View Full Version : General Tech
- My 1989 ford mustang
- What do you think of this? (read post)
- electric fan??
- Strange noise, diagnosis needed!
- 01 SVT Trany CLUNK?
- high pressure oil pump? pros or cons?
- What makes a car a "Daily Driver"??
- Hood and Side Scoops
- Parking brake handle inquiry...
- when i put it in drive
- 20inch Torqs on a bullet?
- How much Nitro
- What will get me 500 horse
- chips
- Intake manifold question
- Water leak , pissing me off
- transmission
- A few questions...
- What is a/the plenum?
- sometimes i just wanna tear it apart
- superchips
- Throttle body
- Wheel Locks
- ET streets?
- DR's
- Caster camber plates 3 bolt vs 4
- Gas Price Per Gallon
- Headlight question
- whats the max
- Which Brand for Convertible Top
- wiring up an electric fan
- Catback on a vert?
- Let me get this straight
- 99-04 pcm smart?
- Jegs = no MAF systems???
- Underside of car
- last time i checked my car ran on gas....
- Question about killswitch.
- Borla side exit parts
- does anyone have a steeda aero spoiler?
- AC Delete
- NEED HELP ASAP> SEATS SAME AS 98?
- How chips work
- Hazard Wiring Diagram. NEED HELP
- Best brand fuel pump
- New distributor and Wires
- Cleaning fuel injectors?
- Newbie?-Subframe dimensions - '65 Fastback
- CAI
- uh oh
- Fuel pump size
- Stock Intake
- Suspension
- Pro 5.0 inquiry
- check engine light goes on and off
- rocker noise and valve covers
- euro clear fog lamps
- G-Tech Pro meter
- how to clean a carb
- Non CARB heads?
- 94-95 throttle adapter
- I have a cracked intake manifold, what should i do?
- anyone running 255/50 16's
- 70 model 351w heads on 302 valve adjustment
- Leaky Convertable Top
- hard to start
- manifold and cam kit
- Door Lock Actuators?
- `92 LX FUSE BOX
- Best overall exhausts?
- 01 GT - quick question
- Help... Estimated price for dyno and custom tune for a 2005???
- 5.4L ?
- whinning
- convertable top
- Next Mod?
- Spark Plugs??
- Mustang GT 2000
- Koeo test question...
- Timing question
- What would this run
- Looking to know if....
- rearends
- Leaking Rag Top
- Website update.
- show me pics of your trunk mounted batts.
- Which type?
- New Headers!!!!
- How important is a PCV valve
- Proper installarion of Super 40 Series Flowmasters on Mustang GT 03
- belts squeak
- H pipe Question
- Does anyone hear your MPH gauge when you drive?
- speedo cable
- whats a pulley?
- wheel spacers???
- wheel spacers
- tranny
- GT Side skirt ripple
- Estimated HP For 96 Cobra Procharged
- (im)balance woes
- BBK or MAC longtubes
- tranny with brake
- MAF Which one to get!!!
- my post
- So I had a bunch of people tell me tonight that Mustangs are "girl cars"...
- Cost of paintjobs? and etc
- Door Locks on a `92 Stang - Siezed Up?
- Packs with H pipe or X pipe
- Ebay CAI...anyone bought?
- what is a reluctor
- oil weight?
- headers with auto tranny
- AOD specs?
- painting brake calipers
- Check this out!
- Question about my dual exhaust.
- quick question, but need help NOW please
- MSD Ignition Question's
- Best HP per $$$?
- 2.73 & 1/4 times...
- Engine code help?
- wheels susp. drop
- Speedo
- Want new Tranny / Need new clutch!
- AOD Flexplate Question
- really bad noob question..
- H pipes
- Air bad light?
- Female Owners of 1964 1/2 - 1973 Mustangs needed for Movie
- What size Fuel pump should i get ?
- Who makes my size?
- V6 to V8 Swap
- vote/coment on this please,-- rebuild 8.8 or buy new auburn rear end ?
- sea foam?
- 2002 8.8 rear end,will it fit my 85 gt
- Ok my first problem post since joining
- Cam Question
- Superchargers
- Should I leave my manifold red?
- How to look for parts
- Just got a 'Stang...
- need help install cd player
- Newb questions for u guys
- Will shocks and struts from an '02 GT fit a '98 GT
- Please Help???? What"s the Widest Tire?
- vert VS. coupe
- Rear Seat Delete
- are these any good?
- Just Bought New Engine Question on What Color is Good For Block
- head advice
- Electric fans
- Know how to install a quarter window?
- 8.8 Traction-Lok Posi off of a Crown Vic
- Stock 03 supercharger on 01 cobra?
- Power for $$$
- Fog Lights
- a/c issues
- wiring cd player in classic stang
- Engine Rattle
- 94 cylinder head questions
- after market gears
- carb-vs-injection
- NEw clutch suggestion
- i have v6 2005 but i want more power without losing my gas mileage
- double link timing chain!
- Numbers on intake manifolds
- Battery Relocation Help
- how to test a EGR if its working?
- Holley 4160 ?'s
- fixing locks!!!
- Don't hate the newbie, hate the search option...
- timing chain?
- Any good shops in South Fla.
- wiring question..
- how do i mold my 93 cobra grille insert ?
- Installing Headers
- Best upper Intake manifold
- What Header,Pipe,Catback Combo?
- How to test out an MAP sensor
- Whats a good way to burp radiator?
- Anybody know anything about the 2000 SHM S2?
- teach me manual valvebodies
- Is this true?
- 88; gt fuel prob
- dumb question
- Backfirining Problem
- guages to buy?
- CHIP?
- injectors
- Please help on a temp sensor!!!!!
- homemade AFR meter
- Holley Systemax
- fiberglass vs metal
- egr problem
- supercharger ????
- using "instant metal" to plug up holes??
- new clutch
- can't see timing mark!!!!!!
- C&L mass aif flow meter
- Oxygen sensors?
- First few moves!
- C-CLIP ELIM.
- Cobra Kit Cars
- anyone cutting 1.5's or 1.6's with nittos?
- glow gauges?
- urgent doing it now
- Which Magazine
- Carlo Bar Q?'s
- 94-98 Headlights
- How to mount a floor console
- Custom Side Mirrors
- seat covers
- 1989 gt 5.0 hatchback
- Cats...
- installed headers have problem help please!!!!!!!!!!!
- Shift light
- starting problem
- Break in Period
- 95 vs 96; 5.0 vs 4.6
- power windows for 1999 conv. v6
- In over my head on a 99 GT.
- gear install
- turn signal problem
- convertible window
- Perfromance chip or Micro Tuner what brand???
- EGR
- MOVED: New Breaks, am I getting burned? $$$
- deep dish bullitts come in today!!!what tire size??
- need help with gears
- My color
- Power Windows are such a pain.
- Questons about a Engine swap from V6 to V8
- How to measure hood raise
- Guess my HP increase....new carb
- new toys!!! (NOW WITH PICS)
- Predator Programmer
- performance meters
- A good place to start?
- pro-m going out of business
- 05 gt or 04 cobra
- Suspesion quality..how your car ride?
- Black rims on black mustang vert.
- Vert Styl;e Bar
- 5-speed or 6-speed?
- looking to swap a v8, couple of questions.
- 302 to 351 swap???
- TSB 04-26-22 -- 2005 Mustang MIL On w/ Diagnostic Codes & Driveability Symptoms
- odometer stopped?
- Cog or rib drive
