PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 [183] 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. shifting problem ?
  2. interior light
  3. what do u think about these rims
  4. Just wondering on the cluster ?
  5. ignition problem
  6. please help quick
  7. changing exhaust
  8. Quick advice
  9. OR Pipe
  10. ever used one of these
  11. street suspension setup
  12. what do yoll thiunk of this superchargr
  13. new times ?
  14. eibach pro kit springs installed
  15. what would this car run at the track
  16. 94 Mustang Quarter Louvers
  17. DSLR Pics of the 5.0
  18. got the interior!
  19. new brake bleeder screw
  20. Quick oil question
  21. i found out how the blow flames out my exhaust with out a kit
  22. QUESTION
  23. exhaust fitting question???
  24. Pilot bearing help!!!
  25. SO I had BAD COOLANT DAY
  26. Is this normal??
  27. 86 sd to Mass Air
  28. How to install new front cobra bumper???
  29. 88 Conv cost to install?
  30. Lower control arm reinforcements
  31. quick question
  32. need help!
  33. Shake Rattle And Roll
  34. Need wiring help
  35. Back In the Saddle
  36. Lifting
  37. ATTN:PRO50SC and others interested in Project 1992 Coupe
  38. Anderson PMS
  39. header hpipe ?"S
  40. Got 4.11's put in, now speedo doesnt work right
  41. ASAP! Emergency need reply fast
  42. Interior differences 79-86 & 87-93
  43. x pipe ?
  44. H pipes
  45. balancer
  46. What k-member u got??
  47. 325 50 15
  48. Word on the Street is..
  49. wondering about the starter
  50. oil coolant? power steering coolant?
  51. Turning a 4 cylinder into a V8
  52. Advice changing a Top ?
  53. prep for paint
  54. Advice for rust?
  55. pictures of my 86 gt with t-tops
  56. What do you guys think of this engine stand?
  57. boom!
  58. u/d pullies
  59. Typhoon intake question
  60. my christmas present came in
  61. Low oil lights are dim
  62. 5.0 question
  63. Dip stick tube Q
  64. Black pony wheels?.. or other black wheels?
  65. Cable question?
  66. skinnies?
  67. STRUT TOWER HELP?????
  68. Problem with adjusting timing
  69. SIMPLE WIRING QUESTION
  70. Centerline Stealth
  71. precision injectors
  72. 5-lug /rear disc conversion
  73. Situatioin fixed?
  74. new paint pics
  75. speed shifting?
  76. what exatly is a vert?
  77. clutch cable
  78. why do ppl hate on verts?? and automatic
  79. Any Suggestions
  80. Selecting right MAF
  81. Tire queston
  82. Need help replacing steering rack bushings
  83. fuel injectors
  84. spring isolaters
  85. Flywheel...
  86. anyone know the guy with the 408 fox?
  87. Oxygen sensor
  88. T5 Tranny Bearings and Seals
  89. best way to paint cheese graders??
  90. need e brake
  91. can i run 15's on my 5lug?
  92. MAF Conversion
  93. question about mac
  94. pypes exhaust systems
  95. pro mass air
  96. Front bumper
  97. Plastic Engine
  98. Accelearation rattle
  99. finally found the gauge cluster i have been loooking for
  100. Ordered some gear for the stang tonight...
  101. Roller rockers?
  102. smoke in the rearview
  103. question about a cold air intake ?
  104. twin turbo 5.0 need help
  105. baffle
  106. K&N
  107. tank install problems (pic)
  108. tach??
  109. Questions about 1983 5.0 convertible
  110. w00t my cars almost done
  111. for my mustang should i get a
  112. gas tank emergency!!!
  113. Making an order tonight, come in and vote!
  114. Capri ?
  115. Need Technical Help
  116. Small back fire at high RPMs HELP!!! SOLVED!
  117. Strut tower brace- worth it or not?
  118. Clutch cable questions
  119. Aftermarket Power Steering Pump
  120. 2 ?'s
  121. Engine advice?
  122. which one would you choose
  123. Water Pump tech Help
  124. please rank my mustang!
  125. euro tails?
  126. smell something burning
  127. advice when looking @ a stang
  128. emblem question
  129. Chrome Bullits on my 86 GT
  130. mac fresh air
  131. I'm and idiot and I have a problem. Need Help!
  132. Muffler swap.
  133. tailpipe problem helppp!!!
  134. Found cheap engine and trans on ebay
  135. all the 80-92 stangs
  136. EGR make car idle high?
  137. Code 33 EVP
  138. NEED HELP ASAP
  139. what other suspension parts needed???
  140. Header / Heads compatability Q?
  141. howdo you remove the headlight bulb?
  142. Fast/Easy Battery Question
  143. Poll:: What do u think about the hood..
  144. EGR blockoff plate, quick question.
  145. What heads do you run?
  146. What do girls think of your cars?
  147. 1998 price???
  148. installed new O2 sensors. pics of old ones
  149. Just bought a new intake manifold
  150. Quick Question!!! Fast!!
  151. need help installing underdrive pulleys asap
  152. New Clutch Cable issues
  153. T-Lok Rebuild
  154. Wire Hiding Question
  155. Auto or Manual
  156. what would u do
  157. do u like???
  158. Summit has a ebay store?
  159. Rearend question
  160. 87 fox and crownvic
  161. Color opinions needed
  162. WHAT TYPE OF SHOCKS AND SPRINGS SHOULD I GET? NEED HELP
  163. vacuum lines
  164. Any daily drivers with aftermarket K-members & front coil over kits?
  165. Aside from MAC, does anyone make a true bolt on 3" cat back?
  166. done with headers what to get next
  167. tune up
  168. car wont start
  169. 351 Drivetrain
  170. up to what speed a 88 Mustang GT is Governed ?
  171. Magnets? for oil
  172. crate locations
  173. Wheels i want, what do you all think..
  174. $250 bolt-ons
  175. Upper intake question
  176. Cats or No cats???
  177. msd 8.5mm wires
  178. stock 5 lug wheels with the 5x4.5" bolt pattern?
  179. 1985 8.8 upgrade
  180. 93 cobra 5 lug conversion?
  181. 5 lug conversion
  182. runnin rich
  183. 6cyld notch
  184. 351 in my sn95
  185. nightime interior light problems
  186. is a 86 5.0 the lightest fox?
  187. Questions?
  188. Should I put my motor to sleep?
  189. steel wheels and Mach 1 hubs
  190. Fuel Pump and MPG
  191. Which cam should I get?
  192. Deciding on build...
  193. Cobra Grille
  194. 86 gt front clip to a 87-93
  195. over heating question
  196. Got some stuff to top off the HCI
  197. traction bars
  198. 95 mustang
  199. EEC questions = safe removal of emissions
  200. C-Clip eliminator kit
  201. rear end gear ratio
  202. Woo Hoo control arm question!
  203. i need help with 3 inch tips please!!
  204. Remote start on a 5 speed
  205. stock springs
  206. spark plug question???
  207. smog pump question???
  208. i want 3 inch tips?
  209. Stupid Timming Question
  210. update
  211. leaking sunroof
  212. addicted
  213. 98 cobra parting out. wha to get?
  214. seats
  215. victor jr intake for sell look
  216. Need input on what shiftlight to get???
  217. Merry Christmas
  218. idle speed
  219. horsepower guess
  220. help, cant get above 5,000 rpm
  221. tail pipe flame question
  222. OLD SCHOOL
  223. christmas fun!
  224. Sig Pictures
  225. Vacuum lines to the Intake
  226. sometimes just keeps cranking
  227. New cowl hood
  228. oil type
  229. Bad Vibs?
  230. replacing the aod for the first time
  231. header question
  232. What did you 5.0 guys get for the holidays?
  233. overheating or not?
  234. Dynamic Racing Products Shifter?
  235. Chevy Mustang
  236. Remanufactured 5.0
  237. Code Problem
  238. a/c delete
  239. Merry Christmas
  240. HELP.....PLEASE, 5.0 question
  241. It's official! I'm keepin the 88!
  242. who has the sig...
  243. is dual 2 inch exhaust hurting my engine?
  244. should i get a cam
  245. tried welding torque boxes
  246. tire/rim "?", everyone answer!
  247. what could a build 357w with a 2200 kenne bell blowzilla do?
  248. MERRY CHRISTMAS TO ALL
  249. Ebay 351 roller motor
  250. Gear Installation Kit
