- Will changing my cat back add power?
- spark too hot?
- Is my clutch slipping in 1st only?
- Fuel Pressure
- up grade 351
- Manual Lever Position (MLP/TR sensor)
- 429 Swap?
- SD to MAF
- car wont run! help
- Valve Covers For 95 Cobra ?
- harmonic balancer suggestions
- Motor mount DIY
- Why cant I get any Engine Codes ?
- Alternator Fuse Location
- typhoon intake
- What can cause a lean condition
- (Updated) Timing @ 24*!!!...Harmonic Balancer went out
- how low can you go on stock cc plates?
- rpm's go up with clutch in
- MOVED: what kind of anti-theft device do you use
- Clutch replacement DIY please
- Are these 24# injectors?
- need a little help
- electrical tsb ?
- turn signals won't work
- MOVED: weather
- 3G Alt install question
- hard to change gears
- 5.0 & 5.0 H.O
- Crank pulley
- 88 gt no start on new crate motor
- 5.0 HO swap
- Strange noise in rear?
- Fuel Pump Question
- GT-40X Heads
- WOT problems
- 2 Steppin a 95?
- 1 3/4 inch headers
- weatherstripping
- Now What ! Shut off while cruising !
- spark plug ?
- 93 cobra forged pistons?
- Belt Question????
- Gas mileage
- o2 harness.. different ones for auto/manual?
- A9P - A9L Differences?
- easiest way to unhook the throttle cable from pedal?
- Cap and rotor help! FAST!
- 94 mustang vacuum lines
- Air Bag Removal
- Federal Mogul Rebuild Kit???
- how much power can the stock fuel pump support?
- MOVED: louvers???
- 12 second recipe
- control arm bushings
- 160 MPH speedometer. is this true??
- wideband
- weird thing happend yestercay w/ my car
- Fuel Pressure problem?
- Clutch and pressureplate replacement?
- trunk firewall
- Fuel, Fire, but it doesn't run? HELP!
- Z304 heads or afr 205
- 95 gt,underdrive pulley install
- brake light switch
- HURRY!! need help NOW!
- Tapping Pan for S/C oil return
- 89 Stang AIR pump removal
- clutch question
- car's getting hot while cruising
- 89-93?..94-97?
- Where is the fuel pump relay located on a 91?
- revs take awhile to drop
- spark plug help
- MOVED: were 2 buy a 4 core radiator
- MOVED: Rear control arms
- Pinion bearing install
- MOVED: just scored some gt-40 heads at the junk yard
- Help on locating a leak!
- anyone have any pictures of their eec connectors with all the wires?
- Newbie to NOS, What carb?
- Wont quit overheating
- 5 lug swap.
- bump steer
- ?? on a '68 302
- TFI Module help
- Suggestions for why car won't start?
- Engine Miss!
- Wheel bearing
- MOVED: Car Porn
- Running Rich, wont pass inspection...OBD?
- nitrous question
- MOVED: 1979 Mustang Cobra Q's
- switchin to carb from fuel injection..benefits??
- tire size
- Nitrous on stock 5.0
- AEM or BBK Cold Air Intake? or another brand?
- Key switch replacement
- Need stock Wheel!!!
- power steering pump whine
- 4 bolt lug pattern???
- Oil pressure/sender unit location
- Do they make a o2 repair kit?
- smog stuff and egr
- Question About Push Rod Length.
- 86 gt tranny how come question
- GOING JUNK YARD DIVEING?
- water neck gasket
- Nitrous GURU'S
- Why are my valves pinging ?
- I need a 10second streetable car.
- Why do I keep going back to LRS???
- Car won't start with key... im stumped.
- Battery draining
- can anyone tell me where to get this vacuum line?
- what is this and where does it go?
- distributor wont go down any further
- valve/piston clearence
- whats good about a typhoon intake manifold
- grease?
- auto to T5 swap - brake booster to pedal
- 30lb injector question
- timing for e-cam
- gt40 heads
- Need a 1-2 slider, any 1 kno a place?
- flowmaster 3 inch
- More GT40 questions.....
- 1992 5.0 vert wont start
- New Clutch
- Heads and headers
- Help Finding a good Cold Air Intake for 92 mustang
- Changing to carb instead of FI
- Delete kits
- too much engine noise
- slicks for my stock rims
- Serpentine Belt Shortening???
- Tranny bolt torque???
- 150 Shot On Stock 95 Cobra?
- WOT problems
- MOVED: Msd 6a
- 89 mustang 5.0 build
- Thumper's ported E7 heads
- MOVED: Summer Mac Madness Sale!
- belt rubbing
- 95 5.0 starting problems
- Clock light out and odometer not working
- Engine Modification Questions...
- Spark and gas but no start
- 5.0 Wideband O2 Placement
- Cannot figure out a/c issue
- MSD
- exhaust leaking?
- Timing
- What is the better of the 2???
- what computer
- BBK GRIPP!
- Can I use the EGR Electrial plug??
- Fan Clutch
- Can timing retard itself?
- Help please!
- Bought a new Cobra, ALREADY having problems!!! Help!!
- Car running like dookie <<<Bad Injector?!
- MOVED: 1/8th mile et?
- Carb to fuel injection
- another cam and intake question for tfs heads?
- Turned timing down....ran like ass
- NEed help with start up
- Turbo help
- oil change + sea foam = over heating!?!?
- check engine light code
- starting engine after h/c/i swap
- the right belt
- Torque Loss?
- Speed Correction for sn95
- 91 ford f-150 heads
- injector harness help
- Spider gears
- MOVED: tax return
- Blower Motor Resistor
- Unidentified Beeping
- Fuel Rail to dizzy clearance
- MOVED: Links for new flywheels
- what rear springs
- what size belt do i need
- New Guy Here..gonna need advice
- starter problems
- trick flow intake manifolds?
- anyone know how to fix the seats?
- intake
- Cobra Intake Mani or GT-40P?
- Exhaust?????????
- new distributor
- Maf unit from a 96 cobra?
- MOVED: Carpet Kits for Fox Body
- MOVED: Poor vert
- MOVED: 94/95 5.0L or 96-98 4.6L Mustang
- MOVED: Best Parts for Built 5.0
- Door pins wont budge need HELP!!!!!
- A/C Compressor clutch(Please HELP!!!)
- MOVED: Guess what I found!!!
- 351 cam in a 347 stroker
- T5 rebuild help question...
- Parking brake problems
- T45 Transmission in 1995 5.0?
- ran codes, how to fix them
- Changing Steering Rack
- What's it worth?
- Help please!!!
- 85 cfi fuel system/pump will it work on 86-93 efi
- connectors question pics inside
- Fuel Lines
- GT40 heads valve stem seal diameter
- speedo gear question
- Ordered pullies, now kinda scared!!!
- Jegs gear sets
- how to adjust throttle cable?
- MOVED: search feature not workin??
- MOVED: Just Bought Another Cobra (PICS!)
- MOVED: Getting into the 13's
- PYPES X PIPE
- needing a new top on my 95 vert
- Help with speedo gear problem
- Pressing on steering wheel messes up idle
- 347 question
- emissions =$
- 94-95 Cobra Wheel Value?
- 351 clutch question
- 5.0 engine coming back?????
- "fuel system lean" code reading??? Please help!!!
- Wiring help please, where they go??
- what cylinders are at tdc at the same time?
- Equea Length Shorties or Long Tube headers???
- Blue smoke from header when reving engine??
- question about timing
- Replaced steering rack bushings today
- Head gasket question
- Rear main seal leaking
- Driveshaft ?
- just finished tuarus fan install
- Most accurate MAF sensor?
- would these wheels fit?
- Help! Fuel Problem
- traction and handling..cheap improvements....
- starter issues???
- Supercharging/ 5.0L Motor Upgrades
- smoke
- Trick Flow top end kit question....
- Capacitor or not?
- cam and carb combo
- Confused??????
