View Full Version : 5.0 Mustang
  1. what is necessary
  2. T-Top
  3. Transmission Troubles
  4. Good exhaust choice for 88 GT 5.0
  5. Rear suspension issue
  6. Timing Chain and Gear
  7. ultimate throttle response
  8. 83 to 87-93 master cylinder swap
  9. best "off the shelf" cam for my application?
  10. Drag Tires
  11. 1993 5.0 Clutch return spring???
  12. Anyone using Anderson Quick Kit 2 top end kit?
  13. A/C Delete
  14. Will 07 S281 wheels fit on a 87 LX 5.0
  15. 347 stroker...which heads?
  16. flywheel
  17. upr front suspension
  18. HO CAM SWAP
  19. Ignition & Key question
  20. C4 and C6
  21. Water pump
  22. MOVED: HOLY MOTHER#*@^$*%@*# Clutch Quadrant/Pedal Problems
  23. limp mode???
  24. Gas milage question?
  25. MOVED: What you think of this Stang?
  26. My steering gave out!!
  27. EGR DELETE
  28. alignment specs for a 90 fox?
  29. MSD Retard Module ?
  30. where to buy
  31. 1995 cobra Foglights
  32. clutch disk diameter
  33. planing to do a 5.0 swap for a friend
  34. motor is running too cool
  35. Lightning Motor into 5.0 Mustang.
  36. Shaking
  37. 302vs347vs351vs460
  38. 1st mod on stock 88 5.0?
  39. Strut Tower
  40. 255 lph fuel pump
  41. 87 vs 93 engine difference
  42. Steering Shaft
  43. Smog Pump issues
  44. pro m question
  45. 95 Mustang GT converted back to Fuel Injection
  46. biggest tire on 9" rims
  47. tranny question??
  48. die after cold start
  49. someone help (adder u might know the part#)
  50. Suspension Issue
  51. a little different gear question
  52. heel toe and sparkplugs
  53. airbag light blinking
  54. air bag light
  55. Help reading carb spec sheet
  56. what kind of intake manifold is this?
  57. Transmisson Whining???
  58. Idle Surge?? HELP
  59. clutch help plz
  60. help! need parts.
  61. 88 gtdies like i turned the key off
  62. Spark Plug Gapping
  63. thanks guys for all yalls help
  64. Axle Question! HELP!
  65. New here. have some ?'s
  66. performance steering?
  67. air temp sensor relocation???
  68. ebay heads
  69. Unclogging-Clogged Heater Tubes
  70. Replacing the front differential seal HELP
  71. staring problem after clutch replacement
  72. 3 quick ?s
  73. question
  74. GT40 lower intake EGR port?
  75. What part of my exhuast is leaking
  76. Anti freeze drip? Need help
  77. hesitation?
  78. MOVED: Affordable Track Car...1005 GT or Cobra?
  79. Manual Breaks on 89
  80. MOVED: cobras vs gts
  81. fuel injection?
  82. fuel injection Q?
  83. hesitation around 4800rpm
  84. MOVED: 1994 Cobra
  85. Changing timing and water pump gaskets
  86. What is this?
  87. 351 crank in a 302?
  88. cobra pushrods the same as stock ho?
  89. long tubes
  90. lifter tapping???
  91. brake leak question
  92. where can i get my block sleeved?
  93. Lightened flywheel?????
  94. MOVED: shift knob
  95. Edelbrock Performers
  96. trac lok
  97. not the clutch.. WHAT ELSE..?
  98. Tranny Question
  99. Which MSD will work best ?
  100. spun a bearing?
  101. Head Light Issue.
  102. turbo
  103. MOVED: anyone hear of J&P control arms?
  104. 5.0 Crate motor
  105. MOVED: Roll cage Requirements
  106. Question for guys that have worked on Cobra engines
  107. Did I kill my Heater Core?
  108. MOVED: Where to source an 8.8 rear
  109. phenolic spacers
  110. longtube headers
  111. MOVED: headlight problem!
  112. MOVED: 95 convertible turn into a hard top
  113. MOVED: Mostly gutted, what to do next?
  114. no power to coil
  115. MOVED: Timing gun question
  116. Gt 40 heads
  117. MOVED: viper motor in a fox?
  118. Removed Catalytic Converter Resulted in Power Loss
  119. low coolant light? Help?
  120. good springs for 18 inch wheels?
  121. no start problem
  122. MSD 2 step controller
  123. MOVED: 95 Cobra Bolt on Horsepower
  124. MOVED: what exaust?
  125. MOVED: dyno#'s updated with video
  126. MOVED: New Parts
  127. 600 double pumper??
  128. Zoom
  129. Bellhousing alignment?
  130. MOVED: What makes more power???
  131. water in oil. but dont know where its comming from.
  132. MOVED: Tuning shops?????
  133. Headlight trouble!!
  134. freeze plugs
  135. MOVED: Aftermarket cd speaker output left side only?
  136. rear main seal..
  137. No blinkers = crappy ignition switch!! Rant within...
  138. car stalled and wont start back uo
  139. GT40P heads and intake
  140. oil leak at distributor
  141. Front suspension help
  142. MOVED: need help with radio
  143. My car won't stop leaking coolant!! Help please!!
  144. Efi or carb
  145. engine complete, need help starting.
  146. 1990 GT turns over but won't start
  147. vibration at 3000 rpm
  148. Another fuel pressure question
  149. Front end conversion
  150. PINION SPLINE QUESTION
  151. MOVED: best things to look for when buying a new foxbody
  152. Sn Master Cylinder on a fox
  153. 94 computer question
  154. distrubitor difference?
  155. correct fuel pressure?
  156. Electric fan install questions?
  157. no felpro cobra gasket sets?
  158. Cam and Timing Chain Install Question
  159. 5 lug conversion axle question
  160. Fuel injection to carb conversion question
  161. throttle body
  162. lifter help!!
  163. one thing after another
  164. MOVED: vert curb weight
  165. MOVED: 3.73 gears yes or no??
  166. no fuel!!!
  167. MOVED: HO vs. NON HO
  168. SURGING IDLE AFTER WARMED UP. SMOG RELATED?
  169. Tranny question for you pros
  170. MOVED: Fox Salvage Yards?
  171. MOVED: Clutch type
  172. 87 - 93 exhaust on a '94?
  173. shifting hard when cold engine
  174. mustang dies at startup
  175. MOVED: What colors my car?
  176. Need help with top end decision.
  177. T5 fluid?
  178. e303 timing help
  179. Short???
  180. MOVED: mpg question
  181. air shocks
  182. MOVED: weight of fox vs. sn95
  183. seafoam
  184. What for optimum handling?
  185. intake manifold question
  186. MOVED: header studs, where to find???
  187. Heater Core, Radiator, or something else?
  188. Diff Play
  189. aluminum radiators
  190. Dart Shortblocks
  191. MOVED: 17"x8" Cobra R's
  192. Grinding, shifting problems
  193. MOVED: E-303 Cam-$75 decent price?
  194. luk clutch? any good?
  195. 86 5.0 - No spark..no reason
  196. max lift with...
  197. cobra?
  198. rear gears
  199. Need help with my engine please
  200. Clutch just went out! Any suggestions?
  201. Trans ????UPDATE
  202. decoding
  203. Top End Kits
  204. Head Part Number Location
  205. speed density
  206. Where can water come from?
  207. starter problems; weird; new starter
  208. pros vs cons
  209. HOw long could you?
  210. head porting
  211. I need some good links on How to rebuild A T5
  212. stock rocker question
  213. new starter
  214. Tremec trans fluid
  215. 5.0 Cobra not running right, help
  216. stalling only on startup
  217. MOVED: tint or no tint???
  218. I'm having throble changing gears on hi rpm
  219. Brand newbie! First mods?
  220. cylinder head studs
  221. about to build h/c/i need help
  222. coverting efi to carb
  223. BUILDING A TURBO MOTOR HELP!!
  224. which suspension upgrades???
  225. intake and headers?
  226. throttle body and maf??
  227. mustang question
  228. headers for trickflow r series heads??
  229. exploder parts
  230. flywheel
  231. sn 95 fr control arms on 5.0 mustang
  232. Car is not running the way it should
  233. Underdrive Pulleys
  234. Big Steering problem??Please help
  235. Fuell cell
  236. MOVED: new clutch & flywheel or ...
  237. 302 qustion
  238. SN95 rear in 89 fox, tire fitment question
  239. Help me out, i'm still a newb
  240. sn95 GT 5.0-What do you put in your tranny?
  241. Whats the Biggest intake spacer to use with.....
  242. MOVED: Painting Bumper
  243. 1993 Gt IDLE PROBLEM HELP
  244. 95 GT, won't start
  245. Rear disk brakes off MkVII or SN95
  246. MOVED: Mustangs do not like ditches!!!
  247. nitrous causing irregular idle??
  248. Passenger side motor mount is bad.
  249. lifter type
  250. 408 into a 4cyl carburated
