- Introduction
- New guy with questions.
- Bullitt Rims
- Power brakes
- how bad are Doug Thorley headers for 351 W with FMX
- Doug Thorley headers
- Heads for 302
- Think it cant be done?
- Mustang Phanton Gauges
- Claremont HS Auto Shop pics
- Engine update W/pics!
- '67 Mustang Disc Brake Spindles
- Demon vs. Holley Carburetors
- Setting my Dwell?????
- under hood cover.
- Electric fans?
- Dash lights color
- Paint a 69 hood
- Header clearance debacle.
- hmm whats wrong?
- Cylinder block drain plug help
- trans dip-stick
- '67 Heater Core with in-dash air
- Auto shipper?
- Thermactor
- Seam Sealer
- Awwhhhhhhhh Crap...
- Heidt's Superide II IFS
- So how crappy are Flowtech headers???
- 67 Mustang
- Smog 5.0 question - bolt ons & HP
- guess what im getting!
- What's the most RWHP you've produced with a non-boosted 302??
- C4 trans
- Man of the month May2007 -- JMD
- 60's mustang h.p.
- MII,Maverick eleanor
- Need Help...not a stang
- Sounds good
- 67 Super Snake (Redux)
- Favorite 2
- Building your own engine help
- What year is your favorite?
- 66 Convertible top problems
- PonyCarburators, Anyone dealt with them before?
- what would it take?
- Oh Yeah new gauge cluster
- Floor pan
- Engine Upgrade
- turn indicators stay on
- Anyone wanna get in on this?
- clearance issue
- Mustang For Sale Site
- Getting divorce anybody around Kzoo, MI?
- this engine good deal?
- Dash Pad Help
- 1966 HIPO Air Cleaner
- This really hurts
- Who wants a fastback
- Gas Tank Need Cleaning
- vacuum routing on 66 390cid?
- trying to install my stereo
- Heater Core Day!
- waterpump bolt
- Still having brake problem.
- Eaton or Ford
- 289 into a 6 cyl fox body
- Soaring and others
- 1968 Mustang - Deal of the month....
- anyone need disc brakes?
- Congrats LCC - ROTM May
- River City Mustangs
- I don't get it re:engine builds
- Carburetor question
- 351 Cleveland ?
- Mustang Coloring Thread
- Pics of my center console I made
- The beast rumbles to life
- Rear Qurter off
- i have a cam?
- transmission question
- Oil Pan Gasket
- Gas Cap
- wiring and ignition switch overload issue
- 1968 gas cap
- 9" rear end question
- Hi All, new Mustang owner
- Hello
- Door Question
- 72 mach 1 351C Cobra Jet?
- wiring harness
- Instrument Lights
- 4 Lug Disc on 67 Question
- 284HDP CRO-16242 Camshaft?
- just talked with the original owner
- Build an engine V crate motor
- new engine
- Up and Running
- long time no see ... car back soon ?
- 9Inch Rear End
- 2005+ seats in a classic?
- Torque Vs Horsepower Stock sound Vs Mean Loppy Sound??
- Mind-Boggling Overheating Issues - $900 Later...
- my key broke!!
- Blah! Blah! Blah! Same Old...
- boss 429 or mach 1 dash
- Radiator question
- crager
- What years were similar to 1979 Cobras?
- 1972 Mach 1 Q code whats it worth?
- I need to know what this is called?
- mainly looking for a 67 - 68 manual mustang but not being picky. just cheap.
- Gas price check again.
- 3 point harness
- conclusion of "my wheel fell off"
- Steering box removal
- Look at this rusty hole
- Justs when you thought power steering was a good thing!!!!!!!!!!!!!!!!!!!
- 67 radio problem
- help with '73 dash and cluster removal
- Difference? Suggestions?
- Cal Mustang
- Buffer Recommendations?
- Carb Tuning
- Air Pan?
- '67 C4 auto upgrade question...
- TANK GOING TOO FAST
- Just a new pic of her cleaned up
- Can I rent a 1967 Mustang convertible?
- 66 cluster assembly
- Dumb question: accelerator pedal spring
- Electric choke: underhood switched power?
- Rear Quarter
- Is It Done This Way
- UPHOLSTERY INSTALLATION HELP
- Does anyone live near MU
- 1st Month update.
- 17 inch wheels on a 69' Mustang Fastback - Correct Fit
- '65 windshield wiper assembly removal
- Tranny and rear end
- U-Joint Clank
- 3sp
- 351w crate motors
- Input on 1979 wanted.
- 1966 Back-up Lights
- It's not a Mustang, but it's one hell of a ride
- Turn signals
- Brake questions
- Paint prep around windshield
- Throttle cable Question.
- are my heads worth anything?
- Brake pedal 'play'
- Help with engine cooling and heater plumbing
- Seat Belt Question
- adapter bushing
- Stuck Spark Plugs
- Chrome valve covers on eBay
- 315/35zr17 gunna be close!
- steering wheel swap?
- 9" swap help questions...
- header/year Q?
- 67 ignition switch help.....
- 67 interior/exterior lights go out when i turn the steering wheel....
- Exhaust question
- power - manual steering conversion
- Rebuilt P/S pump problems
- radiator hoses
- Steering column removal
- Cool two-tone paint
- Pictures of some of my dads cars
- kragen 351w?
- Engine bay blasted and primed
- update as of yesturday
- RPM's drop under braking load.
- 351w
- Ash Tray
- are all t-5 trannys the same
- What the heck are these??
- Coil Over Spring Kit vs. Spring and Handling Kit
- What happened??
- what would you put in your '65
- Good Rearend?
- Want 11 inch drum brakes for 67 Mustang
- audio and glovebox question
- Tank Armor in
- Master Blaster
- 351w is this a good deal?
- Looking into buying a stang.
- Look at what I found around the corner
- RPMs at highway speeds what should it be?
- Guess what came to my job yesterday?
- Leak in C4
- Brand of Fan
- super snake??
- choke?
- Got My New Scoops
- Fan Wiring Diagram - Switch Goes Where?
- Smoked Taillights
- are these 65 heads?
- Got a Quote for paint
- Started a thread in off topic
- CUTTING OUT THE INNER ROCKER PANEL
- Grab-A-Track Why not for street????
- Newbie installing new disk brakes
- Is there a special glue for window metal?
- vett pipes on a stang
- distributor qoustion
- Mustang Meet and Greet
- Did I do OK?
- vinyl top and trunk rack?
- How much would you offer?
- turn signals
- wierd things you have found in your car
- carburetor
- 1968 mustang blasting and help?
- 18.25 inch fan on a 289?
- Quick question about distributor vacuum advance
- Craiglist finds
- top loader and low gears
- Look What I picked up today for $50
- Surface rust removal
- Roush 347 find. Need help.
- info on buying a 71 to 73
- Trouble with my Cleveland!
- Need Help with front blinkers and parking lights
- UNI-LUGS ??
- Mickey Thompson ET Streets
- 66 GT 350 CLONE HELP
- Brake problems.
- Is this a good price or not for a 67 fastback?
- Former POD member
- 65 Fastback F Code
- I have been SCREWED...and didnt even get a hug!
- dodge shelby :( must win.
- Tire Brand Preference??
- aftermarket brakes
- my car was "in an accident" due to a drunk.
- What's it worth? 1971 Vert
- 64-68 mustangs and power options
- 1969/70 drivers side Big Block Shock Tower needed
- wheels
- what are the best looking wheels for a classic
- 351 is out!! Pics of the tear down.. So far..
- Micro Brake Lock.
- Desperate for Decal Locations
- Something new from fat man fab
- '67 power steering in a '65
- flickering electrical
- found! 351c Aussie heads!!!
