View Full Version : 4.6 (Modular) Mustang
  1. Nitrous with a stock motor
  2. best guages to get?
  3. Machine Gun
  4. Do 96-98 cobra's have a 6 or 8 bolt crank??
  5. 2v to 4v
  6. need help ASAP
  7. Mustang Dying! Please help!
  8. Weight diff. between 2v and 4v motors???
  9. How to replace wheel studs?
  10. grinding 2nd sometimes
  11. Saving for big mod what should I do ?
  12. Pinion Seal Leaking
  13. catback exhaust?
  14. octane
  15. 4v swap Fuel pump) questions on 96-98 models
  16. Power Steering Pump Disassembly!!!!
  17. cost of nitros
  18. car is choking-help!
  19. pos 3650 finaly crapped out, for good
  20. rims and tires question
  21. EXTREMELY URGENT HeliCoil Process Question
  22. Swapping SOHC???
  23. need new shocks
  24. Lowering Car
  25. MGW
  26. need some help with fixing the filler line
  27. Little clutch help. . .
  28. help with tuner...
  29. Tires
  30. T.B. install
  31. Sloppy Front Suspension
  32. hey guys what you tink!
  33. 1/4 mile time
  34. could i hit 12's
  35. 12 days left to cruise
  36. Auto Meter Gauge Cluster
  37. speed limiter
  38. am i getting ripped off?
  39. Imrc open?
  40. A/C
  41. nx 2v plate kit
  42. cats question
  43. Gauge swap...
  44. driver side widow?
  45. Intake for 98 mustang gt
  46. window switch question + more
  47. Full Bolt-Ons...
  48. New GT
  49. 98 GT engine swap
  50. need help with sct rev limiter.
  51. Radiator Cap Overflow
  52. how to get midpipe bolt off?
  53. what midpipe do you guys like with magnapack catback?
  54. Installed my sequential tail lights today!! Woo Hoo!
  55. JET SIZE PLEASE!
  56. My car got hit last week
  57. Led Brake Light Help....
  58. Wheel and Tire questions
  59. High mileage 4.6 starting to smoke
  60. fuel leak.... bad......
  61. HELP!!
  62. 98 PI swap?
  63. HOW MUCH SPRAY CAN I GO?
  64. VT Stage ones
  65. fuel pump
  66. What's Your Ride Height?
  67. H pipe install
  68. Mod Motor
  69. Inside the mustang hood
  70. Throttle Body????
  71. dyno tuner and nos
  72. transmission
  73. 97 non pi tt rear end build 315's on gt wheels.
  74. What should I do with my 2V?
  75. Black coolant
  76. how much does it cost to have flowmasters installed?
  77. Oil Catch Can
  78. 4.6 and 3650 in my notch
  79. whats a good clutch???
  80. rear tranny seal on 3650 leaking
  81. Camshaft sensor code came on today
  82. 100 shot
  83. Do shorty mid-pipes from 2v fit 4v's
  84. MGW makin noise HELP?
  85. 5.0 guy needs 4.6 help.
  86. ECM swap question from auto to 5spd.
  87. S/C
  88. Clutch Cable
  89. 110 octane mixture ratio
  90. Engine Light - P1443 Evap. Can. Purge Valve
  91. Who's running polymotor mounts?
  92. Stripped Crankshaft Threads: UPDATE!
  93. New clutch
  94. What's a fair price for a Cobra engine?
  95. Stripped out oil plug
  96. What transmission?
  97. Flywheel Q ?
  98. Steering Problem
  99. Bassani Mid-Length Headers??
  100. 1996 mustang gt fog light install
  101. Exhaust Leak??
  102. Anybody know any parts suppliers that has chin spoilers?
  103. ? About Helicoil Directions
  104. HELLLLLPPP!! PLLLZZ! Busted Bolt!
  105. Quick question - Short throw - will it fit?
  106. Crank pulley will not come off!!!!
  107. Oils that are good for the 4.6L
  108. trans install w/ lng tubes
  109. Do i have a 8bolt or a 6 bolt?
  110. What size clutch for a 96 cobra? 10.5 or 11"
  111. 99 Gt cam install
  112. Size
  113. h pipe questions
  114. will it work?
  115. 4.6L tech romeo/winsor
  116. Accufab TB
  117. TR3650?
  118. Quick fix on A/C drain leak???
  119. Bumper Inserts
  120. How to take out the back seats?
  121. Added Custom intake now Idle runs away
  122. Factory Alarm Issues...
  123. original pulleys
  124. Seats
  125. Help with fpss install
  126. Headers that will connect to stock exhaust?
  127. Bumper Modification
  128. Blown motor @ 39k Miles need help please!!!
  129. wtf..'04 6-disc into an '02 vert
  130. detroit locker
  131. MEZIRE ELECTRIC WATER PUMP WIRING
  132. Magnaflow x pipe and roush cold air for sale
  133. Heat extractor hood.
  134. 03 04 bumper
  135. MGW Shifter slight rattle under acceleration? Normal?
  136. turbo?
  137. mid pipe question
  138. Will a 2000 gt mustang motor work in my 98?
  139. exhuast?
  140. tranny fluid leaking
  141. dyno tune??? Pls help!!
  142. 96 Cobra vs. 97 cobra ecm? I need help
  143. HELP gas leaking only 15 mpg
  144. delete plz
  145. Where can I buy a gun?
  146. Turning Engine By Hand: SMALL UPDATE page 2
  147. Cam suggestions
  148. TIRES!!
  149. Need help badly with 98 GT valve cover gaskets
  150. Mods
  151. ppl with predator tuners
  152. air intake
  153. the perfect gear for DD auto...
  154. The different between SCT and Diablo?
  155. Hp gain with OFf-road h-pipe?
  156. buying tko 500....or 600?
  157. Do 99-04 GT's run rich from the factory?
  158. Keep blowing fuses..
  159. ruff idle after new intake manifold...
  160. couple minor problems
  161. Anyone have a sending unit kicking around they could look at for me?
  162. Brenspeed
  163. steel TOB retainer
  164. early t-45 in my 2000?
  165. T56 SWAP
  166. PROBLEMS with reverse
  167. mgw install
  168. Coil Packs
  169. Im having problems
  170. 03/04 10.5 wheels
  171. This leads me to another question . . .
  172. Front Seat Removal
  173. Little Help from you folks with Steeds springs
  174. loss of power?
  175. Need Help ASAP -- Suspension
  176. suspension checklist
  177. owners manual
  178. lower control arm mach1/gt
  179. gear problem
  180. speedometer changes?
  181. CC plates guys
  182. Do I need Maf.I.a. with a LMaf for 10lbs Boost?
  183. Battery light: UPDATE...PROBLEM SOLVED!
  184. Cobra Dual Fuel Pump Output???
  185. Manual Convertible Top??
  186. cold air intake ?
  187. Exhaust...MAC vs Borla
  188. Paxton sc installation problems
  189. I need suggestions on brakes
  190. Help me have fun!
  191. 17s up front
  192. 02 mustang lug pattern
  193. Smoked fog lights or covers
  194. need a ecu pinout for 2000 mustang gt
  195. P0420 code... great
  196. P0190 Code
  197. Why Me
  198. where to order xcal2
  199. two leaking heater cores in 6 months
  200. chevy lug pattern same as ford?
  201. port and polish heads with high miles???
  202. Cobra Throttle Body
  203. Increasing boost??? Tune??
  204. A/C problem
  205. Anyone ever have a knocking/ticking lash adjuster...
  206. Changed gears, Help/Question
  207. ball joints or tie rods?
  208. Lowering springs
  209. MSD COP's?
  210. ? for those with built motors (egr delete and venting the valve cover)
  211. SC+cams on stock bottom end?
  212. How do I fix broke plastic on my '04 GT Mustang (Fog light area)
  213. Trickflow Trak Heat intake.
  214. need help adjusting dual halo headlights plz
  215. Plugs
  216. Underneath Rear Seat
  217. Good rearend components to upgrade with?
  218. advise and suggestions much appreciated
  219. Noise Of A Shredding Belt? WTF???
  220. help with tuner?
  221. Is there a online parts diagram?
  222. New Tranny any suggestions?
  223. tranny oil
  224. HELP!!!!
  225. Bassani Baffle Tits.
  226. New Intake Manifold
  227. Does my setup sound exactly like flowmasters??
  228. making my 2v into a 4v motor
  229. BUILT 4.6?
  230. Replaced the A/C clutch but it wont engage
  231. dumb question.. need quick answer...
  232. Brake help!
  233. WHAT SIZE WHEELS FOR THE STRIP???
  234. newbie here
  235. 2v revving past 6k
  236. SCT Xcal 2??
  237. New motor + more, need advice.
  238. 97 Gt Transmission Question
  239. HP question
  240. manifold
  241. NEED ADVICE
  242. Error Code P0133
  243. OPTIMA BATTERY GUYS PLEASEEE
  244. HELP!!!! Major Power Steering Problem!!!!
  245. sel codes?
  246. Forged internals
  247. Kenne Bell Supercharger = 550hp
  248. Bad tune??
  249. got it for sale
  250. Magnaflow tip question
