View Full Version : Classic Mustangs
  1. i need help
  2. In need of help
  3. Rear Seats for 65-66
  4. Air Fuel Meter & Wideband O2
  5. Pulled the engine this weekend and...
  6. Question on Lockset
  7. How to test "oil" light
  8. woooo!
  9. Upgrade Front and Rear Suspension on 64.5 mustang
  10. Help with 1966 brake lights
  11. Next 10
  12. 65 Mustang Engine Sounds
  13. Gauges for a Mach 1 -69
  14. T5/Hydraulic clutch and heat question
  15. Need Some Help
  16. 64 1/2 convertible windshield vs. 65 hard top? same?
  17. Strange request
  18. Who burns toluene?
  19. Not another overheating question!
  20. Does this setup sound ok?
  21. pulley question Need a PRO
  22. Trashed Some AFR Valves
  23. Mustang VRS Ferrari!
  24. Transmission Question
  25. just some boost questions
  26. Ignition timing help
  27. electric fans
  28. Qtr window question and a few pics
  29. question about a ford mustang engine rebuild
  30. Oil at $95
  31. 66 mustang tail light bulb size...
  32. Oil sending unit location
  33. Hurricane Ike vs. 67 Mustang Coupe...
  34. 5 lug swap on '66
  35. Painting Chrome
  36. How to find a short?
  37. Block Prep
  38. 65 Stang PERTRONIX IGNITOR I or II?
  39. First look at color
  40. 351 swap question
  41. Cool Video
  42. Vacuum Advance Question
  43. Where to dump old 6 Cylinder???
  44. Turn Indicator
  45. Leaky fuel pump
  46. 66 Engine Compartment Paint???
  47. Mustang Abuse...
  48. Side exhaust exit Help
  49. Found Waffle's wedding photo
  50. CRAIGSLIST SEARCH
  51. Has anyone bought styled steel wheels from CJ Pony?
  52. 69/70 Mustang Rear Spoiler Installation
  53. Just bought a...
  54. Front End Screech
  55. eureka!
  56. WHATS THE DIFF
  57. My new valve covers
  58. need a little help with spinning door locks
  59. The age old question- filler over or under epoxy primer
  60. 8 Hours to remove Leaf Springs - Jeez
  61. will it work? parts from a 94 to 65
  62. Timing Pointer 351w 1969
  63. Retain water problem
  64. DO I NEED A CARB SPACER WITH A STEALTH ?
  65. Electrical Lighting issues,..CAN NOT figure this out
  66. Carpet Faded - Seats Stained
  67. check out these sites!!
  68. Quarter panel to wheel house-sealant?
  69. Factory AC ?
  70. C-4 transmission
  71. Interchange question
  72. coil over question
  73. COOLANT IN THE OIL. HELP!
  74. Electric fan for 65 mustang
  75. 1969 parts for a 1967 Question
  76. one final wheel question
  77. piston questions
  78. gas-a-just shocks??
  79. Have you personally replaced a firewall on your '69?
  80. Fun Ford weekend Fontana, CA
  81. Anyone bought the Pypes exhaust?
  82. Total rookie question.....
  83. How to identify whether it is a "REAL" GT ?
  84. disc brake swap problem
  85. Brake Lights... Shorted?
  86. So whats up with my u joints?
  87. Undercoating
  88. Cars Off to Painters and I am Off to Indonesia
  89. Not really stang related but...........
  90. Any one seen these......?
  91. Front Bucket Seats
  92. Jacks Size
  93. 8" upgrade...brake line question
  94. GRR..help! car wont start, solinoid right?
  95. A couple of Painting questions...
  96. Bellhousing bolts
  97. I need help with a Body Kit
  98. May have a prob
  99. Changing steering wheel
  100. tail light problem
  101. Would this work?
  102. 1st Video of 73 Mach 1 idling
  103. 68 Intake/Carb Question
  104. C4 Transmission Troubles
  105. What is the platform name of the 64-73 Mustangs?
  106. Fuses on a '65
  107. Body filler- DASH
  108. LongTubeHeaders On T-5 Clearance
  109. automatic stalling when put into gear
  110. F^&*ing PERTRONIX
  111. 289 engine block code
  112. Less than great Pony Carbs experience...
  113. Instruments on Dash
  114. noisey top end
  115. 1966 Mustang price question?
  116. Just got my car back from the A/c shop
  117. 1965 Intake Manifold/Carb question
  118. PCV System Help
  119. Can anyone help?
  120. Makes Me Want to Puke!
  121. What was the first Year for Posi rear end
  122. Coil Spring ?
  123. Should i buy this?
  124. Radiator Fan Question
  125. Power Steering Woes
  126. turn key engine
  127. Car stalls at stops, power loss
  128. ROTM August- girlmonth
  129. Car Battery for 65 coupe
  130. 66 mustang rim and tire????
  131. Parking break system
  132. Welding questions/advice
  133. Radiator Fan Shroud
  134. O2 Sensor in a carbureted classic mustang
  135. electric fan wiring
  136. HELP: ticket for loud exhaust?
  137. Splash Guard location
  138. LOOK AT WHAT I FOUND!!!!!!!!!
  139. is it just me or does....
  140. P heads and headers
  141. wow people have nothing else to do
  142. Fan shroud question
  143. restomod
  144. Fender apron Question
  145. 68 289 intake manifold - interchangibility w/ 67 289 A code or a 68 302
  146. not a mustang, maybe still some advise
  147. Leak on Passenger Side
  148. Rear break hose, parking break, and horn
  149. '68 Headrests Needed
  150. tachometer question
  151. 1965 Bright Red Paint Code
  152. rear vibrating at 55-65 mph
  153. 71-73 coupe beltline kit-door felt
  154. Power Steering Cylinder Boot
  155. 351 w build
  156. uh oh
  157. uh oh
  158. making both tires spin
  159. Rubber Pieces for Spring Perches
  160. WildMustang351's 1970 coupe video
  161. Trany issues
  162. 69 mustang rust help?
  163. Where to buy a 289/302 Dependable Long Block Engine
  164. Rear 4 Link
  165. Type of paint?
  166. Carpet underlayment
  167. Brembo 4-pistons caliper on a -67 with drums
  168. What transmission should I go with?
  169. diagnosis?
  170. Well crap, my car broke down on me, lol
  171. Temperature Gauge Problems
  172. 1970 coupe restoration
  173. manual to auto transmission change in 64.5
  174. Any help fuel-injection vs. Carb?
  175. Timing Help
  176. engine running after key is out,...WTF
  177. sound proofing?
  178. First runs with new motor
  179. Don't you love taking non car guys for rides in your car?
  180. Fuel problems
  181. Body Filler
  182. Recommended jetting?
  183. 351W HEADS ON 289 WHICH HEADERS?
  184. Engine Tag Info help needed
  185. Trans,Clutch,???
  186. Rust Bucket coming along!!
  187. Posting pictures
  188. musty seats
  189. squeek e 66
  190. Oil Pan Install / Sealer
  191. Where can I buy..engine stand
  192. 351W rod/piston orientation
  193. 69 Clear Headlight Covers
  194. do i really need a proportioning valve?
  195. Daunting tasks for a mustang beginner.
  196. 429 motor
  197. Mechanical Fuel Pump '65 289 Troubleshooting
  198. Wanting to stroke a 351w
  199. engine temp help!
  200. keeping the paint so its in top condition.
  201. limited slip diff?
  202. marine or aircraft stripper questions
  203. Ride Height, Sagging rear end!
  204. block prep
  205. What are the differences in 69
  206. lift points for floor jack?!?!?!
  207. Hello and HELP!
  208. Farewell for now, its been real!!!!!!
  209. i need help
  210. Door Panels
  211. Most accurate value for a 73 convertible? What do you guys use?
  212. Makes Me Want to Vote
  213. just got my 69 mustang!! help??
  214. CompCams Roller Tip Rockers with Stock Valve Covers
  215. P/S Valve and Tie Rod End
  216. Shelby Hood springs
  217. Why can't i post pics
  218. C6 transmission a negative?
  219. im about to punch myself in the face.
  220. Welding
  221. 1964 1/2 mustang wiring
  222. which paint gun?
  223. Car show classes?
  224. no reverse
  225. 4V Cleveland heads on a 2V Cleveland?
  226. Carb identification help please
  227. it feels like christmas morning. thanks MU!!!!
  228. 408C Coolant in oil
  229. measurement needed,...68 mustang hood
  230. Power steering relocation bracket
  231. i need a temparay master cylinder
  232. Cowl Info?
  233. wooo new paint!!!!!
  234. Proportioning valve on 67 with drums
  235. Just an update, with a couple questions.
  236. Does anybody else miss the "old" Mustang Forums?
  237. would like your opinion
  238. Mustang bone yard
  239. screw me.
  240. Warped Dash
  241. Neutral Safety Switch
  242. 8" U-joint for 6 Cyl
  243. Alternator for stereo system
  244. 8" Rear End Question
  245. little ot
  246. I know this is mustang forums... but...
  247. POR15 Question
  248. 351C help, numbers!!
  249. What are the best headers
  250. Replacing frame rails and floor pans
