View Full Version : Classic Mustangs
  1. Faded int. and Paint Program?
  2. Sprint?
  3. what do i keep doing wrong
  4. Received the Marti Report on the 67 Shell
  5. 1968 Mustang transmission / axle option combinations
  6. Stuck distributor???
  7. DISTRIBUTOR
  8. i found traction bars,..keep, or trash?
  9. 1966 Which V8 Engine Should I Get
  10. are my stock partsworth keeping
  11. what will you do mustang wise with your check from uncle sam?
  12. thermostat install
  13. Sandblasting is Cool!
  14. whats a good fuel pump
  15. What paint scheme should I go with?
  16. Some pics of the 68 coupe big block...
  17. stripping
  18. Temperature?
  19. Tube tires vs. regular tires
  20. Still Over Heating
  21. Reno Earthquakes
  22. 9 inch rear enf
  23. frame rail surprises
  24. Factory Vinyl Roof Question
  25. slight bog? hesitation?
  26. soda blasting
  27. quck thermostat question
  28. 67 on to 66 front end swap
  29. NEED SOME QUICK ADVICE!!!
  30. harmonic balancer bolt
  31. hardtop to convertible
  32. speedometer
  33. No more sunroof..........
  34. 66 Charging System
  35. Warm Starts
  36. '66 Alternator
  37. Low End Torque Issues
  38. 67 and 68 body/frame differences
  39. 1965 Backup lights
  40. 67 V8 vs. 05 V6 HP?
  41. 351cleveland 4v lack of power help please
  42. ANY HELP 351c engine lack of power
  43. Can you POR15 a dipstick housing?
  44. listing wire
  45. Mustangs Plus Car Show tomorrow... HMB on Sunday.
  46. carb popping noise
  47. 351w heads
  48. gas stabilizer question/issue ?
  49. Switched brakes, now not working?
  50. Top 5 best weight loss for a 1967 coupe
  51. STUPID F' ING STRUT ROD!!
  52. Video Thread- A sticky perhaps
  53. Power to manual steeering
  54. workshop pic
  55. Due to popular demand...Wheel Chart 2.0 has been hatched
  56. K code in TN
  57. Paint Stripper?
  58. Crack in transition pan
  59. how deep are you in? where you started and current progress
  60. seat foam question
  61. new top end?
  62. Changing drum brake shoes - advice?
  63. Spot welder report
  64. 68 Mustang GT Convertible
  65. Which POR15 product?
  66. How Hard to replace Timing Chain on 302?
  67. Newbie carb question
  68. custer lights question
  69. 70 hoodscoop turnsignals
  70. Exhaust pop
  71. RACING SEATS INSTALLATION
  72. Tranny leak help
  73. engine rotation
  74. Removing Lift Shackles
  75. Drive Shaft
  76. Advise for replacing quarter panel and wheel house.
  77. 1969 mustang 351w/FMX tranny
  78. Edelbrock carb for RPM/RPM Air-Gap intake
  79. '69 Power steering pump paint
  80. 65 luxury coupe?
  81. Timing Set Points
  82. Stripped Header Bolt
  83. 1966 Stang Shop manual
  84. KRC PS tank
  85. side exhaust or to the rear?
  86. pulley spacer
  87. pics of rims
  88. made a little trip today
  89. Engine Stall
  90. 1966 Reference Books - Technical Manuals
  91. coolant leak help
  92. Getting an old 66 running again
  93. Another AOD question
  94. what carb is everyone running?
  95. Duraspark question
  96. 429 w/c6 in a 68?
  97. Windshield trim clip pins replacement
  98. roofside rail weatherstripping
  99. what are the parts i need for an electric fan conv.
  100. after removing the starter I found two small alignment pins or rod bearings collected
  101. Humiliating Question - Where Does the Oil Go?
  102. Electronic Ignition VS Original
  103. Lettering and Battery
  104. Power steering
  105. Head casting munber??
  106. curb height
  107. My Stang update >>DUW- lots of pics
  108. Carb identification and advice
  109. Custom Console Build (Photos or ideas?)
  110. Carb question
  111. I snapped my P/S lowering bracket..
  112. New member,old stang...
  113. Pics of the 383 Stroker
  114. Tires/Rims for my 70 coupe...
  115. clamp that holds speedo gear?,..where
  116. any 65-66 owners with 18s?...wheels
  117. Manual to P/S Conversion
  118. New crank and some pics(56k be aware)
  119. Anybody else ??
  120. sending unit cable?
  121. Picked up my 65 coupe (pics inside)
  122. piston question
  123. Difference between coils
  124. Quarter Gas Filler
  125. what are you guys getting for gas milage?
  126. Timing Chain???
  127. Found an issue that I need some help with. pic added
  128. original vacuum line? cut or save?
  129. Speedometer
  130. heaterbox/core?
  131. 1972 mach 1
  132. motor update
  133. door handles question
  134. Seat opinions...
  135. Acceptable Belt Configuration?
  136. Headers for my 1966...going to Carlisle Pa
  137. First week-end with the T5 + engine rebuilt
  138. will bullits off of a 06 mustang fit on a 65 mustang
  139. P/S pump burnt out..
  140. Intake question
  141. Eastwood underhood black any experiences?
  142. Another Gas Price Thread...
  143. Alright to paint headers?
  144. Caulk?
  145. Crane Roller Rockers - Push rod length
  146. HELP! New distributor wont fit correctly
  147. Help with Date and DSO codes
  148. 351W stroked to 408 - making the oil pump clear
  149. 1966 Factory or Dealer Installed A/C
  150. Custom console
  151. 65 white interior - help me out here
  152. quick question.
  153. Unique cut out the cowls-why??
  154. new or used steering? 66 coupe
  155. Engine Rebuild or Replace
  156. coil question
  157. Intake Removal
  158. Damaged/Disintegrating Water Outlet Barb
  159. specification
  160. tach problems
  161. Rear Tire size??
  162. Estimation of horsepower?
  163. Uninstall center link from pitman and idler
  164. 69 in the back seat
  165. Spring Photos of "The Baby"
  166. Spring Photo Of "The Baby"
  167. Why can't I keep a gear?
  168. Mystery Coolant Disapearance
  169. Fiberglass fenders vs Sheet Metal??
  170. Roller rockers 351w
  171. metal rod in the vaccuum modulator
  172. Suspension
  173. how much torque to the front cover bolts of 65 289.
  174. Torque converter install question
  175. Carb Question
  176. 03 cobra rims on a 1966 stang
  177. Will they fit without rubbing?
  178. Wiring Diagram "SPLICE"
  179. Calculating a 1966 "Build Date" from VIN
  180. Chunk of metal in oil pan
  181. Window leak test failed
  182. Engine Cowl paint
  183. Still have oil in water - help with tests.
  184. auto trans question.
  185. New valve covers wont seal need help
  186. question plz help
  187. Finished my resto mod, fake pony interior
  188. i could use some suggestions
  189. how wide is the travel area of roller tip rockers on valve stem
  190. Excessive C4 shifter play
  191. I'm trying to install summit harmonic balancer but
  192. 64.5 - 66 key blanks - trusted websites
  193. Newer Mustang but a classic ad
  194. replacement part needed
  195. 67 GTA steering wheel question....
  196. Installing the cam timing gear the dowel pin recesses
  197. Intake Question
  198. Door skin replacement
  199. Quick Question
  200. T-5 conversion Any suggestions?
  201. It's good to be back!
  202. Underdrive Pulley
  203. 65 mustang Rear End Question
  204. Help with paint
  205. Opinions on replacement starter
  206. Starter Solenoid
  207. 351w distributor wiring??
  208. files lost pictures needed
  209. new stereo install
  210. Overhead console vinyl
  211. Anyone seen one of these?
  212. Seat Bolts
  213. Coil direction?
  214. anyone have a link with a 66 wiring diagram
  215. How Do I Install My HEI Distributor?////vacuum line
  216. Rookie Question "TDC" How to set it
  217. my leaf springs are shot
  218. 67 (02/67) Washer Reservoir question....
  219. Need help with an engine swap on my 69 coupe
  220. Brake Problems
  221. New Rad installed?
  222. African update
  223. A/C compressor for 1969?
  224. Check this out!!!
  225. gas prices suck...any one heard of an alcoholic DD?
  226. info on T5 cross members?
  227. where can i get
  228. I built a period correct 65-66 9" housing with a smooth back
  229. 302 Roller block
  230. flex a form leaf springs
  231. 1967 resto manual
  232. Cleaning out calipers?
  233. is it a 260 or 289? i have eng. code and pics!
  234. shuts off out of no where
  235. Door Spring
  236. 302 has developed a ping
  237. Blown Head Gaskets
  238. speaker size for kick panels in 66
  239. 05+ wheels on a 67
  240. timing?
  241. Canyon cruise and new drag radials
  242. Restoration of my 66
  243. 31spline axles?
  244. Which engine should i buy
  245. do i need a particular valve cover to clear roller tip rockers and also
  246. 66 Ammeter
  247. '71 Mustang Axle Help!
  248. is it legal in all states to.....
  249. Help replacing U-bolts on rear leaf springs.
  250. widest tire?
