View Full Version : 5.0 Mustang
  1. any fan advice
  2. power steering line clamps leaking
  3. clutch noise PLZ HELP!!
  4. Does my belt have enough tension?
  5. any wiring gods out there???
  6. Loose rocker arm
  7. Suspension Tips.
  8. just replaced the water pump
  9. Underdrives
  10. LOwering?
  11. 95GT sounds cammed out but isn't, any clues???
  12. 95gt spark plug help
  13. Almost done with the engine upgrade need help with exhaust
  14. replacing enlink bushings
  15. Body molding trim pieces?
  16. supercharger help?????
  17. coilover front suspension HELP!!
  18. clutch problem
  19. Need info on a st of bolts (builders enter)
  20. Pro Comp electronics aluminum heads
  21. plastic trim plate question
  22. ran codes, now questions
  23. Day 1
  24. NHRA legal battery relocation
  25. Need help with this one!!
  26. 302 to 460 Swap
  27. Baer rear disc brake conversion (parking brake)
  28. Key lock cylinder or ignition switch??
  29. 5.0 wagon??!
  30. Converting to manual steering?
  31. convert gt 5.0 to cobra 5.0??
  32. cowl vent grille
  33. .020 over 347
  34. cam question
  35. Fuel pump runs constant?
  36. Curious about factory installation
  37. Anyone here using the ARP crank bolt?
  38. taill lightsss
  39. stock mufflers
  40. short blocks and firing order
  41. Cam gear rubbing
  42. What gap for these plugs
  43. How to install 92 GT tail lights???????
  44. just bought a 94 GT.
  45. What to do next.
  46. Adding supercharger to 171,000 mile 5.0?
  47. Oil pan gasket blues
  48. The ideas don't stop. Roots blower?
  49. newbie question on edelbrock pro-flow
  50. changing starter question
  51. new guy with a few questions about building a injected street motor
  52. Slight vibration
  53. Different color roller rockers
  54. Qa1 k member and a arms question
  55. Shock and Strut upgrade.......?
  56. Trying to remove the harmonic balancer off of my 94 gt.
  57. hazard lights
  58. Quick cam question
  59. Steering wheel options for my 92' GT?
  60. F Cam on Stock 5.0
  61. Opinions on LC-1 wideband
  62. Ignition?
  63. still bad idle
  64. vibration coming from tranny area
  65. Another timing question
  66. aod leak
  67. 88 Mustang with a side of trouble.
  68. Car Rides Very Rough..
  69. pushrod bushing help
  70. Roller Rocker Question
  71. O/D not working after shifter kit install. need ASAP
  72. Need help with a strange VIN #
  73. t-5 to c4
  74. roller rockers
  75. wheres the bap?
  76. 1987 mustang gt no spark
  77. getting a 4cyl cable to work with a v8
  78. Need a lil insight.
  79. 5.0 AC Delete
  80. 24lb injectors
  81. Finally i may have a new body but have ?
  82. RPM drop off when given gas
  83. low coolant sensor?
  84. 1985 mustang 5.0 auto just got her..need some help on a problem??
  85. Motors making a crazy noise!!!!!
  86. 1987 mustang gt fuel problem
  87. Tire size question..?
  88. 302 Engine experts I have an intake manifold question.
  89. 302 crankshaft and block question
  90. 5 lug swap
  91. clutch cable
  92. mini starter conversion on 1987 Mustang convertible
  93. Do I need bigger injectors
  94. my mustang revs up when i start it?
  95. reving up problem?
  96. 1.75 Hooker long tubes
  97. Paint code?
  98. How to check PTV clearance
  99. strut tower install
  100. Dizzy wont sit flush on block
  101. misfire on cold start
  102. fuel ?
  103. Backing Plate for Transmission
  104. 91 LX 5.0 T5 Issues
  105. Holy crap.. Offroad H pipe fumes question
  106. struts and shocks
  107. Engine/Trans Removal
  108. puddle in my floor board?
  109. front frame rail rebuild
  110. nox?
  111. Rear end Help What Gear?
  112. Is this too Hot? :(
  113. starter-solenoid cable?
  114. Turbo-ing a carbed car?
  115. T-5 to automatic swap. Any tips? plz help
  116. 1989 and 1991 gt ???
  117. first foxbody build
  118. Plenum Connections
  119. Is the 302 a good weapon of choice?
  120. Alternator/charging system problem.
  121. oil pump seized up. please help!!!
  122. Cooling upgrade; is this setup too much?
  123. 303 cams and catts
  124. adjusting ride height
  125. Gas pedal feels wierd.
  126. DO NOT TRY AND SELL IN TECH!!
  127. Decking gt40 heads?
  128. ok so i have a few question please help
  129. granatelli vs. c&l
  130. chasing grounds on a 4cyl to v8 swap
  131. Car Problems 351W Help!!
  132. 1990 gt dash wiring harness
  133. ? about pulling a motor
  134. what heads do these plugs go too?
  135. first 5.0
  136. Need advice on heads
  137. Need some info on a hurst...
  138. N/A Anderson Power Pipe
  139. rear lower control arm help
  140. newbie problems with oil pressure and temp gauge
  141. Engine Oil not Draining 1995 GT
  142. sn95 pad and rotor change weird outcome
  143. 5.0 build
  144. Car won't start
  145. Growling noise coming from the intake?
  146. STARTING PROBS
  147. let motor breathe better?
  148. Question about Bumpsteer numbers
  149. big block ford?
  150. SVT-R Conversion
  151. 5.0 Dies Abruptly
  152. Ran a KOEO test, what do they mean?
  153. intercooloing system
  154. Cast GT40 heads....YES or NO?
  155. Belt squeeks after car starts up
  156. v85.0 engine randomly dies
  157. GT 40 Intake on 95 Gt 5.0
  158. Any tips on removing Upper Strut Mounts
  159. Cam Selection
  160. cobra upper and lower
  161. Bad ignition cylinder?
  162. 95 conv top
  163. 5.0 1995 Mustang GT Loose engine wire?
  164. changing injectors oops plz help
  165. carb throttle linkage conversion
  166. Roller 312 build questions
  167. Can a 94 gt tun with 24# inj. w/stock comp?
  168. MAP Sensor or not? Where is the vacuum line?
  169. Edelbrock performers vs canfields...
  170. 94 gt 5.0 ho motor+harness+computer 104000MILESSSSSSSSSSSS
  171. x pipe or h pipe???
  172. IAC Problem
  173. Which Valve Cover Bolts
  174. ATF or Gear Oil?
  175. Walbro 190gph fuel pump question??
  176. Fuel Pump Wont cut off
  177. 4cyl cluster for a 5.0
  178. Questions about installing a new harmonic balancer.
  179. Leaking Doors on Sunroofed Hatch
  180. Motor Mount Problems
  181. 1989 lx 4cyl to 302
  182. how to tell apart maf calibrated tubes?
  183. 306 to 347 stroker?
  184. J302 Heads
  185. overheatng problems
  186. starting problems again...
  187. TREMEC 3550 and reverse
  188. Clutch install with long tube headers
  189. transmission help??
  190. How do I tell what transmission I have?
  191. Eibach spring uneven out of the box
  192. rough idle when warm
  193. aod question. please help
  194. lca's install
  195. can a stock fuel punp handle 24lb injectors?
  196. Help High Idle
  197. 302 to 347
  198. Help plz car running like pure crap!!
  199. oil pressure
  200. Changing rear GT lights to LX???????
  201. broken bolt =(
  202. gt40 upper intake bolt length?
  203. Broke intake bolt, vac lines and A/C line...need a little help!
  204. idle at 1500rpm???
  205. A/C Problem
  206. BBK Air Intake Kit, Horsepower?
  207. How difficult is a 5 lug conversion?
  208. msd 6a
  209. throttle body?
  210. rev limiter?
  211. Zoom HP Clutch & Aluminum Flywheel: Mistake?
  212. 91 ford gt???
  213. Noise in the carb?
  214. flywheel ?
  215. Confussed about first drop
  216. 5.0 starter same as 2.3 Starter?
  217. Im going to kill myself or the car!!
  218. 89 gt wont start when hot
  219. what parts is this?
  220. where is the diagnostic port?
  221. wut size belts?
  222. noob with a problem
  223. TFI module relocation kits?
  224. 5.0 H/O ?
  225. 89 stock fuel pump
  226. 347 stroker kit or turbo ?
  227. is my car haunted????
  228. trick flow twisted wedge heads help?
  229. oil pressure and more issues -daily ride please help
  230. Whats the best option??
  231. steeda tri ax?
  232. Good subframe connectors..
  233. parking brake help
  234. new to the 5.0 World!
  235. water pump replacement question
  236. sway bar
  237. What can cause it to no fire on all cylinders?
  238. 5.0 Question
  239. h-pipe rubbing
  240. TPI Sensor Help
  241. no spark issuses
  242. Adj. Alternator bracket ?'s
  243. Vibration at 65mph after rearend rebuild
  244. 1989 5.0 convertible help please!!!!!
  245. Brake line quesiton
  246. Strange Spark plug in supercharged 5.0
  247. Header install this weekend
  248. Anybody have one of these?
  249. Heater Hose Help!!
  250. computer rpm fuel shut-off
