- Is anyone else having problems posting?
- what's it worth??
- automatic to manual
- Wooden headliner?
- My stang has left home for the 1st time in a while
- which cam to chose
- Paint help
- Reversed lights, highbeams, and Emergency Signals
- numbers matching engine
- removing door skin
- i need rocker arms
- Car stalling
- Sad Sad Weekend
- For the guys I like here
- Speedo gear question.
- Radiator location other than stock.
- wheel spacers-need approval
- problems with new T5, any ideas what to check? {SOLVED!}
- Older Mustang W/ Newer Cobra Wheels.
- light switch help
- Console Door Enigma
- Everyone Say Hello To My Newest Stablemate
- cam selection
- Need to get alignment close enough to drive
- Newbie with a Question: Choke Housing
- okay man, Where to mount stuff?
- Bent Slave Cylinder
- how stupid am i for thinking this?
- tranny problems
- Getting her straight
- rear tailight panel
- won't start need help
- Media blasting gone wrong...possibly
- help:fuelpump issues
- 1966 Mustang: Speedometer not accurate...
- Pertronix Problem, or coincidence?
- Brake problems...
- 65 Alternator information
- Left Turn Signal Won't Turn Off
- MSD 8479 installation question.
- rotating assembly
- Mustang II Front End Swap Questions
- Circuit Board Plug, numbering
- manual or power stering!??!?!??
- 289 Performer and 600cfm carb Edlebrock
- Does any one have an extra turn signal canceling ring???
- Market for a 66 289?
- never heard of this engine before
- Cowl reinstalled!!!
- Upper Body Dimensions for a 67 Mustang
- SVO skirt
- Best place to sell?
- Car timing off?????
- Electric Radiator Fan (Brand Please)???
- Two Stoplight Switches???
- Rebuilding a C4 Trans?
- TURN SIGNAL SWITCH
- Replaced factory 289 Intake
- 66 Rims
- Weatherstripping Recommendations
- nearly there ... getting excited again
- power steering pump problem
- wheel hop
- Complete Modern Brake Set-Up
- Anybody else find this ad a bit odd?
- got it running, but having minor timing issues..and race story
- wilwood disks, master cylinder questions,...
- Picked up the 8.8 today!
- 65 Mustang C4 Transmission
- 65 shelby side scoop attachment help
- electrical help!
- Rear Valence
- Just listed on ebay
- 1965 6 cylinder valves???
- family addiction
- Help on rebuilding a 289
- classic mustang market - going to sell mine :(
- mechanical fuel pump question
- 67 Mustang vent window?
- atruggles to shut off
- how many of you have 71 to 73 lets see your ride
- mail order catalogs
- hey what the
- Rear shock replacement on a 65 fastback
- New dual exhaust but fumes seem worse
- Replacing clutch advice
- Squeaky Polyethelene Bushings!
- body prep?
- 1965 droptop mustang
- engine build suggestions
- thermactor cylinder plugs/ header problems
- water pump help
- Repainting, how do you decide on a paint color?
- Water pump install for 1965
- Long time lurker finally makes a user name :)
- Replacing thermostat?
- what i did today
- My Project for the past year
- pertronix coil
- fuel pump issues
- How Much Dynamat or FatMat
- need help with my 68
- Clock Problems
- Need cluster in for electronic to work?
- Shortening Axle Tubes... how hard can it be?
- seat belt bolt
- 1966 GT clone
- 351 C tune up
- replacing wiring harness
- 1965 Seats front and rear
- lowering steering column in 69
- Where to buy a master brake cylinder?
- Exhaust advice needed
- well got my HEI installed..now my air cleaner doesn't fit
- Complete Cowl replacement
- 67 Turn Signal Switch Walk-Through Help
- Burlap seat underlayment
- Someone explain jet extensions to me
- How hot does the bay get?
- finally got the thing started!
- New cars new problems
- Best Oil Pan Gasket????
- Need Help, 71 instrument cluster removal
- pulleys
- 65 Kickpanels?
- Ordered quarter panels
- Wheels/tires
- Crazy VIN Story
- Sticking Throttle
- 65 Starter Solenoid diagram and picture
- escort power brake ....
- POR-15
- Temp Head repair
- NEW VANITY PLATE!!1 SUGGESTIONS
- Tanny issues
- Strange deal with lights
- The error of my ways-for Daves amusement
- 65 Coupe for sale cheap.
- Here are some pictures of my car. It is almost done (if they ever are).
- WHY.
- Hydraulic Clutch & Power Brake Booster
- 65 steering and suspension inspection
- Clutch setup
- collector reducers
- new process 435 parts : URGENT!!!!!!!!!
- Thinking about reworking my REAR END>
- Help with steering wheel
- corrosion control
- New to mustangs and need some help.
- HALP!!!
- Suspension, squak sound
- Which rack to buy...
- just got my first MUSTANG
- WOOHOO! Found a 9" housing. Problem is...
- Need help please.
- Shock tower Reinforceent Pictures
- new 67, new trans help
- help
- Question about some deposits in gear oil
- Front End
- My new John Deer......
- Cutting rear housings
- Im not so pissed anymore. I found an 8.8.
- Canada Mustang online part store closure
- shock mount supports?
- Mustang Project Log
- seat riser
- Need help
- Electrical/Ignition experts...and anyone else willing to take a stab.
- Overheating
- Yaa tool and parts
- I'm beyond frustrated
- manual rack
- When will the Forum poll feature work again?
- carburetor converter
- Eleanor SS Project-follow along
- 06 17" wheels on 66 Coupe
- Paint gun???
- How long with the internal cumbustion engine be around?
- 3-pt. Seat Belt Danger in Mustangs?
- blow through turbo set up
- Noise Question
- Rear axle "play"
- Virtual Engine Dyno
- Disc Brakes on a '65 Coupe
- Do not know if anyone has seen this but...
- Swapping rear end gear ratios, suggestions?
- Wiper Question
- Is This a 1969 Mustang Jack ???? Hump on Top
- what wheels are these?
- Electrical Grounds
- 08 bullitt grill?
- 1968 289 engine
- MSD wire not firing? How do I test the wires?
- Engine bay clean up-some fotos*
- Magnum500's
- 650 Holley. what do i do with it?
- Tranmission kickdown
- 351 EFI
- 427 windsor kit
- Racing stripes for 1965
- gas tank
- 68 Mustang Seat belt
- Pully ?? for 69 with 302
- diesel engine???
- Upholstery Question (68 Coupe)
- rear end spline
- Stroke
- PAINT COLOR
- New Torque Thrust Rims
- Aiming Headlights
- vibration
- Desperatly need a pic of inside a 65/66 front fender
- Finally, a powertrain!
- fmx shifter seal
- wing removal
- Detroit Locker for 8" rear
- Glass
- 5 speed
- smooth rear interior quarter panels
- What color is my Car?
- O crap.... I Installed it upside down...will it work ?
- Rear End Gearing?
- A modern car stereo in a 66 Coupe
- Popping under load
- 5.0->>>289 headers?
- timing mystery
- Retail price of 65B?
- Got MPG?
- 66 vin number
- back seat seatbelts in a 65?
- My last insurance question...
- 3 Point Seat Belts
- T5 Bellhousing
- Should I buy another one?
- Fitment of headers
- Performance upgrades?
- 65 GT gauges in regular coupe?
- Wheel Adapter
- Do the forum searches still work????
- WTF LOL are you serious???
- clutch cable
- Not a mustang but.. uhh.. wtf?
- Engine induction
- Was there a factory AM/FM radio in '65?
- FAQ issues
- suggestions on selling my mustangs
- suspension
- Pulling the engine... but
