View Full Version : 5.0 Mustang
  1. Running with open shorties
  2. trick flow upper intake hp?
  3. trick flow upper intake hp?
  4. How to fix these codes 81 82 95?????
  5. TPS set at .98 problems
  6. Fuel Pressure psi?
  7. car dies when warm.
  8. fuel gauge not working
  9. replacing rad support
  10. new rear end and disc brakes
  11. Bell housing removal
  12. Need help on edelbrock heads need advice
  13. Rocker arm movement
  14. Which 02 sensor to get?
  15. Frame rot in front end.
  16. threaded insert ?
  17. t56 in a 94gt
  18. Center Console
  19. rebuild to a 347 stocker from a 302
  20. just when i thought i got lucky
  21. Disappointing Dyno Numbers
  22. Rear Lower Control Arms
  23. T-bird IRS into 84 fox body
  24. 6 Speed Tranny
  25. Gear Question
  26. codes 41 and 91 on 93 lx 5.0
  27. 5.0 general mod info thread. (same as general discussion)
  28. stocker 347 rebuild
  29. 94 GT Intake Question
  30. starter gear
  31. Front End Vibrations
  32. Sputtering and backfire Help please!
  33. New Stereo Install
  34. Will I notice a SOTP power increase with these mods?
  35. head swap
  36. Wheres the power
  37. carb size
  38. regain power
  39. 351 heads
  40. Skid plate for underbody? 88 gt w/possible custom exhaust
  41. 1989 GT..auto tranny went bad...What years have the AOS?
  42. Buying an 89
  43. check engine light
  44. 7.5 axel??????????????
  45. Losing Coolant
  46. 7.5 to 8.8
  47. 302 headers on 351W
  48. Fuel Pressure Regulator
  49. Guage needles replaced incorrectly?
  50. carb swap wiring questions
  51. headlight problems help!!!!!!!
  52. Did I get the wrong electric fan?
  53. shifter knob ?
  54. INTAKE MANIFOLD
  55. Headers/460 swap ?s
  56. Need some help...
  57. Help with EGR solenoid and ground upgrades!
  58. Need A Mass Air Sensor
  59. water pressure installation!!
  60. Information on running dumps
  61. starter?
  62. Will these mufflers work on a 89 Mustang GT
  63. electical problems
  64. Suspension questions...
  65. Piston Help!!!!
  66. 302 28oz to 50oz ballancer
  67. 95 power seat track
  68. 89 build up, few questions..
  69. Big Block Fox
  70. a couple T5 questions
  71. AFR 165S 1402# ?
  72. edelbrock power package
  73. Transmission and Rearend Gurus I need Your Help
  74. Trying to scan codes
  75. **HELP** Piston Rings
  76. tuning questions
  77. Moving the IAC from air tube-94gt
  78. waterpump ?
  79. Will a truck 302 fit in a mustang ?????
  80. Transmission crossmember question.
  81. Missfire at Idle.
  82. 331 vs. 347
  83. rear disc conversion
  84. Low Coolant Light
  85. I believe i have a balance problem! help please
  86. Oil Cooler or High Volume Oil Pump, NOT BOTH?
  87. 87-93 Tanny Fitment?
  88. STUPID ABS LIGHT!!!
  89. what size injectors should i get?
  90. 3G Alternator
  91. dash wiring harness
  92. Rear End Question
  93. bad headgasket maybe?
  94. Stereo install help
  95. 94 gt bogging question
  96. 304 rwhp on a 331 with afr heads ..but?
  97. tubular gt-40 vs. trick flow street burner intake
  98. Help, I beg of you! Won't turn over!
  99. water pump installation
  100. gas gage
  101. Missing Headlight Piece
  102. thanks mustang guru
  103. Exhaust decision delima
  104. Transmission Flush
  105. Remove Smog, increase/decrease my vacuum leaks??
  106. gas gage
  107. Fly cutting & gt40p?
  108. ? about wire harness 4cyl to 5.0 swap
  109. Traction
  110. Rear end clunk noise. Please help
  111. o/r h pipe
  112. Bolt problem
  113. Serp. Belt Size
  114. 90 GT Runs with key off.
  115. H Pipe Question
  116. Quick, but stupid timing mark Q
  117. Electric fan question
  118. KOER test, codes, and i couldnt get KOEO to work? help.. ( lean car )
  119. motors finally all built
  120. explorer motor question
  121. BEEFING THE 347
  122. headers
  123. Car stalls on start
  124. charging problem on a 93
  125. how to adjst. parking brake?!
  126. Engine start up after 1.5 years.
  127. 302 to 351 windser
  128. oil pressure gauge not moving
  129. Help!
  130. Main Cause Of Overheating?
  131. abnormal rocker wear, help!
  132. funny problems who can help
  133. tailshaft leak
  134. GEARS
  135. xe264 cam with gt40 valve springs?
  136. Power Seat Wiring question
  137. 94GT With Rough Idle + Codes!
  138. F-CAM
  139. explorer motor
  140. 351 windser engine performace help!!
  141. solid roller cam? daily driver?
  142. car runs like crapp
  143. Tubular k member
  144. head gasket again?
  145. head and cam lift
  146. Is the upper to lower gasket reuseable?
  147. oil level
  148. What are some of the bigger cams without p/v contact?
  149. oil gone where?
  150. Is this normal? Reguarding transgo shift kit.
  151. weird noises HELP?
  152. WINDAGE TRAY
  153. Replace oil pump/shaft? Or it's fine to let it go?
  154. rebuild/spraying notor
  155. Blowing Coolant out the Overflow..
  156. CFI + New pump = Excess Fuel
  157. OIL LEAK
  158. crank question
  159. Stuck
  160. sn95 axle question
  161. s/c questions
  162. Fuel Pump Question
  163. Serpentine Belt
  164. Fog light brackets
  165. goin to an exploder tomorrow need help.
  166. Thinking of buying 5.0
  167. changing the transmission filter
  168. Front coil-over help
  169. I need some opinions!
  170. Rear Seat Removal
  171. just a question about oil filters!!!
  172. exhaust leaking from somewhere
  173. Off Road H or Off road X with Flows
  174. timing with 110 octane?
  175. Heater Core Write Ups.
  176. What to look for when pulling oil pan?
  177. FRPP fox radiator
  178. Underhood Steam
  179. Car dies with A/C on
  180. 68 GT with issues!
  181. quick help please
  182. No Start When HOT!? 1992 GT
  183. Ground and connector question..
  184. Fuel Injector
  185. Ele. fan install questions...
  186. NEED HELP LOTS OF BLUE SMOKE
  187. A Couple Concerns
  188. 95 cobra hot center console.
  189. looking for black chrome fr500 on a fox?
  190. steering rack questions
  191. oil pressure???
  192. dazed and confused
  193. will it really matter???
  194. installed the gt40p's and now slow start
  195. 70 302 choke ?s
  196. Oil In Radiator! Help!
  197. Air conditioning help!! please
  198. electrical question for a 93 lx vert 5.0
  199. Cam
  200. Rocker Studs
  201. rack and pinion
  202. Engine Build/Rebuilding Advice and Help
  203. Cold Air
  204. 2 Questions...
  205. Spring Spacers...
  206. How many carb guys want efi?
  207. exhaust/CAI questions
  208. Nervous About My Motor...
  209. cant get stock tach to work with crane cams fireball hi-6 ignition box
  210. 94 wont start
  211. vibration
  212. Battery ground question?
  213. Fuel line ?
  214. 5speed grinding 3rd
  215. Front Clip conversion (87-93 to 79-86 4-eye)
  216. snapped a line and need to know what it is (pics)
  217. vortech fmu question
  218. Home Made Turbo
  219. fuel pressure issue
  220. tuner
  221. mac lt's 1 3/4
  222. instrument panel light
  223. 1st shot of spray
  224. Whats the difference with the cobra intakes?
  225. brakes still chirping?
  226. A/C Oil and Freon Capacity????
  227. How big is...
  228. Anyone With '94-'95 5.0 Help Please!!!
  229. Stock 87' 5.0, holley 1850 600cfm, Jetting?
  230. Replacing Radiator In A 91 LX Hatchback
  231. Funny noise
  232. A few Wiring issues...
  233. Headlight condinsation
  234. spark plugs
  235. surging at idle, need help
  236. take a look at the piston
  237. T5 question
  238. 88 hatchback
  239. What to do?
  240. Spec or Centerforce?
  241. 91 gt problems
  242. Viper Alarm Removal / NO Accessory 12 Volts to CCRM
  243. Some performance parts for my fox 1988LX auto, advice
  244. BBK's on GT40P's
  245. motor jumpy and stuttering after explorer intake install
  246. I need a good set ( but cheap ) of rubber around the door?
  247. Ticking again...Video
  248. Clunking noise in back? Shocks?
  249. water leak through hard water line
  250. coolant squirting
