View Full Version : Classic Mustangs
  1. 66 electric problems Directionals ???
  2. Where are the rear brake hoses?
  3. Cheaters dont drive Mustangs!!
  4. $2800 Craigslist Find.
  5. body, no paint
  6. Hot August Nights
  7. Stainless Exhaust Photos
  8. Who has that blue/silver 65-66 custom ride?
  9. 351C 2V where's the RPM conection
  10. RE-Post- Want to learn more about some classics
  11. '65 Coupe Ventilation System
  12. new wheels need help
  13. C4 leaking
  14. C4 Upgrade ?
  15. Size Does Matter. Not a Mustang, but Hysterical
  16. Annual driveway fun at Dodgestang's house
  17. Postpro problem... RESOLVED
  18. little help finding numbers?
  19. Media Blasting and body work
  20. 1965 K Code Identification Questions
  21. Black Ca Plates
  22. Exhaust?
  23. Clanking
  24. Auto Body, Paint, and Restoration at a Reasonable Price
  25. 1965 K Code Convertible?
  26. rustolium colors
  27. 302 to 347
  28. Poor man's jack stands
  29. Boosted drums vs. Disc Brakes
  30. OT - Took a little time off from the Mustang
  31. 67 Window Frame Restoration Help
  32. A little closer on the Double Din install
  33. Going to throw this out there
  34. 9' rear end transplant question
  35. Oil Preasure extention
  36. Possible new car to buy...but a problem...
  37. 289 Rebuild, Low Oil Pressure Help!!!!!
  38. power steering pump pulley?
  39. need opinoin on headers-Edit:need tech advice now plz&thnku
  40. suggestions for newbie welcome!!
  41. Final Wheel Question
  42. Door Opening Dimensions
  43. Bullitt Car
  44. Noob post about engine parts
  45. todays project
  46. Subframes
  47. Finaly, got the wheels on.
  48. Hissing Shock
  49. Distributer options
  50. new owner, SO MANY questions
  51. Steering Wheel
  52. Disc Brake Swap / Brake Light Switch
  53. Ignition trouble?
  54. gauges
  55. 67 Mustang, L6 Starts easy, then stalls
  56. 66 mustang 2000 4.6 swap
  57. weird squeak
  58. doing a hood skin! Let the fun begin!
  59. Went to my first show today.
  60. Transmission Upgrade
  61. c4 transmission wierdness
  62. 68 Mustang
  63. Well I think it might be time for a rebuild
  64. Stangaholic for 60's Mustangs
  65. Master Cylinder
  66. 67 Trunk Seal Help & Carpet ***UPDATE FINISHED***
  67. 66 headers
  68. Steering Box
  69. 67 Disc / Master cyclinder Q ?
  70. video forum
  71. Coupe to Convertable
  72. MPG with different engines?
  73. what will she do?
  74. Roof voids/channels???
  75. Anti-Theft ideas?
  76. versailles rear end
  77. 351ers help me out.
  78. Can anyone help real quick?
  79. Autolite 1100 problems
  80. springs and perches rotated 180 out
  81. d 9" rear from a 74 thunderbird??
  82. my slow process motor update
  83. spoilers for my 66?
  84. 289 upgrades
  85. carb choke
  86. My mustang nearing paint
  87. Another day on the 65
  88. Paint colors? with a Black vinyl top
  89. 69 Valence
  90. '66 Convert: Color of Top Cover?
  91. 1970 Steering Column
  92. T5 Transmission Upgrade
  93. Deluxe Seat Belts?
  94. What Wheel Selection Should I get?
  95. Powder Coating
  96. Backup Lights Not Working FMX
  97. Need Help with painting dash and door panels
  98. Throttle Return Spring
  99. choke heat tube
  100. ever get annoyed with it
  101. Odd Find
  102. Annyone used these?
  103. How much
  104. 66 Wheel size (17 x 9.5 rear)
  105. 3.67 for unleaded today - how about you?
  106. What parts do I need-tko600??
  107. Eww clutch
  108. which air cleaner
  109. finsihing up engine compartment. problem starting back up
  110. Anyone using a Retrotek EFI?
  111. To sell or store?
  112. 64 1/2 Mustang Horn assembly
  113. Not enough room
  114. Headre problem?!?!
  115. transmission problem
  116. firewall hard shell connector?
  117. ok my car is starting to piss me off
  118. Sorry insurance question again.
  119. Spraying POR-15..
  120. front bench
  121. does NOTHING work in my car?!?!?!?
  122. 66 gt C4 speedometer cable,..how and where
  123. exhaust shop prices,...?
  124. Branson MO car show
  125. Carb Guidance
  126. Broken band
  127. No start
  128. Would you mount your fan like this?
  129. Gas Mileage
  130. first Mustand
  131. Are these Classic 1983 Mustang Cobra Recaros??
  132. Awesome stuff
  133. WHEEL HELP !!!!!!
  134. how to search here ... (maybe add to FAQ)
  135. Tire Size Advice
  136. Engine "cycles" at idle.
  137. Is any one else having problems replying to posts???
  138. Removing windshield and backglass?!?
  139. 71 Mach 1 with 429 CJ
  140. Hello Moderator/Owner
  141. 67 Cross member ?
  142. Vinyl Top Question
  143. interchangeable rack and pinion
  144. Hipo I6
  145. confused about a T5 conversion
  146. Bullitt Clones vs Eleanor Clones
  147. thinking: does a power MC interfere w/ cable cltuch routing?
  148. Pics of my ride
  149. modifying 66 mustang
  150. Suspension Experts...Help With Steering Wander
  151. Discharge Nozzle?
  152. AOD Anyone?
  153. how fast have you gone?
  154. t5 spline count vs c4
  155. newbie question here...
  156. Color Sanding?
  157. '69 Measurements Found!
  158. current project
  159. Tail light - Help Please
  160. Need a closeup photo of an R Model front attached
  161. change rod bolts
  162. JBA Mid Length Headers for 351w?
  163. Best double pumper carburator
  164. turboomg a carbed 289
  165. header options?
  166. Bad Day-need some input-power steering hose
  167. Cylinder Heads
  168. modifying 1966 mustang
  169. Shipping
  170. A couple of videos
  171. got some questions
  172. Tach placement??
  173. 65 fastback rear seat removal
  174. Ken Harrison 6x9's
  175. Not a mustang but.. - anyone know
  176. 70 won't turn off engine now.
  177. Have you upgraded to HEI?
  178. Single to Dual MC
  179. Pictures of my 1965
  180. Pics of a 73 coupe with a NASA (NACA) hood?
  181. where can I find at t5 tail shaft bushing.
  182. Question about Maaco? yes...i know
  183. Serious miss, backfire etc.
  184. new paint
  185. Hello
  186. Is stripping/bodywork/painting for NOVICE???
  187. Whos painted their interior themselves?
  188. Tranny oil leak
  189. Power Drain?
  190. Were is More HP?
  191. carb issues
  192. Appraisal??
  193. Rear end clean up??
  194. 351C Intermittent Sputtering - Need Help
  195. cleaning up the garage, anyone 67-70 need exhaust?
  196. ??ripped off??
  197. gas for old stangs
  198. maxing out performance
  199. Gauge Cluster Refurbish
  200. Timing marks
  201. a bit OT but a cool story
  202. Looking at a 68
  203. engine combo sound strong?
  204. Heater vacume line
  205. weatherstripping for 67 convertible
  206. Upper Dash Trim for 65?
  207. did i get ripped off?
  208. Check out these cars on ebay-69 boss
  209. Preventive Maintance ???
  210. b!t@h, b!t@h, b!t@h
  211. new double D...daily driver that is
  212. 302 or 351W?
  213. she sure is sweet wish I had the cash
  214. ballpark hp
  215. steering column wiring?
  216. Numbers on back of block? what are they?
  217. 65 mustang carb problems??
  218. 68 Stang
  219. SSBS brake conversion question
  220. Financing for classic cars?
  221. 65 fastback engine
  222. Autolite Carb Question/Help
  223. Gotta love a whinner
  224. front suspension bolt ?
  225. 65 clutch out???
  226. gauge cluster removal
  227. Good deal?
  228. Windshield still leaks!!!
  229. is there a problem or not?!?!?!?!
  230. Perfect Paint Job?
  231. fasteners/part no identification
  232. electrical problems
  233. What Is It???
  234. whag do i do with the vreg wires
  235. Going to go pick up wheels/came out with a problem
  236. new purchase
  237. rear seat & trunk parts?
  238. Power sterring hose rubbing against header
  239. Total control rack and pinion a huge sucess
  240. Mangum 500's, 15 x 7, any fit issues on a 65 with drums?
  241. pretty sure my carb is shot
  242. Update on Oooo Dat Smell...
  243. Where are engine bay pictures
  244. Glasspacks? anyone use them?
  245. reverse light/neutral safety switch plug for toploader
  246. Powerplant...installed...for now
  247. rigged up spaghetti
  248. 68 mustang brake light problem
  249. 65 door data plate
  250. tool for punching holes for welds?
