View Full Version : 5.0 Mustang
  1. Valve train problems!!! please help
  2. What size rear end is this?
  3. T5 fluid to quiet it down a little...
  4. Mustang aftermatket wheel offfset with 5 bolt spacers
  5. car not starting
  6. MOVED: Best looking sn95 hood
  7. How did it work?
  8. Newbie here with a question or two
  9. stupid question about a charging issue
  10. Computer info?
  11. new bat + no juice = wtf
  12. Fuel Sending Unit
  13. Loadin up
  14. New front shocks suggestions?
  15. Engine Surges between 500 & 1000 RPM?
  16. Noise coming from the rear end of my Stang
  17. ecu codes
  18. 1987 Gt Drivability issue.
  19. What torque converter do I need?
  20. Took the GTS Garage Queen to the track...
  21. car dies when in reverse
  22. Need some timing questions answered...
  23. hesitation and popping through throttle body
  24. Easiest way through firewall?
  25. 1991 5.0 problem
  26. replacing fog light bulbs
  27. power gain?
  28. Help with installing sunpro gauges
  29. quick help please
  30. what to set timing on
  31. Intake Question (trick flow street)
  32. coolant sensors
  33. couple of AOD questions from a 66 Coupe owner
  34. 5.0 help
  35. Has anyone used this?
  36. MOVED: 5.0 car club western nc
  37. Weight Reduction
  38. VORTECH S TRIM
  39. Gasket Set
  40. underdrive pulleys?
  41. Woohoo!
  42. idle surge still !!!
  43. Quick trans ?
  44. IDLE SURGE FIXED!!!
  45. 2nd gear noise
  46. whats better: gt 40p heads cobra intake 65 mm throttle body or supercharger?
  47. CC plate install question
  48. 400m project
  49. BBK clutch Quad adjustment problems
  50. valve springs?
  51. 87 gt not working
  52. Torque Converter question
  53. Speedo Cable Help
  54. Drag suspension
  55. How to flush engine block??
  56. windshield wiper question
  57. shift kit came in
  58. 5spd trans xmember
  59. MOVED: 5.0=cop magnet
  60. rear suspension questions
  61. replacing alternator
  62. Fried Everything?
  63. AOD to T5 Swap
  64. 17x8 wheels 96-98 spindle
  65. Best cam for my setup
  66. 5.0 rebuild?
  67. what is this?
  68. MOVED: Cracked Windshield
  69. late night+hooking up batt.= BAD
  70. did i blow a head gasket?
  71. throttle lag
  72. HELP - shes eating batteries
  73. DO THEY MAKE A STEERING WHEEL ADAPTER FOR THE 95 MUSTANG???? PLEASE HELP
  74. Interior swap out help
  75. blew a heater hose ?
  76. Gutting out cats?
  77. 1.72 rocker question
  78. Dallas Mustang Speedcal
  79. flowtech x pipe question
  80. Spring Question Vert vs. hardtop
  81. Car Audio Help
  82. Window motor question. Electrical
  83. Help finding a crate engine
  84. exhaust
  85. Distrib and timeing
  86. Putting New Engine in my 91 GT crate or rebuild?
  87. MOVED: WHERE TO GET CHEAP SHIFTER???"
  88. Turn signals won't work
  89. I need to get rid of my rear drums! HELP
  90. MOVED: PICS and THOUGHT OF SHIFTER???
  91. First Build 347 please help
  92. how big of stall with my set up?
  93. MOVED: Carfax
  94. 05+ brakes on a Fox
  95. weld racing draglites
  96. Will Mac header bolts work w/ BBK shorties
  97. ? about airbags
  98. t-5 want go into gear
  99. Brake lines with 5 lug conversion
  100. supercharger on stock mustang opinion
  101. New some advice
  102. t-5 identification help
  103. Switching from reg to Synthetic and cold air intake
  104. cam in 86
  105. INSTALL A SPEEDOMETER CABLE
  106. 90 GT guage cluster question
  107. Stock cam?
  108. maf and tb?
  109. Axle or Wheel Bearing Damaged
  110. svo caliper
  111. saw something strange on a 90 gt today at wrk help me identify it??
  112. MOVED: TERMINATOR vs HONDA TURBO Street Race !!!
  113. Cost of used doors
  114. MOVED: '03 Mach 1 or Camaro Ls1
  115. MOVED: POLL: H-Pipe or X-Pipe or Pro chamber
  116. 5 lug ?
  117. how do you get the ignition switch out?
  118. 3 piece O/R H pipe...any good?
  119. Heads and Intake questions...
  120. 88' GT weld wheel backspace?
  121. Proportioning Valve lines
  122. c4
  123. how much will it cost
  124. how to build 95 gt?
  125. Low oil pressure
  126. valve adjustment
  127. stay with stock cam, or go to E303 (must be emission legal)
  128. engine off fuel pump still pumping??
  129. Swap: 5.0 5 speed into 4cyl auto
  130. 87-93 Under Dash Wiring Harness
  131. Convertable top frame?
  132. Oil Weight
  133. no sound from speakers
  134. HELP!!!!!!!!!!
  135. in the middle of a t5 rebuild
  136. c-4 to tremec tko 600
  137. Stock MUSTANG 5.0 vs MODDED 350Z !!! AWESOME!!
  138. Need quick advise on a 5.0
  139. Gear ratio's
  140. Car Won't Start (with video)
  141. speedo gear/ r&p gears
  142. Backfiring- WTF?
  143. E-Brake Light on Dash doesn't work
  144. Help with rear speakers!
  145. complete rebuild..stroker kit or not?and best and cheapest palce to order from
  146. got some money saved and ready
  147. MOVED: racing seats
  148. straight answer with the oil pressure, whats good,bad,ugly.
  149. headers
  150. 5.0 rebuild
  151. c&l maf question
  152. MOVED: wild woodys
  153. Rear Drum- lug bolt install, need help/advise
  154. kenne bell then motor?
  155. wtf, gasket tips, need help this sucks
  156. header leak
  157. re:my foxbody stalling problem need help
  158. What size are the rear speakers in my car?
  159. 89 gt 5.0?
  160. gt40s?
  161. AOD Problem
  162. How much tranny fluid
  163. still speedo problem
  164. Please Help Guys.
  165. 1988 mustang cd player wiring
  166. Charcoal canister
  167. Drop springs
  168. the stroker is no more
  169. 1992 Mustang Wire harness Are there two different types of wiring harness on the FOX?
  170. Radiator blew out!!!!
  171. MOVED: Saleen MUSTANG ----- twin turbo, over 900 rwhp!!!
  172. T-5 Question(s)
  173. 5spd..?
  174. quick help please!!
  175. OBD-1 codes for a 1993 Ford Taurus?
  176. AOD fluid change
  177. FRPP Valve Covers...possible fitment issues
  178. 306 stroker question?
  179. Water Pump or Thermostat?
  180. any way to cut down an axle shaft?
  181. 5-lug conversion
  182. dyno tuning ?
  183. Stock or aftermarket cats?
  184. PARTS THAT WERE OVER LOOKED
  185. vid slp1 idle oil question
  186. Serpentine belt ripped apart why?
  187. MOVED: Post pics with black Headlight Covers
  188. Just did the 140mph speedo swap now I have a problem
  189. equal length shorties
  190. Timing question
  191. spark plugs
  192. Transmission Fluid
  193. fuel Press
  194. MAF
  195. MOVED: What do you think i could get
  196. emissions removal
  197. Exhaust question
  198. Real bad warm idle??
  199. NEED HELP with parking brake handle
  200. how low for offset bushings
  201. Lost to 06 SE-R! Need upgrades!
  202. not getting fuel
  203. AOD shift cable
  204. Change CAI, now car idles and runs rough
  205. Couple Questions... (Need Your Opinions!)
  206. maf conversion
  207. Buying a 90 5.0
  208. Fuel Pump
  209. Car starts without clutch engaged
  210. whats this???
  211. How tough are t5s to rebuild
  212. Cobra 1993 SVT 5.0 Question
  213. Parking brake Cable Replacement
  214. 2 dumb questions
  215. wtf! wrong ps pump bracket??
  216. Triple x block???
  217. Fuel Level Gauge Problems
  218. need help with axles
  219. retorque after head gasket install
  220. Help!!!!!!!!!!!!
  221. 1500rpm bucking and starting up issues
  222. Thermactor plug ? reall y confused
  223. water pump question
  224. Billet Dizzy Gear
  225. offset bushings
  226. 95gt t-boned
  227. suspension opinions needed!
  228. Can I put an EGR spacer on my cobra intake?
  229. Fox 5.0 now stalls after installing catted H pipe
  230. do gt40p heads work with bbk longtubes
  231. 5.0 and NOS
  232. t-5 transmission fluid thru the shifter
  233. Accel Ignition
  234. Accel Ignition
  235. 87-93 distributors the same?
  236. MOVED: Whats it worth
  237. re:help on 5 lug conversion on mustang foxbody
  238. car idleing bad, pulled codes
  239. a/c turn signals stopped working
  240. Intake/Airflow discussion for a newbie
  241. Question from a 4.6er
  242. Some EEC test questions??
  243. Springs/Shock/Strut Install ?
  244. QUICK! Is this the air silencer!?
  245. Spark plug gap.
  246. Major Engine Problem Need Help ASAP
  247. Computer Year?
  248. Code 54. ACT sensor location?
  249. tv cable/shift linkage adjustment help....
  250. AOD won't shift. HELP!
