View Full Version : Classic Mustangs
  1. Found some bottom end
  2. Help with a Centerforce clutch
  3. Bondo Questions
  4. what paint for engine block?
  5. 68 coupe project
  6. re keying ignition or door locks
  7. power steering fluid
  8. mustang art
  9. Oh No! Do I need a new transmission now?
  10. Engine Codes and Where To Find Them?
  11. Quick Question on 1966 Exterior Trim
  12. Axle breather bolt brake line clip
  13. Door Handles
  14. this thing is sweet! anyone else seen this thing?
  15. Saturday project
  16. Remove rust from chrome - this worked!
  17. 66 drum size
  18. post your cars interior!
  19. RPM Air Gap vs Weiand 8124
  20. Anyone go to O/C MD for the Car Show?
  21. Stereo and Alarm on '65
  22. what shocks for a 65
  23. whats this?
  24. Need help with 68 302
  25. horn help
  26. Off Topic
  27. Making a choice, want to run it by the Mustang experts...
  28. I swear I won't post this on every forum I belong too...just some of them...new best
  29. Brake handle removal
  30. not enough fuel
  31. are any classics going to the meet and greet on june 7 in novi
  32. Mufflers for stock 289 V8...which sound best?
  33. Off Topic, Hydrogen question, it may power your Stang someday
  34. Installing my rollbar, need opinions
  35. errors
  36. why can't i roast them..
  37. Should have sanded after blasting
  38. boxing control arms
  39. old iginition switch won't turn? PROBLEM SOLVED
  40. T5 swap has begun (Finished Photos)
  41. custom panels
  42. firewall insulation
  43. Just for the record! - slightly off topic!
  44. zero compression on piston one
  45. tcp g-bar install with pics
  46. DipStick install in a C-4
  47. Ready for a Challenge?
  48. '66 Mustang with a '77 302 wiring problem
  49. Try to test that Brown Gas thinggy.
  50. what kind of distibutor to use?
  51. rim question
  52. body problem
  53. Top ten reasons for owning a classic Mustang
  54. I know this is a warn out wheel question.
  55. Speedometer
  56. UK fastback '69
  57. Newbie type question about drain plugs
  58. 8.8 Swap
  59. best classic stang
  60. paint question
  61. Overhaulin' 65 coupe
  62. one of the only 67/8's i like.
  63. ignition switch replacement issue
  64. Just bought a rust free 68 vert
  65. I am looking for a 67'-68'
  66. what length pushrods?
  67. V8 Spindles
  68. Semi-new Corral
  69. Removing lifters???
  70. 1973 serial numbers
  71. 66 coupe
  72. Cowl repair progress
  73. Drip Rail Moulding on a vinyl top
  74. Problem filling the gas tank
  75. (OT) name for an american car club ... ?!
  76. throw out the rubber!!
  77. father and son project
  78. pics of new wheels '66 coupe
  79. Starting problem
  80. Carpet underlayment? What is this stuff?
  81. Is this A/C strut needed or what?
  82. 1969 mustang window trim removal
  83. Shelby Control arm mod
  84. Deck Lid Extensions on a coupe?
  85. new headers **pics**
  86. disc brakes and car value?
  87. Floor pans
  88. Not a Mustang, but I think you guys can help anyways...
  89. 289 Engine in an F Code Vin???
  90. Aftermarket hoods whats the difference
  91. Windshield Replacement
  92. Neutral Safety Switch FMX
  93. 1970 glove box door
  94. Feature Car Web Sites
  95. nevermind
  96. Matching numbers
  97. Kickdown Rod 351w 1969
  98. Primer on Primer
  99. Interior handles
  100. Which Cable Clutch to Buy
  101. "Rare" Mustang for sale
  102. help installing a 302 in a 67
  103. masking tape
  104. Vintage Air A/C Bracket?
  105. Anyone ever tried this?
  106. 289 bored .40
  107. On and on and OONNNN!!!!
  108. local rebuilder
  109. Gaskets and Neutral Safety Switch
  110. Replacing door lock cylinders...
  111. Burping the Radiator
  112. Fast Idle Cam Sticking
  113. 67 Galaxy parts -> 70 Mustang Coupe?
  114. timing for newbees
  115. window problem, need help please.
  116. my engine is in!!!!!! *pics*
  117. bodywork ques
  118. For all those paranoid about the Economic Stimulus money...
  119. Progress towards paint
  120. Spindle Mods
  121. 68 coupe automatic shift lever dumbquestion
  122. Seat Belt Question
  123. Classic Mustang With 05+ Grille... PICS
  124. I need some pictures of 302 powered Classic Mustangs.
  125. Brake Question
  126. Duraspark conversion KISS Keep It Simple Stangers
  127. Exhaust?
  128. 5 point or 4 point
  129. how much do you think blowers cost
  130. if you have the color of magnesium mettalic plz post your mustang on here
  131. 67 mustang 289 question
  132. 1965 Fastback Cobra Recreation... how much is it worth?
  133. Fuel Injection
  134. problems with c4
  135. "constant" switched power
  136. Torque Specs
  137. Poor Ride
  138. I6 C4 Tranny question
  139. Why does it keep stalling?
  140. Brakes
  141. Need selling advice
  142. Need some recommendations...
  143. Appraisal with Geico?
  144. Engine bay paint
  145. heater core
  146. What type of sealant or sealing method to use?
  147. Removing the harmonic balancer
  148. Paint striping
  149. I know what tire size, what rim size though?
  150. Another Cooling Question
  151. South texas heat
  152. 65 8in rear found (finally)
  153. seat risers
  154. something broke?!, curbs aren't your friend!!
  155. Running Too hot ?
  156. Starting my disc conversion...finally
  157. reds still fade?
  158. Relay question
  159. Still looking
  160. primed
  161. Entire powertrain for how much?
  162. Wheels/Tires for 1968 Mustang
  163. today i....(with pics)
  164. How to get BOTH of my '66 horns to work??
  165. Rusted Floor Panel Question
  166. New water pump gone bad
  167. 73 mustang carb
  168. question about throttle return spring
  169. Installing 351C and C6 in a '67 Convertible... any advice?
  170. few pics of the stangs
  171. Buying 68 Coupe: HELP!
  172. Disk conversion
  173. Oil and Brakes
  174. Where to buy a set of 65-66 turn signals?
  175. New Car
  176. Big problem?
  177. post your mustangs color
  178. Brake Help
  179. New pics with Radial TA's...
  180. repair (swap) order, opinions please
  181. budget 13 inch brakes
  182. Busy Weekend 1/pics
  183. Disc brake swap proportioning valve options
  184. Pulley arrangement? Help!
  185. oil sending unit problem
  186. my mustang
  187. pushrods lifters
  188. do you know someone who knows someone?
  189. Bought a new Mustang! (Pics)
  190. Rust Filled with Poly
  191. steering box. when to install
  192. Replacing Water Pump Pulley
  193. ELECTRIC FAN RELAY???
  194. Emblem removal and paint
  195. Follow up to gluing quarter skins
  196. how high can compression go before before more octane is needed?
  197. ignition coil re-wire question.
  198. Looking for good Mustang tech in Omaha, NE
  199. High Octane additives??
  200. The lamp itself maybe?
  201. Blowpack, Pop sound, not float
  202. I6 and C4 Q's
  203. Starter Relay Wiring Question
  204. c4
  205. How to spend my tax rebate...?
  206. Turn signal troubles
  207. Question about toploaders
  208. Got my 3.55 today
  209. looking around
  210. 1966 Stall Problem
  211. try-y headers, or regular style
  212. Opentracker Upper Control Arm question
  213. Performer 289 Heater Hose connection
  214. Quarter Windows
  215. Wheel Fitment HELP!!!!!
  216. Looking for a new repair manual, what do you suggest?
  217. Leaf springs
  218. Fuel Reading
  219. rearaxle 9" housing to 3rd member. gasket or gasketmaker
  220. Brake Line Blues......................
  221. My heater core grenaded
  222. its on the road!!!
  223. Just Got Body Work Done...
  224. check out this 67 fastback.
  225. would it be worth it?
  226. shell tranny fluid
  227. 351w motor
  228. What fun would it be if I didn't have work to do
  229. Ford related but off topic
  230. '67 fastback
  231. help! measurements needed.
  232. timing issue. I've just replaced the stock top and front of my 65 289
  233. what to run
  234. Push Button (pics)
  235. Replacing a door hinge
  236. Do I need the breather hose
  237. just a few pics and a vid
  238. engine crossbraces welded to shock towers?
  239. all new parts !
  240. http://www.grundy.com/
  241. seat belt ticket
  242. Altenator Problem
  243. vin decoding
  244. Mustang prices - fact or fantasy?
  245. 65 Rustang - Replacement Order ?
  246. Door question
  247. electric fuel pump
  248. New (to me) roof
  249. Wrong Rear Axel? I need to drive stang again
  250. stripped bolts
