on my car
  214. which spark plugs should I buy
  215. hardware??
  216. Hi flow CATS
  217. Header Install
  218. Stang Will Not Start/Stay Running
  219. Need help finding a rattling noise
  220. re-use metal screen when installing CAI
  221. cams/heads questions
  222. Installation Price on a Supercharger and Tune??
  223. UPR intake spacer???
  224. 03-04 Cobra bumper FAQs
  225. 60# Injectors, really?
  226. HELP! Offset of rims?
  227. Heater Hose On PI Swap
  228. speed limiter
  229. 96 Window Problem
  230. x-pipe fitment issue
  231. smoke!
  232. Getting engine rebuilt
  233. Timing chain tentioner question
  234. seasonal chances = different weight?
  235. Cobra Calipers? WTF.
  236. ? about over hauling
  237. Jumpy Idle
  238. cobra bumper on GT- Need Help!
  239. Battery Light errr
  240. Brake Caliper question
  241. SERIOUS Transmission Problem...!
  242. Help! No idea what is going on!
  243. Tuning issue?
  244. Leaking Oil
  245. RPM too high!!! Help pls.
  246. whats possible?
  247. Steering Knuckle/hub????
  248. Vortech Help??
  249. Which motor mounts
  250. Engine Vibration
