View Full Version : Classic Mustangs
  1. 1965 Trunk sheetmetal replacment
  2. how can i tell if my mustang is "numbers matching"?
  3. Moderate Build
  4. Mechanical vs Vaccuum Timing
  5. which gaket set?
  6. Need help quick: Power steering cylinder
  7. '65 Front end question
  8. My new project
  9. Before and After pics...
  10. MY LUCK wrong freakin part.....
  11. 68 quarter ornament
  12. Friend's '66
  13. It's Painted! GT 351 :-)
  14. Help, PCV valve hooked to wrong spot on Holley?
  15. Back with the new cam - feedback
  16. What steering box?
  17. Covertible Top Codes
  18. Styled Steel Wheel Covers - Anyone Use These?
  19. I think... I am getting Closer
  20. Door Panel Glue??
  21. 69/70 owners, help and maybe pics? gratze.
  22. disk brakes
  23. Original Owner-FMX to 4 speed in 73 Mach 1
  24. Door glass replacement
  25. Someone with a T5 and 3.55s in the Bay Area?
  26. 67 Rear Valence Stud Placement
  27. 88 grand marquis rear end for 68 stang?
  28. Need chrome for a 69 Passenger Side Door panel
  29. I wish you mustang guys well
  30. Question...need answer pretty quick
  31. checking vacuum advance
  32. Power Steering Pull
  33. Alternator Good or Bad?
  34. Battery boiling on my 65 6 cyl
  35. Export Brace Reinforcement?
  36. Well isn't that Grande
  37. bolting a 302 to engine stand bolt specs
  38. Gauge Cluster Question
  39. some teens bench building..........
  40. Question About Seats
  41. 351 W Fires but but wont run
  42. A good way to get the seats and tracks off a 1970 mustang coupe
  43. 302 Block, 351 heads
  44. Matching Numbers...on 1965
  45. Question About Installing New Engine
  46. Anyone Ever Painted their Whitewalls to Make Redlines?
  47. Quick Drum Brake Question
  48. What headers to buy?
  49. determining original options
  50. manual steering question
  51. What is your favorite retailer of Mustang parts
  52. Advice on Leaf Springs
  53. new rug
  54. Cold Air kit
  55. Fuel fitting sizes...
  56. C4 Transmission questions
  57. C4 Transmission questions
  58. Flowmaster 40 Dual Exhaust kit.
  59. Best Place for a new front bumper
  60. 71 9 inch in a 68?
  61. pleeeeese help,...electrical lighting issues
  62. 347 Won't Start
  63. 1968 Shelby gt500 update...
  64. Do you like this car for this $$ ?
  65. is this a rip off or what?
  66. Monte Carlo Bar
  67. 351W or C "engine bay fitting"
  68. Engine Swap 200ci to 289
  69. 68 power steering pitman arm
  70. Have you guys had good luck with Mustangs Plus
  71. A/C Installation on a '68 Coupe
  72. WOOOO HOOOO!!!!!!!!!
  73. 1969 fiero seats
  74. T-5 Q&A
  75. Starting this '67
  76. 73 Carpet color question
  77. How Long Can a Tranny Sit on a Bench and Still Be OK?
  78. Exhaust, Flowmaster 40s vs Magnaflow
  79. Finding an old one
  80. Door Alignment Issue
  81. 73 dash paint
  82. 65-66 V8 Motor Mount & Frame Mount Thoughts
  83. Lincoln? rear end
  84. how to feed a fuel pump ???
  85. 68 mustang headlight dimmer switch location
  86. mechanical fuel pump installed correctly?
  87. Compression and Vacuum test? Please help.
  88. I'm driving !!!
  89. standard vs pony interior
  90. I've put about 2500 on the new xe256H from comp cams
  91. Any problems with the studs?
  92. Anything wrong with high voltage going back to battery?
  93. in need of help in puyallup, wa.
  94. engine help needed
  95. C4 & putting it in park question
  96. Need quick input: 65 Fastback - yes or no?
  97. 289 to 302
  98. how to adjust neutral safety switch?
  99. top harness and voltage regulator questions
  100. Pictures from Houston Mustang show
  101. antoher whats it worth,...66 mild resto vert
  102. Pictures of my '67 convertible
  103. Swapping 4 lugs for 5?
  104. Could use some help thinking thru long block
  105. fel pressure gauges not resistant to fuel ..?!
  106. new door prob
  107. 68 Fastback Engine and T56 swap
  108. where to buy inexpensive chrome headers?
  109. Ok . . . My setback.
  110. HEY GUESS WHAT? COOLANT IN THE OIL...AGAIN!!! PLEASE READ!
  111. 15 Years in the Making pt.3
  112. It Started!!!
  113. Some progress pics
  114. Need help with back wheels.
  115. she's running !!! :-]
  116. Widest tire for 14x5 inch wheels?
  117. 1966 pony interior touch up
  118. Ford wiring connectors
  119. Mustang Trans 3spd man. wont shift
  120. Exhaust Manifold
  121. Headers Installation Help
  122. LEAK LEAK LEAK LEAK LEAK LEAK LEAK LEAK
  123. PCV valve setup
  124. Having Trouble Bleeding Brakes
  125. What should be a simple question...
  126. 67 Stang marker lights
  127. Part three... stang getting saved
  128. new seats
  129. How do you remove a manual steering adapter from the pitman arm?
  130. Checklist.....need advice..
  131. dash speaker plate for 2 speakers
  132. Is AOD the way to go?
  133. Houston All-Ford Show - Anyone going?
  134. Just sharing .... The Engine is in!
  135. Which Radiator for 5.0 swap.
  136. '65 or '66 original Fastback GT!
  137. 67 Center Console
  138. I'm leaking (intake manifold?)
  139. If it's not one thing, it's another
  140. Is this a safe jack support location?
  141. Pleasure to work with
  142. Rattling windows.... anyone know of a kit?
  143. Where would you like extra DC & even AC power?
  144. How the HELL does the PS pulley come off??
  145. Another Mustang
  146. Rocker Arm Nearly Sawed through Stud!
  147. Wiper motor
  148. Pic request!!!!!! Black or Silver/Gray....
  149. Why did the P.O. do this?
  150. Toploader question
  151. Gas Leak?
  152. More Power From A 351C 2-V?
  153. Booster question
  154. Head question
  155. Engine Installation / Distributor ...
  156. Ignition Coil Hookup
  157. Gasket Material for Taillights, Chrome
  158. Classifieds
  159. Need a little help
  160. Restoring California black and yellow license plate
  161. Should I replace Alternator after Installing Amplifiers???
  162. gt 350 decal
  163. 1963 Mustang???
  164. Pulley Whine
  165. Two Questions
  166. Would... and how?
  167. heater question ???
  168. Wiring question??
  169. VALVE adjustment help, professionals only !!
  170. The Best Place to buy Retoration parts?
  171. Are there emblems for L6's?
  172. POLARIZING MUSTANG GENERATORS ?
  173. EARLY MUSTANG BODY AND INTERIOR PARTS ?
  174. Project '67 Coupe with a few mods :)
  175. gauges dont work....go figure
  176. Transmission Fluid for 1969 Automatic
  177. 69 spindles to 68 coupe
  178. old engine out, new engine in :-)
  179. 65 and 67 Exhaust Systems, Same or Different
  180. Finally Finished the T5 Swap, some little things to work out
  181. Steering Wheel?
  182. SubFrame Connector instalation Question
  183. Thermostat Question
  184. Broken Axel Help
  185. Portland Oregon swap meet.
  186. Transmission leak
  187. Gauge Feed Wire Harness HELP!!!
  188. # DOOE C 351 windsor heads?
  189. Ohhh! I F'd up. Over-torque intake manifold?
  190. which hood and where (thoughts)
  191. Alternator HELP please...
  192. Body work
  193. engine suggestions wanted?
  194. cowl cover-what will i lose?
  195. Mechanical Lifters
  196. quarter panels any good?
  197. Body work.
  198. wheels and offset question on a 66
  199. cigarette lighter doesnt work
  200. Budget 68 Resto-Mod 4.6 DOHC. (All my work condensed)
  201. ash tray proven!
  202. Master cylinder leak - cap
  203. Heres pics of my 302.
  204. VIN NUmber Locations
  205. 302 and 5 speed in '65?
  206. 351w starter & 164-tooth
  207. HELP! Wiring Harness in 66 - Nightmare? Cost?
  208. Flywheel question
  209. This is bad for a guy in Seattle
  210. Question on my 65 coupe
  211. Rebuilt Steering Box or Flaming River??
  212. lighter engine raised car in front ...
  213. 66 p/s pump ?
  214. rally-pac dilemma
  215. Need Help with Engine
  216. help: slip yoke damage
  217. Headers and Other Stuff
  218. non metallic emberglo?
  219. My engine repainted
  220. Need help and looking for some ideas
  221. mounting depth of kick panels with speaker pods
  222. $32.00 Mustang rims off Ebay!
  223. paint job?
  224. Finally.. Off to paint! Current pics.
  225. get rid of the rust in my engine block
  226. Newby Help - 347 Engine HP Low
  227. Looking for an old post with link
  228. stuck
  229. New rear end?
  230. 71 mustang electrical issue
  231. Newbie installing intake questions -- Pictures
  232. What the FUK? Almost blew up my engine!! listen ...
  233. Idler Arm and Tranny Fluid?
  234. Stuck intake manifold.
  235. Disk Brake Question
  236. which is the best T5 conversion Crossmember
  237. 65' Mustang update
  238. Recognize these wheels?
  239. 66 seat belt info neded....help!
  240. engine timing, ignition on manifold vacuum (not ported)
  241. Shorty Exhaust Headers?
  242. 1970 mach 1 9" rear into a 68 fastback
  243. 67 wheel tire combo
  244. working on floors,
  245. Whats wrong with these pictures!!!!!!!!!!
  246. It has paint take 2...
  247. It has PAINT!!!!
  248. WHO knows how to adjust rocker arms....
  249. help shine up
  250. Fixing up my 68 Stang
