View Full Version : Classic Mustangs
  1. Transmission Question
  2. Front End
  3. Headers...
  4. 360 in a 69 Mach I
  5. correct oil
  6. bought HEI, questions..
  7. First Project Car
  8. How to pick the right speedometer gear???
  9. New motor running but has issues
  10. Window Tint
  11. Model Making Help
  12. 68 door window adjustment
  13. Specific questions. '69 FB quarters. Photos needed.
  14. Radiators, more questions!
  15. Rubber fillers are stapled to splash guards?
  16. frame replacement
  17. Weatherstriping?
  18. so if i want to order somthing from ford..
  19. Transmission suggestions!!
  20. Engine stand bolts?
  21. Looking for pics of your rear end...Exhaust, that is!! (UPDATE: pics)
  22. AOD/Tremec
  23. Road Test
  24. transimission leak through breather tube
  25. Need help! '68 dash pad installation
  26. Double posted by mistake, please delete
  27. Aluminum Collector Gaskets
  28. brakes or suspension?
  29. Insurance...again
  30. 68 coupe progress pics - dialup warning!
  31. Choosing gear size
  32. 67 & 68 mustang
  33. 65 Mustang Parts
  34. Chrome thermostat housing leak
  35. Rebuilding a 66 Mustang
  36. K code GT
  37. got appraised :)
  38. Install Help - Ford Racing Hood Latch and Pin Kit
  39. Can't believe how stupid I am
  40. Radiator and Fan
  41. 65 Headlight wiring question
  42. California Special Trunk Lid
  43. How do I post pictures without having them as attachments?
  44. Swapping valve covers
  45. Steering issue - need some help
  46. Disappointing power output
  47. 69 Mach 1 hood/side stripes/rear stripe: vinyl or paint?
  48. CSRP (Sort of) Disc Brake Swap DONE!!
  49. Waiting, waiting, waiting...
  50. CRAGAR WHEELS ?
  51. Progress pics. 68 427 fastback
  52. My newest dilemma...can anyone help?
  53. S 197 V6 wheels?
  54. body metal
  55. A/C pulley
  56. I really am an idiot
  57. Cowl again
  58. Thermostat position
  59. inner fender alignment
  60. How do you post a picture in your sig?
  61. 1st ride out of the driveway today
  62. types of 67 mustangs (fastback vs notchback)
  63. Knocking Rear End
  64. Very strange exhaust problem
  65. Engine Temperature
  66. question on brake conversation
  67. 4.6 engine. 67 mustang. opps, info, tech advice or just insults.
  68. Gotta love parts delivery day
  69. Plans for the 4th? Aka: My birthday!
  70. NOOOOO!!!!
  71. 3.80 swap progress (first drive! Weeee)
  72. motorcycle oil
  73. Electrical Issue
  74. color
  75. 5.0 roller to classic 302
  76. 1966 A/C option cost??
  77. ignition timing with vacuum
  78. Almost ready to sell
  79. Steering wheel nut size?
  80. Tach?
  81. fastback conversion
  82. U-Bolt installation tricks
  83. 65 Mustang automatic
  84. The big EFI swap
  85. I CANT GET ONTO CLASSIC INLINES!!!!!!!!!
  86. What kind of oil woud you use?
  87. Anyone ever use Kirker paint products
  88. Machine Shop "experts"?
  89. 1966 Mustang (200 CID) Ignition Timing?
  90. 65-66 Quarter panels
  91. First Post- Engine and Tranny Selection
  92. Gas tank
  93. Replacing wheel Studs on Brake Drum
  94. Holley 570 Street Avenger and 650 Double Pumper CHEAP!!!!
  95. electrical lighting issues,...where to start
  96. Question re wiring for 65 fastback
  97. 1967 mustang vins missing, where do I look?
  98. Rattle and Roll, but dont want the rattle...
  99. shelby
  100. He took his post but left the picture
  101. 351W Combo? Look Strong?
  102. 66 power steering hose and belt numbers needed,...help
  103. wilwood users or mustang II drop spindle users,...
  104. Bushings
  105. Will trans hold
  106. Rear end delima.
  107. Anybody else's search option not working on this forum???
  108. Purchase of Interior restoration Kit
  109. potential stupid question but....
  110. Am I the only one?
  111. Spring Solutions for Sag
  112. 68 Mustang Wheel Horn Pad
  113. 1960's Ford Mustang Door Panel Info.
  114. Fighting with automatic shifter
  115. wheel spacers
  116. neutral saftey switch
  117. 35*
  118. Help ID this upper and lower
  119. M/U s*cks........
  120. A friend just sold his 66
  121. HEI Distributor?
  122. How easy is it to install these upgrades!?
  123. -
  124. 67 restoration need help!!
  125. Cowl
  126. Seats dont align?
  127. new 15 by 7 styled steel wheels on the way..thx guys
  128. 67 wheel sizes
  129. 1972 Mustang Door Panel Carpet Trim???
  130. power steering help
  131. Will this rear end fit?
  132. front bolt up
  133. Headliner Bows
  134. shocks
  135. Need Help on 1970 Mustang Speaker Selection
  136. AOD TRANNY CONVERSION
  137. has any one used this
  138. Tips for replacing rear main?
  139. c4 and part for sale.
  140. New intake and carb question?
  141. T-5 Short Shift
  142. Problem
  143. question
  144. electric fuel pump recommendation
  145. Rear Frame Rail / Trunk Floor
  146. 67 vs 68 Fastback
  147. our backwards resto...66 vert...PART II
  148. 66 coupe int. door paint
  149. Repair Manual
  150. electrical burn question
  151. 302 swap
  152. Car Show **PICTURES**
  153. oil change questions
  154. seat belt install ?'s
  155. Bad Gauge? Says HOT!
  156. forum gallery
  157. Battery relocation...
  158. mabeye this is just my imagination
  159. Finally
  160. Wiring Problems Issues
  161. Restoration tips and ideas
  162. Do i need the solnoid?
  163. ceramic coated headers
  164. 65 with 351?
  165. why cant i post in my old thread,,...?
  166. electric fuel pump and overheating
  167. T5 install, slip yokes
  168. 67 mustang firewall
  169. buying 3.55 gears (quality and $ question)
  170. Radiator for a 1965 200ci
  171. engine identification
  172. Have you seen this VIN issue before?
  173. monte bars
  174. Painting Emblems
  175. Suggested Ramps
  176. Mustang Gurus.......
  177. blower belt
  178. My 302 DYNO run 495hp! pics too!
  179. Rising Hood
  180. engine bay pics/ hiding wires
  181. ford 9 inch?
  182. ford 9 inch?
  183. Equalizer bars
  184. Removing front Seats
  185. 289 vs 351w
  186. Possibly the coolest 60's big Ford interior option I have seen.
  187. Gauges go crazy after installation
  188. Weld through primer?
  189. What gear for a dyno run?
  190. Urethane
  191. Does anyone know the size of a 1966 Mustang stock fuel tank?
  192. Off to Paint
  193. Attention baddog671
  194. radiator questions
  195. FF PICS FROM 07'
  196. modern headlights and twin supercharged.
  197. 235/60-15s on a 1965 question
  198. Exhaust manifold specs?
  199. OK..LET ME REPHRASE THIS
  200. anyone have service manual
  201. anyone ever use seafoam on your classic?
  202. 1st time start up
  203. Sweet new purchase :)
  204. power steering question
  205. My 68
  206. Power steering?
  207. not a mustang but still pretty awesome
  208. Bad Day @ DMV
  209. So I'm Pissed... No, really pissed!
  210. Power brake conversion
  211. transmission questions
  212. 289 Any Rebuild Kits
  213. Resistor Wire..??
  214. Drip rails rotted out
  215. Disappointed?
  216. best location for H pipe on dual exhaust
  217. Unique bodies make it home safely
  218. STARTING PROBLEM HELP!
  219. 65 Mustang Question
  220. sell? part out? or Store for resto?
  221. 14 by 7 styled steel wheels
  222. Floor Panels
  223. heater delete
  224. Free 65 Mustang sheet metal parts (Atlanta)
  225. Air Cleaners, ford style changing
  226. Where can i get a brand new 6 cyl
  227. Need a new brake master cylinder
  228. Roof Swap
  229. Fuel System list.
  230. yea new brake parts !!!
  231. 1970 Mustang Disc Brake swap
  232. 428 Manual Flywheel
  233. 4 Speed to Automatic Swap ?
  234. a/c heater blower squeak
  235. Dimensions
  236. New upholstery
  237. Vacume booster vac line help needed
  238. 1966 Restore...advice?
  239. Purple 302 block
  240. Original Ford Fender?
  241. Junkyard parts..
  242. 289 to 427
  243. project DD rendering. Photoshop skillz
  244. Electrical issue..
  245. Carpet Dye?
  246. 71 rear disc convo?
  247. Tires
  248. 72 coupe swap out fmx and 8" rear
  249. Tri-Y Header Torque Spec's
  250. Tri-Y Header Torque Spec's
